TCS4020
TCS4020
    TANGCHENG(汤诚)
    SOT23-5
    DC-DC电源芯片
TCS4020 数据手册
TCS4020 2A, 6V, 1.5MHz, 40uA IQ Synchronous Step-Down Converter DESCRIPTION The TCS4020 is monolithic buck switching regulators based on constant on-time (COT) control for fast transient response. Operating with an input range of 2.6V-6.0V, the TCS4020 deliver 2A of continuous output current with integrated P-Channel and NChannel MOSFETs.The internal synchronous power switches provide high efficiency.At light loads, FEATURES  2.6V to 6.0V Operating Input Range  Up to 2A Output Current  Up to 97% Peak Efficiency  1% Feedback Voltage Accuracy  PFM Mode at Light Load  Internal Soft-start  TCS4020 operate in low frequency to maintain high 1.5MHz Switching Frequency  efficiency. Input Under Voltage Lockout  Current Run-away Protection  Short Circuit Protection output short-circuit protection,start-up current run-away  Thermal Protection protection and input under voltage lockout, and  SOT23-5 Package The TCS4020 guarantee robustness with hiccup thermal protection. The TCS4020 is available in 5-pin SOT23-5 APPLICATIONS package, which provides a compact solution with  5V or 3.3V Point of Load Conversion minimal external components.  Set Top Boxes  Telecom/Networking Systems  Storage Equipment  GPU/DDR Power Supply TYPICAL APPLICATION 地址:深圳市宝安区西乡共和工业路明月花都 F 栋 1009 室 Ver1.0 Jan.06.2025 Page 1 电话:0755-28236800 网址:WWW.TCTEK.CN TCS4020 2A, 6V, 1.5MHz, 40uA IQ Synchronous Step-Down Converter ORDER INFORMATION DEVICE1) PACKAGE TOP MARKING2) ENVIRONMENTAL3) TCS4020_E SOT23-5 AS20XX Green PIN CONFIGURATION EN 1 GND 2 SW 3 5 FB 4 VIN PIN DESCRIPTION Pin Name Description 1 EN 2 GND Ground pin. 3 SW SW is the switching node that supplies power to the output. Connect the output LC filter from SW to the output load. 4 VIN Input voltage pin. VIN supplies power to the IC. Connect a 2.6V to 6.0V supply to VIN and bypass VIN to GND with a suitably large capacitor to eliminate noise on the input to the IC. 5 FB Output feedback pin. FB senses the output voltage and is regulated by the control loop to 0.6V. Connect a resistive divider at FB. Drive EN pin high to turn on the regulator and low to turn off the regulator. 地址:深圳市宝安区西乡共和工业路明月花都 F 栋 1009 室 Ver1.0 Jan.06.2025 Page 2 电话:0755-28236800 网址:WWW.TCTEK.CN TCS4020 2A, 6V, 1.5MHz, 40uA IQ Synchronous Step-Down Converter ABSOLUTE MAXIMUM RATING 1) Vin, EN, FB,Pins ..............................................................................................................................-0.3V to 7.0V SW Pin …..........................................................................-0.3V(-1V for 20ns, -3V for 10ns) to 7.0V(9V for 5ns) Junction Temperature 2)................................................................................................................................ 150ºC Lead Temperature …....................................................................................................................................260ºC Storage Temperature ................................................................................................................. -65ºC to +150ºC ESD Susceptibility (Human Body Model) ...................................................................................................... 2kV RECOMMENDED OPERATING CONDITIONS3) Input Voltage VIN ...............................................................................................................................2.6V to 6.0V Output Voltage VOUT ............................................................................................................................0.6V to VIN Operating Junction Temperature..................................................................................................-40ºC to 125ºC THERMAL PERFORMANCE4) θJA θJc SOT23-5.......................................................................................................................................105.......27ºC/W Note: 1) Exceeding these ratings may damage the device. These stress ratings do not imply function operation of the device at any other conditions beyond those indicated under RECOMMENDED OPERATING CONDITIONS. 2) The TCS4020 include thermal protection that is intended to protect the device in overload conditions. Continuous operation over the specified absolute maximum operating junction temperature may damage the device. 3) The device is not guaranteed to function outside of its operating conditions. 4) Measured on a two-layer TCS4020 Evaluation Board at T A=25℃. 地址:深圳市宝安区西乡共和工业路明月花都 F 栋 1009 室 Ver1.0 Jan.06.2025 Page 3 电话:0755-28236800 网址:WWW.TCTEK.CN TCS4020 2A, 6V, 1.5MHz, 40uA IQ Synchronous Step-Down Converter ELECTRICAL CHARACTERISTICS VIN=5V, TA =25℃, unless otherwise stated. Item Symbol Condition Min. Typ. Max. Units 2.45 V VIN Under Voltage Lockout Threshold VIN_UVLO VIN rising 2.3 VIN Under Voltage Lockout Hysteresis VIN_UVLO_HY ST VIN falling 200 EN Rising Threshold VEN_H VEN rising, FB=0.3V 1.1 1.2 1.3 V EN Falling Threshold VEN_L VEN falling, FB=0.3V 0.9 1 1.1 V EN delay time TEN_delay VIN=3.6V, VEN=3.3V 470 Shutdown Current ISHDN VIN=6.0V, VEN=0V 0.1 1 μA Quiescent Current IQ VEN=5V, IOUT=0A, VFB=VREF*105% 40 70 μA Regulated Feedback Voltage VFB FB Leakage Current IFB PFET On Resistance5) RDSON_P 120 mΩ NFET On Resistance5) RDSON_N 90 mΩ PFET Leakage Current ILEAK_P VIN=6.0V, VEN=0V, VSW=0V 1 uA NFET Leakage Current ILEAK_N VIN=6.0V, VEN=0V, VSW=6.0V 1 uA PFET Current Limit ILIM_TOP NFET Current Limit ILIM_BOT Switch Frequency FSW Minimum On Time5) Minimum Off Time5) Maximum Duty Cycle5) mV us 2.6V
TCS4020 价格&库存
很抱歉,暂时无法提供与“TCS4020”相匹配的价格&库存,您可以联系我们找货
