SD10U45SL
10A/45V Ultra Low VF Schottky Rectifier
FEATURES
MACHANICAL DATA
High current capability, low forward voltage
Excellent high temperature stability
Low power loss, and high efficiency
High forward surge capability
RoHS compliant, and Halogen free
Case: TO-277 small outline plastic package
Terminal: Matte tin plated, solderable per
MIL-STD-750, Method 2026
Molding
Compound
Flammability
Rating:UL94-0
High temperature soldering guaranteed:
260℃/10second
Packed with FRP substrate and epoxy
underfilled
ORDERING INFORMATION
APPLICATIONS
Device: SD10U45SL
Package: TO-277
Marking: 10U45
Material: Halogen free
Packing: Tape & 13’’ Reel
Quantity per reel: 3,000pcs
Switching mode power supply applications
Portable equipment battery applications
High frequency rectification
DC/DC converter
Designed as bypass diodes for solar panels
PIN CONFIGURATION
PACKAGE OUTLINE
ABSOLUTE MAXIMUM RATING (Tamb=25°C, unless otherwise specified)
Symbol
Parameter
Value
Units
VRRM
Repetitive Peak Reverse Voltage
45
V
IF(AV)
Average Forward Current
10
A
IFSM
Peak Forward Surge Current, 8.3ms single half
sine-wave
280
A
TJ &
TSTG
Junction and Storage Temperature
-40~+150
°C
Revision:20240701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
SD10U45SL
ELECTRICAL CHARACTERISTICS (Tamb=25°C, unless otherwise specified)
Symbol
VF
Parameter
Test Condition
Forward Voltage (note 1)
Typ
Max
Units
IF = 2A
0.32
0.36
V
IF = 8A
IF = 10A
IF = 2A, @100℃
IF = 10A, @100℃
0.39
0.45
0.42
0.48
V
V
0.23
0.36
0.26
0.38
V
V
VBR
Reverse Breakdown Voltage
IR = 0.5mA
IR
Reverse Leakage Current
VR = 45V
VR = 45V, @100℃
Rth(JA)
Thermal Resistance (note 2)
Min
45
V
0.3
mA
mA
℃/W
Note 1: Pulse test width PW=300usec, 1% duty cycle
Note 2: Polymide PCB, 2oz. copper. Cathode pad dimensions 18.8x14.4mm. Anode pad dimensions 5.6x14.4mm
Revision:20240701-P2
ht t p : //
www.lgesem i .c o m
SD10U45SL
ELECTRICAL CHARACTERISTICS CURVE
Revision:20240701-P3
ht t p : //
www.lgesem i .c o m
SD10U45SL
TO-277 PACKAGE OUTLINE DIMENSIONS
unit: mm
FOOT PRINT RECOMMENDATION
unit: mm
PACKAGE INFORMATION
Device
SD10U45SL
Revision:20240701-P4
Package
Shipping
TO-277
5000/Tape&Reel
ht t p : //
www.lgesem i .c o m
很抱歉,暂时无法提供与“SD10U45SL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.54000
- 100+1.18800
- 1250+0.99220
- 2500+0.90090
- 5000+0.83600
