Datasheet V1.0a
TMR2901
Ultra High Sensitivity TMR linear sensor
General Description
The TMR2901 linear sensor utilizes a unique push-pull Wheatstone bridge composed of four TMR sensor elements. The
TMR2901 is available in a 3 mm X 3 mm X 0.75 mm DFN8 package and 6mm X 5mm X 1.5mm SOP8 package.
Features and Benefits
Tunneling Magneto resistance (TMR) Technology
High Sensitivity (25mV/V/Oe)
Very Low Noise Spectral Density (2nT/√Hz @1Hz)
Low Power Consumption
Excellent Thermal Stability
Very Low Hysteresis
Compatible with wide Range of Supply Voltages
NO need for set/reset calibration
Applications
Weak Magnetic Field Sensing
Current Sensors
TMR2901
Position and Displacement Sensing
Transfer Curve
The following figure shows the response of the TMR2901 to an applied magnetic field in the range of ±5 Oe and ±30 Oe when the
TMR2901 is biased at 1V.
1/5
Datasheet V1.0a
Pin Configuration
(Arrow indicates direction of applied field that generates a positive output voltage.)
(SOP8 top view)
(DFN bottom view)
Pin No.
Pin Name
Pin Function
1,2,7,8
N/A
Not Connected
3
GND
Ground
4
V-
Analog Differential Output 2
5
V+
Analog Differential Output 1
6
Vcc
Supply Voltage
Absolute Maximum Ratings
Parameter
Symbol
Limit
Unit
Supply Voltage
VCC
7
V
Reverse Supply Voltage
VRCC
7
V
Max Exposed Field
HE
4000
Oe
ESD Voltage
VESD
4000
V
Operating Temperature
TA
-40~125
°C
Storage Temperature
Tstg
-50 ~150
°C
(1)
Specification (VCC=1.0V, TA=25°C,Differential Output)
Parameter
Symbol
Conditions
Supply Voltage
VCC
Operating
Supply Current
ICC
Resistance
R
Sensitivity
SEN
Saturation Field
Hsat
Non-Linearity
NONL
Offset Voltage
Voffset
Hysteresis
Hys
Fit @±1 Oe
TCR
H = 0 Oe
Temperature Coefficient of
Resistance
Sensitivity
Self Noise
Output Open
Fit @±1 Oe
Typ
Max
Unit
1
7
V
0.1
(2)
45,9
10
KOhm
27
mV/V/Oe
±20
Oe
0.3
%FS
-10
@1Hz
Notes:
2/5
mA
7
Fit @±1 Oe
TCS
Ni
Min
10
mV/V
0.2
Oe
-500
PPM/°C
-1100
PPM/°C
2
nT/√Hz
Datasheet V1.0a
(1) 1 Oe (Oersted) = 1 Gauss in air = 0.1 millitesla = 79.8 A/m.
(2) Custom resistance may be available upon request.
Package Information
SOP8 package drawing:
DFN package drawing:
3/5
Datasheet V1.0a
TMR Sensor Position
Top view and side view (unit:mm)
4/5
Datasheet V1.0a
MultiDimension Technology Co., Ltd.
Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China
Web: www.dowaytech.com/en
Email: info@dowaytech.com
The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable.
Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the
right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not
assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in
appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to
fully indemnify MultiDimension for any damages resulting from such applications.
5/5
很抱歉,暂时无法提供与“TMR2901P”相匹配的价格&库存,您可以联系我们找货
