SFH 9206
SFH 9206
    AMSOSRAM(艾迈斯半导体)
    SOIC-6
    反射 光学传感器 0.039" ~ 0.197"(1mm ~ 5mm) 6-SOIC(0.126",3.20mm 宽)
SFH 9206 数据手册
2015-12-22 Reflective Interrupter Version 1.5 SFH 9206 Features: • 940nm emitter in combination with a silicon NPN phototransistor • Optimal operating distance 1 mm to 5 mm • Daylight cut-off filter • Emitter and detector electrically isolated • Soldering Methode: IR Reflow Soldering • Product complies to MSL Level 4 Applications • Position reporting • End position switch • Speed monitoring and regulating • Motion transmitter Ordering Information Type: Collector-emitter current Ordering Code IPCE [µA] Kodak neutral white testcard with 90% reflection; IF = 10 mA, VCE = 5 V, d = 1 mm SFH 9206 160 ... 2000 Q65111A3179 SFH 9206-4 160 ... 320 - SFH 9206-5/6 250 ... 800 Q65111A3177 SFH 9206-6/7 400 ... 1250 Q65111A3178 SFH 9206-8 1000 ... 2000 - 2015-12-22 1 Version 1.5 SFH 9206 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Emitter Reverse voltage VR 5 V Forward current IF 50 mA Surge current (tp ≤ 10 μs, D=0) IFSM 0.7 A Ptot 100 mW RthJA 495 K/W Collector-emitter voltage VCE 16 V Collector-emitter voltage (t ≤ 2 min) VCE 30 V Emitter-collector voltage VEC 7 V Collector current IC 10 mA Ptot 100 mW RthJA 495 K/W Power consumption Thermal resistance junction - ambient 1) page 14 Detector Total Power dissipation Thermal resistance junction - ambient 1) page 14 Interrupter Operating and storage temperature range Top; Tstg -40 ... 100 °C Ambient temperature range TA -40 ... 100 °C Total power dissipation Ptot 150 Electrostatic discharge VESD mW 2 kV Characteristics (TA = 25 °C) Parameter Symbol Values Unit 950 nm Emitter Peak wavelength (IF = 50 mA, tp = 20 ms) (typ) Forward voltage (IF = 50 mA, tp = 20 ms) (typ (max)) VF Reverse current (VR = 5 V) IR Detector 2015-12-22 λpeak 2 1.45 (≤ 1.8) not designed for reverse operation V µA Version 1.5 SFH 9206 Parameter Symbol Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE Dark current (VCE = 16 V, E = 0) (typ (max)) ICE0 Photocurrent (ambient light sensitivity) (VCE = 5 V, EV = 1000 lx) (typ) (min) (typ) (max) Values Unit 5 pF 1 (≤ 50) nA IPCE 1 mA IPCE IPCE IPCE 160 600 2000 µA µA µA 200 (< 600) mV Interrupter Collector-emitter current (Kodak neutral white testcard with 90% reflection; IF = 10 mA, V CE = 5 V, d = 1 mm) Collector-emitter saturation voltage (typ (max)) VCEsat (Kodak neutral white testcard with 90% reflection; IF = 10 mA, IC = 55 µA, d = 1 mm) Switching Times Turn-on time 2) page 14 (VCC = 5 V, IC = 100 µA, RL = 1 kΩ) (typ) ton 40 µs Rise time 2) page 14 (VCC = 5 V, IC = 100 µA, RL = 1 kΩ) (typ) tr 30 µs Turn-off time 2) page 14 (VCC = 5 V, IC = 100 µA, RL = 1 kΩ) (typ) toff 45 µs Fall time 2) page 14 (VCC = 5 V, IC = 100 µA, RL = 1 kΩ) (typ) tf 40 µs 2015-12-22 3 Version 1.5 SFH 9206 Mechanical test setup d Reflector with 90% reflexion (Kodak neutral white test card) OHM02257 Test Circuit for Switching and Response Time ΙF RL ΙC VCC Output OHM02258 2015-12-22 4 Version 1.5 SFH 9206 Collector Current 3) page 14 IC / ICmax = f(d), TA = 25°C Collector Current 3) page 14 IC = f(IF), d = 1 mm, 90% reflection, TA = 25°C OHF05610 100 IC % IC IC max OHF05611 6 mA 5 80 70 4 60 3 50 40 2 30 20 10 0 1 Kodak neutral white test card Mirror 0 0 1 2 3 4 mm 5 d Relative Spectral Emission (typ) Irel = f(λ), TA = 25°C OHF05612 2.0 1.5 1.0 mA 50 3) page 14 OHF04134 100 I rel % mA IC 5 10 15 20 25 30 35 IF Photocurrent 3) page 14 IC = f(VCE), d = 1 mm, 90% reflection, TA = 25°C 2.5 0 I F = 25 mA 80 I F = 20 mA 60 I F = 15 mA 40 I F = 10 mA 0.5 20 I F = 5 mA 0 -1 10 100 101 0 800 V 102 2015-12-22 850 900 950 nm 1025 λ VCE 5 Version 1.5 SFH 9206 Forward Current 3) page 14 IF = f(VF), single pulse, tp = 100 µs IF Max. Permissible Forward Current IF = f(TA) OHF03828 100 A IF OHF05614 60 mA 50 10 -1 5 40 10-2 30 5 20 10-3 5 10-4 10 0 0.5 1 1.5 0 2.5 V 3 2 0 20 40 60 80 ˚C 100 TA VF Permissible Pulse Handling Capability IF = f(tp), TA = 25 °C, duty cycle D = parameter 0.75 A IF Permissible Pulse Handling Capability IF = f(tp), T A = 85 °C, duty cycle D = parameter OHF05615 tP D= T 0.75 A tP IF IF T tP D= T tP IF T 0.60 0.55 0.50 0.45 D= 0.40 0.005 0.35 0.01 0.02 0.30 0.05 0.25 0.1 0.2 0.20 0.5 0.15 1 0.10 0.05 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 0.60 0.55 0.50 D= 0.45 0.005 0.40 0.01 0.02 0.35 0.05 0.30 0.1 0.2 0.25 0.5 0.20 1 0.15 0.10 0.05 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp 2015-12-22 OHF05616 tp 6 Version 1.5 SFH 9206 Dark Current 3) page 14 ICEO = f(TA), VCE = 20 V, E = 0 Collector-Emitter Capacitance 3) page 14 CCE = f(VCE), f = 1 MHz, E = 0, TA = 25°C OHF01530 10 3 nA OHF01528 5.0 Ι CEO C CE pF 4.0 10 2 3.5 3.0 10 1 2.5 2.0 1.5 10 0 1.0 0.5 10 -1 -25 0 25 50 0 10 -2 75 ˚C 100 TA Relative Spectral Sensitivity 3) page 14 Srel = f(λ), TA = 25°C 10 -1 10 0 10 1 V 10 2 V CE Photocurrent 3) page 14 IPCE / IPCE(25°C) = f(TA), VCE = 5 V, If=10mA 1.4 OHF05686 I pce I pce (25 ˚C) 1.0 0.8 0.6 0.4 0.2 0 -60 -40 -20 0 20 40 60 80 ˚C 120 TA 2015-12-22 7 Version 1.5 SFH 9206 Package Outline Dimensions in mm. Pinning Pin Description 1 Anode 2 - 3 Emitter 4 Collector 5 - 6 Cathode Package Reflective Interrupter Approximate Weight: 40.0 mg 2015-12-22 8 Version 1.5 SFH 9206 Recommended Solder Pad Dimensions in mm (inch). Reflow Soldering Profile Product complies to MSL Level 4 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t 2015-12-22 9 Version 1.5 SFH 9206 OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range Taping Dimensions in mm (inch). 2015-12-22 °C 10 s Version 1.5 SFH 9206 Tape and Reel 12 mm tape with 1000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions [mm] Tape dim ensions in m m W P0 12 + 0.3 / - 0.1 4 ± 0.1 P1 P2 D0 E F 4 ± 0.1 or 8 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 5.5 ± 0.05 Reel dimensions [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 12 60 12.4 + 2 18.4 Barcode-Product-Label (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 2015-12-22 11 Version 1.5 SFH 9206 Dry Packing Process and Materials Moisture-sensitive label or print Barcode label L VE el LE see lab e If nk, bla cod bar y . H) (R . dit mi hu e ve ed ag ati RH % /60 ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe TIO or d , cte itio U g coSEND an bje ing ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < tor ll pro SE _ < urs ). urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt˚C or l wi fac Flo tim s at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic 5a is be or de 24 tin en pro ve l 6 Le de , e te co , g: un wh Le ve l ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim se for ist ure ale op se for > , Mo se ure 3 is or . , is ha se Mo istist nk be nk rd g -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. Transportation Packing and Materials Barcode label Y M DE 18 R -1 Q + -1 P P: OU GR 01 C: 99 8 D/ 21 D) 00 (9 00 : 20 (Q 14 2 5 TY A 21 : 11 00 R ic S NO O 12 H em H S TC BA 3G P) : 12 (6 NO T LO T) (1 (X DE M R 18 -1 Q + -1 P RO UP : G (G ) u L lt S iT Y O T P 67 L 6 44 M D/ (9 D) 00 : 20 )Q TY C: 01 Y E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Muster : 34 : NO PR O ) (X Packing Sealing label Dimensions of transportation box in mm Width Length Height 195 ± 5 195 ± 5 30 ± 5 2015-12-22 M RA OS D 5 14 2 110 0 (Q O 12 3G TC (6 P) NO : 12 LO (1 T) T BA 8 H S S em R ic AM o n O d u p ct to o H rs NO 2199 : NO PR OD ) < at 2100 34 on M du O p ct to or s 44 el ) L )Q E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da e 40 be oc ry tim ˚C e r th ll pr tim cto ). r oo 23 wi nt tim e l wi fa r Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk g rd M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP e ed r oo tim vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE OI M TO OP (G M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 12 OHA02044 Version 1.5 SFH 9206 Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-12-22 13 Version 1.5 SFH 9206 Glossary 1) Thermal resistance: Mounting on PC-board with > 5 mm2 pad size 2) IC as a function of the forward current of the emitting diode, the degree of reflection and the distance between reflector and component (d) 3) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2015-12-22 14 Version 1.5 SFH 9206 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-12-22 15
SFH 9206 价格&库存
很抱歉,暂时无法提供与“SFH 9206”相匹配的价格&库存,您可以联系我们找货
SFH 9206
  • 1000+5.846161000+0.74984
  • 2000+5.552752000+0.71220
  • 3000+5.402413000+0.69292
  • 5000+5.232665000+0.67115
  • 7000+5.131747000+0.65820
  • 10000+5.0333810000+0.64559
库存:7525
SFH 9206
  • 5+9.63280
  • 250+9.42036
  • 500+9.22250
库存:105
SFH 9206
  • 1+11.188931+1.43510
  • 5+9.779305+1.25430
  • 10+8.9863910+1.15260
  • 50+7.1362550+0.91530
  • 100+6.25523100+0.80230
库存:942
SFH 9206
  • 250+9.42036
  • 500+9.22250
库存:840
SFH 9206
  • 1+13.633761+1.74868
  • 10+9.6463710+1.23725
  • 100+7.25147100+0.93008
  • 500+6.19219500+0.79422
库存:7525
