10D2-08LCS
10D2-08LCS
    SEMITEC(石冢)
    插件,P=5mm
    NTC热敏电阻 10Ω ±15% 2800K 插件,P=5mm
10D2-08LCS 数据手册
Power Thermistor (= Inrush Current Limiter) Series NTC thermistors heat up when a current passes through them. The heat up then causes a dramatic decrease in resistance. This effect is used by SEMITEC's power thermistor series to suppress inrush currents. Circuits including for example electric bulbs or capacitors induce an inrush current of more than 100 times the normal current when the circuit is switched on. SEMITEC's power thermistors suppress this inrush current and thereby protect electric equipment from damage. Applications Switch circuits, adapters, LCD TVs, plasma TVs, air conditioners, DVD players, audio equipment, LCD projectors, copy machines, PCs, printers, office automation, slot machines and many more How to use power thermistors The temperature of a thermistor generally changes slowly, even if the ambient temperature is changed rapidly from T1 to T2. The "thermal time constant" describes the time necessary until the thermistor reaches 63.2% of the temperature difference. If a current flows through a thermistor it heats up and resistance decreases. However, the resistance is stabilized at a saturation resistance value which is determined by the impressed electric power and the thermistor's dissipation factor. The "residual resistance" value describes the maximum resistance value for the maximum permissible current. The thermistor resistance for the suppressed current should be higher than 4.2 ohm when below 30A according to the formula below. If a small voltage is applied to a thermistor, then a corresponding small current will flow and cause the thermistor to heat up. The "dissipation factor" describes the electric power value which leads to an increase of the thermistor's temperature by 1℃. Δt is the temperature increase of the thermistor. Accordingly, for this example suitable thermistors are 6D2-22, 5D2-18 and 8D2-18. In cases where a quick response time (= small thermal time constant) is needed a small size / large effect (= large rated zero-power resistance) power thermistor such as the 8D2-18 is advantageous. Use below circuit for power supplies of 100V and 200V. 17 The maximum permissible current describes the current value which increases the temperature of the thermistor to 200℃ (Version 2) and 160℃ (Version 1) respectively at an ambient temperature of 25℃. When the ambient temperature is higher than 25℃ then the maximum permissible current is reduced as per the table below. to an air temperature of High humidity heat test to a humidity Test sample is exposed to the maximum rating current at an ambient temperature of 25℃ for 1,000 hours. Temperature cycle Test samples is subjected to the following temperature cycle (10 times): ~ High humidity heat test to an air temperature of to a humidity Test sample is exposed to the maximum rating current at an ambient temperature of 25℃ for 1,000 hours. Temperature cycle Test samples is subjected to the following temperature cycle (10 times): Safety standards UL1434 File No. E926689 (1D2-22 excluded) □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ The rated values in the "dissipation factor" and "thermal time constant" columns are reference values. 18 □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ □ 19 Caution1 Part No.2 Exerting physical stress on on the lead wire from the side may cause cracks and damage the "legs". For example D2-05: Marking is 5D2 whereas "5" stands for resistance (ohm) and D2 for the type. □ □ □ □ □ □ □ □ □ □D2-05 □ □ □D2-08 □ □ □D2-11 □ □ □D2-13 □ □ □D2-15 □ □ □D2-18 □ □ □D2-22 □ □ 20 Taping quantity ~ ~ ~ ~ 21
10D2-08LCS 价格&库存
很抱歉,暂时无法提供与“10D2-08LCS”相匹配的价格&库存,您可以联系我们找货
