NSM2012-05B5R-DSPR
NSM2012-05B5R-DSPR
    NOVOSENSE(纳芯微)
    SOIC-8
    电流传感器 ±5A 1 通道 霍尔效应 双向 SOIC-8
NSM2012-05B5R-DSPR 数据手册
NSM2012 High-Accuracy, Hall-Effect-Based Current Sensor IC with Common-Mode Field Rejection in 3kV Isolation Datasheet (EN) 1.2 Product Overview NSM2012 is an integrated path current sensor with a very low on-resistance of 1.2mΩ, reducing heat loss on the chip. NOVOSENSE innovative isolation technology and signal conditioning design can meet high isolation levels while sensing the current flowing through the internal Busbar. A differential Hall pair is used internally, so it has a strong immunity to external stray magnetic fields. NSM2012 supports both a ratiometric output and a fixed output mode. The fixed mode enables customers to use ADC differential sampling of VREF and VOUT voltages to reduce external common-mode (such as temperature,etc). Compared with the current sampling method of the Shunt+ isolated op amp, NSM2012 eliminates the need for the primary side power supply and has a simple and convenient layout. At the same time, it has extremely high isolation withstand voltage and Lifetime stability. In high-side current monitoring applications, NSM2012 can reach a working voltage of 600Vpk, and it can withstand 6kV surge voltage without adding any protection devices. Due to NSM2012 internal accurate temperature compensation algorithm and factory accuracy calibration, this current sensor can maintain good accuracy in the full temperature working range, and the customer does not need to do secondary programming or calibration.  CMTI > 100V/ns  CTI(I)  Creepage distance/Clearance distance: 4mm  NOVOSENSE innovative ‘Spin Current’ technology makes offset temperature drift very small  Ratiometric output or fixed output  Working temperature: -40°C ~ 125°C  Primary internal resistance: 1.2mΩ  SOIC8 package  UL62368/EN62368 safety certification  ROHS compliance Applications      Solar System Industrial Power Supply Motor Control OBC/DCDC/PTC Heater Charging Pile Device Information Part Number NSM2012 Package SOIC8 Body Size 4.9mm × 3.9mm Functional Block Diagrams Support 3.3V/5V power supply (different version) Key Features         High bandwidth and fast response time 400kHz bandwidth 1.5us response time High-precision current measurement Differential Hall sets can immune stray field High isolation level that meets UL standards Withstand isolation voltage (VISO): 3000Vrms Maximum surge isolation withstand voltage (VIOSM): 6kV Copyright © 2025, NOVOSENSE Figure 1. NSM2012 Block Diagram Page 1 NSM2012 Datasheet (EN) 1.2 INDEX 1. PIN CONFIGURATION AND FUNCTIONS ............................................................................................................... 4 2. ABSOLUTE MAXIMUM RATINGS ............................................................................................................................ 5 3. ESD RATINGS ........................................................................................................................................................... 5 4. ISOLATION CHARACTERISTICS ............................................................................................................................. 5 5. SPECIFICATIONS ..................................................................................................................................................... 6 5.1. COMMON CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5VOR3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................... 6 5.2. NSM2012-02B3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................... 7 5.3. NSM2012-02B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................... 8 5.4. NSM2012-05B3F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................... 9 5.5. NSM2012-05B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 10 5.6. NSM2012-10B3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 11 5.7. NSM2012-10B5F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 12 5.8. NSM2012-10B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 13 5.9. NSM2012-10U3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 14 5.10. NSM2012-10U5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 15 5.11. NSM2012-20B3F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 16 5.12. NSM2012-20B3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 17 5.13. NSM2012-20B5F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 18 5.14. NSM2012-20B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 19 5.15. NSM2012-25B5F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 20 5.16. NSM2012-25B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 21 5.17. NSM2012-30B3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 22 5.18. NSM2012-30B5F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 23 5.19. NSM2012-30B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 24 5.20. NSM2012-30U5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 25 5.21. NSM2012-40B3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 26 5.22. NSM2012-40B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 27 5.23. NSM2012-50B3R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 3.3V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 28 Copyright © 2025, NOVOSENSE Page 2 NSM2012 Datasheet (EN) 1.2 5.24. NSM2012-50B5F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 29 5.25. NSM2012-50B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 30 5.26. NSM2012-50U5F-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 31 5.27. NSM2012-65B5R-DSPR CHARACTERISTICS (TA= -40°C TO 125°C, VCC = 5V, UNLESS OTHERWISE SPECIFIED) ............................................................................................................................................................. 32 5.28. TYPICAL PERFORMANCE CHARACTERISTICS ........................................................................................ 33 NSM2012-30B3R-DSPR[1] ....................................................................................................................................... 33 NSM2012-30B5R-DSPR[1] ....................................................................................................................................... 34 NSM2012-10U5R-DSPR[1] ....................................................................................................................................... 35 NSM2012-20B5R-DSPR[1] ....................................................................................................................................... 36 6. FUNCTION DESCRIPTION .................................................................................................................................... 38 6.1. 6.2. 6.3. 6.4. OVERVIEW .................................................................................................................................................... 38 NSM2012 R VERSION (SINGLE-ENDED RATIOMETRIC OUTPUT) ........................................................... 38 NSM2012 F VERSION (FIXED OUTPUT) ..................................................................................................... 38 DEFINITION OF NSM2012 TERMS .............................................................................................................. 39 7. APPLICATION NOTE .............................................................................................................................................. 41 7.1. 7.2. 7.3. TYPICAL APPLICATION CIRCUIT ................................................................................................................ 41 PCB LAYOUT ................................................................................................................................................. 41 THERMAL EVALUATION ............................................................................................................................... 42 8. PACKAGE INFORMATION...................................................................................................................................... 44 9. ORDER INFORMATION .......................................................................................................................................... 45 10. TAPE AND REEL INFORMATION ......................................................................................................................... 47 11. REVISION HISTORY ............................................................................................................................................. 49 Copyright © 2025, NOVOSENSE Page 3 NSM2012 Datasheet (EN) 1.2 1. Pin Configuration and Functions IP+ 1 IP+ 2 IP- 3 IP- 4 8 VCC IP+ 1 7 VOUT IP+ 2 6 NC IP- 5 GND IP- NSM2012 8 VCC 7 VOUT 3 6 VREF 4 5 GND NSM2012 R Version F Version Figure 1.1 NSM2012 Package Table 1.1 NSM2012 Pin Configuration and Description NSM2012 PIN NO. Symbol Function 1-2 IP+ Current flows into the chip, positive direction 3-4 IP- Current flows out of the chip, negative direction 5 GND Ground 6 VREF/NC For ’F’ version, this Pin is VREF; For ‘R’ version, internal circuit connection, this Pin can also connect to GND 7 VOUT Output voltage 8 VCC Power supply Copyright © 2025, NOVOSENSE Page 4 NSM2012 Datasheet (EN) 1.2 2. Absolute Maximum Ratings Parameters Symbol Min Typ Max Unit VCC VCC -0.3 6.5 V 25°C Vout/Vref -0.3 VCC+0.3 V 25°C Others Pin -0.3 VCC+0.3 V 25°C Storage temperature TStorage -40 150 °C Ambient temperature Toperation -40 125 °C Junction temperature Tj -40 150 °C Comments 3. ESD Ratings Ratings Value Unit Human body model (HBM), per AEC-Q100-002-RevD Electrostatic discharge  All pins ±8 kV ±2 kV Charged device model (CDM), per AEC-Q100-011-RevB  All pins 4. Isolation Characteristics Parameters Symbol Rating Unit Comments Dielectric Surge Voltage Vsurge 6 kV Based on IEC61000-4-5 1.2µs/50µs waveform 60s isolation voltage parameters, according to UL62368-1, 3.6kV/ 1s insulation performance will be tested before delivery, and partial discharge is verified to be less than 5pC Dielectric Strength Test Voltage Working Voltage for Basic Isolation VISO 3000 Vrms VWVBI 424 Vrms 600 Vdc Maximum approved working voltage for basic isolation according to UL60950-1 and UL62368-1 Common-mode transient immunity CMTI >100 V/ns The criterion for judging the failure is that the output peak is greater than 100mV and the duration is longer than 1us Creepage Creepage 4 mm Minimum Creepage Clearance Clearance 4 mm Minimum Clearance Comparative Tracking Index CTI >=600 Copyright © 2025, NOVOSENSE CTI I Page 5 NSM2012 Datasheet (EN) 1.2 5. Specifications 5.1. Common Characteristics (TA= -40°C to 125°C, VCC = 5Vor3.3V, unless otherwise specified) Parameters Symbol Supply voltage VCC Supply current ICC Primary conductor resistance RP Min Typ Max Unit Comments 3 3.3 3.6 V 3.3V version 4.5 5 5.5 V 5V version 12 15 mA No load,Vcc=5V 7.5 8 mA No load,Vcc=3.3V mΩ TA = 25°C ms It is recommended that customers read data after Vcc reaches Vccmin 1ms, and internal register loading 1ms after POR 1.2 Power-on time Tpo Output capacitance load[1][2] CL Output resistance load[1][2] RL Output short current Ishort Rail to Rail output voltage[1][2] Vs Common mode field rejection[1][2] CMFR >40 dB Power supply rejection ratio PSRR -50 dB Only for ‘F’ version, DC to 1 kHz, 100 mV pk-pk ripple around Vcc=5V, IP=0A Rise time Tr 0.9 us Vout=2.2V, TA = 25°C, CL=1nF, Vcc=3.3V, 30AB, R version Propagation dealy Tpd 0.9 us Vout=2.2V, TA = 25°C, CL=1nF, Vcc=3.3V, 30AB, R version Response time Tresponse 1.5 us Vout=3V, TA = 25°C, CL=1nF, Vcc=3.3V, 30AB, R version Bandwidth[1][2] BW 400 kHz -3dB bandwidth, TA = 25°C, CL=1nF, Vcc=3.3V, 30AB, R version 120 uArms/√ Hz TA = 25°C, CL=1nF, Vcc= 5V 140 uArms/√ Hz ±0.2 % Noise density [1][2] Non-linearity Copyright © 2025, NOVOSENSE 1 10 10 kΩ 25 0.1 mA VCC-0.1 ND ENL nF V Short to Vcc and short to GND, TA = 25°C TA = 25°C, CL=1nF, RL=10K to Vcc or GND TA = 25°C, CL=1nF, Vcc= 3.3V Page 6 NSM2012 Parameters Reference voltage Datasheet (EN) 1.2 Symbol Vref Min Typ Max Unit Comments 2.49 2.5 2.51 V ‘FB’ version, Vcc=5V 1.64 1.65 1.66 V ‘FB’ version, Vcc=3.3V 0.49 0.5 0.51 V ‘FU’ version, Vcc=5V 0.32 0.33 0.34 V ‘FU’ version, Vcc=3.3V Ratiometric output sensitivity error SERR 0.75 % ‘R’ version, Vcc= 4.85V~5.15V, TA = 25°C Rationmetric output offset error VOUT0R 0.1 % ‘R’ version, Vcc= 4.85V~5.15V, TA = 25°C Ratiometric output zero current output voltage QVO VCC/2 ‘RB’ version, Vcc=5V/3.3V 0.1*VCC ‘RU’ version, Vcc=5V/3.3V [1]: Guaranteed by design. [2]: Guaranteed by Bench Validation [3]: The increase or decrease of data in charpter 5.X will not send a PCN to the customer if the evaluation does not affect the customer's use. 5.2. NSM2012-02B3R-DSPR Characteristics (TA= -40°C to 125°C, VCC = 3.3V, unless otherwise specified) Parameters Symbol Min Current sensing range Ipr -2 Sensitivity Sens 660 mV/A Iprmin
NSM2012-05B5R-DSPR 价格&库存
很抱歉,暂时无法提供与“NSM2012-05B5R-DSPR”相匹配的价格&库存,您可以联系我们找货
