山东晶导微电子有限公司
ES5AB THRU ES5JB
Jingdao Microelectronics
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V
PINNING
Forward Current – 5 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Simplified outline SMB and symbol
MECHANICAL DATA
• Case : SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight : 0.055g / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES5AB
ES5BB
ES5CB
ES5DB
ES5EB
ES5GB
ES5JB
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T c = 115 °C
I F(AV)
5
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
100
A
Maximum Forward Voltage at 5A
VF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance 2)
Operating and Storage Temperature Range
1.25
1.0
1.7
V
IR
5
100
μA
Cj
50
pF
t rr
35
ns
RθJA
RθJC
45
15
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.04
SMB-E-ES5AB~ES5JB-5A600V
Page 1 of 3
山东晶导微电子有限公司
ES5AB THRU ES5JB
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
6
5
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
4
3
2
1
Single phase half-wave 60 Hz
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
50
75
100
125
150
175
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =25°C
1.0
ES5AB~ES5DB
ES5EB/ES5GB
0.1
80
100
Fig.5 Typical Junction Capacitance
Fig.4 Typical Forward Characteristics
10
60
% of PIV.VOLTS
ES5JB
0.01
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.001
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.04
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
ES5AB THRU ES5JB
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.11
3.3
5.08
0.05
0.8
0.152
1.91
155
220
7.9
59
12
83
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.04
JD705049B5
Marking
Type number
Marking code
ES5AB
ES5A
ES5BB
ES5B
ES5CB
ES5C
ES5DB
ES5D
ES5EB
ES5E
ES5GB
ES5G
ES5JB
ES5J
Page 3 of 3
很抱歉,暂时无法提供与“ES5JB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.71610
- 100+0.42710
- 800+0.29900
- 3000+0.21360
- 6000+0.20300
- 30000+0.18790
- 国内价格
- 10+0.35805
- 100+0.27683
- 600+0.27268
- 1200+0.26450
- 3000+0.25260
- 国内价格
- 10+0.38830
- 100+0.29740
- 300+0.25520
- 3000+0.22640
- 6000+0.20420
- 9000+0.19330
- 国内价格
- 10+0.40014
- 100+0.32033
- 300+0.28048
- 3000+0.25056
- 6000+0.22659
- 9000+0.21460
- 国内价格
- 1+0.38500
- 200+0.24860
- 1500+0.21670
- 3000+0.19140
