AS5600-ASOM
AS5600-ASOM
    AMSOSRAM(艾迈斯半导体)
    SOIC-8
    12位可编程非接触式电位器
AS5600-ASOM 数据手册
Product Document Published by ams OSRAM Group AS5600 12-Bit Programmable Contactless Potentiometer General Description The AS5600 is an easy to program magnetic rotary position sensor with a high-resolution 12-bit analog or PWM output. This contactless system measures the absolute angle of a diametric magnetized on-axis magnet. This AS5600 is designed for contactless potentiometer applications and its robust design eliminates the influence of any homogenous external stray magnetic fields. The industry-standard I²C interface supports simple user programming of non-volatile parameters without requiring a dedicated programmer. By default the output represents a range from 0 to 360 degrees. It is also possible to define a smaller range to the output by programming a zero angle (start position) and a maximum angle (stop position). The AS5600 is also equipped with a smart low power mode feature to automatically reduce the power consumption. An input pin (DIR) selects the polarity of the output with regard to rotation direction. If DIR is connected to ground, the output value increases with clockwise rotation. If DIR is connected to VDD, the output value increases with counterclockwise rotation. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS5600, 12-bit Programmable Contactless Potentiometer are listed below: Figure 1: Added Value of Using AS5600 Benefits Features • Highest reliability and durability • Contactless angle measurement • Simple programming • Simple user-programmable start and stop positions over the I²C interface • Great flexibility on angular excursion • Maximum angle programmable from 18° up to 360° • High-resolution output signal • 12-bit DAC output resolution • Selectable output • Analog output ratiometric to VDD or PWM-encoded digital output ams Datasheet [v1-06] 2018-Jun-20 Page 1 Document Feedback AS5600 − General Description Benefits Features • Low-power consumption • Automatic entry into low-power mode • Easy setup • Automatic magnet detection • Small form factor • SOIC-8 package • Robust environmental tolerance • Wide temperature range: -40°C to 125°C Applications The AS5600 is ideally suited for contactless potentiometers, contactless knobs, pedals, RC servos and other angular position measurement solutions. Block Diagram The functional blocks of this device are shown below: Figure 2: Functional Blocks of AS5600 VDD3V3 SDA SCL DIR Register Setting VDD5V I²C LDO 3.3V PGO OTP Hall Sensors Analog Front-End AFE PWM 12-bit A/D ATAN (CORDIC) Digital Processing and Filtering Driver OUT 12-bit D/A AGC Magnetic Core AS5600 GND Page 2 Document Feedback ams Datasheet [v1-06] 2018-Jun-20 AS5600 − Pin Assignments Pin Assignments Figure 3: SOIC-8 Pin-Out 1 8 DIR VDD3V3 2 7 SCL OUT 3 6 SDA GND 4 5 PGO AS5600 VDD5V Figure 4: Pin Description Pin Number Name 1 VDD5V Supply Positive voltage supply in 5V mode (requires 100nF decoupling capacitor) 2 VDD3V3 Supply Positive voltage supply in 3.3V mode (requires an external 1-μF decoupling capacitor in 5V mode) 3 OUT Analog/digital output Analog/PWM output 4 GND Supply Ground 5 PGO Digital input Program option (internal pull-up, connected to GND = Programming Option B) 6 SDA Digital input/output I²C Data (consider external pull-up) 7 SCL Digital input I²C Clock (consider external pull-up) 8 DIR Digital input Direction polarity (GND = values increase clockwise, VDD = values increase counterclockwise) ams Datasheet [v1-06] 2018-Jun-20 Type Description Page 3 Document Feedback AS5600 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD5V DC Supply Voltage at VDD5V pin -0.3 6.1 V VDD3V3 DC Supply Voltage at VDD3V3 pin -0.3 4.0 V VIO DC Supply Voltage at all digital or analog pins -0.3 VDD+0.3 V ISCR Input current (latch-up immunity) -100 100 mA JESD78 Continuous Power Dissipation (TA = 70°C) PT Continuous power dissipation 50 mW Electrostatic Discharge ESDHBM Electrostatic discharge HBM ±1 kV MIL 883 E method 3015.7 Temperature Ranges and Storage Conditions TSTRG Storage temperature range TBODY Package body temperature RHNC Relative humidity (non-condensing) MSL Moisture sensitivity level Page 4 Document Feedback -55 125 5 3 °C 260 °C 85 % ICP/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is “Matte Tin” (100% Sn) ICP/JEDEC J-STD-033 ams Datasheet [v1-06] 2018-Jun-20 AS5600 − Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with minimum and maximum values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Operating Conditions Figure 6: System Electrical Characteristics and Temperature Range Symbol Parameter VDD5V Positive supply voltage in 5.0V mode VDD3V3 Positive supply voltage in 3.3V mode Conditions Min Typ Max Units 4.5 5.0 5.5 V 3.3V operation mode 3.0 3.3 3.6 V During OTP burn procedure (2) 3.25 3.3 3.35 V 5.0V operation mode During OTP burn procedure (2) IDD Supply current in NOM (1) PM = 00 Always on 6.5 mA lDD_LPM1 Supply current in LPM1 (1) PM = 01 Polling time = 5ms 3.4 mA lDD_ LPM2 Supply current in LPM2 (1) PM = 10 Polling time = 20ms 1.8 mA lDD_ LPM3 Supply current in LPM3 (1) PM = 11 Polling time = 100ms 1.5 mA Supply current per bit for burn procedure Initial peak, 1 μs 100 mA IDD_BURN Steady burning,
AS5600-ASOM 价格&库存
很抱歉,暂时无法提供与“AS5600-ASOM”相匹配的价格&库存,您可以联系我们找货
AS5600-ASOM
    库存:1000
    AS5600-ASOM
    • 1+7.74360
    • 10+6.90120
    • 30+6.10200
    • 100+5.50800
    • 500+4.40640
    • 1000+4.28760
    AS5600-ASOM
    • 1+5.75649
    • 30+5.55799
    • 100+5.16099
    • 500+4.76399
    • 1000+4.56549
