10D2-07LD
10D2-07LD
    SEMITEC(石冢)
    插件,P=5mm
    NTC热敏电阻 10Ω ±15% 插件,P=5mm
10D2-07LD 数据手册
Specifications (Disk type) *12 *3 * Part No. R25 * ( ) 5D2-05 8D2-05 10D2-05 12D2-05 16D2-05 3D2-07 5D2-07 8D2-07 10D2-07 12D2-07 16D2-07 22D2-07 2D2-10 3D2-10 5D2-10 8D2-10 10D2-10 12D2-10 16D2-10 2D2-14 3D2-14 4D2-14 5D2-14 8D2-14 10D2-14 12D2-14 16D2-14 5 8 10 12 16 3 5 8 10 12 16 22 2 3 5 8 10 12 16 2 3 4 5 8 10 12 16 1 Maximum rating current at 25C (A) 1.7 1.3 1.2 1.4 1.2 2.4 3.0 2.0 2.0 1.7 2.0 1.0 5.0 4.0 4.0 3.0 3.0 1.8 1.6 5.0 5.0 5.0 4.0 2.5 2.2 2.0 1.8 Residual* resistance ( ) Dissipation factor (mW/ C) 0.610 0.970 1.210 0.860 1.150 0.370 0.352 0.562 0.706 0.780 1.125 1.547 0.107 0.160 0.267 0.427 0.533 0.780 0.940 0.107 0.160 0.213 0.267 0.470 0.590 0.710 0.940 14 14 14 14 14 30 30 30 30 30 30 30 32 32 32 32 32 32 32 36 36 36 36 36 36 36 36 2 Thermal *3 time constant (s) 25 27 31 26 30 35 35 41 45 41 45 50 50 53 53 70 75 53 70 90 80 95 110 80 95 105 115 Rating temp (C) Maximum capacitance at AC220V (F) 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 40160 36 39 39 49 57 42 80 110 140 80 160 190 330 350 290 320 330 173 173 860 630 700 740 289 371 454 578 R25 : Rated zero-power resistance value at 25C. Residual resistance is the maximum value when maximum rating current is applied. Time when thermistor temperature reaches 63.2% of the temperature difference. The value is measured in the air. Part number Dimensions 5 D 2 - 07 K CS D D 5D210 5D210 0.8 tinned copper wire H0 H0 1.0 min. 1.0 min. d d 2. Clinch lead type 1. Straight lead type D2-05 D2-07 D2-10 D2-14 D 72 92 112 152 T 6.8max. H 92 112 152 192 d 3.50.75 H 5D210 T 20 min. UL approved File No. E92669 Thermistor type devices D 20min. Lead -wire form C : Clinch lead D : Straight lead CS : Clinch short Resistance tolerance L :15% K :10% Diameter of element Type Resistance 3. Clinch short lead type H0 14.0max. 15.0max. 19.5max. 22.5max. d 5.01 5.01 5.01 7.51 25
10D2-07LD 价格&库存
很抱歉,暂时无法提供与“10D2-07LD”相匹配的价格&库存,您可以联系我们找货
