KW4 HKL533.TK-F5FB-4L35M3-AGAE
    AMSOSRAM(艾迈斯半导体)
    SMD
KW4 HKL533.TK-F5FB-4L35M3-AGAE 数据手册
www.osram-os.com K W4 HKL533.TK DATASHEET KW4 HKL533.TK Datasheet   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All reserved | Version 1.0 | 2025-03-07 1 rights K W4 HKL533.TK DATASHEET OSLON® Black Flat S KW4 HKL533.TK SMT package for High Power Forward Lighting applications widely in-use in global automotive market since several years. The leadframe based black package concept provides outstanding contrast and excellent 2nd board reliability for standard Headlamp solutions. The OSLON Black Flat S meets both excellent brightness in combination with high luminance. Applications - Static Forward Lighting Features - Package: SMD epoxy package - Chip technology: UX:3  - Typ. Radiation: 120° (Lambertian emitter) - Color: Cx = 0.319, Cy = 0.330 acc. to CIE 1931 (● white) - Corrosion Robustness Class: 3B - Qualifications: AEC-Q102 Qualified - ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)  - Color over angle: Better than passus 3.7.2.1 of supplement proposal 7 to ECE reg. 128 2 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Ordering Information  Type Luminous Flux 1) IF = 1000 mA ΦV Ordering Code KW4 HKL533.TK-F5FB-4L35M3-AGAE 1550 ... 1940 lm Q65113A7965 KW4 HKL533.TK-F5FB-5L16M1-AGAE 1550 ... 1940 lm Q65113A7923 KW4 HKL533.TK-F6FB-5L25M2-AGAE 1600 ... 1940 lm Q65113A7924   3 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Maximum Ratings Parameter Symbol Operating Temperature 2) Top min. max. -40 °C 135 °C Storage Temperature Tstg min. max. -40 °C 135 °C Junction Temperature Tj max. 150 °C Junction Temperature for short time applications* Tj max. 175 °C Forward current TS = 25 °C IF min. max. 50 mA 1500 mA Surge current t ≤ 50 μs; D = 0.025; TJ = 150 °C  IFS max. 2000 mA Surge current t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 2500 mA ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) VESD Reverse current 3) IR * The median lifetime (L70/B50) for Tj = 175°C is 100h.   4 | Version 1.0 | 2025-03-07 Values 8 kV max. 200 mA K W4 HKL533.TK DATASHEET Characteristics IF = 1000 mA; TS = 25 °C Parameter Symbol Chromaticity Coordinate 4) Cx Cy typ. typ. 0.319 0.330 Viewing angle at 50% IV 2φ typ. 120 ° Forward Voltage 5) IF = 1000 mA VF min. typ. max. 11.20 V 12.60 V 13.50 V Reverse voltage (ESD device) VR ESD min. 45 V Reverse voltage  IR = 20 mA VR max. 1.2 V Real thermal resistance junction/solderpoint 6) RthJS real typ. max. 1.00 K / W 1.20 K / W Electrical thermal resistance junction/solderpoint 6) with efficiency ηe = 39 % RthJS elec. typ. max. 0.61 K / W 0.73 K / W 3)   5 | Version 1.0 | 2025-03-07 Values K W4 HKL533.TK DATASHEET Brightness Groups  Group Luminous Flux 1) IF = 1000 mA min. ΦV Luminous Flux 1) IF = 1000 mA max. ΦV F5 1550 lm 1600 lm F6 1600 lm 1650 lm F7 1650 lm 1700 lm F8 1700 lm 1760 lm F9 1760 lm 1820 lm FA 1820 lm 1880 lm FB 1880 lm 1940 lm Forward Voltage Groups  Group Forward Voltage 5) IF = 1000 mA min. VF Forward Voltage 5) IF = 1000 mA max. VF AG 11.20 V 12.00 V SG 12.00 V 12.80 V AE 12.80 V 13.50 V   6 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Chromaticity Coordinate Groups   550 nm 500 nm 600 nm 700 750 nm 400 380 nm  5M3  4M3 5L3 4L3   7 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Chromaticity Coordinate Groups   550 nm 500 nm 600 nm 700 750 nm 400 380 nm   6M1 5M1 6L1 5L1   8 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Chromaticity Coordinate Groups   550 nm 500 nm 600 nm 700 750 nm 400 380 nm   5M2 5L2   9 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Chromaticity Coordinate Groups 4) Group Cx Cy Group Cx Cy Group Cx Cy 4L3 0.3100 0.3065 5L3 0.3191 0.3246 5M3 0.3191 0.3321 0.3100 0.3185 0.3191 0.3366 0.3191 0.3451 0.3191 0.3366 0.3281 0.3548 0.3254 0.3578 0.3191 0.3246 0.3281 0.3428 0.3281 0.3597 0.3100 0.3140 0.3130 0.3200 0.3281 0.3503 0.3100 0.3270 0.3130 0.3330 0.3221 0.3307 0.3191 0.3451 0.3221 0.3512 0.3221 0.3427 0.3191 0.3321 0.3221 0.3382 0.3311 0.3608 0.3130 0.3125 0.3160 0.3261 0.3311 0.3488 0.3130 0.3245 0.3160 0.3391 0.3221 0.3382 0.3221 0.3427 0.3251 0.3572 0.3221 0.3512 0.3221 0.3307 0.3251 0.3442 0.3254 0.3578 0.3160 0.3186 0.3311 0.3616 0.3160 0.3306 0.3311 0.3563 0.3251 0.3487 0.3251 0.3367 4M3 5L1 5L2   10 | Version 1.0 | 2025-03-07 5M1 5M2 6L1 6M1 K W4 HKL533.TK DATASHEET Group Name on Label  Example: F5-4L3-AE Brightness Color Chromaticity F5 4L3   11 | Version 1.0 | 2025-03-07 Forward Voltage AE K W4 HKL533.TK DATASHEET Relative Spectral Emission 7) Φrel = f (λ); IF = 1000 mA; TJ = 25 °C  KW4 HKL533.TK 1.0 : V : white 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 650 700 750 Note: Percentage of red: >5% acc. to ECE regulation Percentage of UV: 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 21 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit https://ams-osram.com/support/application-notes   22 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on our website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications Our components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. Our products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using our components in product safety devices/ applications or medical devices/applications, buyer and/or customer has to inform our local sales partner immediately and we and buyer and /or customer will analyze and coordinate the customer-specific request between us and buyer and/or customer.   23 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 1 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Operating Temperature: The Operating Temperatur Top is referenced to the Solderpoint Ts of this device. Proper current derating must be observed to maintain junction temperature below the maximum. 3) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 4) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 1 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to GUM with a coverage factor of k = 3). 5) Forward Voltage: The forward voltage is measured during a current pulse of typically 1 ms, with an internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 6) Thermal Resistance: Rth max is based on statistic values (6σ) used for Derating. 7) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   24 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET Revision History Version Date Change 1.0 2025-03-07 Initial Version   25 | Version 1.0 | 2025-03-07 K W4 HKL533.TK DATASHEET   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All rights reserved 26 | Version 1.0 | 2025-03-07
KW4 HKL533.TK-F5FB-4L35M3-AGAE 价格&库存
很抱歉,暂时无法提供与“KW4 HKL533.TK-F5FB-4L35M3-AGAE”相匹配的价格&库存,您可以联系我们找货
  • 1+35.33415
  • 10+31.03324
  • 25+27.84660
  • 100+27.01350
  • 500+26.21163
库存:1489
