M2 Series
● 低阻抗,耐高纹波电流,小型化Low ESR, high ripple current, miniaturized
● SMD类型:峰值260℃无铅回流焊接条件SMD type: lead free reflow soldering condition at 260℃ peak correspondence
● 通过RoHS认证RoHS compliant
◆ 规格表 Specifications
项目Items
使用温度范围
Category
temperture range
额定工作电压范围
Rated voltage range
静电容量允许偏差
Capacitance tolerance
漏电流
Leakage current
损耗角正切值tanδ
Dissipation factor
温度特性
Low temperture
characteristics
(Max.impedance ratio)
耐久性
Endurence
耐湿负荷特性
Damp heat
(Steady state)
浪涌电压特性
Surge voltage
焊接耐热性
Resistance to
soldering heat
特性参数Characteristics
-55 ~ +105℃
2.5 ~ 160V
±20%(M)
(at 20℃,120Hz)
施加额定工作电压2分钟后读数,小于或等于规格值 (at 20℃)
Less than or equal to the specified value, after 2 minutes
application of rated voltage at 20℃
Rated voltage (V)
2.5~6.3
10~160
tanδ (Max.)
0.08
0.12
Z(-25℃)/Z(+20℃)
≦ 2.0
Z(-55℃)/Z(+20℃)
≦ 2.5
2.5~25V
I≤0.2CV 或500μA(取大值)
35~160V
I≤0.1CV 或
299μA(取大值)
(at 20℃,120Hz)
(100KHz)
105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃ after application of
rated voltage for 2000 hours at 105℃.
Appearance
No significant damage
Capacitance change
≦±20% of the initial value
D.F.(tanδ)
≦150% of the specified value
ESR
Leakage current
≦The specified value
在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application ofrated
voltage for 1000 hours at 60℃,90%~ 95% RH.
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
浪涌电压=额定电压× 1.15(V)
Surge voltage=Rated voltage × 1.15(V)
在15℃~35℃环境中,按充电30秒;放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复测试,应满足以下要求
The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified
at 15℃~35℃ for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds.
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
按回流焊试验后,应满足于以下要求
Measurement for solder temperature profile shall be made at the capacitor top and the terminal.
Capacitance change
≦±10% of the initial value
D.F.(tanδ)
≦130% of the specified value
ESR
Leakage current
◆ 外形图Dimensions (mm)
ΦD
W
H
C
R
P
5
5.3
5.3
5.9
0.5~0.8
1.4
6.3*4~7.7
6.5
6.5
7.2
0.5~0.8
2.2
6.3*8~15
8
6.5
8.3
6.5
8.3
7.2
9.0
0.7~1.1
0.7~1.1
2.2
3.1
10
10.3
10.3
11.0
0.7~1.1
4.5
1
M2 Series
◆ 纹波电流补正系数 Rated Ripple Current Coefficient
频率Frequency(Hz)
120Hz ≦ f ﹤1kHz
1kHz≦ f ﹤ 10kHz
10kHz ≦ f ﹤ 100kHz
100kHz≦ f ﹤ 500kHz
系数 Coefficient
0.05
0.30
0.7
1.00
◆ 尺寸与技术参数一览表Standard Ratings
Cap(uF)
Rated voltage
(V)
2.5
4
W
Rated capacitance
(uF)
Case size
ΦD×L(mm)
ESR(mΩ)
at 20℃,100 KHz
Leakage Current
(μA)
Rated ripple current
(mArms/105℃/100kHz)
470
6.3*9
18
500
4100
560
6.3*9
18
500
4100
680
6.3*9
18
500
4100
820
6.3*9
18
500
4100
560
6.3*9
18
500
4100
680
6.3*9
18
544
4100
820
6.3*9
18
656
4100
1000
6.3*9
18
800
4100
1200
6.3*9
18
960
4100
6.3*5.8
30
500
2690
6.3*7.7
25
500
2900
6.3*5.8
30
500
2690
6.3*7.7
25
500
2900
470
6.3*7.7
25
592.2
3500
560
6.3*7.7
25
705.6
3500
680
6.3*9
18
856.8
3800
820
6.3*9
18
1033.2
3800
6.3*10
18
1260
4200
8*9.5
15
1260
4900
8*12.6
15
1890
5200
10*13.5
15
1890
5700
10*13.5
15
2772
5700
6.3*5.8
30
500
2500
6.3*7.7
30
500
2650
6.3*7.7
30
660
2650
6.3*7.7
30
940
2700
6.3*9
30
940
2900
560
6.3*9
3100
680
8*9.5
18
1360
4700
8*12.6
16
1640
4900
10*10.5
15
1640
4900
8*12.6
16
2000
4900
10*13.5
15
2000
5300
8*12.6
16
3000
4900
10*13.5
15
3000
5300
10*13.5
15
4400
5300
220
330
6.3
1000
1500
2200
220
330
470
10
820
1000
1500
2200
2
M2 Series
Cap(uF)
Rated voltage
(V)
W
Rated capacitance
(uF)
Case size
ΦD×L(mm)
ESR(mΩ)
at 20℃,100 KHz
Leakage Current
(μA)
(mArms/105℃/100kHz)
47
6.3*5.8
40
500
1900
68
6.3*5.8
40
500
1900
6.3*5.4
45
500
1850
6.3*5.8
40
500
1900
6.3*7.7
35
500
2100
6.3*5.8
35
704
2260
6.3*7.7
30
704
2500
8*9.5
3400
6.3*7.7
30
864
2260
6.3*7.7
30
1056
2260
6.3*9
25
1056
2900
8*9.5
18
1056
3700
6.3*10
25
1504
3500
8*9.5
18
1504
3700
8*12.6
18
1504
4100
10*10.5
15
1504
4800
680
8*12.6
18
2176
4100
820
8*12.6
18
2624
4100
8*12.6
18
3200
4100
10*13.5
15
3200
4900
1500
10*13.5
15
4800
4900
47
6.3*5.8
50
500
1870
6.3*5.4
50
500
1700
6.3*5.8
45
500
1870
6.3*7.7
45
500
1950
6.3*5.8
40
900
1900
6.3*7.7
40
1100
2100
6.3*8.5
40
1100
2100
8*9.5
30
1100
3100
6.3*10
35
1650
2500
8*9.5
30
1650
3100
6.3*10.8
35
2350
2900
8*9.5
30
2350
3100
8*12.6
25
2350
3800
10*10.5
25
2350
4500
10*10.5
25
2800
4500
8*12.6
25
3400
4200
10*13.5
4800
820
10*13.5
4800
1000
10*13.5
4800
100
220
270
16
330
470
1000
100
180
220
25
330
470
560
680
3
M2 Series
Cap(uF)
Rated voltage
(V)
W
Rated capacitance
(uF)
Case size
ΦD×L(mm)
ESR(mΩ)
at 20℃,100 KHz
Leakage Current
(μA)
(mArms/105℃/100kHz)
22
6.3*5.8
100
299
1200
6.3*5.4
80
299
1200
6.3*5.8
80
299
1200
6.3*5.8
60
350
1400
6.3*7.7
60
350
1500
6.3*9
50
350
1700
8*9.5
40
350
2400
6.3*10
50
525
1700
6.3*10.5
40
770
1900
8*9.5
40
770
2500
8*12.6
40
770
2900
10*10.5
40
770
3100
8*12.6
35
1155
2900
10*10.5
35
1155
3100
10*13.5
30
1155
3500
470
10*13.5
30
1645
3500
560
10*13.5
30
1960
3500
680
10*13.5
30
2380
3900
6.3*5.8
100
299
780
6.3*9
100
299
850
6.3*9
100
299
850
6.3*7.7
80
299
850
6.3*9
80
299
900
8*9.5
50
299
1100
8*9.5
50
500
1150
8*12.6
40
500
1550
10*13.5
35
500
2100
8*12.6
40
750
1550
10*13.5
35
750
2400
10*10.5
35
1100
2100
10*13.5
35
1100
2450
330
10*13.5
35
1650
2500
10
6.3*7.7
120
299
700
6.3*5.8
100
299
650
6.3*7.7
100
299
700
6.3*9
100
299
750
6.3*9
100
299
820
8*9.5
45
299
950
8*12.6
40
299
1300
47
100
150
35
220
330
22
33
47
50
100
150
220
22
63
33
47
4
M2 Series
Cap(uF)
Rated voltage
(V)
Case size
ΦD×L(mm)
ESR(mΩ)
at 20℃,100 KHz
Leakage Current
(μA)
(mArms/105℃/100kHz)
8*12.6
40
630
1300
10*10.5
40
630
1700
10*13.5
35
630
2100
150
10*13.5
35
945
2200
220
10*13.5
35
1386
2200
10
6.3*9
120
299
550
22
8*9.5
60
299
1100
33
8*9.5
60
299
1100
8*12.6
60
376
1300
10*10.5
50
376
1400
68
10*13.5
45
544
1800
100
10*13.5
45
800
1900
10
6.3*9
120
299
550
8*9.5
60
299
850
8*12.6
60
299
1190
33
8*12.6
60
330
1190
47
10*13.5
50
470
1550
68
10*13.5
50
680
1600
82
10*13.5
50
820
1600
4.7
8*9.5
350
299
550
10
8*12.6
250
299
750
8*12.6
250
299
750
10*10.5
300
299
750
18
10*13.5
200
299
950
22
10*13.5
200
352
950
W
Rated capacitance
(uF)
100
63
80
47
22
100
160
15
5
很抱歉,暂时无法提供与“RL1V221M0809M2”相匹配的价格&库存,您可以联系我们找货
