BTRSB6V5C601
600W Surface Mount Transient Voltage Suppressor
FEATURES
• 600W Peak Pulse Power dissipation at 10/1000μs waveform ,
Repetition rate (duty cycle): 0.01%
• 6.5V Stand-off Voltages
• Glass passivated junction
• Bi-Directional versions available
• Low leakage
• Low inductance
• Very Fast Response Time
• Excellent clamping capability
• Plastic package is flammability rated 94V-0
Underwriters Laboratories
• Halogen free and ROHS compliant
MECHANICAL DATA
• Package : SMB/DO-214AA
• Case Material: Green Molding Compound
• Terminals: Meets MSL level 1 , per J-STD-020 , maximum peak of 260℃
• Polarity Indicator: Color band denotes cathode
(Note: Bi-directional devices have no polarity indicator)
APPLICATIONS
• AC/DC Power supply
• I/O Interface
• Low frequency signal transmission line
(RS232, RS485, etc.)
SCHEMATIC & PIN CONFIGURATION
Bi-directional
2016/03/16 Ver.1
B-tron®
Tel: (86)755-8148 7166 Fax: (86)755-8148 7199
WWW.B-tronSemi.com
Page 1
BTRSB6V5C601
ELECTRICAL PARAMETERS (TA=25℃ Unless otherwise noted)
Bi-directional
Symbol
Ipp
VC
VRWM
IR
VBR
IT
IF
VF
Parameter
Maximum Reverse Peak Pulse Current
Clamping Voltage @ Ipp
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
Test Current
Forward Current
Forward Voltage @ IF
ABSOULTE MAXIMUM RATINGS (TA=25℃ Unless otherwise noted)
Parameter
Symbol
Typical
Unit
Peak Pulse Power ( tp =10/1000μs )(Note 1,2)
PPP
600
W
Maximum Peak Pulse Current ( tp =10/1000μs ) (Note 1)
IPP
53.6
A
Steady State Power Dissipation @ TA = 50°C (Note 2)
PM(AV)
5.0
W
Operating Junction Temperature
TJ
-40 ~ 150
Storage Temperature Range
TSTG
-40 ~ 150
Junction to Ambient on Printed Circuit
RθJA
Lead Soldering Temperature
TL
90
℃/W
260 ( 10sec )
Note: 1. Non-repetitive current pulse, TA = 25℃。
2. Mounted on 5.0mm x 5.0mm(0.03mm thick) Copper Pads to each terminal。
2016/03/16 Ver.1
B-tron®
WWW.B-tronSemi.com
Page 2
BTRSB6V5C601
ELECTRICAL CHARACTERISTICS
Part Number
Reverse
Standoff
Voltage
VRWM (V)
BTRSB6V5C601
6.5
Breakdown
Voltage
VBR @ IT
Min (V)
7.22
Max (V)
7.98
Test
Current
Max. Reverse
Leakage @
VRWM
IT (mA)
IR (μA)
10
Max. Clamping
Voltage @ Ipp
500
Max. Peak
Pulse Current
VC (V)
Ipp (A)
11.2
53.6
TYPICAL CHARACTERISTICS
2016/03/16 Ver.1
B-tron®
WWW.B-tronSemi.com
Page 3
BTRSB6V5C601
SOLDERING PARAMETERS
PACKAGE OUTLINE
DIM
2016/03/16 Ver.1
B-tron®
Inches
Millimeters
Min.
Max.
Min.
Max.
A
0.077
0.087
1.96
2.20
B
0.171
0.191
4.35
4.85
C
0.130
0.155
3.30
3.94
D
0.087
0.098
2.20
2.50
E
0.030
0.060
0.76
1.52
F
0.001
0.008
0.02
0.20
G
0.200
0.220
5.08
5.59
H
0.006
0.012
0.15
0.30
WWW.B-tronSemi.com
Page 4
BTRSB6V5C601
RECOMMENDED PAD LAYOUT DIMENSIONS
DIM
Inches
Millimeters
A
0.087
2.2
B
0.057
1.45
C
0.100
2.55
D
0.057
1.45
E
0.220 Ref.
5.60 Ref.
ORDERING INFORMATION
2016/03/16 Ver.1
Chip Size
Parts on 13 inch (330mm) Reel
SMB/DO-214AA
3,000PCS
B-tron®
WWW.B-tronSemi.com
Page 5
很抱歉,暂时无法提供与“BTRSB6V5C601”相匹配的价格&库存,您可以联系我们找货
