N-Channel Enhancement Mode Field
Effect Transistor
NIKO-SEM
P8806BM
SOT-23
Halogen-Free & Lead-Free
PRODUCT SUMMARY
D
V(BR)DSS
RDS(ON)
ID
60V
88mΩ
2A
G
G. GATE
D. DRAIN
S. SOURCE
S
ABSOLUTE MAXIMUM RATINGS (T A = 25 °C Unless Otherwise Noted)
PARAMETERS/TEST CONDITIONS
SYMBOL
LIMITS
UNITS
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
TC = 25 °C
TC = 70 °C
Pulsed Drain Current
1
1.6
IDM
TA = 25 °C
Power Dissipation
2
ID
0.78
PD
TA = 70 °C
Operating Junction & Storage Temperature Range
A
11
W
0.5
Tj, Tstg
-55 to 150
°C
THERMAL RESISTANCE RATINGS
THERMAL RESISTANCE
Junction-to-Ambient
SYMBOL
2
TYPICAL
MAXIMUM
UNITS
159
°C / W
RJA
1
Pulse width limited by maximum junction temperature.
2
The value of RθJA is measured with the device mounted on 1in FR-4 board with 2oz. Copper, in a still air
environment with TA =25°C.
2
ELECTRICAL CHARACTERISTICS (TJ = 25 °C, Unless Otherwise Noted)
PARAMETER
SYMBOL
TEST CONDITIONS
LIMITS
UNIT
MIN TYP MAX
STATIC
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = 250A
60
VGS(th)
VDS = VGS, ID = 250A
1.3
Gate-Body Leakage
IGSS
VDS = 0V, VGS = ±20V
±100
Zero Gate Voltage Drain Current
IDSS
VDS = 48V, VGS = 0V
1
VDS = 40V, VGS = 0V, TJ = 55 °C
10
Gate Threshold Voltage
Drain-Source On-State
1
Resistance
RDS(ON)
V
1.9
2.3
VGS =4.5V, ID = 2A
71
108
VGS = 10V, ID = 2 A
59
88
nA
A
mΩ
J-33-2
REV 1.1
1
Effect Transistor
NIKO-SEM
P8806BM
SOT-23
Forward Transconductance
1
gfs
VDS = 5V, ID = 2A
10
S
DYNAMIC
Input Capacitance
Ciss
VGS = 0V, VDS = 25V, f = 1MHz
228
286
343
30
38
45.6
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
16
28
39
Qg
6.8
8.5
10.2
0.6
0.8
1
2
3.3
4.6
Total Gate Charge
2
Gate-Source Charge
Gate-Drain Charge
2
Fall Time
2
2
Turn-Off Delay Time
VDS = 30V , VGS = 10V,
ID = 2A
Qgs
Qgd
Turn-On Delay Time
Rise Time
2
2
2
td(on)
pF
nC
8.3
tr
VDS = 30V ,
10
td(off)
ID 2A, VGS = 10V, RGEN =6Ω
tf
nS
4.5
SOURCE-DRAIN DIODE RATINGS AND CHARACTERISTICS (T J = 25 °C)
Continuous Current
Forward Voltage
1
IS
VSD
Reverse Recovery Time
trr
Reverse Recovery Charge
Qrr
IF = 2A, VGS = 0V
IF = 2A, dlF/dt = 100A / S
0.6
A
1.2
V
9
18
27
nS
5
10
15
nC
Pulse test : Pulse Width 300 sec, Duty Cycle 2%.
Independent of operating temperature.
1
2
J-33-2
REV 1.1
2
Effect Transistor
NIKO-SEM
SOT-23
Output Characteristics
Transfer Characteristics
12
VGS=10V
VGS=9V
VGS=8V
VGS=7V
VGS=6V
VGS=5V
VGS=4.5V
9
ID, Drain-To-Source Current(A)
12
VGS=3.2V
6
VGS=3V
3
9
6
25℃
3
125℃
2
3
4
5
VDS, Drain-To-Source Voltage(V)
1
2
3
4
5
VGS, Gate-To-Source Voltage(V)
On-Resistance VS Gate-To-Source
Voltage
0.5
On-Resistance VS Drain Current
0.12
RDS(ON)ON-Resistance(OHM)
ID=2A
-20℃
0.3
0.2
0.1
0.09
VGS=4.5V
0.06
VGS=10V
0.03
4
6
8
3
6
9
12
ID , Drain-To-Source Current(A)
On-Resistance VS Temperature
Capacitance Characteristic
350
2.4
2.2
300
CISS
2.0
C , Capacitance(pF)
Normalized Drain to Source
ON-Resistance
P8806BM
1.8
1.6
1.4
1.2
1.0
VGS=10V
ID=2A
0.8
250
200
150
100
50
COSS
CRSS
0.6
-50
-25
50
75
100
125
5
10
15
30
TJ , Junction Temperature(˚C)
J-33-2
REV 1.1
3
Effect Transistor
NIKO-SEM
Source-Drain Diode Forward Voltage
100
VDS=30V
ID=2A
8
IS , Source Current(A)
VGS , Gate-To-Source Voltage(V)
SOT-23
Gate charge Characteristics
Characteristics
10
P8806BM
6
4
2
10
1
150℃
25℃
0.1
4
6
8
0.0
10
0.2
Qg , Total Gate Charge(nC)
0.4
0.6
0.8
1.2
1.4
VSD, Source-To-Drain Voltage(V)
Safe Operating Area
Single Pulse Maximum Power Dissipation
12
100
Operation in This
Area is Limited by
RDS(ON)
Single Pulse
RθJA = 159 ˚C/W
TA = 25˚C
9
10
Power(W)
ID , Drain Current(A)
1.0
1
6
1ms
0.1
3
NOTE :
1.VGS = 10V
2.TA =25˚C
3.RθJA = 159 ˚C/W
4.Single Pulse
10ms
100ms
DC
0.01
0.1
1
10
100
0.01
0.1
1
10
100
Single Pulse Time(s)
Transient Thermal Response Curve
Transient Thermal Resistance
r(t) , Normalized Effective
10
1
Duty cycle=0.5
Notes
0.2
0.1
0.1
0.05
1.Duty cycle, D= t1 / t2
2.RthJA = 159 ℃/W
3.TJ-TA = P*RthJA(t)
4.RthJA(t) = r(t)*RthJA
0.02
0.01
single pulse
0.01
0.0001
0.001
0.01
0.1
1
10
100
T1 , Square Wave Pulse Duration(S)
J-33-2
REV 1.1
4
很抱歉,暂时无法提供与“P8806BM”相匹配的价格&库存,您可以联系我们找货
