AZ9436-01G
Transient Voltage Suppressing Device
For ESD/Surge/Transient Protection
Features
over-voltage damage and latch-up caused by
ESD/Surge Protection for 1 Line with
Electrostatic Discharging (ESD), Lightning, and
Unidirectional.
Cable Discharge Event (CDE).
Provide ESD protection for each line to
AZ9436-01G is a unique design which
IEC 61000-4-2 (ESD) ±30kV (air / contact)
IEC 61000-4-5 (Lightning) 12A (8/20µs)
! Suitable for, 36V and below, operating voltage
includes proprietary clamping cell in a single
package.
During transient conditions, the proprietary
applications
clamping cell prevents over-voltage on the power
Small package saves board space
line
Protect one I/O line or one power line
downstream components.
Fast turn-on and Low clamping voltage
Solid-state silicon-avalanche and active circuit
immunity requirements of IEC 61000-4-2, Level 4
triggering technology
(±15kV air, ±8kV contact discharge).
or
control/data
lines,
protecting
any
AZ9436-01G may be used to meet the ESD
Green part
! AEC-Q101 qualified
Circuit Diagram / Pin Configuration
Applications
Battery Contacts
Power Manager System
PDA’s
Portable Devices
Digital Cameras
Digital Frames
Cellular Handsets and Accessories
Notebooks, desktops, and servers
Microprocessor-based equipment
Peripherals
1
2
Description
AZ9436-01G is a design which includes a
unidirectional ESD rated clamping cell to protect
one power line, or one control line, or one low
SOD-123 (Top View)
speed data line in an electronic systems. The
AZ9436-01G has been specifically designed to
protect
sensitive
components
which
are
connected to power and control lines from
Revision 2015/06/01 © 2015 Amazing Micro.
1
www.amazingIC.com
AZ9436-01G
SPECIFICATIONS
ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
RATING
UNITS
Peak Pulse Current (tp =8/20µs)
IPP
12
A
Operating Supply Voltage (pin-1 to pin-2)
VDC
39.6
V
Pin-1 to pin-2 ESD per IEC 61000-4-2 (Air)
VESD-1
±30
kV
Pin-1 to pin-2 ESD per IEC 61000-4-2 (Contact)
VESD-2
±30
Lead Soldering Temperature
TSOL
260 (10 sec.)
o
Operating Temperature
TOP
-55 to +125
o
-55 to +150
o
Storage Temperature
TSTO
C
C
C
ELECTRICAL CHARACTERISTICS
PARAMETER
SYMBOL
CONDITIONS
MINI
TYP
MAX
UNITS
36
V
1
µA
Reverse
Stand-Off
VRWM
Pin-1 to pin-2, T=25 oC.
Voltage
Reverse
Leakage Current
ILeak
VRWM = 36V, T=25 oC, pin-1 to
pin-2.
Reverse
Breakdown
VBV
IBV = 1mA, T=25 oC, pin-1 to pin-2
40
49
V
VF
IF = 15mA, T=25 oC, pin-2 to pin-1
0.5
1.2
V
Voltage
Forward Voltage
Surge Clamping
Voltage
ESD Clamping
Voltage (Note 1)
VCL-surge
Vclamp
Capacitance
43
V
Contact mode, T=25 oC, pin-1 to
47
V
0.26
Ω
pin-2.
Rdynamic
Resistance
Channel Input
to pin-2
IEC 61000-4-2 +8kV (ITLP = 16A),
ESD Dynamic
Turn-on
IPP=5A, tp=8/20µs, T=25 oC, pin-1
CIN
IEC 61000-4-2 0~+8kV, T=25 oC,
Contact mode, pin-1 to pin-2.
VR = 0V, f = 1MHz, T=25 oC, pin-1
to pin-2.
420
pF
Note 1: ESD Clamping Voltage was measured by Transmission Line Pulsing (TLP) System.
TLP conditions: Z0= 50Ω, tp= 100ns, tr= 2ns.
2
www.amazingIC.com
AZ9436-01G
Typical Characteristics
Reverse Clamping Voltage vs. Peak Pulse Current
Forward Clamping Voltage vs. Peak Pulse Current
60
3
Pin-1 to Pin-2
58
Pin-2 to Pin-1
54
Clamping Voltage (V)
56
52
50
48
46
44
42
2
1
Waveform
Parameters:
tr = 8µs
td = 20µs
Waveform
Parameters:
tr = 8µs
td = 20µs
40
38
4
5
6
7
8
9
10
11
12
13
4
14
5
6
8
9
10
11
V_pulse
Pin-1 to Pin-2
TLP_I
Input Capacitance (pF)
TLP_V
15
14
f = 1MHz, T = 25 C
350
100ns
13
400
25
Pulse from a
20 transmission line
12
T ypical Variation of C IN vs. V IN
T ransmission Line Pulsing (T LP) M easurement
Transmission Line Pulsing (TLP) Current (A)
7
Peak Pulse Current (A)
DUT
_
Pin-1 to Pin-2
T = 25 C
10
5
300
250
200
150
100
50
10
15
30
35
40
45
50
Transmission Line Pusling (TLP) Voltage (V)
2
4
6
8 10 12 14 16 18 20 22 24 26 28 30 32 34 36
Input Voltage (V)
3
www.amazingIC.com
AZ9436-01G
Applications Information
In order to obtain enough suppression of ESD
The AZ9436-01G is designed to protect one
induced transient, good circuit board is critical.
line against System ESD/Lightning pulses by
Thus, the following guidelines are recommended:
clamping them to an acceptable reference.
Minimize the path length between the
protected lines and the AZ9436-01G.
The usage of the AZ9436-01G is shown in Fig.
Place the AZ9436-01G near the input
1. Protected lines, such as data lines, control
terminals or connectors to restrict transient
lines, or power lines, are connected at pin 1. The
coupling.
pin 2 should be connected directly to a ground
plane on the board. All path lengths connected to
The ESD current return path to ground
should be kept as short as possible.
the pins of AZ9436-01G should be kept as short
Use ground planes whenever possible.
as possible to minimize parasitic inductance in
NEVER route critical signals near board
the board traces.
edges and near the lines which the ESD
transient easily injects to PCB internal circuit.
IC to be protected
Connector
VDD
Data
Control
2
2
1
AZ9436- 01G
1
AZ9436- 01G
1
AZ9436-01G
GND
2
Fig. 1 ESD protection scheme by using AZ9436-01G.
4
www.amazingIC.com
AZ9436-01G
Mechanical Details
SOD-123
PACKAGE DIAGRAMS
TOP VIEW
PACKAGE DIMENSIONS
Symbol
Inches
MIN.
MAX.
MIN.
MAX.
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.450
0.650
0.018
0.026
c
0.080
0.150
0.003
0.006
D
1.500
1.700
0.059
0.067
E
2.600
2.800
0.102
0.110
E1
3.550
3.850
0.140
0.152
L
L1
SIDE VIEW
Millimeters
0.500 REF
0.250
8
0.020 REF
0.010
8
LAND LAYOUT
0.7 mm
Notes:
This LAND LAYOUT is for reference
purposes only. Please consult your
manufacturing partners to ensure your
company’s PCB design guidelines are met.
5
www.amazingIC.com
AZ9436-01G
MARKING CODE
BX
NX
1
Part Number
2
Marking Code
AZ9436-01G
NX
(Green Part)
Note : Green means Pb-free, RoHS, and
Halogen free compliant.
N = Device Code
X = Date Code
Ordering Information
PN#
Material
Type
Reel size
MOQ
AZ9436-01G.R7G
Green
T/R
7 inch
3,000/reel
MOQ/internal box
MOQ/carton
4 reel= 12,000/box 6 box =72,000/carton
Revision History
Revision
Modification Description
Revision 2015/02/10
Preliminary Release.
Revision 2015/06/01
Formal Release.
6
www.amazingIC.com
很抱歉,暂时无法提供与“AZ9436-01G.R7G”相匹配的价格&库存,您可以联系我们找货
