� �D�
宏迦橙
BZT52C2V4 THRU BZT52C51
SURFACE MOUNT ZENER DIODES
www.ichjc.com
Features
SOD-123
•Low Zener Impedance
•Power Dissipation of 500mW
•High Stability and High Reliability
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
Zener diode is generally used as reference voltage sources in regulated power
supplies or as protective diode in overvoltage protection circuits.
Mechanical Data
•Case: SOD-123
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
VALUE
Forward Voltage @ IF=10mA
VF
V
0.9
Power Dissipation
PD
mW
500
Storage Temperature
Tstg
-65 ~+150
Typical Thermal Resistance
RθJ-A
℃ /W
357
Junction Temperature
Tj
Electrical Parameter
SYMBOL
Reverse zener voltage @ IZT
ZZT
Maximum Zener Impedance @ IZT
IZK
Reverse Current
Maximum Zener Impedance @ IZK
VR
Reverse voltage
IF
VF
Revision:ZD-May.2023-A0
IF
I
Reverse current
ZZK
IR
-55 ~+150
PARAMETER
VZ
IZT
VZ VR
Reverse leakage current @ VR
IR
IZT
VF
V
Forward current
Forward voltage @ IF
1 of 5
Zhuhai Hongjiacheng Technology co., Ltd
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
Type Number Marking
BZT52C2V4
WX
BZT52C3V0
W2
BZT52C2V7
BZT52C3V3
BZT52C3V6
BZT52C3V9
BZT52C4V3
BZT52C4V7
BZT52C5V1
BZT52C5V6
BZT52C6V2
W1
W3
W4
W5
W6
W7
W8
W9
WA
BZT52C6V8
WB
BZT52C8V2
WD
BZT52C10
WF
BZT52C7V5
BZT52C9V1
BZT52C11
WC
WE
BZT52C16
WK
BZT52C20
WM
BZT52C24
WO
BZT52C30
WQ
BZT52C36
WS
BZT52C33
BZT52C39
WL
WN
WP
WR
WT
BZT52C43
WU
BZT52C51
WW
BZT52C47
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.50
12.35
WJ
BZT52C27
2.57
WI
BZT52C15
BZT52C22
2.28
10.45
WH
BZT52C18
Min.
WG
BZT52C12
BZT52C13
Zener Voltage Range
WV
11.40
14.25
15.20
17.10
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
44.65
48.45
VZ@IZT (V)
ZZT@IZT
ZZK@IZK
Maximum
Reverse Current
IR@VR
Nom.
Max.
ZZT (Ω)
IZT (mA)
ZZK (Ω)
IZK (mA)
IR (μA)
VR(V)
2.7
2.84
100
5
600
1.0
2.4
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
2.52
3.15
3.47
3.78
4.10
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10
10.50
12
12.60
11
13
15
16
18
24
27
30
33
36
39
43
47
51
11.55
13.65
15.75
16.80
18.90
21.00
23.10
25.20
28.35
31.50
34.65
37.80
100
95
95
90
90
90
80
60
40
10
15
15
15
15
30
30
40
45
55
55
70
80
80
80
90
40.95
130
49.35
100
45.15
53.55
100
100
5
5
5
5
5
5
5
5
5
5
5
5
5
600
600
600
600
600
600
500
480
400
150
80
80
80
5
100
5
150
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2 of 5
150
150
170
200
200
225
225
250
250
300
300
325
350
350
700
750
750
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
50
10
5
5
3
3
3
2
1
3
2
1
1.0
0.7
1.0
0.2
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
1.0
1.0
1.0
0.5
0.1
0.1
0.1
1.0
1.0
1.0
1.0
1.0
1.0
2.0
2.0
2.0
4.0
4.0
5.0
5.0
6.0
7.0
8.0
8.0
8.0
0.1
10.5
0.1
12.6
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
Typical
Temperature
coefficent
@ IZTC(mV/℃ )
Min.
Max.
mA
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
23.1
25.2
27.3
32.0
35.0
38.0
0.4
1.2
2.5
3.2
3.8
4.5
5.4
1.2
3.7
4.5
5.3
6.2
7.0
8.0
9.0
6.0
10.0
9.2
13.0
7.0
14.4
21.0
-2.7
14.0
18.9
10.4
16.8
11.2
15.4
Test
Current
IZTC
12.4
16.4
18.4
21.4
24.4
27.4
30.4
33.4
10.0
10.0
10.0
11.0
14.0
16.0
18.0
20.0
22.0
25.3
29.4
33.4
37.4
41.2
12.0
12.0
12.0
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
5
5
5
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
100
1
40
2
4
3
5
6
ZenerVoltageVZ(V)
7
8
9
10
0.5
10
11
36
30
27
25
30
ZenerVoltageVZ(V)
35
45
40
100
50
Pulsed
10
30
TemperatureCoeffcientθVZ (mV/℃)
15
Fig.2 Zener Characteristics(11V to 43V)
TypicalT a Values
ForBZT52CXXXSeries
35
LeakagecurrentIR(μA)
25
Vz@IzT
15
1
0.1
10
0.01
5
T a =100℃
1E-3
8
12
16
28
NominalZenerVoltageVZ(V)
32
36
40
1E-4
44
T a =25℃
Fig.3 Temperature Coefficients
DynamicImpedanceZZT(Ω)
CapacitanceC(pF)
1
10
30
35
45
40
T a =25℃
I Z(AC)= 0.1I Z(DC)
f=1kHz
I Z =5mA
10
1
100
Fig.5 Typical Capacitance
25
100
1VBias
BiasAt
50%Of V ZNom
I Z =1mA
0VBias
10
15
1000
T a =25℃
f=1MHz
100
10
Fig.4 Typical Leakage Current
1000
1
24
1
Fig. 1 Zener Characteristics(Vz Up to 10V)
-5
18
16
11
12
13
15
10
9.1
8.2
6.8
7.5
6.2
5.6
5.1
4.7
1
39
P D =500mW
10
2.4
10
0.5
T a =25℃
Pulsed
P D =500mW
33
ZenerCurrentIZ(mA)
T a =25℃
Pulsed
ZenerCurrentIZ(mA)
100
1
10
100
Fig.6 Effect of Zener Voltage on Zener Impedance
3 of 5
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
500
450
400
PowerDissipationPD(mW)
350
300
250
200
150
100
50
50
75
100
AmbienttemperatureTa(℃)
125
150
Fig. 7 Power Derating Curve
4 of 5
www.ichjc.com
� �D�
宏迦橙
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SOD-123
R1
0.012
3000
30000
120000
7''
Package Outline Dimensions (SOD-123)
Symbol
E
C
A
B
B
C
A
D
E
D
G
F
H
F
θ
Suggested Pad Layout
J
K
J
2.55
2.85
3.55
1.40
0.95
0.51
J
K
5 of 5
Max.
θ
M
Min.
0.15
Symbol
M
Millimeters
G
H
Dimensions
0.08
0.140
0.152
1.80
0.055
0.071
1.35
0.71
0.15
0.006
0.008
0.003
Dimensions
2.36
0.053
0.152
0.037
8°
0.25
0.112
0.140
0.006
Max.
0.100
0.45
Min.
1.22
Max.
3.85
Millimeters
0.91
Min.
Inches
Min.
0.036
0.048
0.010
8°
Inches
Max.
0.092
www.ichjc.com
很抱歉,暂时无法提供与“BZT52C15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06570
- 500+0.05913
- 5000+0.05475
- 10000+0.05256
- 30000+0.05037
- 50000+0.04905
- 国内价格
- 50+0.10876
- 500+0.08673
- 3000+0.06783
- 6000+0.06048
- 24000+0.05411
- 51000+0.05066
