ESP32-C5-WROOM-1-N4
ESP32-C5-WROOM-1-N4
    ESPRESSIF(乐鑫)
    SMD-28P
    RF收发器模块
ESP32-C5-WROOM-1-N4 数据手册
ESP32-C5-WROOM-1 ESP32-C5-WROOM-1U Datasheet Version 1.1 Module that supports 2.4 and 5 GHz dual-band Wi-Fi 6 (802.11ax), Bluetooth® 5 (LE), Zigbee, and Thread (802.15.4) Built around ESP32-C5 series of SoCs, 32-bit RISC-V single-core microprocessor Flash up to 32 MB Up to 22 GPIOs, rich set of peripherals On-board PCB antenna or external antenna connector ESP32-C5-WROOM-1 ESP32-C5-WROOM-1U www.espressif.com 1 Module Overview 1 Module Overview Note: Check the link or the QR code to make sure that you use the latest version of this document: https://espressif.com/documentation/esp32-c5-wroom-1_wroom-1u_datasheet_en.pdf 1.1 Features – 20 MHz bandwidth CPU and On-Chip Memory – Downlink fullband MU-MIMO • ESP32-C5 embedded, 32-bit RISC-V • Fully compatible with IEEE 802.11b/g/n protocol single-core microprocessor, up to 240 MHz • ROM: 320 KB – 20 MHz and 40 MHz bandwidth • HP SRAM: 384 KB – MCS0 ~ MCS7 • LP SRAM: 16 KB – Wi-Fi Multimedia (WMM) • PSRAM: Up to 8 MB (optional) – TX/RX A-MPDU, TX/RX A-MSDU – Immediate Block ACK Wi-Fi – Fragmentation and defragmentation • 1T1R in 2.4 and 5 GHz dual band – Transmit opportunity (TXOP) • Operating frequency: 2412 ~ 2484 MHz, 5180 ~ – Automatic Beacon monitoring (hardware 5885 MHz TSF) • Data rate up to 150 Mbps – Four virtual Wi-Fi interfaces • IEEE 802.11ax-compliant – Simultaneous support for Infrastructure BSS in Station mode, SoftAP mode, Station – 20 MHz-only non-AP mode + SoftAP mode, and promiscuous mode – Uplink and downlink OFDMA to enhance Note that when ESP32-C5 scans in Station connectivity and performance in mode, the SoftAP channel will change congested environments for IoT along with the Station channel applications – Antenna diversity – Downlink MU-MIMO (multi-user, multiple – 802.11mc FTM input, multiple output) to increase network capacity Bluetooth® – Beamformee that improves signal quality • Bluetooth LE: Bluetooth Core 6.0 certified – Spatial reuse to maximize parallel • Bluetooth mesh 1.1 transmissions • High power mode (20 dBm) – Target wake time (TWT) that optimizes • Direction finding (AoA/AoD) power saving mechanisms • IEEE 802.11ac-compliant Espressif Systems • Periodic advertising with responses (PAwR) 2 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 1 Module Overview • LE connection subrating system timer, general-purpose timers, RTC timer, watchdog timers, etc. • LE power control • Speed: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps Integrated Components on Module • LE advertising extensions and multiple • 48 MHz crystal oscillator advertising sets • Up to 32 MB SPI flash (optional) • Allow devices to operate in Broadcaster, • Dual-band diplexer Observer, Central, and Peripheral roles concurrently Antenna Options IEEE 802.15.4 • ESP32-C5-WROOM-1: On-board PCB antenna • ESP32-C5-WROOM-1U: External antenna via a • Compliant with IEEE 802.15.4-2015 protocol connector or module pins • OQPSK PHY in 2.4 GHz band • Data rate: 250 Kbps Operating Conditions • Thread 1.4 • Operating voltage/Power supply: 3.0 ~ 3.6 V • Zigbee 3.0 • Operating ambient temperature: –40 ~ 85 °C Certification Peripherals • GPIO, SPI, parallel IO interface, UART, I2C, I2S, • RF certification: See certificates RMT (TX/RX), pulse counter, LED PWM, USB • Green certification: RoHS/REACH Serial/JTAG controller, MCPWM, GDMA, CAN FD controller, SDIO slave controller, BitScrambler, Test event task matrix, ADC, temperature sensor, • HTOL/HTSL/uHAST/TCT/ESD brownout detector, analog voltage comparator, 1.2 Series Comparison ESP32-C5-WROOM-1 and ESP32-C5-WROOM-1U are two general-purpose 2.4 and 5 GHz dual-band Wi-Fi 6 (802.11ax), Bluetooth® 5 (LE), Zigbee, and Thread (802.15.4) modules. The rich set of peripherals and high performance make the module an ideal choice for smart homes, industrial automation, health care, consumer electronics, etc. ESP32-C5-WROOM-1 comes with a PCB antenna. ESP32-C5-WROOM-1U comes with a connector for an external antenna. A wide selection of module variants are available. The variant nomenclature is shown in Figure 1-1, and the series comparisons are listed in Table 1-1 and Table 1-2. Espressif Systems 3 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 1 Module Overview The nomenclature for the module variants is as follows: ESP32-C5 -XX-XX H/N x R x PSRAM size (MB) PSRAM (optional) Flash size (MB) Ambient temperature (℃) H:-40 ~ 105 N:-40 ~ 85 Module name Figure 1-1. ESP32-C5 Module Variant Nomenclature The series comparison for the two modules is as follows: Table 1-1. ESP32-C5-WROOM-1 (ANT) Series Comparison1 Part Number2 Flash3,4 PSRAM ESP32-C5-WROOM-1-N4 4 MB (Quad SPI) - ESP32-C5-WROOM-1-N8R8 8 MB (Quad SPI) ESP32-C5-WROOM-1-N16R8 16 MB (Quad SPI) ESP32-C5-WROOM-1-N32R8 32 MB (Quad SPI) 8 MB (Quad SPI) Embedded Chip Ambient Temp.5 (°C) Size6 (mm) ESP32-C5HF4 ESP32-C5HR8 –40 ~ 85 18.0 × 27.5 × 3.3 1 This table shares the notes 3-6 presented in Table 1-2 below. Espressif Systems 4 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 1 Module Overview Table 1-2. ESP32-C5-WROOM-1U (CONN)7 Series Comparison Part Number2 Flash3,4 PSRAM ESP32-C5-WROOM-1U-N4 4 MB (Quad SPI) - ESP32-C5-WROOM-1U-N8R8 8 MB (Quad SPI) ESP32-C5-WROOM-1U-N16R8 16 MB (Quad SPI) ESP32-C5-WROOM-1U-N32R8 32 MB (Quad SPI) 8 MB (Quad SPI) Embedded Chip Ambient Temp.5 (°C) Size6 (mm) ESP32-C5HF4 ESP32-C5HR8 –40 ~ 85 18.0 × 21.2 × 3.3 2 Variants with special flash, PSRAM sizes, or ambient temperatures are not listed individually. For customization requests, please contact us. For variants not listed above, refer to Figure 1-1 ESP32-C5 Module Variant Nomenclature for the detailed specifications. 3 For specifications, refer to Section 6.5 Memory Specifications. 4 By default, the SPI flash on the module operates at a maximum clock frequency of 80 MHz and does not support the auto suspend feature. If you need the flash auto suspend feature, please contact us. 5 Ambient temperature specifies the recommended temperature range of the environment immediately outside the Espressif module. 6 For details, refer to Section 10.1 Module Dimensions. 7 ESP32-C5-WROOM-1U uses ANT1 by default. To order a custom ANT2 model, append the suffix T2 to the general part number, for example: ESP32-C5-WROOM-1U-N8R8T2. At the core of the modules is ESP32-C5 *, a 32-bit RISC-V single-core microprocessor operates at up to 240 MHz. You can power off the CPU and make use of the low-power coprocessor to constantly monitor the peripherals for changes or crossing of thresholds. Note: For more information on ESP32-C5, please refer to ESP32-C5 Series Datasheet. 1.3 Applications • Smart Home • Service Robot • Industrial Automation • Audio Devices • Health Care • Generic Low-power IoT Sensor Hubs • Consumer Electronics • Generic Low-power IoT Data Loggers • Smart Agriculture • POS Machines Espressif Systems • Wi-Fi + Bluetooth Networking Card 5 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Contents Contents 1 Module Overview 2 1.1 Features 2 1.2 Series Comparison 3 1.3 Applications 5 2 Block Diagram 11 3 Pin Definitions 12 3.1 Pin Layout 12 3.2 Pin Description 13 4 Boot Configurations 16 4.1 Chip Boot Mode Control 17 4.2 SDIO Sampling and Driving Clock Edge Control 18 4.3 ROM Messages Printing Control 18 4.4 JTAG Signal Source Control 19 4.5 Chip Power-up and Reset 20 5 Peripherals 21 5.1 Peripheral Overview 21 5.2 Peripheral Description 21 5.2.1 21 5.2.2 Connectivity Interface 5.2.1.1 UART Controller 21 5.2.1.2 SPI Controller 22 5.2.1.3 I2C Controller 23 5.2.1.4 I2S Controller 23 5.2.1.5 USB Serial/JTAG Controller 24 5.2.1.6 CAN FD Controller 25 5.2.1.7 LED PWM Controller 25 5.2.1.8 Pulse Count Controller 26 5.2.1.9 Motor Control PWM 26 5.2.1.10 Remote Control Peripheral 27 5.2.1.11 Parallel IO Controller 28 5.2.1.12 BitScrambler 28 5.2.1.13 SDIO Slave Controller 29 Analog Signal Processing 30 5.2.2.1 Temperature Sensor 30 5.2.2.2 ADC Controller 30 5.2.2.3 Analog Voltage Comparator 31 6 Electrical Characteristics 32 6.1 Absolute Maximum Ratings 32 6.2 Recommended Operating Conditions 32 Espressif Systems 6 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Contents 6.3 DC Characteristics (3.3 V, 25 °C) 32 6.4 Current Consumption Characteristics 33 6.4.1 Current Consumption in Active Mode 33 6.4.2 Current Consumption in Other Modes 34 6.5 Memory Specifications 35 7 RF Characteristics 36 7.1 2.4 GHz Wi-Fi Radio 36 7.1.1 2.4 GHz Wi-Fi RF Transmitter (TX) Characteristics 36 7.1.2 2.4 GHz Wi-Fi RF Receiver (RX) Characteristics 37 7.2 7.3 7.4 5 GHz Wi-Fi Radio 39 7.2.1 5 GHz Wi-Fi RF Transmitter (TX) Characteristics 39 7.2.2 5 GHz Wi-Fi RF Receiver (RX) Characteristics 40 Bluetooth 5 (LE) Radio 42 7.3.1 Bluetooth LE RF Transmitter (TX) Characteristics 42 7.3.2 Bluetooth LE RF Receiver (RX) Characteristics 43 802.15.4 Radio 45 7.4.1 802.15.4 RF Transmitter (TX) Characteristics 46 7.4.2 802.15.4 RF Receiver (RX) Characteristics 46 8 Module Schematics 47 9 Peripheral Schematics 49 10 Physical Dimensions 51 10.1 Module Dimensions 51 10.2 Dimensions of External Antenna Connector 52 11 PCB Layout Recommendations 54 11.1 PCB Land Pattern 54 11.2 Module Placement for PCB Design 55 12 Product Handling 56 12.1 Storage Conditions 56 12.2 Electrostatic Discharge (ESD) 56 12.3 Reflow Profile 56 12.4 Ultrasonic Vibration 57 Datasheet Versioning 58 Related Documentation and Resources 59 Revision History 61 Espressif Systems 7 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 List of Tables List of Tables 1-2 ESP32-C5-WROOM-1 (ANT) Series Comparison1 ESP32-C5-WROOM-1U (CONN)7 Series Comparison 3-1 ESP32-C5-WROOM-1 Pin Definitions 1 13 3-2 ESP32-C5-WROOM-1U Pin Definitions 14 4-1 16 1-1 4 5 Default Configuration of Strapping Pins 4-2 Description of Timing Parameters for the Strapping Pins 17 4-3 Boot Mode Control 18 4-4 SDIO Input Sampling Edge/Output Driving Edge Control 18 4-5 UART0 ROM Message Printing Control 19 4-6 USB Serial/JTAG ROM Message Printing Control 19 4-7 JTAG Signal Source Control 20 4-8 Description of Timing Parameters for Power-up and Reset 20 6-1 Absolute Maximum Ratings 32 6-2 Recommended Operating Conditions 32 6-3 DC Characteristics (3.3 V, 25 °C) 32 6-4 Current Consumption for Wi-Fi (2.4 GHz) in Active Mode 33 6-5 Current Consumption for Wi-Fi (5 GHz) in Active Mode 33 6-6 Current Consumption for Bluetooth LE in Active Mode 34 6-7 Current Consumption for 802.15.4 in Active Mode 34 6-8 Current Consumption in Modem-sleep Mode 34 6-9 Current Consumption in Low-Power Modes 35 6-10 Flash Specifications 35 6-11 PSRAM Specifications 35 7-1 36 2.4 GHz Wi-Fi RF Characteristics 7-2 2.4 GHz TX Power with Spectral Mask and EVM Meeting 802.11 Standards 7-3 2.4 GHz TX EVM Test1 36 7-4 2.4 GHz RX Sensitivity 37 7-5 2.4 GHz Maximum RX Level 38 7-6 2.4 GHz RX Adjacent Channel Rejection 38 7-7 39 5 GHz Wi-Fi RF Characteristics 36 7-8 5 GHz TX Power with Spectral Mask and EVM Meeting 802.11 Standards 7-9 5 GHz TX EVM Test1 39 7-10 5 GHz RX Sensitivity 40 7-11 5 GHz Maximum RX Level 41 7-12 5 GHz RX Adjacent Channel Rejection 41 7-13 Bluetooth LE RF Characteristics 42 7-14 Bluetooth LE - Transmitter Characteristics - 1 Mbps 42 7-15 Bluetooth LE - Transmitter Characteristics - 2 Mbps 42 7-16 Bluetooth LE - Transmitter Characteristics - 125 Kbps 43 7-17 Bluetooth LE - Transmitter Characteristics - 500 Kbps 43 7-18 Bluetooth LE - Receiver Characteristics - 1 Mbps 43 7-19 Bluetooth LE - Receiver Characteristics - 2 Mbps 44 7-20 Bluetooth LE - Receiver Characteristics - 125 Kbps 45 Espressif Systems 8 Submit Documentation Feedback 39 ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 List of Tables 7-21 Bluetooth LE - Receiver Characteristics - 500 Kbps 45 7-22 802.15.4 RF Characteristics 45 7-23 802.15.4 Transmitter Characteristics - 250 Kbps 46 7-24 802.15.4 Receiver Characteristics - 250 Kbps 46 Espressif Systems 9 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 List of Figures List of Figures 1-1 ESP32-C5 Module Variant Nomenclature 4 2-1 ESP32-C5-WROOM-1 Block Diagram 11 2-2 ESP32-C5-WROOM-1U Block Diagram 11 3-1 12 ESP32-C5-WROOM-1 Layout (Top View) 3-2 ESP32-C5-WROOM-1U Layout (Top View) 13 4-1 17 Visualization of Timing Parameters for the Strapping Pins 4-2 Visualization of Timing Parameters for Power-up and Reset 8-1 ESP32-C5-WROOM-1 Schematics 20 47 8-2 ESP32-C5-WROOM-1U Schematics 48 9-1 49 ESP32-C5-WROOM-1 Schematics 9-2 ESP32-C5-WROOM-1U Schematics 50 10-1 ESP32-C5-WROOM-1 Dimensions 51 10-2 ESP32-C5-WROOM-1U Dimensions 51 10-3 Dimensions of External Antenna Connector 52 11-1 ESP32-C5-WROOM-1 PCB Land Pattern 54 11-2 ESP32-C5-WROOM-1U PCB Land Pattern 55 12-1 Reflow Profile 56 Espressif Systems 10 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 2 Block Diagram 2 Block Diagram 3V3 48 MHz Crystal 3V3 48 MHz Crystal ESP32-C5-WROOM-1 Antenna ESP32-C5-WROOM-1 2.4G ESP32-C5 EN ESP32-C5 PSRAM(opt.) 5G 2.4G RF RF Matching Matching 5G RF Matching SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI EN RF Matching GND Antenna Diplexer Diplexer GPIOs RF Matching RF Matching GPIOs SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI PSRAM(opt.) QSPI Flash(opt.) GND QSPI Flash(opt.) Figure 2-1. ESP32-C5-WROOM-1 Block Diagram 3V3 48 MHz Crystal 3V3 48 MHz Crystal GND GND 2.4G ESP32-C5 PSRAM(opt.) ESP32-C5 5G 2.4G RF RF Matching Matching 5G Antenna2 Antenna1 RF Matching RF Matching SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI EN ESP32-C5-WROOM-1U Antenna2 Diplexer Diplexer GPIOs RF Matching Antenna1 RF Matching GPIOs PSRAM(opt.) SPICS0 SPICLK SPID SPIQ SPIHD SPIWP VDD_SPI EN ESP32-C5-WROOM-1U QSPI Flash(opt.) QSPI Flash(opt.) Figure 2-2. ESP32-C5-WROOM-1U Block Diagram Note: For the pin mapping between the chip and the in-package flash/PSRAM, please refer to ESP32-C5 Series Datasheet > Table Pin Mapping Between Chip and Flash/PSRAM. Espressif Systems 11 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 3 Pin Definitions 3 Pin Definitions 3.1 Pin Layout The pin diagram below shows the approximate location of pins on the module. For the actual diagram drawn to scale, please refer to Chapter 10.1 Module Dimensions. Keepout Zone GND 1 28 GND 3V3 2 27 IO26 EN 3 26 IO25 IO2 4 25 TX0 IO3 5 24 RX0 IO0 6 23 IO24 22 NC 21 IO23 20 NC IO1 GND GND GND GND 29 GND GND GND GND GND 7 IO6 8 IO7 9 IO8 10 19 NC/IO15 IO9 11 18 IO27 IO10 12 17 IO4 IO13 13 16 IO5 IO14 14 15 IO28 Figure 3-1. ESP32-C5-WROOM-1 Layout (Top View) Pin Layout (Top View) Espressif Systems 12 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 GND ANT2 GND 3 Pin Definitions 32 31 30 ANT1 28 GND 2 27 IO26 EN 3 26 IO25 IO2 4 25 TX0 IO3 5 24 RX0 IO0 6 23 IO24 22 NC 21 IO23 20 NC GND 1 3V3 IO1 GND GND GND GND 29 GND GND GND GND GND 7 IO6 8 IO7 9 IO8 10 19 NC/IO15 IO9 11 18 IO27 IO10 12 17 IO4 IO13 13 16 IO5 IO14 14 15 IO28 Figure 3-2. ESP32-C5-WROOM-1U Layout (Top View) Pin Layout (Top View) 3.2 Pin Description The module ESP32-C5-WROOM-1 has 29 pins, and module ESP32-C5-WROOM-1U has 32 pins. See pin definitions in Table 3-1 ESP32-C5-WROOM-1 Pin Definitions 1 and Table 3-2 ESP32-C5-WROOM-1U Pin Definitions. For peripheral pin configurations, please refer to Section 5.2 Peripheral Description. Table 3-1. ESP32-C5-WROOM-1 Pin Definitions 1 Name No. Type2 GND 1 P Ground 3V3 2 P Power Supply EN 3 I Function High: on, enables the chip. Low: off, the chip powers off. Note: Do not leave the EN pin floating. IO2 4 I/O/T MTMS, GPIO2, LP_GPIO2, LP_UART_RTSN, LP_I2C_SDA, ADC1_CH1, FSPIQ Cont’d on next page Espressif Systems 13 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 3 Pin Definitions Table 3-1 – cont’d from previous page No. Type2 Function IO3 5 I/O/T MTDI, GPIO3, LP_GPIO3, LP_UART_CTSN, LP_I2C_SCL, ADC1_CH2 IO0 6 I/O/T GPIO0, XTAL_32K_P, LP_GPIO0, LP_UART_DTRN IO1 7 I/O/T GPIO1, XTAL_32K_N, LP_GPIO1, LP_UART_DSRN, ADC1_CH0 IO6 8 I/O/T GPIO6, LP_GPIO6, ADC1_CH5, FSPICLK IO7 9 I/O/T GPIO7, FSPID, SDIO_DATA1 IO8 10 I/O/T GPIO8, PAD_COMP0, SDIO_DATA0 IO9 11 I/O/T GPIO9, PAD_COMP1, SDIO_CLK IO10 12 I/O/T GPIO10, FSPICS0, SDIO_CMD IO13 13 I/O/T GPIO13, USB_D-, SDIO_DATA3 IO14 14 I/O/T GPIO14, USB_D+, SDIO_DATA2 IO28 15 I/O/T GPIO28 IO5 16 I/O/T MTDO, GPIO5, LP_GPIO5, LP_UART_TXD, ADC1_CH4, FSPIWP IO4 17 I/O/T MTCK, GPIO4, LP_GPIO4, LP_UART_RXD, ADC1_CH3, FSPIHD IO27 18 I/O/T GPIO27 NC/IO15 19 I/O/T SPICS1, GPIO153 NC 20 - IO23 21 I/O/T NC 22 - IO24 23 I/O/T GPIO24 RX0 24 I/O/T U0RXD, GPIO12 TX0 25 I/O/T U0TXD, GPIO11 IO25 26 I/O/T GPIO25 IO26 27 I/O/T GPIO26 GND 28 P Ground EPAD 29 P Ground Name NC GPIO23 NC 1 This table shares the notes 2 and 3 presented in Table 3-2 below. Table 3-2. ESP32-C5-WROOM-1U Pin Definitions Name No. Type2 GND 1 P Ground 3V3 2 P Power Supply EN 3 I Function High: on, enables the chip. Low: off, the chip powers off. Note: Do not leave the EN pin floating. MTMS, GPIO2, LP_GPIO2, LP_UART_RTSN, LP_I2C_SDA, ADC1_CH1, IO2 4 I/O/T IO3 5 I/O/T MTDI, GPIO3, LP_GPIO3, LP_UART_CTSN, LP_I2C_SCL, ADC1_CH2 IO0 6 I/O/T GPIO0, XTAL_32K_P, LP_GPIO0, LP_UART_DTRN IO1 7 I/O/T GPIO1, XTAL_32K_N, LP_GPIO1, LP_UART_DSRN, ADC1_CH0 IO6 8 I/O/T GPIO6, LP_GPIO6, ADC1_CH5, FSPICLK FSPIQ Cont’d on next page Espressif Systems 14 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 3 Pin Definitions Table 3-2 – cont’d from previous page No. Type2 Function IO7 9 I/O/T GPIO7, FSPID, SDIO_DATA1 IO8 10 I/O/T GPIO8, PAD_COMP0, SDIO_DATA0 IO9 11 I/O/T GPIO9, PAD_COMP1, SDIO_CLK IO10 12 I/O/T GPIO10, FSPICS0, SDIO_CMD IO13 13 I/O/T GPIO13, USB_D-, SDIO_DATA3 IO14 14 I/O/T GPIO14, USB_D+, SDIO_DATA2 IO28 15 I/O/T GPIO28 IO5 16 I/O/T MTDO, GPIO5, LP_GPIO5, LP_UART_TXD, ADC1_CH4, FSPIWP IO4 17 I/O/T MTCK, GPIO4, LP_GPIO4, LP_UART_RXD, ADC1_CH3, FSPIHD IO27 18 I/O/T GPIO27 NC/IO15 19 I/O/T SPICS1, GPIO153 NC 20 - IO23 21 I/O/T NC 22 - IO24 23 I/O/T GPIO24 RX0 24 I/O/T U0RXD, GPIO12 TX0 25 I/O/T U0TXD, GPIO11 IO25 26 I/O/T GPIO25 IO26 27 I/O/T GPIO26 GND 28 P Ground EPAD 29 P Ground GND 30 P Ground ANT24 31 I/O GND 32 P Name NC GPIO23 NC RF input and output Ground 2 P: power supply; I: input; O: output; T: high impedance. 3 In modules with the in-package SPI PSRAM, this pin is used as SPICS1 for SPI PSRAM and cannot be used for other functions; in modules without the in-package SPI PSRAM, this pin can be used as GPIO15. 4 By default, ESP32-C5-WROOM-1U uses ANT1, and ANT2 is disabled. To use ANT2, please contact us. Espressif Systems 15 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 4 Boot Configurations 4 Boot Configurations Note: The content below is excerpted from ESP32-C5 Series Datasheet > Section Boot Configurations. For the strapping pin mapping between the chip and modules, please refer to Chapter 8 Module Schematics. The chip allows for configuring the following boot parameters through strapping pins and eFuse parameters at power-up or a hardware reset, without microcontroller interaction. • Chip boot mode – Strapping pin: GPIO26, GPIO27, and GPIO28 • SDIO sampling and driving clock edge – Strapping pin: GPIO25 and MTDI • ROM message printing – Strapping pin: GPIO27 – eFuse parameter: EFUSE_UART_PRINT_CONTROL and EFUSE_DIS_USB_SERIAL_JTAG_ROM_PRINT • JTAG signal source – Strapping pin: GPIO7 – eFuse parameter: EFUSE_DIS_PAD_JTAG, EFUSE_DIS_USB_JTAG, and EFUSE_JTAG_SEL_ENABLE The default values of all the above eFuse parameters are 0, which means that they are not burnt. Given that eFuse is one-time programmable, once programmed to 1, it can never be reverted to 0. For how to program eFuse parameters, please refer to ESP32-C5 Technical Reference Manual > Chapter eFuse Controller. The default values of the strapping pins, namely the logic levels, are determined by pins’ internal weak pull-up/pull-down resistors at reset if the pins are not connected to any circuit, or connected to an external high-impedance circuit. Table 4-1. Default Configuration of Strapping Pins Strapping Pin Default Configuration Bit Value GPIO25 Floating – GPIO26 Floating – GPIO27 Pull-up 1 GPIO28 Pull-up 1 GPIO7 Floating – MTMS Floating – MTDI Floating – To change the bit values, the strapping pins should be connected to external pull-down/pull-up resistances. Espressif Systems 16 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 4 Boot Configurations All strapping pins have latches. At Chip Reset, the latches sample the bit values of their respective strapping pins and store them until the chip is powered down or shut down. The states of latches cannot be changed in any other way. It makes the strapping pin values available during the entire chip operation, and the pins are freed up to be used as regular IO pins after reset. For details on Chip Reset, see ESP32-C5 Technical Reference Manual > Chapter Reset and Clock. The timing of signals connected to the strapping pins should adhere to the setup time and hold time specifications in Table 4-2 and Figure 4-1. Table 4-2. Description of Timing Parameters for the Strapping Pins Parameter tSU Description Min (ms) Setup time is the time reserved for the power rails to stabilize before the CHIP_PU pin is pulled high to activate the chip. 0 Hold time is the time reserved for the chip to read the strapping tH pin values after CHIP_PU is already high and before these pins 3 start operating as regular IO pins. tSU tH VIH_nRST CHIP_PU VIH Strapping pin Figure 4-1. Visualization of Timing Parameters for the Strapping Pins 4.1 Chip Boot Mode Control GPIO26, GPIO27 and GPIO28 control the boot mode after the reset is released. See Table 4-3 Boot Mode Control. Espressif Systems 17 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 4 Boot Configurations Table 4-3. Boot Mode Control Boot Mode SPI Boot1 GPIO26 GPIO27 Any value Any value GPIO28 11 Joint Download Boot 02 Any value 1 0 Joint Download Boot 13 0 0 0 1 Bold marks the default value and configuration. 2 Joint Download Boot 0 mode supports the following download methods: • USB-Serial-JTAG Download Boot • UART Download Boot • SPI Slave Download Boot (chip revision v0.1 only) 3 Joint Download Boot 1 mode supports the following download methods: • UART Download Boot • SDIO Download Boot In SPI Boot mode, the ROM bootloader loads and executes the program from SPI flash to boot the system. In Joint Download Boot 0 mode, users can download binary files into flash using UART0, USB, or SPI Slave interfaces. It is also possible to download binary files into SRAM and execute it from SRAM. In Joint Download Boot 1 mode, users can download binary files into flash using UART0 or SDIO interfaces. It is also possible to download binary files into SRAM and execute it from SRAM. 4.2 SDIO Sampling and Driving Clock Edge Control The strapping pin GPIO25 and MTDI can be used to decide on which clock edge to sample signals and drive output lines. See Table 4-4 SDIO Input Sampling Edge/Output Driving Edge Control. Table 4-4. SDIO Input Sampling Edge/Output Driving Edge Control Edge behavior GPIO25 MTDI Falling edge sampling, falling edge output 0 0 Falling edge sampling, rising edge output 0 1 Rising edge sampling, falling edge output 1 0 Rising edge sampling, rising edge output 1 1 1 GPIO25 and MTDI are floating by default, so above are not default configurations. 4.3 ROM Messages Printing Control During the boot process, the messages by the ROM code can be printed to: • (Default) UART0 and USB Serial/JTAG controller • UART0 Espressif Systems 18 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 4 Boot Configurations • USB Serial/JTAG controller To print ROM messages to UART0 or USB Serial/JTAG controller, see the description below. EFUSE_UART_PRINT_CONTROL and GPIO27 control printing ROM messages to UART0 as shown in Table 4-5 UART0 ROM Message Printing Control. Table 4-5. UART0 ROM Message Printing Control Register2 UART0 ROM Message Printing ROM messages are always printed to UART0 during boot eFuse3 0 (0b00) Print is enabled during boot 1 (0b01) Print is disabled during boot 0 Print is disabled during boot 2 (0b10) Print is enabled during boot Print is disabled during boot Print is disabled during boot GPIO27 x4 0 1 0 1 3 (0b11) x x x 1 1 Bold marks the default value and configuration. 2 Register: LP_AON_STORE4_REG[0] 3 eFuse: EFUSE_UART_PRINT_CONTROL 4 x: x indicates that the value has no effect on the result and can be ignored. EFUSE_DIS_USB_SERIAL_JTAG_ROM_PRINT controls the printing to USB Serial/JTAG controller as shown in Table 4-6 USB Serial/JTAG ROM Message Printing Control. Table 4-6. USB Serial/JTAG ROM Message Printing Control USB Serial/JTAG ROM Message EFUSE_DIS_USB_SERIAL_JTAG_ROM_PRINT Printing Enabled 0 1 Disabled Ignored 1 Bold marks the default value and configuration. 4.4 JTAG Signal Source Control The strapping pin GPIO7 can be used to control the source of JTAG signals during the early boot process. This pin does not have any internal pull resistors and the strapping value must be controlled by the external circuit that cannot be in a high impedance state. As Table 4-7 shows, GPIO7 is used in combination with EFUSE_DIS_PAD_JTAG, EFUSE_DIS_USB_JTAG, and EFUSE_JTAG_SEL_ENABLE. Espressif Systems 19 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 4 Boot Configurations Table 4-7. JTAG Signal Source Control eFuse 12 JTAG Signal Source eFuse 23 6 USB Serial/JTAG Controller eFuse 34 0 0 0 JTAG pins MTDI, MTCK, MTMS, and MTDO 1 GPIO7 x5 1 0 x 1 USB Serial/JTAG Controller6 0 1 JTAG is disabled x x x 1 1 Bold marks the default value and configuration. 2 eFuse 1: EFUSE_DIS_PAD_JTAG 3 eFuse 2: EFUSE_DIS_USB_JTAG 4 eFuse 3: EFUSE_JTAG_SEL_ENABLE 5 x: x indicates that the value has no effect on the result and can be ignored. 6 In Joint Download Boot 1 mode, the USB Serial/JTAG controller is forcibly disabled, and the JTAG signal only comes from JTAG pins. If PAD_JTAG is also disabled, then JTAG is disabled. 4.5 Chip Power-up and Reset Once the power is supplied to the chip, its power rails need a short time to stabilize. After that, CHIP_PU – the pin used for power-up and reset – should be pulled high to activate the chip. For information on CHIP_PU as well as power-up and reset timing, see Figure 4-2 and Table 4-8. tST BL tRST 2.8 V VDDPST1, VDDPST2, VDDPST3, VDDA1, VDDA2, VDDA3, VDDA4, VDDA5, VDDA6, VDDA7, VDDA8 VIL_nRST CHIP_PU Figure 4-2. Visualization of Timing Parameters for Power-up and Reset Table 4-8. Description of Timing Parameters for Power-up and Reset Parameter Description Min (µs) Time reserved for the power rails of VDDPST1, VDDPST2, VDtST BL DPST3, VDDA1, VDDA2, VDDA3, VDDA4, VDDA5, VDDA6, VDDA7, and VDDA8 to stabilize before the CHIP_PU pin is pulled high to 50 activate the chip tRST Espressif Systems Time reserved for CHIP_PU to stay below VIL_nRST to reset the chip (see Table 6-3) 20 Submit Documentation Feedback 50 ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals 5 Peripherals 5.1 Peripheral Overview ESP32-C5 integrates a rich set of peripherals including SPI, parallel IO interface, UART, I2C, I2S, RMT (TX/RX), pulse counter, LED PWM, USB Serial/JTAG controller, MCPWM, GDMA, CAN FD controller, SDIO slave controller, BitScrambler, event task matrix, ADC, temperature sensor, brownout detector, analog voltage comparator, as well as up to 22 GPIOs, etc. For detailed information about module peripherals, please refer to ESP32-C5 Series Datasheet > Section Functional Description. Note: The content below is sourced from ESP32-C5 Series Datasheet > Section Peripherals. Some information may not be applicable to ESP32-C5-WROOM-1 and ESP32-C5-WROOM-1U as not all the IO signals are exposed on the module. To learn more about peripheral signals, please refer to ESP32-C5 Technical Reference Manual > Section Peripheral Signal List. 5.2 Peripheral Description This section describes the chip’s peripheral capabilities, covering connectivity interfaces and on-chip sensors that extend its functionality. 5.2.1 Connectivity Interface This subsection describes the connectivity interfaces on the chip that enable communication and interaction with external devices and networks. 5.2.1.1 UART Controller ESP32-C5 has three UART interfaces, i.e. UART0, UART1, and LP UART. All the three interfaces provide hardware flow control (CTS and RTS signals) and software flow control (XON and XOFF). Feature List • programmable baud rates up to 5 MBaud • RAM shared by TX FIFOs and RX FIFOs • support for various lengths of data bits and stop bits • parity bit support • special character AT_CMD detection • RS485 protocol support (not supported by LP UART) • IrDA protocol support (not supported by LP UART) • high-speed data communication using GDMA (not supported by LP UART) • receive timeout feature Espressif Systems 21 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals • UART as the wake-up source • software and hardware flow control For details, see ESP32-C5 Technical Reference Manual > Chapter UART Controller (UART). Pin Assignment The pins connected to transmit and receive signals (U0TXD and U0RXD) for UART0 are multiplexed with GPIO11 and GPIO12 via IO MUX. Other signals can be routed to any GPIOs via the GPIO matrix. For LP UART, the pins used are multiplexed with LP_GPIO0 ~ LP_GPIO5 via LP IO MUX. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.2 SPI Controller ESP32-C5 features three SPI interfaces (SPI0, SPI1, and SPI2). SPI0 and SPI1 can be configured to operate in SPI memory mode, while SPI2 can be configured to operate in general-purpose SPI mode. Feature List • SPI Memory mode In SPI memory mode, SPI0 and SPI1 interfaces are for external SPI memory. Data are transferred in unit of byte. Up to four-line STR reads and writes are supported. The clock frequency is configurable to a maximum of 120 MHz. • SPI2 General-purpose SPI (GP-SPI) mode SPI2 can operate in master and slave modes. SPI2 supports two-line full-duplex communication and single/two/four-line half-duplex communication in both master and slave modes. The host’s clock frequency is configurable. Data are transferred in unit of byte. The clock polarity (CPOL) and phase (CPHA) are also configurable. The SPI2 interface can connect to GDMA. – In master mode, the clock frequency is 80 MHz at most, and the four modes of SPI transfer format are supported. – In slave mode, the clock frequency is 40 MHz at most, and the four modes of SPI transfer format are also supported. For details, see ESP32-C5 Technical Reference Manual > Chapter SPI Controller (SPI). Pin Assignment For SPI0/1, the pins are multiplexed with GPIO15 ~ GPIO18 and GPIO20 ~ GPIO22 via the IO MUX. For SPI2, the pins for data and clock signals are multiplexed with GPIO2 and GPIO4 ~ GPIO7 via the IO MUX. The pins for chip select signals for multiplexed with GPIO10 via the IO MUX. SPI2 signals can also be routed to any GPIOs via the GPIO matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. Espressif Systems 22 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals 5.2.1.3 I2C Controller ESP32-C5 has an I2C and an LP I2C bus interface. I2C is used for I2C master mode or slave mode, depending on your configuration, while LP I2C is always in master mode. Feature List • standard mode (100 Kbit/s) • fast mode (400 Kbit/s) • up to 800 Kbit/s (constrained by SCL and SDA pull-up strength) • 7-bit and 10-bit addressing mode • double addressing mode • 7-bit broadcast address For details, see ESP32-C5 Technical Reference Manual > Chapter I2C Controller (I2C). Pin Assignment For regular I2C, the pins used can be chosen from any GPIOs via the GPIO Matrix. For LP I2C, the pins used are multiplexed with LP_GPIO2 and LP_GPIO3 via LP IO MUX. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.4 I2S Controller ESP32-C5 includes a standard I2S interface. This interface can operate as a master or a slave in full-duplex mode or half-duplex mode, and supports 8-bit, 16-bit, 24-bit, or 32-bit serial communication. BCK clock frequency, from 10 kHz up to 40 MHz, is supported. The I2S interface supports TDM Philips, TDM MSB alignment, TDM PCM standard, PDM standard, and PCM-to-PDM TX interface. It connects to the GDMA controller. Feature List • master mode and slave mode • full-duplex and half-duplex communications • separate TX and RX units that can work independently or simultaneously • a variety of audio standards supported: – TDM Philips standard – TDM MSB alignment standard – TDM PCM standard – PDM standard • various TX/RX modes Espressif Systems 23 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals – TDM TX mode, up to 16 channels supported – TDM RX mode, up to 16 channels supported – PDM TX mode * raw PDM data transmission * PCM-to-PDM data format conversion, up to 2 channels supported – PDM RX mode * raw PDM data reception • configurable clock source with frequency up to 240 MHz • configurable high-precision sample clock with a variety of sampling frequencies supported • 8/16/24/32-bit data width • synchronous counter in TX mode • ETM feature • direct memory access • standard I2S interface interrupts For details, see ESP32-C5 Technical Reference Manual > Chapter I2S Controller (I2S). Pin Assignment The pins for the I2S controller can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.5 USB Serial/JTAG Controller ESP32-C5 contains a USB Serial/JTAG controller. This unit can be used to program the SoC’s flash, read program output, as well as attach a debugger to the running program. All of these are possible for any computer with a USB host without any active external components. Feature List • USB 2.0 full speed compliant, capable of up to 12 Mbit/s transfer speed (note that this controller does not support the faster 480 Mbit/s high-speed transfer mode) • CDC-ACM virtual serial port and JTAG adapter functionality • programming the chip’s flash • CPU debugging with compact JTAG instructions • a full-speed USB PHY integrated in the chip For details, see ESP32-C5 Technical Reference Manual > Chapter USB Serial/JTAG Controller (USB_SERIAL_JTAG). Espressif Systems 24 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals Pin Assignment The pins for the USB Serial/JTAG controller are multiplexed with GPIO13 ~ GPIO14 via IO MUX. GPIO13 ~ GPIO14 are also multiplexed with the pins for the SDIO Slave controller. The SDIO Slave controller can be used together with the USB Serial/JTAG controller in single SPI mode, but not in quad SPI mode. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.6 CAN FD Controller The Controller Area Network Flexible Data-Rate (CAN FD) is a multi-master, multi-cast communication protocol designed for automotive applications. The CAN FD controller facilitates the communication based on this protocol. Feature List • compliant with ISO11898-1:2015 • RX buffer FIFO with 32 - 4096 words (1 - 204 CAN FD frames with 64 byte of data) • 2 - 8 TXT buffers (1 CAN FD frame in each TXT buffer) • 32-bit slave memory interface (APB, AHB, RAM-like interface) • support of ISO and non-ISO CAN FD protocol • timestamping and time triggered transmission • support interrupts • loopback mode, bus monitoring mode, ACK forbidden mode, self-test mode, and restricted operation mode For details, see ESP32-C5 Technical Reference Manual > Chapter Controller Area Network Flexible Data-Rate. Pin Assignment The pins for the CAN FD Controller can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.7 LED PWM Controller The LED PWM controller can generate independent digital waveform on six channels. Feature List • generating digital waveform with configurable periods and duty cycle. The resolution of duty cycle can be up to 20 bits • multiple clock sources, including 80 MHz PLL clock, external main crystal clock, and internal fast RC oscillator Espressif Systems 25 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals • operation when the CPU is in Light-sleep mode • gradual increase or decrease of duty cycle, which is useful for the LED RGB color-gradient generator • up to 16 duty cycle ranges for gamma curve generation, each can be independently configured in terms of duty cycle direction (increase or decrease), step size, the number of steps, and step frequency For details, see ESP32-C5 Technical Reference Manual > Chapter LED PWM Controller. Pin Assignment The pins for the LED PWM controller can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.8 Pulse Count Controller The Pulse Count controller (PCNT) in ESP32-C5 captures pulses and counts pulse edges in seven modes. Feature List • four independent pulse counters (units) that count from 1 to 65535 • each unit consists of two independent channels sharing one pulse counter • all channels have input pulse signals (e.g. sig_ch0_un) with their corresponding control signals (e.g. ctrl_ch0_un) • independently filter glitches of input pulse signals (sig_ch0_un and sig_ch1_un) and control signals (ctrl_ch0_un and ctrl_ch1_un) on each unit • each channel has the following parameters: 1. selection between counting on positive or negative edges of the input pulse signal 2. configuration to Increment, Decrement, or Disable counter mode for control of signal’s high and low states • support step counting • maximum frequency of pulses: 40 MHz For details, see ESP32-C5 Technical Reference Manual > Chapter Pulse Count Controller. Pin Assignment The pins for the Pulse Count controller can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.9 Motor Control PWM ESP32-C5 integrates an MCPWM that can be used to drive digital motors and smart light. Espressif Systems 26 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals Feature List • a clock divider (prescaler), three PWM timers, three PWM operators, and a dedicated capture submodule. PWM timers are used to generate timing references. PWM operators generate desired waveform based on the timing references • a PWM operator can use the timing reference of any PWM timer • a PWM operator can use the same timing reference with other PWM operators • PWM operators can use different PWM timers’ values to produce independent PWM signals • PWM timers can be synchronized For details, see ESP32-C5 Technical Reference Manual > Chapter Motor Control PWM (MCPWM). Pin Assignment The pins for the Motor Control PWM can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.10 Remote Control Peripheral The Remote Control Peripheral (RMT) supports two channels of infrared remote transmission and two channels of infrared remote reception. By controlling pulse waveform through software, it supports various infrared and other single wire protocols. Feature List • four channels: – TX channels 0 ~ 1 – RX channels 2 ~ 3 – four channels share a 192 x 32-bit RAM • the transmitter supports: – normal TX mode – wrap TX mode – modulation on TX pulses – continuous TX mode – multiple channels (programmable) transmitting data simultaneously • the receiver supports: – normal RX mode – wrap RX mode – RX filtering – demodulation on RX pulses Espressif Systems 27 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals For more details, see ESP32-C5 Technical Reference Manual > Chapter Remote Control Peripheral (RMT). Pin Assignment The pins for the Remote Control Peripheral can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.11 Parallel IO Controller ESP32-C5 integrates a PARLIO controller for parallel data transfer. It has a transmitter and a receiver, connected with the GDMA controller. In full-duplex mode the PARLIO controller supports up to 4-bit parallel data transfer, while in half-duplex mode it supports up to 8-bit parallel data transfer. Feature List • multiple clock sources and clock division, with clock frequency up to 40 MHz • receiver/transmitter supports input and output clock inverse • 1/2/4/8-bit data transfer • changeable sample sequence for data to be transmitted and received in 1-bit, 2-bit, and 4-bit mode • support for multiple data sampling mode by the receiver • support for multiple GDMA EOF signal generation modes by the receiver • output external chip select signals with configurable delay cycles • support for transmitter clock gating For more details, see ESP32-C5 Technical Reference Manual > Chapter Parallel IO Controller. Pin Assignment The pins for the Parallel IO controller can be chosen from any GPIOs via the GPIO Matrix. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.12 BitScrambler The ESP32-C5 has an extensive amount of DMA-capable peripherals. These can move data from memory to an external device, and vice versa, without any interference from the CPU. This only works if the external device needs or emits the data in question in the same format as the software expects it: if not, the CPU needs to rewrite the format of the data. Examples include a need to swap bytes, reverse bytes, and shift the data left or right. As bitwise operations tend to be fairly CPU-expensive and the purpose of DMA is to not use the CPU in the transfer, ESP32-C5 integrates one BitScrambler, which are dedicated peripherals to change the format of data in between memory and the peripheral. The RX channel is dedicated to peripheral-to-memory transfers, and the TX channel is dedicated to memory-to-peripheral transfers. The BitScrambler is capable of performing the Espressif Systems 28 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals aforementioned operations, but as a flexible programmable state machine, it is capable of more advanced things as well. Feature List • one BitScrambler, one channel for RX (peripheral-to-memory), one channel for TX (memory-to-peripheral). The two channels support only half-duplex communications, and cannot work at the same time • support for memory-to-memory transfers • process up to 32 bits per DMA clock period • data path controlled by a BitScrambler program stored in the instruction memory • input registers able to read 0, 8, 16, or 32 bits per clock cycle • output registers: – able to write 0, 8, 16, or 32 bits per clock cycle – data sources for output register bits: 64 bits of input data, two counters, LUT RAM data, data output of last cycle, comparators – with some restrictions, each of the 32 output register bits can come from any bit on the data sources • 8 x 257-bit instruction memory, for storing eight instructions, controlling control flow and the data path • 2048 bytes of lookup table (LUT) memory, configurable as various word widths For more details, see ESP32-C5 Technical Reference Manual > Chapter BitScrambler. Pin Assignment The BitScrambler does not directly interact with IOs, so it has no pins assigned. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.1.13 SDIO Slave Controller The SDIO Slave controller in ESP32-C5 provides hardware support for the Secure Digital Input/Output (SDIO) device interface. It allows an SDIO host to access ESP32-C5 via an SDIO bus protocol. Feature List • compatible with SDIO Physical Layer Specification V2.00 and SDIO Specifications V2.00 • support SPI, 1-bit SDIO, and 4-bit SDIO transfer modes • clock range of 0 ~ 50 MHz • configurable sample and drive clock edge • integrated and SDIO-accessible registers for information interaction • support SDIO interrupts Espressif Systems 29 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals • automatic padding data and discarding the padded data on the SDIO bus • block size up to 512 bytes • interrupt vector between the host and slave for bidirectional interrupt • support DMA for data transfer • support wake-up from sleep when connection is retained For more details about the SDIO Slave controller, refer to the ESP32-C5 Technical Reference Manual > Chapter SDIO Slave Controller (SDIO). Pin Assignment The pins for the SDIO Slave controller are multiplexed with GPIO7 ~ GPIO10, GPIO13, and GPIO14 via IO MUX. GPIO13 ~ GPIO14 are also multiplexed with the pins for the USB serial/JTAG controller. The SDIO Slave controller can be used together with the USB Serial/JTAG controller in single SPI mode, but not in quad SPI mode. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter IO MUX and GPIO Matrix. Note: This peripheral is not supported by chip revision v0.0 and v0.1. 5.2.2 Analog Signal Processing This subsection describes components on the chip that sense and process real-world data. 5.2.2.1 Temperature Sensor ESP32-C5 provides a temperature sensor to monitor temperature changes inside the chip in real time. The sensor converts analog voltage to digital values and supports compensation for the temperature offset. Feature List • software-triggered temperature measurement. Once triggered, the sensor continuously measures temperature. Software can read the data any time. • hardware-triggered automatic temperature monitoring • two modes for automatic monitoring of temperature and support for triggering interrupts • configurable temperature offset based on the application scenario for improved accuracy • configurable temperature measurement range • support for several Event Task Matrix (ETM) related events and tasks For more details, see ESP32-C5 Technical Reference Manual > Chapter Temperature Sensor. 5.2.2.2 ADC Controller ESP32-C5 integrates One 12-bit successive approximation ADC (SAR ADC) for measuring analog signals from up to six channels. Espressif Systems 30 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 5 Peripherals Feature List • 12-bit resolution • analog inputs sampling from up to six pins • one-shot sampling mode and multi-channel sampling mode • multi-channel sampling mode supports: – configurable channel sampling sequence – two filters whose filter coefficients are configurable – two threshold monitors that can trigger an interrupt when the filtered value is below a low threshold or above a high threshold – continuous transfer of converted data to memory via GDMA interface • support for several Event Task Matrix (ETM) related events and tasks For more details, see ESP32-C5 Technical Reference Manual > Chapter ADC Controller. Pin Assignment The pins for the ADC controller are multiplexed with GPIO1 ~ GPIO6. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. 5.2.2.3 Analog Voltage Comparator ESP32-C5 provides an analog voltage comparator which contains two special pads. This peripheral can be used to compare the voltages of the two pads or compare the voltage of one pad with a stable internal voltage that is adjustable. Feature List • internal or external reference voltage • supported internal reference voltage ranging from 0 to 0.7 * VDD_PST • support for ETM • interrupt triggered when the measured voltage reaches the reference voltage For more details, see ESP32-C5 Technical Reference Manual > Chapter Analog Voltage Comparator. Pin Assignment The analog voltage comparator has dedicated pads, GPIO8 and GPIO9. GPIO9 is the test pad, and GPIO8 serves as the reference pad when using an external reference voltage. For more information about the pin assignment, see ESP32-C5 Series Datasheet > Section IO Pins and ESP32-C5 Technical Reference Manual > Chapter GPIO Matrix and IO MUX. Espressif Systems 31 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 6 Electrical Characteristics 6 Electrical Characteristics The values presented in this section are preliminary and may change with the final release of this datasheet. 6.1 Absolute Maximum Ratings Stresses above those listed in Table 6-1 Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under Table 6-2 Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Table 6-1. Absolute Maximum Ratings 6.2 Symbol Parameter VDD33 Power supply voltage Min Max Unit –0.3 3.6 V Recommended Operating Conditions Table 6-2. Recommended Operating Conditions Symbol Parameter Min Typ Max Unit VDD33 Power supply voltage 3.0 3.3 3.6 V IV DD Current delivered by external power supply 0.6 — — A TA Operating ambient temperature –40 — 85 °C 6.3 DC Characteristics (3.3 V, 25 °C) Table 6-3. DC Characteristics (3.3 V, 25 °C) Parameter Description CIN Pin capacitance VIH Min Typ Unit pF High-level input voltage — 0.75 × VDD 1 — VIL Low-level input voltage –0.3 — — 1 VDD + 0.3 0.25 × VDD 1 IIH High-level input current — — 50 nA Low-level input current — 50 nA — V IIL 2 Max V V VOH 2 High-level output voltage — 0.8 × VDD 1 VOL 2 Low-level output voltage — — — 0.1 × VDD 1 — 40 — mA — 28 — mA IOH IOL High-level source current (VDD 1 = 3.3 V, VOH >= 2.64 V, PAD_DRIVER = 3) Low-level sink current (VDD 1 = 3.3 V, V OL = 0.495 V, PAD_DRIVER = 3) V RP U Internal weak pull-up resistor — 45 — kΩ RP D Internal weak pull-down resistor — 45 — kΩ Cont’d on next page Espressif Systems 32 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 6 Electrical Characteristics Table 6-3 – cont’d from previous page Parameter VIH_nRST VIL_nRST Description Min Chip reset release voltage (CHIP_PU voltage is within the specified range) Typ Max Unit 0.75 × VDD 1 — VDD 1 + 0.3 V –0.3 — 0.25 × VDD 1 V Chip reset voltage (CHIP_PU voltage is within the specified range) 1 VDD – voltage from a power pin of a respective power domain. 2V and V are measured using high-impedance load. OH 6.4 OL Current Consumption Characteristics 6.4.1 Current Consumption in Active Mode The current consumption measurements are taken with a 3.3 V supply at 25 °C ambient temperature. TX current consumption is rated at a 100% duty cycle. RX current consumption is rated when the peripherals are disabled and the CPU idle. Table 6-4. Current Consumption for Wi-Fi (2.4 GHz) in Active Mode Work Mode RF Condition TX Active (RF working) Description Peak (mA) 802.11b, 1 Mbps, DSSS @ 19dBm 337 802.11g, 54 Mbps, OFDM @ 15.7dBm 272 802.11n, HT20, MCS7 @ 15.9dBm 272 802.11n, HT40, MCS7 @ 15dBm 265 802.11ax, MCS9 @ 14dBm 249 802.11b/g/n, HT20 RX 94 802.11n, HT40 102 802.11ax, HE20 94 Table 6-5. Current Consumption for Wi-Fi (5 GHz) in Active Mode Work Mode RF Condition TX Active (RF working) RX Espressif Systems Description Peak (mA) 802.11a, 6 Mbps, OFDM @ 17.5dBm 397 802.11n, HT20, MCS7 @ 14.6dBm 364 802.11n, HT40, MCS7 @ 14.4dBm 361 802.11ac, VHT20, MCS7 @ 14.4dBm 364 802.11ax, HE20, MCS7 @ 14.4dBm 365 802.11a/n, HT20 121 802.11n, HT40 128 802.11ac, VHT20 120 802.11ax, HE20 122 33 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 6 Electrical Characteristics Table 6-6. Current Consumption for Bluetooth LE in Active Mode Work Mode RF Condition TX Active (RF working) Description Peak (mA) Bluetooth LE @ 19.7dBm 364 Bluetooth LE @ 7dBm 205 Bluetooth LE @ 0.5dBm 171 Bluetooth LE @ –16.7dBm RX 105 Bluetooth LE 85 Table 6-7. Current Consumption for 802.15.4 in Active Mode Work Mode RF Condition TX Active (RF working) RX Description Peak (mA) 802.15.4 @ 19.5dBm 360 802.15.4 @ 6.8dBm 206 802.15.4 @ 0dBm 180 802.15.4 @ –17dBm 105 802.15.4 85 Note: The content below is excerpted from Section Power Consumption in Other Modes in ESP32-C5 Series Datasheet. 6.4.2 Current Consumption in Other Modes Table 6-8. Current Consumption in Modem-sleep Mode Typ (mA) CPU Frequency Mode (MHz) All Peripherals All Peripherals Clocks Disabled Clocks Enabled1 WAITI 18 27 CPU while loop 26 35 Run CoreMark 34 43 WAITI 15 27 CPU while loop 20 32 Run CoreMark 26 37 WAITI 12 24 CPU while loop 15 26 Run CoreMark 18 29 8 18 CPU while loop 10 19 Run CoreMark 12 21 Description 240 160 Modem-sleep2,3 80 WAITI 40 1 In practice, the current consumption might be different depending on which peripherals are enabled. 2 In Modem-sleep mode, Wi-Fi is clock gated. 3 In Modem-sleep mode, the consumption might be higher when accessing flash. Espressif Systems 34 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 6 Electrical Characteristics Table 6-9. Current Consumption in Low-Power Modes Mode Description Typ (mA) CPU and wireless communication modules are powered down, Light-sleep 0.25 peripheral clocks are disabled, and all GPIOs are high-impedance CPU, wireless communication modules and peripherals are pow- 0.06 ered down, and all GPIOs are high-impedance 6.5 Deep-sleep RTC timer and LP memory are powered on 0.012 Power off CHIP_PU is set to low level, the chip is powered off 0.002 Memory Specifications The data below is sourced from the memory vendor datasheet. These values are guaranteed through design and/or characterization but are not fully tested in production. Devices are shipped with the memory erased. Table 6-10. Flash Specifications Parameter Description Min Typ Max Unit Power supply voltage (1.8 V) 1.65 1.80 2.00 V Power supply voltage (3.3 V) 2.7 3.3 3.6 V FC Maximum clock frequency 80 — — MHz — Program/erase cycles 100,000 — — cycles TRET Data retention time 20 — — years TP P Page program time — 0.8 5 ms TSE Sector erase time (4 KB) — 70 500 ms TBE1 Block erase time (32 KB) — 0.2 2 s TBE2 Block erase time (64 KB) — 0.3 3 s Chip erase time (16 Mb) — 7 20 s Chip erase time (32 Mb) — 20 60 s Chip erase time (64 Mb) — 25 100 s Chip erase time (128 Mb) — 60 200 s Chip erase time (256 Mb) — 70 300 s VCC TCE Table 6-11. PSRAM Specifications Parameter VCC FC Espressif Systems Description Min Typ Max Unit Power supply voltage (1.8 V) 1.62 1.80 1.98 V Power supply voltage (3.3 V) 2.7 3.3 3.6 V Maximum clock frequency 80 — — MHz 35 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics 7 RF Characteristics This section contains tables with RF characteristics of the Espressif product. The RF data is measured at the antenna port, where RF cable is connected, including the front-end loss. The external antennas used for the tests on the modules with external antenna connectors have an impedance of 50 Ω. Devices should operate in the center frequency range allocated by regional regulatory authorities. The target center frequency range and the target transmit power are configurable by software. See ESP RF Test Tool and Test Guide for instructions. Unless otherwise stated, the RF tests are conducted with a 3.3 V (±5%) supply at 25 ºC ambient temperature. 7.1 2.4 GHz Wi-Fi Radio Table 7-1. 2.4 GHz Wi-Fi RF Characteristics Name Description Center frequency range of operating channel 2412 ~ 2484 MHz Wi-Fi wireless standard IEEE 802.11b/g/n/ax 7.1.1 2.4 GHz Wi-Fi RF Transmitter (TX) Characteristics Table 7-2. 2.4 GHz TX Power with Spectral Mask and EVM Meeting 802.11 Standards Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps, DSSS — 19.5 — 802.11b, 11 Mbps, CCK — 19.5 — 802.11g, 6 Mbps, OFDM — 18.5 — 802.11g, 54 Mbps, OFDM — 16.5 — 802.11n, HT20, MCS0 — 18.5 — 802.11n, HT20, MCS7 — 16.5 — 802.11n, HT40, MCS0 — 17.5 — 802.11n, HT40, MCS7 — 15.5 — 802.11ax, HE20, MCS0 — 18.5 — 802.11ax, HE20, MCS9 — 14.5 — Rate Table 7-3. 2.4 GHz TX EVM Test1 Rate Min Typ Limit (dB) (dB) (dB) 802.11b, 1 Mbps, DSSS — –25.0 –10.0 802.11b, 11 Mbps, CCK — –25.0 –10.0 Cont’d on next page Espressif Systems 36 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-3 – cont’d from previous page Rate Min Typ Limit (dB) (dB) (dB) 802.11g, 6 Mbps, OFDM — –25.0 –5.0 802.11g, 54 Mbps, OFDM — –30.0 –25.0 802.11n, HT20, MCS0 — –25.0 –5.0 802.11n, HT20, MCS7 — –31.5 –27.0 802.11n, HT40, MCS0 — –25.0 –5.0 802.11n, HT40, MCS7 — –31.5 –27.0 802.11ax, HE20, MCS0 — –25.0 –5.0 802.11ax, HE20, MCS9 — –34.5 –32.0 1 EVM is measured at the corresponding typical TX power provided in Table 7-2 2.4 GHz TX Power with Spectral Mask and EVM Meeting 802.11 Standards above. 7.1.2 2.4 GHz Wi-Fi RF Receiver (RX) Characteristics For RX tests, the PER (packet error rate) limit is 8% for 802.11b, and 10% for 802.11g/n/ax. Table 7-4. 2.4 GHz RX Sensitivity Rate Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps, DSSS — –100.0 — 802.11b, 2 Mbps, DSSS — –97.0 — 802.11b, 5.5 Mbps, CCK — –94.0 — 802.11b, 11 Mbps, CCK — –90.0 — 802.11g, 6 Mbps, OFDM — –95.0 — 802.11g, 9 Mbps, OFDM — –93.0 — 802.11g, 12 Mbps, OFDM — –92.0 — 802.11g, 18 Mbps, OFDM — –90.0 — 802.11g, 24 Mbps, OFDM — –87.0 — 802.11g, 36 Mbps, OFDM — –84.0 — 802.11g, 48 Mbps, OFDM — –80.0 — 802.11g, 54 Mbps, OFDM — –78.0 — 802.11n, HT20, MCS0 — –94.5 — 802.11n, HT20, MCS1 — –93.0 — 802.11n, HT20, MCS2 — –90.0 — 802.11n, HT20, MCS3 — –87.0 — 802.11n, HT20, MCS4 — –83.5 — 802.11n, HT20, MCS5 — –79.0 — 802.11n, HT20, MCS6 — –77.0 — 802.11n, HT20, MCS7 — –76.0 — 802.11n, HT40, MCS0 — –92.0 — 802.11n, HT40, MCS1 — –90.0 — Cont’d on next page Espressif Systems 37 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-4 – cont’d from previous page Rate Min Typ Max (dBm) (dBm) (dBm) 802.11n, HT40, MCS2 — –87.0 — 802.11n, HT40, MCS3 — –83.0 — 802.11n, HT40, MCS4 — –81.0 — 802.11n, HT40, MCS5 — –76.0 — 802.11n, HT40, MCS6 — –74.0 — 802.11n, HT40, MCS7 — –73.0 — 802.11ax, HE20, MCS0 — –94.5 — 802.11ax, HE20, MCS1 — –91.5 — 802.11ax, HE20, MCS2 — –89.0 — 802.11ax, HE20, MCS3 — –86.0 — 802.11ax, HE20, MCS4 — –83.0 — 802.11ax, HE20, MCS5 — –79.0 — 802.11ax, HE20, MCS6 — –77.5 — 802.11ax, HE20, MCS7 — –75.5 — 802.11ax, HE20, MCS8 — –71.5 — 802.11ax, HE20, MCS9 — –69.5 — Table 7-5. 2.4 GHz Maximum RX Level Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps, DSSS — 5 — 802.11b, 11 Mbps, CCK — 5 — 802.11g, 6 Mbps, OFDM — 5 — 802.11g, 54 Mbps, OFDM — 0 — 802.11n, HT20, MCS0 — 5 — 802.11n, HT20, MCS7 — 0 — 802.11n, HT40, MCS0 — 5 — 802.11n, HT40, MCS7 — 0 — 802.11ax, HE20, MCS0 — 5 — 802.11ax, HE20, MCS9 — 0 — Rate Table 7-6. 2.4 GHz RX Adjacent Channel Rejection Rate Min Typ Max (dB) (dB) (dB) 802.11b, 1 Mbps, DSSS — 41 — 802.11b, 11 Mbps, CCK — 40 — 802.11g, 6 Mbps, OFDM — 37 — 802.11g, 54 Mbps, OFDM — 17 — Cont’d on next page Espressif Systems 38 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-6 – cont’d from previous page Rate Min Typ Max (dB) (dB) (dB) 802.11n, HT20, MCS0 — 34 — 802.11n, HT20, MCS7 — 16 — 802.11n, HT40, MCS0 — 24 — 802.11n, HT40, MCS7 — 13 — 802.11ax, HE20, MCS0 — 38 — 802.11ax, HE20, MCS9 — 12 — 7.2 5 GHz Wi-Fi Radio Table 7-7. 5 GHz Wi-Fi RF Characteristics Name Description Center frequency range of operating channel 5180 ~ 5885 MHz Wi-Fi wireless standard IEEE 802.11a/n/ac/ax 7.2.1 5 GHz Wi-Fi RF Transmitter (TX) Characteristics Table 7-8. 5 GHz TX Power with Spectral Mask and EVM Meeting 802.11 Standards Min Typ Max (dBm) (dBm) (dBm) 802.11a, 6 Mbps, OFDM — 18.5 — 802.11a, 54 Mbps, OFDM — 16.5 — 802.11n, HT20, MCS0 — 18.5 — 802.11n, HT20, MCS7 — 15.5 — 802.11n, HT40, MCS0 — 17.5 — 802.11n, HT40, MCS7 — 14.5 — 802.11ac, VHT20, MCS0 — 18.5 — 802.11ac, VHT20, MCS7 — 15.5 — 802.11ax, HE20, MCS0 — 18.5 — 802.11ax, HE20, MCS7 — 15.5 — Rate Table 7-9. 5 GHz TX EVM Test1 Rate Min Typ Limit (dB) (dB) (dB) 802.11a, 6 Mbps, OFDM — –25.0 –5.0 802.11a, 54 Mbps, OFDM — –29.0 –25.0 802.11n, HT20, MCS0 — –25.0 –5.0 802.11n, HT20, MCS7 — –31.0 –27.0 Cont’d on next page Espressif Systems 39 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-9 – cont’d from previous page Rate Min Typ Limit (dB) (dB) (dB) 802.11n, HT40, MCS0 — –25.0 –5.0 802.11n, HT40, MCS7 — –31.0 –27.0 802.11ac, VHT20, MCS0 — –25.0 –5.0 802.11ac, VHT20, MCS7 — –31.0 –27.0 802.11ax, HE20, MCS0 — –25.0 –5.0 802.11ax, HE20, MCS7 — –31.5 –27.0 1 EVM is measured at the corresponding typical TX power provided in Table 7-8 5 GHz TX Power with Spectral Mask and EVM Meeting 802.11 Standards above. 7.2.2 5 GHz Wi-Fi RF Receiver (RX) Characteristics For RX tests, the PER (packet error rate) limit is 10% for 802.11a/n/ac/ax. Table 7-10. 5 GHz RX Sensitivity Min Typ Max (dBm) (dBm) (dBm) 802.11a, 6 Mbps, OFDM — –94.5 — 802.11a, 9 Mbps, OFDM — –93.0 — 802.11a, 12 Mbps, OFDM — –91.5 — 802.11a, 18 Mbps, OFDM — –89.5 — 802.11a, 24 Mbps, OFDM — –86.5 — 802.11a, 36 Mbps, OFDM — –83.5 — 802.11a, 48 Mbps, OFDM — –78.5 — 802.11a, 54 Mbps, OFDM — –76.5 — 802.11n, HT20, MCS0 — –94.0 — 802.11n, HT20, MCS1 — –92.5 — 802.11n, HT20, MCS2 — –89.5 — 802.11n, HT20, MCS3 — –86.5 — 802.11n, HT20, MCS4 — –82.5 — 802.11n, HT20, MCS5 — –78.5 — 802.11n, HT20, MCS6 — –77.0 — 802.11n, HT20, MCS7 — –75.5 — 802.11n, HT40, MCS0 — –91.5 — 802.11n, HT40, MCS1 — –89.5 — 802.11n, HT40, MCS2 — –86.5 — 802.11n, HT40, MCS3 — –83.5 — 802.11n, HT40, MCS4 — –80.5 — 802.11n, HT40, MCS5 — –75.5 — 802.11n, HT40, MCS6 — –73.5 — 802.11n, HT40, MCS7 — –72.5 — Rate Cont’d on next page Espressif Systems 40 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-10 – cont’d from previous page Min Typ Max (dBm) (dBm) (dBm) 802.11ac, VHT20, MCS0 — –94.5 — 802.11ac, VHT20, MCS1 — –92.5 — 802.11ac, VHT20, MCS2 — –89.5 — 802.11ac, VHT20, MCS3 — –86.5 — 802.11ac, VHT20, MCS4 — –83.0 — 802.11ac, VHT20, MCS5 — –78.5 — 802.11ac, VHT20, MCS6 — –77.0 — 802.11ac, VHT20, MCS7 — –75.5 — 802.11ax, HE20, MCS0 — –94.0 — 802.11ax, HE20, MCS1 — –91.0 — 802.11ax, HE20, MCS2 — –88.0 — 802.11ax, HE20, MCS3 — –85.5 — 802.11ax, HE20, MCS4 — –82.0 — 802.11ax, HE20, MCS5 — –78.5 — 802.11ax, HE20, MCS6 — –77.0 — 802.11ax, HE20, MCS7 — –74.5 — Rate Table 7-11. 5 GHz Maximum RX Level Min Typ Max (dBm) (dBm) (dBm) 802.11a, 6 Mbps, OFDM — 5 — 802.11a, 54 Mbps, OFDM — 0 — 802.11n, HT20, MCS0 — 5 — 802.11n, HT20, MCS7 — 0 — 802.11n, HT40, MCS0 — 5 — 802.11n, HT40, MCS7 — 0 — 802.11ac, VHT20, MCS0 — 5 — 802.11ac, VHT20, MCS7 — 0 — 802.11ax, HE20, MCS0 — 5 — 802.11ax, HE20, MCS7 — 0 — Rate Table 7-12. 5 GHz RX Adjacent Channel Rejection Rate Min Typ Max (dB) (dB) (dB) 802.11a, 6 Mbps, OFDM — 29 — 802.11a, 54 Mbps, OFDM — 9 — 802.11n, HT20, MCS0 — 26 — 802.11n, HT20, MCS7 — 8 — Cont’d on next page Espressif Systems 41 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-12 – cont’d from previous page Rate Min Typ Max (dB) (dB) (dB) 802.11n, HT40, MCS0 — 29 — 802.11n, HT40, MCS7 — 11 — 802.11ac, VHT20, MCS0 — 25 — 802.11ac, VHT20, MCS7 — 6 — 802.11ax, HE20, MCS0 — 25 — 802.11ax, HE20, MCS7 — 6 — 7.3 Bluetooth 5 (LE) Radio Table 7-13. Bluetooth LE RF Characteristics Name Description Center frequency range of operating channel 2402 ~ 2480 MHz RF transmit power range –15~20 dBm 7.3.1 Bluetooth LE RF Transmitter (TX) Characteristics Table 7-14. Bluetooth LE - Transmitter Characteristics - 1 Mbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 7.0 — kHz Max. |f0 − fn |n=2, 3, 4, ...k — 0.6 — kHz Max. |fn − fn−5 |n=6, 7, 8, ...k — 0.6 — kHz |f1 − f0 | — 0.3 — kHz ∆ F 1avg — 250.0 — kHz — 255.0 — kHz ∆ F 2avg /∆ F 1avg — 0.98 — — ± 2 MHz offset — –33 — dBm ± 3 MHz offset — –40 — dBm > ± 3 MHz offset — –45 — dBm Min. ∆ F 2max (for at least 99.9% of all ∆ F 2max ) In-band emissions Typ Table 7-15. Bluetooth LE - Transmitter Characteristics - 2 Mbps Parameter Carrier frequency offset and drift Description Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 7.0 — kHz Max. |f0 − fn |n=2, 3, 4, ...k — 0.6 — kHz Max. |fn − fn−5 |n=6, 7, 8, ...k — 0.7 — kHz |f1 − f0 | — 0.3 — kHz ∆ F 1avg — 495.1 — kHz Modulation characteristics Espressif Systems Typ Cont’d on next page 42 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-15 – cont’d from previous page Parameter Description Min Min. ∆ F 2max (for at least Max Unit — 515.0 — kHz ∆ F 2avg /∆ F 1avg — 0.99 — — ± 4 MHz offset — –43 — dBm ± 5 MHz offset — –45 — dBm > ± 5 MHz offset — –45 — dBm 99.9% of all ∆ F 2max ) In-band emissions Typ Table 7-16. Bluetooth LE - Transmitter Characteristics - 125 Kbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 7.0 — kHz Max. |f0 − fn |n=1, 2, 3, ...k — 0.3 — kHz |f0 − f3 | — 0.3 — kHz Max. |fn − fn−3 |n=7, 8, 9, ...k — 0.4 — kHz ∆ F 1avg — 251.2 — kHz — 256.7 — kHz Min. ∆ F 1max (for at least 99.9% of all ∆ F 1max ) In-band emissions Typ ± 2 MHz offset — –31 — dBm ± 3 MHz offset — –40 — dBm > ± 3 MHz offset — –43 — dBm Table 7-17. Bluetooth LE - Transmitter Characteristics - 500 Kbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max. |fn |n=0, 1, 2, 3, ...k — 7.0 — kHz Max. |f0 − fn |n=1, 2, 3, ...k — 0.5 — kHz |f0 − f3 | — 0.2 — kHz Max. |fn − fn−3 |n=7, 8, 9, ...k — 0.5 — kHz ∆ F 2avg — 246.3 — kHz — 253.3 — kHz ± 2 MHz offset — –31 — dBm ± 3 MHz offset — –40 — dBm > ± 3 MHz offset — –43 — dBm Max Unit Min. ∆ F 2max (for at least 99.9% of all ∆ F 2max ) In-band emissions Typ 7.3.2 Bluetooth LE RF Receiver (RX) Characteristics Table 7-18. Bluetooth LE - Receiver Characteristics - 1 Mbps Parameter Description Min Typ Sensitivity @30.8% PER — — –98.5 — dBm Maximum received signal @30.8% PER — — 5 — dBm Cont’d on next page Espressif Systems 43 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-18 – cont’d from previous page Parameter Max Unit 9 — dB — –4 — dB F = F0 – 1 MHz — –3 — dB F = F0 + 2 MHz — –31 — dB F = F0 – 2 MHz — –34 — dB F = F0 + 3 MHz — –33 — dB F = F0 – 3 MHz — –43 — dB F ≥ F0 + 4 MHz — –37 — dB F ≤ F0 – 4 MHz — –50 — dB — — –28 — dB Adjacent channel to F = Fimage + 1 MHz — –27 — dB image frequency F = Fimage – 1 MHz — –30 — dB 30 MHz ~ 2000 MHz — –13 — dBm 2003 MHz ~ 2399 MHz — –25 — dBm 2484 MHz ~ 2997 MHz — –20 — dBm 3000 MHz ~ 12.75 GHz — –20 — dBm — — –41 — dBm Max Unit Co-channel Adjacent channel C/I and receiver selectivity performance Image frequency Out-of-band blocking performance Intermodulation Description Min F = F0 MHz — F = F0 + 1 MHz Typ Table 7-19. Bluetooth LE - Receiver Characteristics - 2 Mbps Parameter Description Sensitivity @30.8% PER — — –96.0 — dBm Maximum received signal @30.8% PER — — 5 — dBm F = F0 MHz — 8 — dB F = F0 + 2 MHz — –8 — dB F = F0 – 2 MHz — –10 — dB F = F0 + 4 MHz — –27 — dB F = F0 – 4 MHz — –42 — dB F = F0 + 6 MHz — –39 — dB F = F0 – 6 MHz — –50 — dB F ≥ F0 + 8 MHz — –48 — dB F ≤ F0 – 8 MHz — –54 — dB — — –27 — dB Adjacent channel to F = Fimage + 2 MHz — –26 — dB image frequency F = Fimage – 2 MHz — –28 — dB 30 MHz ~ 2000 MHz — –13 — dBm 2003 MHz ~ 2399 MHz — –25 — dBm 2484 MHz ~ 2997 MHz — –20 — dBm 3000 MHz ~ 12.75 GHz — –20 — dBm — — –39 — dBm Co-channel C/I and receiver Adjacent channel selectivity performance Image frequency Out-of-band blocking performance Intermodulation Espressif Systems 44 Submit Documentation Feedback Min Typ ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics Table 7-20. Bluetooth LE - Receiver Characteristics - 125 Kbps Parameter Description Max Unit Sensitivity @30.8% PER — — –106.5 — dBm Maximum received signal @30.8% PER — — 5 — dBm F = F0 MHz — 3 — dB F = F0 + 1 MHz — –6 — dB F = F0 – 1 MHz — –7 — dB F = F0 + 2 MHz — –34 — dB F = F0 – 2 MHz — –39 — dB F = F0 + 3 MHz — –30 — dB F = F0 – 3 MHz — –47 — dB F ≥ F0 + 4 MHz — –46 — dB F ≤ F0 – 4 MHz — –54 — dB — — –28 — dB Adjacent channel to F = Fimage + 1 MHz — –34 — dB image frequency — –31 — dB Max Unit Co-channel Adjacent channel C/I and receiver selectivity performance Image frequency Min F = Fimage – 1 MHz Typ Table 7-21. Bluetooth LE - Receiver Characteristics - 500 Kbps Parameter Description Sensitivity @30.8% PER — — –103.0 — dBm Maximum received signal @30.8% PER — — 5 — dBm F = F0 MHz — 3 — dB F = F0 + 1 MHz — –6 — dB F = F0 – 1 MHz — –7 — dB F = F0 + 2 MHz — –33 — dB F = F0 – 2 MHz — –38 — dB F = F0 + 3 MHz — –38 — dB F = F0 – 3 MHz — –47 — dB F ≥ F0 + 4 MHz — –41 — dB F ≤ F0 – 4 MHz — –52 — dB — — –23 — dB Adjacent channel to F = Fimage + 1 MHz — –29 — dB image frequency — –29 — dB Co-channel Adjacent channel C/I and receiver selectivity performance Image frequency 7.4 Min F = Fimage – 1 MHz Typ 802.15.4 Radio Table 7-22. 802.15.4 RF Characteristics Name Description Center frequency range of operating channel 2405 ~ 2480 MHz 1 Zigbee in the 2.4 GHz range supports 16 channels at 5 MHz spacing from channel 11 to channel 26. Espressif Systems 45 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 7 RF Characteristics 7.4.1 802.15.4 RF Transmitter (TX) Characteristics Table 7-23. 802.15.4 Transmitter Characteristics - 250 Kbps Parameter Min RF transmit power range –15.0 — 20.0 dBm — 4.0% — — EVM 7.4.2 Typ Max Unit 802.15.4 RF Receiver (RX) Characteristics Table 7-24. 802.15.4 Receiver Characteristics - 250 Kbps Parameter Description Sensitivity @1% PER — — Maximum received signal @1% PER — Adjacent channel Relative jamming level Alternate channel Espressif Systems Max Unit –103.5 — dBm — 5 — dBm F = F0 + 5 MHz — 28 — dB F = F0 – 5 MHz — 32 — dB F = F0 + 10 MHz — 48 — dB F = F0 – 10 MHz — 53 — dB 46 Submit Documentation Feedback Min Typ ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 8 Module Schematics This is the reference design of the module. GND VDD33 C1 GND XOUT GND GND 1 C20 48MHz 1uF VDD33 C26 1uF R2 499 7 /HOLD NC: No component. 1uF VDD33 GND C3 U1 C15 GND ANT_5G GND VDDA5 VDDA4 VDDA3 GND ANT_2G VDDA2 VDDA1 VDDPST3 GPIO28 GPIO27 Dual Band Diplexer 0.1uF 49 48 47 46 45 44 43 42 41 40 39 38 37 ANT_5G GND L3 C24 GND RF_ANT_5G TBD C25 TBD TBD ANT_2G GND L2 GND GND RF_ANT_2G TBD C23 1 H_PORT GND CM 3 L_PORT DI /WP FLASH 5 2 3 SPID SPIQ SPIWP SPICS1_IO15 SPICS0 SPIQ SPIWP SPIHD SPICLK SPID IO23 IO24 IO25 IO26 IO27 IO28 R3 R4 R5 R6 R7 TBD GND VDD33 C11 C10 C8 2.6pF 3.0pF 0.1uF GND C29 10uF GND C12 VDD33 0.1uF GND C31 NC GND For chips with in-package SPI flash (e.g., ESP32-C5HF4), the SPICS0, SPIQ, SPIWP, VDD_SPI, SPIHD, SPICLK and SPID pins are not connected(NC); U2, C3, C5, R3~R7 are not required. GND Figure 8-1. ESP32-C5-WROOM-1 Schematics COM_ANT_D L5 GND 5 GND TBD GND 2.0nH(0.1nH) GND 6 COM_ANT TBD 1 2 C28 TBD GND The values of C23, L2, C22, C24, L3, C25, C27, L5 and C28 vary with the actual PCB board. Add a stub to the ground pad. 0 0 0 0 0 GND Diplexer ESP32-C5_QFN48 L7 7 C27 U3 GND GND ANT1 2 C22 TBD RF 2.4G&5G: Single-ended 50ohm. 8 10nF NC MTDI MTMS XTAL_32K_N XTAL_32K_P VDDPST1 CHIP_PU VDDA8 XTAL_P XTAL_N VDDA7 GND VDDA6 C14 1uF DO GND GND SPICS1 SPICS0 SPIQ SPIWP VDD_SPI SPIHD SPICLK SPID GPIO23 GPIO24 GPIO25 GPIO26 GND 8 VDD CLK GND SPIHD 6 /CS 4 ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 SPICLK MTCK MTDO GPIO6 GPIO7 GPIO8 GPIO9 GPIO10 U0TXD U0RXD GPIO13 GPIO14 VDDPST2 C4 VDD_SPI U2 GND 0 R1 0 0.1uF 1 10uF GND 12 11 10 9 8 7 6 5 4 3 2 1 R8 13 14 15 16 17 18 19 20 21 22 23 24 C5 GND C30 GND VDD_SPI SPICS0 1.0pF C19 IO4 IO5 IO6 IO7 IO8 IO9 IO10 TX0 RX0 VDD33 IO13 IO14 0.1uF C17 0.6pF GND EN IO0 IO1 IO2 IO3 GND C16 VDD33 GND 10uF 10K(NC) VDD33 GND SPICS1_IO15 IO27 IO4 IO5 IO28 C21 R10 The value of R1 varies with the actual PCB board. R1 could be a resistor or inductor, the initial value is suggested to be 24 nH. IO23 VDD33 GND The values of C1 and C2 vary with the selection of the crystal. GND ESP32-C5-WROOM-1(Pin-out) D1 ESD TBD 2 TBD IO26 IO25 TX0 RX0 IO24 C2 XTAL_P XTAL_N 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 For modules with embedded PSRAM, SPICS1 is connected to the embedded PSRAM and is not available for other uses. 47 Submit Documentation Feedback EPAD GND IO26 IO25 TX0 RX0 IO24 NC IO23 NC NC/IO15 IO27 IO4 IO5 IO28 GND 3V3 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 25 26 27 28 29 30 31 32 33 34 35 36 1 2 3 4 5 6 7 8 9 10 11 12 13 14 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 XIN ESP32-C5-WROOM-1 NC VDD33 GND Y1 3 GND 4 GND 4 Espressif Systems 8 Module Schematics GND COM_ANT2 1 C20 1uF GND XOUT The values of C1 and C2 vary with the selection of the crystal. The value of R1 varies with the actual PCB board. R1 could be a resistor or inductor, the initial value is suggested to be 24 nH. VDD33 GND GND SPICS1_IO15 IO27 IO4 IO5 IO28 XTAL_P XTAL_N IO23 C26 1uF C30 10uF GND 0 GND R1 GND 1uF VDD33 GND 12 11 10 9 8 7 6 5 4 3 2 1 0 R2 499 VDD_SPI ANT_5G GND VDDA5 VDDA4 VDDA3 GND ANT_2G VDDA2 VDDA1 VDDPST3 GPIO28 GPIO27 48 47 46 45 44 43 42 41 40 39 38 37 ANT_5G C3 U1 GND L3 C24 TBD ANT_2G Dual Band Diplexer GND L2 TBD GND GND RF_ANT_2G TBD C23 1 H_PORT 2 GND 3 L_PORT C22 U3 TBD TBD 1 SPICLK 6 SPIHD 7 /CS CLK /HOLD DI DO 4 SPICS0 VDD U2 GND 8 0.1uF /WP FLASH 5 SPID 2 SPIQ 3 SPIWP SPICS1_IO15 SPICS0 SPIQ SPIWP SPIHD SPICLK SPID IO23 IO24 IO25 IO26 IO27 IO28 R3 R4 R5 R6 R7 ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 GND NC GND 6COM_ANT_D 5 GND L5 TBD COM_ANT C27 C28 TBD TBD Add a stub to the ground pad. L7 0 0 0 0 0 VDD33 2.0nH(0.1nH) C11 C10 C8 2.6pF 3.0pF 0.1uF GND GND GND C29 10uF GND C12 VDD33 0.1uF GND For chips with in-package SPI flash (e.g., ESP32-C5HF4), the SPICS0, SPIQ, SPIWP, VDD_SPI, SPIHD, SPICLK and SPID pins are not connected(NC); U2, C3, C5, R3~R7 are not required. GND Figure 8-2. ESP32-C5-WROOM-1U Schematics R12 0(NC) R11 0 D2 ESD(NC) COM_ANT2 COM_ANT1 ANT1 CONN Diplexer GND GND C31 NC: No component. GND 7 GND GND ESP32-C5_QFN48 C5 GND R10 GND CM 1uF 10K(NC) RF 2.4G&5G: Single-ended 50ohm. 8 0.1uF GND RF_ANT_5G TBD C25 The values of C23, L2, C22, C24, L3, C25, C27, L5 and C28 vary with the actual PCB board. SPICS1 SPICS0 SPIQ SPIWP VDD_SPI SPIHD SPICLK SPID GPIO23 GPIO24 GPIO25 GPIO26 GND 0.1uF VDD_SPI GND GND C15 NC MTCK MTDO GPIO6 GPIO7 GPIO8 GPIO9 GPIO10 U0TXD U0RXD GPIO13 GPIO14 VDDPST2 10nF NC R8 13 14 15 16 17 18 19 20 21 22 23 24 C4 48 Submit Documentation Feedback IO4 IO5 IO6 IO7 IO8 IO9 IO10 TX0 RX0 VDD33 IO13 IO14 C14 49 4 VDD33 GND 0.3pF C19 For modules with embedded PSRAM, SPICS1 is connected to the embedded PSRAM and is not available for other uses. 10uF C17 0.8pF GND EN IO0 IO1 IO2 IO3 C21 C16 VDD33 GND ESP32-C5-WROOM-1U GND TBD 48MHz VDD33 ESP32-C5-WROOM-1U(Pin-out) D1 ESD C2 2 TBD IO26 IO25 TX0 RX0 IO24 3 4 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 C1 MTDI MTMS XTAL_32K_N XTAL_32K_P VDDPST1 CHIP_PU VDDA8 XTAL_P XTAL_N VDDA7 GND VDDA6 EPAD GND IO26 IO25 TX0 RX0 IO24 NC IO23 NC NC/IO15 IO27 IO4 IO5 IO28 GND 3V3 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 VDD33 GND GND 32 31 30 GND ANT2 GND 1 2 3 4 5 6 7 8 9 10 11 12 13 14 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 GND Y1 XIN GND 25 26 27 28 29 30 31 32 33 34 35 36 GND VDD33 GND 8 Module Schematics Espressif Systems GND GND GND GND 9 Peripheral Schematics 9 Peripheral Schematics This is the typical application circuit of the module connected with peripheral components (for example, power supply, antenna, reset button, JTAG interface, and UART interface). C5 12pF(NC) 1 GND R5 R3 0(NC) IO0 R4 0(NC) IO1 2 NC X1 32.768KHz(NC) GND C6 X1: ESR= Max. 70 KΩ 12pF(NC) NC: No component. GND VDD33 R1 TBD SW1 R2 C4 U1 C1 C2 22uF 0.1uF EN 0 0.1uF GND GND C3 TBD GND GND VDD33 GND 1 2 3 4 5 6 7 8 9 10 11 12 13 14 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 ESP32-C5-WROOM-1 GND 3V3 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 EPAD GND IO26 IO25 TX0 RX0 IO24 NC IO23 NC NC/IO15 IO27 IO4 IO5 IO28 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 VDD33 IO26 IO25 DEBUG_TX0 DEBUG_RX0 IO24 JP1 1 2 3 4 IO23 1 2 3 4 UART GND NC/IO15 IO27 IO4 IO5 IO28 JP3 1 2 1 2 USB_DUSB_D+ USB R6 R7 C8 C7 TBD TBD GND TBD TBD JP2 IO26 IO27 IO28 1 2 3 1 2 3 BOOT Boot Configurations. GND Figure 9-1. ESP32-C5-WROOM-1 Schematics Espressif Systems 49 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 9 Peripheral Schematics C5 RF 2.4G&5G: Single-ended 50ohm. 12pF(NC) 1 GND R5 R3 0(NC) IO0 R4 0(NC) IO1 2 GND C6 ANT2 12pF(NC) GND NC: No component. R1 TBD SW1 R2 C1 C2 22uF 0.1uF EN 0 0.1uF GND GND C3 TBD GND GND EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 1 2 3 4 5 6 7 8 9 10 11 12 13 14 JP3 1 2 USB_DUSB_D+ USB R6 R7 C8 C7 TBD TBD GND EPAD GND IO26 IO25 TX0 RX0 IO24 NC IO23 NC NC/IO15 IO27 IO4 IO5 IO28 GND 3V3 EN IO2 IO3 IO0 IO1 IO6 IO7 IO8 IO9 IO10 IO13 IO14 U1 1 2 GND GND 32 31 30 VDD33 C10 TBD GND GND ANT2 GND VDD33 RF_ANT TBD C9 TBD X1: ESR= Max. 70 KΩ GND C4 L1 NC X1 32.768KHz(NC) 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 VDD33 IO26 IO25 DEBUG_TX0 DEBUG_RX0 IO24 JP1 1 2 3 4 IO23 1 2 3 4 UART GND NC/IO15 IO27 IO4 IO5 IO28 ESP32-C5-WROOM-1U TBD TBD JP2 IO26 IO27 IO28 1 2 3 1 2 3 BOOT Boot Configurations. GND Figure 9-2. ESP32-C5-WROOM-1U Schematics • If an external antenna ANT2 is used, it is recommended to reserve an RF circuit as shown in the figure above. By default, ESP32-C5-WROOM-1U uses ANT1, and ANT2 is disabled. To use ANT2, please contact us. • Please control the voltage levels of strapping pins. For more details, please refer to Chapter 4 Boot Configurations. • Soldering the EPAD to the ground of the base board is not a must, however, it can optimize thermal performance. If you choose to solder it, please apply the correct amount of soldering paste. Too much soldering paste may increase the gap between the module and the baseboard. As a result, the adhesion between other pins and the baseboard may be poor. • To ensure that the power supply to the ESP32-C5 chip is stable during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32-C5’s power-up and reset sequence timing diagram, please refer to Section 4.5 Chip Power-up and Reset. Espressif Systems 50 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 10 Physical Dimensions 10 Physical Dimensions 10.1 Module Dimensions Unit: mm 3.3±0.15 6.5 18±0.2 0.8 Antenna Area 1.27 Antenna Area 0.4 28 x 0.9 5 10.922 0.5 0.4 1.3 9.8298 3 Ø0. 4.7 28 x Ø0.55 19.7 28 x 0.9 4.7 1.3 1.27 16.51 27.5±0.2 15.8 28 x 0.85 1.1 28 x 0.45 Top View Bottom View Side View Figure 10-1. ESP32-C5-WROOM-1 Dimensions Unit: mm 5 1.27 3 2.38 2.38 18±0.2 3.3±0.15 10.46 3 1.27 0.8 4.7 1.3 U HR T 2 0.4 4.7 31 x 0.85 1.1 31 x 0.45 3 10.922 3 0.5 9.8298 0.4 1.3 31 x 0.9 15.9 19.6 15.8 1.27 . Ø1 31 x Ø0.55 1.27 31 x 0.9 16.51 21.2±0.2 11.1 Top View Bottom View Side View Figure 10-2. ESP32-C5-WROOM-1U Dimensions Note: For information about tape, reel, and product marking, please refer to ESP32-C5 Module Packaging Information. Espressif Systems 51 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 10 Physical Dimensions 10.2 Dimensions of External Antenna Connector ESP32-C5-WROOM-1U uses the first generation external antenna connector as shown in Figure 10-3 Dimensions of External Antenna Connector. This connector is compatible with the following connectors: • U.FL Series connector from Hirose • MHF I connector from I-PEX • AMC connector from Amphenol Unit: mm Figure 10-3. Dimensions of External Antenna Connector Espressif Systems 52 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 10 Physical Dimensions The external antenna used for ESP32-C5-WROOM-1U during certification testing is SY-WIFI-ESP-Dual Band Ant. The module does not include an external antenna upon shipment. If needed, select a suitable external antenna based on the product’s usage environment and performance requirements. It is recommended to select an antenna that meets the following requirements: • 2.4 GHz & 5 GHz band • 50 Ω impedance • The maximum gain does not exceed 3.86 dBi (2.4 GHz) or 3.65 dBi (5 GHz), the gain of the antenna used for certification • The connector matches the specifications shown in Figure 10-3 Dimensions of External Antenna Connector Note: • If you use an external antenna of a different type or gain, additional testing, such as EMC, may be required beyond the existing antenna test reports for Espressif modules. Specific requirements depend on the certification type. • If RF function is enabled, make sure an antenna is connected. Operation without an antenna may result in unstable behavior or potential damage to the RF circuit. Espressif Systems 53 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 11 PCB Layout Recommendations 11 PCB Layout Recommendations 11.1 PCB Land Pattern This section provides the following resources for your reference: • Figures for recommended PCB land patterns with all the dimensions needed for PCB design. See Figure 11-1 ESP32-C5-WROOM-1 PCB Land Pattern and Figure 11-2 ESP32-C5-WROOM-1U PCB Land Pattern. • Source files of recommended PCB land patterns to measure dimensions not covered in Figure 11-1. You can view the source files for ESP32-C5-WROOM-1 and ESP32-C5-WROOM-1U with Autodesk Viewer. • 3D models of ESP32-C5-WROOM-1 and ESP32-C5-WROOM-1U. Please make sure that you download the 3D model file in .STEP format (beware that some browsers might add .txt). Unit: mm Via for thermal pad Copper 28 1.3 0.4 4.7 10.922 1.27 27.5 1.3 0.4 4.7 28 x 0.9 1 7.99 Antenna Area 28 x 1.5 16.51 6.5 18 9.8298 15 3 14 0.5 17.5 Figure 11-1. ESP32-C5-WROOM-1 PCB Land Pattern Espressif Systems 54 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 11 PCB Layout Recommendations Unit: mm Via for thermal pad Copper 0.5 18 32 31 30 28 1.3 0.4 10.922 29 21.2 4.7 1.27 1.3 0.4 4.7 31 x 0.9 1 16.51 5 1.27 31 x 1.5 1.69 Recommend 50 Ω impedance control for ANT2 pad if used 9.8298 15 3 14 0.5 17.5 Figure 11-2. ESP32-C5-WROOM-1U PCB Land Pattern 11.2 Module Placement for PCB Design If module-on-board design is adopted, attention should be paid while positioning the module on the base board. The interference of the base board on the module’s antenna performance should be minimized. For details about module placement for PCB design, please refer to ESP32-C5 Hardware Design Guidelines > Section Positioning a Module on a Base Board. Espressif Systems 55 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 12 Product Handling 12 Product Handling 12.1 Storage Conditions The products sealed in moisture barrier bags (MBB) should be stored in a non-condensing atmospheric environment of < 40 °C and 90%RH. The module is rated at the moisture sensitivity level (MSL) of 3. After unpacking, the module must be soldered within 168 hours with the factory conditions 25±5 °C and 60%RH. If the above conditions are not met, the module needs to be baked. 12.2 Electrostatic Discharge (ESD) • Human body model (HBM): ±2000 V • Charged-device model (CDM): ±500 V 12.3 Reflow Profile Solder the module in a single reflow. Peak temperature: 235 – 250 °C Peak time: 30 – 70 s Soldering time: > 30 s Solder: Sn-Ag-Cu (SAC305) lead-free solder Temperature (°C) 250 230 217 200 180 150 100 50 Ramp-up Preheating Soldering Cooling 25 25 – 150 °C 60 – 90 s 1 – 3 °C/s 150 – 200 °C 60 – 120 s > 217 °C 60 – 90 s < 180 °C –5 ~ –1 °C/s 0 50 Time (s) 100 150 200 250 Figure 12-1. Reflow Profile Espressif Systems 56 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 12 Product Handling 12.4 Ultrasonic Vibration Avoid exposing Espressif modules to vibration from ultrasonic equipment, such as ultrasonic welders or ultrasonic cleaners. This vibration may induce resonance in the in-module crystal and lead to its malfunction or even failure. As a consequence, the module may stop working or its performance may deteriorate. Espressif Systems 57 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Datasheet Versioning Datasheet Versioning Datasheet Version v0.1 ~ v0.5 (excluding v0.5) Status Watermark Definition This datasheet is under development for products Draft Confidential in the design stage. Specifications may change without prior notice. This datasheet is actively updated for products in v0.5 ~ v1.0 Preliminary (excluding v1.0) release the verification stage. Specifications may change Preliminary before mass production, and the changes will be documentation in the datasheet’s Revision History. This datasheet is publicly released for products in v1.0 and higher Official release mass production. Specifications are finalized, and — major changes will be communicated via Product Change Notifications (PCN). Not Any version — Any version — Recommended This datasheet is updated less frequently for for New Design (NRND)1 products not recommended for new designs. End of Life (EOL)2 This datasheet is no longer mtained for products that have reached end of life. 1 Watermark will be added to the datasheet title page only when all the product variants covered by this datasheet are not recommended for new designs. 2 Watermark will be added to the datasheet title page only when all the product variants covered by this datasheet have reached end of life. Espressif Systems 58 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Related Documentation and Resources Related Documentation and Resources Related Documentation • ESP32-C5 Series Datasheet- Specifications of the ESP32-C5 hardware. • ESP32-C5 Technical Reference Manual – Detailed information on how to use the ESP32-C5 memory and peripherals. • ESP32-C5 Hardware Design Guidelines – Guidelines on how to integrate the ESP32-C5 into your hardware product. • ESP32-C5 Series SoC Errata – Descriptions of known errors in ESP32-C5 series of SoCs. • Certificates https://espressif.com/en/support/documents/certificates • ESP32-C5 Product/Process Change Notifications (PCN) https://espressif.com/en/support/documents/pcns?keys=ESP32-C5 • ESP32-C5 Advisories – Information on security, bugs, compatibility, component reliability. https://espressif.com/en/support/documents/advisories?keys=ESP32-C5 • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32-C5 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • ESP-FAQ – A summary document of frequently asked questions released by Espressif. https://espressif.com/projects/esp-faq/en/latest/index.html • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32-C5 Series SoCs – Browse through all ESP32-C5 SoCs. https://espressif.com/en/products/socs?id=ESP32-C5 • ESP32-C5 Series Modules – Browse through all ESP32-C5-based modules. https://espressif.com/en/products/modules?id=ESP32-C5 • ESP32-C5 Series DevKits – Browse through all ESP32-C5-based devkits. https://espressif.com/en/products/devkits?id=ESP32-C5 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Espressif Systems 59 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Related Documentation and Resources Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Espressif Systems 60 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Revision History Revision History Date Version 2026-03-04 v1.1 Release Notes According to PCN20251201, added notes about ESP32-C5HF4 pins in Figure 8-1 ESP32-C5-WROOM-1 Schematics and Figure 8-2 ESP32-C5-WROOM-1U Schematics 2026-01-05 v1.0 Official release; cleared all preliminary annotations • In Chapter 1.2 Series Comparison: – Updated ”Ordering Code” to ”Part Number” – Added information for ESP32-C5-WROOM-1-N32R8 and ESP32-C5- 2025-11-25 v0.8 WROOM-1U-N32R8 • In Chapter 4 Boot Configurations, removed content related to crystal frequency selection In Chapter 1.2 Series Comparison: 2025-09-11 v0.7 • Added Figure 1-1 ESP32-C5 Module Variant Nomenclature • Updated the ordering code and added the embedded chip for both ESP32-C5-WROOM-1 and ESP32-C5-WROOM-1U • In Chapter 2 Block Diagram, added a note about pin mapping between the chip and the in-package flash • In Chapter 10.2 Dimensions of External Antenna Connector, added the 2025-08-07 v0.6 external antenna information for certification • Added Sections 4.5 Chip Power-up and Reset, 6.5 Memory Specifications and Datasheet Versioning 2025-05-21 v0.5 Espressif Systems Preliminary release 61 Submit Documentation Feedback ESP32-C5-WROOM-1 & WROOM-1U Datasheet v1.1 Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2026 Espressif Systems (Shanghai) Co., Ltd. All rights reserved. www.espressif.com
ESP32-C5-WROOM-1-N4 价格&库存
很抱歉,暂时无法提供与“ESP32-C5-WROOM-1-N4”相匹配的价格&库存,您可以联系我们找货
ESP32-C5-WROOM-1-N4
    • 1+27.74520
    • 30+25.76340
    • 100+24.77250
    库存:1293
