LF H81621S T-CND
LF H81621S T-CND
    CND-TEK(磁联达)
    SMD-16P,12.7x7.1mm
LF H81621S T-CND 数据手册
EN LF H81621S T-CND 10/100M Single Port Transformer Module 1. Compatible with various 10/100 Base-TX transceiver requiring 1:1 transmit and receive turns ratio 2. Compliant with IEEE 802.3u standard including baseline wander compensation specification of 350µH OCL when Biased at 8mA 3. Low profile Surface Mount Packaging designed for Hi-Temp Reflow Process 4. Single channel interface for 10/100Mbps Ethernet applications with CMC’s tuned to Enhance EMC system performance 5. Operating Temperature range: 0℃ TO +70℃ 6. Storage temperature range: -25℃ TO +125℃ DIMENSIONS & SCHEMATICS CND-tek H81621S YYWW-X CN Recommended Land Pattern Note:1、Dimension:mm, 2.Unless otherwise specified,tolerances are: 0.15mm TECHNICAL SPECIFICATIONS OCL : 350 µH Min. @ 100 KHz, 100mV with 8mA DC Bias Leakage 0.5 µH Max. @ 100KHz, 0.1V Inductance: Cw/w: 28pF Max. @ 100KHz, 0.1V DCR: 1.20 Ω Max. Turns Ratio(±5%): 1CT:1CT(TX), 1CT:1CT(RX) Polarity: 1-16, 6-11 In-Phase Insertion Loss: -1.1 dB Max. @ 1-100MHz Return Loss: -16dB Min. @ 1-30MHz -12 dB Min. @ 30-60 MHz -10 dB Min.@ 60-80 MHz -42 dB Min.@ 1-60 MHz -35 dB Min.@ 60-100 MHz Cross Talk: Common Mode Rejection : -42 dB Min.@ 1-30 MHz -35 dB Min.@ 60 MHz -30 dB Min.@ 80-100 MHz Isolation HI-POT: 1500Vrms 1mA 1Second PACKING SPECIFICATION label Carton Label 1. units/reel:2000PCS 2. reel/carton:5PCS 3. units/carton :10000PCS EXPORT CARTON:367(L)x337(W)x235(H)
LF H81621S T-CND 价格&库存
很抱歉,暂时无法提供与“LF H81621S T-CND”相匹配的价格&库存,您可以联系我们找货
LF H81621S T-CND
库存:100
