AS5510-DSOM
AS5510-DSOM
    AMSOSRAM(艾迈斯半导体)
    SOIC-8
    霍尔效应 传感器 单路 轴 8-SOIC
AS5510-DSOM 数据手册
Product Document Published by ams OSRAM Group AS5510 Linear Hall Sensor with I²C Output General Description The AS5510 is a Linear Hall Sensor with 10 bit resolution and I²C interface. It can measure absolute position of lateral movement of a simple 2-pole magnet. Depending on the magnet size, a lateral stroke of 0.5~2mm can be measured with air gaps around 1.0mm. To conserve power, the AS5510 may be switched to a power down state when it is not used. It is available in a WLCSP and SOIC8 package and qualified for an ambient temperature range from -30°C to 85°C. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS5510, Linear Hall sensor with I²C output are listed below: Figure 1: Added Value of Using AS5510 Benefits Features Highest reliability and durability Contactless position measurement Ideal for battery powered devices Power down mode Easy to use Simple configuration over the I2C interface High-resolution output 10bit resolution Operates in wide magnetic range Programmable sensitivity Smallest form factor Available in two different packages: WLCSP & SOIC8 Applications The AS5510 is ideal for: • Position sensing • Servo drive feedback • Camera lens control • Closed loop position control. ams Datasheet [v1-07] 2015-Feb-27 Page 1 Document Feedback AS5510 − General Description Block Diagram The functional blocks of this device for reference are shown below: Figure 2: AS5510 Block Diagram Front End Offset Compensation Buffer & Filter DSP I2C Factory Gain Trim Test Page 2 Document Feedback Power down Biasing & Reference ADC 10 bit SDA SCL ADR VDD VSS ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Pin Assignment Pin Assignment The AS5510 pin assignments are described below. Figure 3: Pin Diagram for WLCSP Package Pin Configuration of AS5510 in WLCSP Package(Top view): The AS5510 is available in a 6-pin Chip Scale Package with a ball pitch of 400μm. Pin A1 indicator 1 2 3 A VSS ADR VDD B SDA SCL Test Figure 4: Pin Diagram for SOIC8 Package ams Datasheet [v1-07] 2015-Feb-27 NC 1 VSS 2 ADR 3 VDD 4 AS5510 Pin Configuration of AS5510 in SOIC8 Package(Top view): Package drawing not to scale. 8 NC 7 SCL 6 SDA 5 TEST Page 3 Document Feedback AS5510 − Pin Assignment Figure 5: Pin Description Pin Name Pin Number Pin Type Description WLCSP SOIC8 NC - 1 - VSS A1 2 Supply pin ADR A2 3 Digital input VDD A3 4 Supply pin Test B3 5 Digital input/output Test pin, must be connected to VSS during operation SDA B1 6 Digital input / Digital output open drain I²C data I/O, 20mA driving capability SCL B2 7 Digital input NC - 8 - Page 4 Document Feedback Not Connected Negative supply pin, analog and digital ground I²C address selection pin Connect to either VSS (56h) or VDD (57h) Positive supply pin. A capacitor of 100nF should be connected to this pin and VSS I²C clock Not Connected ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute Maximum Ratings Figure 6: Absolute Maximum Ratings Parameter Min Max Units DC supply voltage at pin VDD -0.3 5 V Input pin voltage -0.3 VDD+0.3 V Input current (latchup immunity) -100 100 mA Norm: JEDEC 78 kV Norm: MIL 883 E method 3015 Electrostatic discharge Storage temperature ±2 -55 125 Body temperature (Lead-free package) for WLCSP TBody Relative Humidity non-condensing °C 260 5 85 Moisture Sensitivity Level for WLCSP 1 Moisture Sensitivity Level for SOIC8 3 ams Datasheet [v1-07] 2015-Feb-27 °C 260 Body temperature (Lead-free package) for SOIC8 Comments The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/ JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. % Represents a max. floor life time of unlimited Page 5 Document Feedback AS5510 − Electrical Characteristics Electrical Characteristics Figure 7: Operating Conditions Symbol Parameter VDD Supply voltage at pin VDD Isupp Supply current Conditions Min Typ Max Units 2.5 3 3.6 V 3.5 mA 25 μA @ 25°C ambient temperature Ipd Tamb Power down current Ambient temperature -30 85 °C DC Characteristics for Digital Inputs and Outputs CMOS Input: ADR Operating conditions: Tamb = -30°C to 85°C, VDD = 2.5V to 3.6V (3V operation) unless otherwise noted. Figure 8: Electrical Characteristics ADR Input Symbol Parameter Min Typ Max Units VIH High level input voltage 0.7 * VDD VDD V VIL Low level input voltage 0 0.3 * VDD V Input leakage current -1 1 μA ILEAK Page 6 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Electrical Characteristics CMOS I²C: SDA, SCL Operating conditions: Tamb = -30°C to 85°C, VDD = 2.5V to 3.6V (3V operation) unless otherwise noted. Figure 9: Electrical Characteristics I²C Symbol Parameter Conditions Min Max Units VIL LOW-level input voltage -0.5 0.3 * VDD V VIH HIGH-level input voltage 0.7 * VDD VDD +0.5V V Vhys Hysteresis of Schmitt Trigger inputs VDD > 2.5V VOL LOW-level output voltage (open-drain or open-collector) at 3mA sink current VDD > 2.5V IOL LOW-level output current VOL = 0.4V tof Output fall time from VIHmax to VILmax 120 (1) ns tSP Pulse width of spikes that must be suppressed by the input filter 50 (2) ns +10 (3) μA 0.05 * VDD V 0.4V 20 V mA Ii Input current at each I/O pin CB Total capacitive load for each bus line 550 pF CI/O I/O capacitance (SDA, SCL) (4) 10 pF -10 Note(s) and/or Footnote(s): 1. In Fast-mode Plus, fall time is specified the same for both output stage and bus timing. If series resistors are used this has to be considered for bus timing. 2. Input filters on the SDA and SCL inputs suppress noise spikes of less than 50 ns. 3. I/O pins of Fast-mode and Fast-mode plus devices must not obstruct the SDA and SCL lines if VDD is switched OFF. 4. Special purpose devices such as multiplexers and switches may exceed this capacitance due to the fact that they connect multiple paths together. ams Datasheet [v1-07] 2015-Feb-27 Page 7 Document Feedback AS5510 − Electrical Characteristics Electrical and Magnetic Specifications Figure 10: Electrical and Magnetic Specifications Symbol RES Parameter Conditions Resolution Default Setting Bin Offsetinp Magnetic Input Range Configurable via I²C or factory trimming option Typ bit ±50 mT ±25 mT ±12.5 mT ±18.75 mT Linearity error (2) tPwrUp tPwrOn This time is needed for the first power-up of the device until the offset compensation is finished; Includes readout of the PPROM fuses Power-on time (4) Time after switching from power-down mode into active mode until the offset compensation is finished Page 8 Document Feedback Units 10 Input related offset (1) Initial Power up time from cold start (3) Max 250 0.45 mT 3 % 1.5 ms μs ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Electrical Characteristics Symbol Parameter Conditions Typ Max Units 50 KHz 20 μs 0.8 mTpp 12.5 KHz 50 μs 0.5 mTpp Fast Mode (Default setting) fS ADC sampling frequency After offset compensation finished tdelay System propagation delay Noiseinp Input related noise (5) Equivalent to 8 * rms Slow Mode (I²C command option) fS ADC sampling frequency After offset compensation finished tdelay System propagation delay Noiseinp Input related noise (5) Equivalent to 8 * rms Note(s) and/or Footnote(s): 1. Offset inp = 0.35mT residual offset + 0.1mT earth magnetic field.    adc – out ( maxB ) – adc – out ( zeroB )  lin error 2. Linearity error = = 1 –  -------------------------------------------------------------------------------------------------------------- × 100 –  2 ×  adc out  maxB --------------- – adc – out ( zeroB )  –    2  3. This time is needed for the first power-up of the device until the offset compensation is finished; Includes readout of the PPROM fuses; It depends on the sensitivity setting. 4. Time after switching from power-down mode into active mode until the offset compensation is finished. 5. Input related Noise (Noise Inp) is the repeatability of the measurement. ams Datasheet [v1-07] 2015-Feb-27 Page 9 Document Feedback AS5510 − Detailed Description Detailed Description Figure 11: Linear Position Sensor AS5510 + Magnet magnet N S magnet N S AS5510 WLCSP AS5510 SOIC8 PCB PCB Linear Position Sensor AS5510 + Magnet: The AS5510 can measure the absolute position of lateral movement in combination with a diametrical two pole magnet. Typical Application The typical application circuit of AS5510 is shown below: Figure 12: Typical Application Circuit VDD = 2.5 ~ 3.6V VDD AS5510 #1 VDD 2.7 ~ 10k VSS 100nF SCL Microcontroller SCL SDA SDA I²C interface I²C ADDR = 56h ADR Test VDD VDD VSS AS5510 #2 100nF SCL SDA I²C ADDR = 57h ADR VDD Test Page 10 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Detailed Description I²C Interface The AS5510 includes an I²C slave according to the NXP specification UM10204. • 7-bit slave address 101011x, the last address bit x is set by the ADR pin (0 or 1) • Random/Sequential Read • Byte/Page Write • Fast-mode plus with 20mA SDA drive strength • Internal hold time of 120ns for SDA signal is included (Start/Stop detection) Not implemented: • 10-bit Slave Address • Clock Stretching • General Call Address • General Call – Software Reset • Read of Device ID The communication from the AS5510 includes: • Reading the magnetic field strength in 10-bit data • Reading the status bits Note(s): The I²C address of the chip is selected by hardware (pin ADR). Depending on the state of this pin, the I²C address is either: • Pin ADR = LOW  I²C address = 1010110b(56h) • Pin ADR = HIGH  I²C address = 1010111b(57h) ams Datasheet [v1-07] 2015-Feb-27 Page 11 Document Feedback AS5510 − Detailed Description I²C Interface Data Operating conditions: Tamb = -30 to 85°C, VDD=2.5 to 3.6V (3V operation) unless otherwise noted. Figure 13: I²C Timings Symbol Parameter Min Typ Max Units 1 MHz fSCLK SCL clock frequency tBUF Bus free time; time between STOP and START condition 0.5 μs Hold time; (repeated) START condition (1) 0.26 μs tLOW LOW period of SCL clock 0.5 μs tHIGH HIGH period of SCL clock 0.26 μs tSU.STA Setup time for a repeated START condition 0.26 μs tHD.DAT Data hold time (2) tSU.DAT Data setup time(3) tHD.STA 0.45 50 μs ns tR Rise time of SDA and SCL signals 120 ns tF Fall time of SDA and SCL signals (4) 120 ns tSU.STO Setup time for STOP condition 0.26 μs Note(s) and/or Footnote(s): 1. After this time the first clock is generated. 2. A device must internally provide a hold time of at least 120ns (Fast-mode Plus) for the SDA signal (referred to the VIHmin of the SCL) to bridge the undefined region of the falling edge of SCL. 3. A fast-mode device can be used in standard-mode system, but the requirement t SU.DAT = 250ns must then be met. This is automatically the case if the device does not stretch the LOW period of the SCL signal. If such a device does stretch the LOW period of the SCL signal, it must output the next data bit to the SDA line t Rmax + TSU.DAT = 1000 + 250 = 1250ns before the SCL line is released. 4. In Fast-mode Plus, fall time is specified the same for both output stage and bus timing. If series resistors are used this has to be considered for bus timing. Page 12 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Detailed Description Figure 14: I²C Timing Diagram SDA tbuf tLOW tR tHD.STA tF SCL tSU.DAT tHD.STA Stop Start tHD.DAT tHIGH tSU.STA tSU.STO Repeated Start I²C Modes The AS5510 supports the I²C bus protocol. A device that sends data onto the bus is defined as a transmitter and a device receiving data as a receiver. The device that controls the message is called a master. The devices that are controlled by the master are referred to as slaves. A master device that generates the serial clock (SCL), controls the bus access and generates the START and STOP conditions must control the bus. The AS5510 operates as a slave on the I²C bus. Within the bus specifications a standard mode (100 kHz maximum clock rate) a fast mode (400 kHz maximum clock rate) and fast mode plus (1MHz maximum clock rate) are defined. The AS5510 works in all three modes. Connections to the bus are made through the open-drain I/O lines SDA and the input SCL. Clock stretching is not included. The following bus protocol has been defined: • Data transfer may be initiated only when the bus is not busy. • During data transfer, the data line must remain stable whenever the clock line is HIGH. Changes in the data line while the clock line is HIGH are interpreted as start or stop signals. Accordingly, the following bus conditions have been defined: Bus Not Busy Both data and clock lines remain HIGH. Start Data Transfer A change in the state of the data line, from HIGH to LOW, while the clock is HIGH, defines a START condition. Stop Data Transfer A change in the state of the data line, from LOW to HIGH, while the clock line is HIGH, defines the STOP condition. ams Datasheet [v1-07] 2015-Feb-27 Page 13 Document Feedback AS5510 − Detailed Description Data Valid The state of the data line represents valid data when, after a START condition, the data line is stable for the duration of the HIGH period of the clock signal. The data on the line must be changed during the LOW period of the clock signal. There is one clock pulse per bit of data. Each data transfer is initiated with a START condition and terminated with a STOP condition. The number of data bytes transferred between START and STOP conditions are not limited, and are determined by the master device. The information is transferred byte-wise and each receiver acknowledges with a ninth bit. Acknowledge Each receiving device, when addressed, is obliged to generate an acknowledge bit after the reception of each byte. The master device must generate an extra clock pulse that is associated with this acknowledge bit. A device that acknowledges must pull down the SDA line during the acknowledge clock pulse in such a way that the SDA line is stable LOW during the HIGH period of the acknowledge-related clock pulse. Of course, setup and hold times must be taken into account. A master must signal an end of READ access to the slave by not generating an acknowledge bit on the last byte that has been clocked out of the slave. In this case, the slave must leave the data line HIGH to enable the master to generate the STOP condition. Figure 15: Data Read (Write Pointer, Then Read) - Slave Receive and Transmit Slave Address SDA Repeated if more Bytes are transferred MSB SCL 1 Start Condition 2 ... 6 LSB R/W ACK 7 8 9 ACK 1 ... 7 8 9 Stop Condition or Repeated Start Condition Depending upon the state of the R/W bit, two types of data transfer are possible: Data transfer from a Master Transmitter to a Slave Receiver. The first byte transmitted by the master is the slave address, followed by R/W = 0. Next follows a number of data bytes. The slave returns an acknowledge bit after each received byte. If the slave does not understand the command or data it sends a “not acknowledge”. Data is transferred with the most significant bit (MSB) first. Page 14 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Detailed Description Data transfer from a Slave Transmitter to a Master Receiver. The master transmits the first byte (the slave address). The slave then returns an acknowledge bit, followed by the slave transmitting a number of data bytes. The master returns an acknowledge bit after all received bytes other than the last byte. At the end of the last received byte, a “not acknowledge” is returned. The master device generates all of the serial clock pulses and the START and STOP conditions. A transfer is ended with a STOP condition or with a repeated START condition. Since a repeated START condition is also the beginning of the next serial transfer, the bus is not released. Data is transferred with the most significant bit (MSB) first. The AS5510 can operate in the following two modes: Slave Receiver Mode (Write Mode) Serial data and clock are received through SDA and SCL. Each byte is followed by an acknowledge bit (or by a not acknowledge depending on the address-pointer pointing to a valid position). START and STOP conditions are recognized as the beginning and end of a serial transfer. Address recognition is performed by hardware after reception of the slave address and direction bit (see Figure 16). The slave address byte is the first byte received after the START condition. The slave address byte contains the 7-bit AS5510 address. The 7-bit slave address is followed by the direction bit (R/W), which, for a write, is 0. After receiving and decoding the slave address byte the device outputs an acknowledge on the SDA. After the AS5510 acknowledges the slave address + write bit, the master transmits a register address to the AS5510. This sets the address pointer on the AS5510. If the address is a valid readable address the AS5510 answers by sending an acknowledge. If the address-pointer points to an invalid position a “not acknowledge” is sent. The master may then transmit zero or more bytes of data. In case of the address pointer pointing to an invalid address the received data are not stored. The address pointer will increment after each byte transferred independent from the address being valid. If the address-pointer reaches a valid position again, the AS5510 answers with an acknowledge and stores the data. The master generates a STOP condition to terminate the data write. ams Datasheet [v1-07] 2015-Feb-27 Page 15 Document Feedback AS5510 − Detailed Description S Figure 16: Data Write - Slave Receiver Mode 1010110 0 S – Start A – Acknowledge (ACK) P – Stop Page 16 Document Feedback A XXXXXXXX A XXXXXXXX A XXXXXXXX A XXXXXXXX NA P Data transferred: X+1 Bytes + Acknowledge ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Detailed Description Slave Transmitter Mode (Read Mode) The first byte is received and handled as in the slave receiver mode. However, in this mode, the direction bit indicates that the transfer direction is reversed. Serial data is transmitted on SDA by the AS5510 while the serial clock is input on SCL. START and STOP conditions are recognized as the beginning and end of a serial transfer (Figure 17 and Figure 18). The slave address byte is the first byte received after the master generates a START condition. The slave address byte contains the 7-bit AS5510 address. The 7-bit slave address is followed by the direction bit (R/W), which, for a read, is 1. After receiving and decoding the slave address byte the device outputs an acknowledge on the SDA line. The AS5510 then begins to transmit data starting with the register address pointed to by the register pointer. If the register pointer is not written to before the initiation of a read mode the first address that is read is the last one stored in the register pointer. The AS5510 must receive a “not acknowledge” to end a read. S Figure 17: Data Read (from Current Pointer Location) - Slave Transmitter Mode 1010110 1 A XXXXXXXX S – Start A – Acknowledge (ACK) NA – Not Acknowledge (NACK) P – Stop A XXXXXXXX A XXXXXXXX A XXXXXXXX NA P Data transferred: X+1 Bytes + Acknowledge Note: Last data byte is followed by NACK 1010110 0 A XXXXXXXX S – Start SA – Repeated Start A – Acknowledge (ACK) NA – Not Acknowledge (NACK) P – Stop ams Datasheet [v1-07] 2015-Feb-27 A Sr S Figure 18: Data Read (Write Pointer, Then Read) - Slave Receive and Transmit 1010110 1 A XXXXXXXX A XXXXXXXX A XXXXXXXX NA P Data transferred : X+1 Bytes + Acknowledge Note: Last data byte is followed by NACK Page 17 Document Feedback AS5510 − Detailed Description Automatic Increment of Address Pointer The AS5510 slave automatically increments the address pointer after each byte transferred. The increase of the address pointer is independent from the address being valid or not. Invalid Addresses If the user sets the address pointer to an invalid address, the address byte is not acknowledged. Nevertheless a read or write cycle is possible. The address pointer is increased after each byte. Reading When reading from a wrong address, the AS5510 slave returns all zero. The address pointer is increased after each byte. Sequential read over the whole address range is possible including address overflow. Write A write to a wrong address is not acknowledged by the AS5510 slave, although the address pointer is increased. When the address pointer points to a valid address again, a successful write accessed is acknowledged. Page write over the whole address range is possible including address overflow. SDA, SCL Input Filters Input filters for SDA and SCL inputs are included to suppress noise spikes of less than 50ns. Furthermore the SDA line is delayed by 120ns to provide an internal hold time for Start/Stop detection to bridge the undefined region of the falling edge of SCL. The delay needs to be smaller than tHD.STA 260ns. For Standard-mode and Fast-mode an internal hold time of 300ns is required, which is not covered by the AS5510 slave. Page 18 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Register Description Register Description Figure 19: Register Map (1) Bit Register Address Access Type 7 6 5 4 3 2 1 0 D7 D6 D5 D4 D3 D2 D1 D0 R OCF Parity (even) D9 D8 R Fast(0) Slow mode (1) Polarity(0) PD(0) R/W Offs2 Offs1 Offs0 R/W 04h Offs9 Offs8 R/W 0Bh Sens 1 Sens 0 R/W 00h 01h 02h 03h Offs7 Offs6 Offs5 Offs4 Offs3 Note(s) and/or Footnote(s): 1. Blank or not listed fields may contain factory settings. To change a configuration, read out the register, modify only the desired bits and write the new configuration. ams Datasheet [v1-07] 2015-Feb-27 Page 19 Document Feedback AS5510 − Register Description Figure 20: Register Description Register Address Name Description 00h, 01h D9 to D0 10 Bit ADC output value that corresponds to the magnetic field input 01h Parity 01h OCF Offset compensation loop status 0 = Offset compensation loop in use 1 = Offset compensation loop has finished 02h PD Power down mode 0 = Normal operation (Default) 1 = Power Down mode. 02h Polarity Even parity bit calculated from D9 to D0 Output signal polarity 0 = Normal polarity (Default) 1 = Reversed polarity (reversed magnet) 0 = Fast mode (Default) 1 = Slow mode. Enables averaging of the output values (reduced noise, better repeatability slower sampling frequency. See Electrical and Magnetic Specifications 02h Fast / Slow mode 03h, 04h Offs9 to Offs0 Contains the offset compensation value. For read access only. Don't modify the register values. Sensitivity Sensitivity setting 0h = Input range ± 50mT Sensitivity = 97.66μT/LSB (Default) 1h = Input range ± 25mT Sensitivity = 48.83μT/LSB 2h = Input range ± 12.5mT Sensitivity = 24.41μT/LSB 3h = Input range ± 18.75mT Sensitivity = 36.62μT/LSB 0Bh Page 20 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Package Drawings & Markings Package Drawings & Markings WLCSP Package The WLCSP package drawings and markings are shown below: Figure 21: Package Dimensions (WLCSP) Top View Device number Side View Bottom View Green RoHS Note(s) and/or Footnote(s): 1. ccc Coplanarity 2. All dimensions in μm ams Datasheet [v1-07] 2015-Feb-27 Page 21 Document Feedback AS5510 − Package Drawings & Mark ings Figure 22: Recommended Footprint Package Dimensions X x0 x1 x1 x0 y0 D y1 y0 Y Symbol Typ Unit X 1460 μm x0 330 μm x1 400 μm Y 1100 μm y0 350 μm y1 400 μm D 270 μm Figure 23: Package Marking (WLCSP) Figure 24: Package Code XXXX XXXX Tracecode Page 22 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Package Drawings & Markings SOIC8 Package The SOIC8 package drawings and markings are shown below: Figure 25: Package Dimensions SOIC8 Symbol Min Nom Max A - - 1.75 A1 0.10 - 0.25 A2 1.25 - - b 0.31 - 0.51 c 0.17 - 0.25 D - 4.90 BSC - E - 6.00 BSC - E1 - 3.90 BSC - e - 1.27 BSC - L 0.40 - 1.27 L1 - 1.04 REF - L2 - 0.25 BSC - R 0.07 - - R1 0.07 - - h 0.25 - 0.50 Θ 0º - 8º Θ1 5º - 15º Θ2 0º - - aaa - 0.10 - bbb - 0.20 - ccc - 0.10 - ddd - 0.25 - eee - 0.10 - fff - 0.15 - ggg - 0.15 - N Green ams Datasheet [v1-07] 2015-Feb-27 8 RoHS Page 23 Document Feedback AS5510 − Package Drawings & Mark ings Figure 26: Package Marking (SOIC8) Figure 27: Package Code XXX@ Page 24 Document Feedback XXX @ Tracecode Sublot Identifier ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Ordering & Contact Information Ordering & Contact Information The devices are available as the standard products shown in the figure below. Figure 28: Ordering Information Ordering Code Package Marking Delivery Form Delivery Quantity AS5510-DWLT 6pin WL-CSP 1.4x1.1mm AS5510 Tape & Reel 12.000pcs AS5510-DWLM 6pin WL-CSP 1.4x1.1mm AS5510 Mini Reel 1000pcs AS5510-DSOT 8pin SOIC AS5510 Tape & Reel 2.500pcs AS5510-DSOM 8pin SOIC AS5510 Mini Reel 500pcs D → Temperature Range: -30°C to 85°C WL → Package: WL-CSP Wafer Level - Chip Scale Package SO → Package: SOIC 8 T → Delivery Form: Tape & Reel M → Delivery Form: Mini Reel Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v1-07] 2015-Feb-27 Page 25 Document Feedback AS5510 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 26 Document Feedback ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing inits General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v1-07] 2015-Feb-27 Page 27 Document Feedback AS5510 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 28 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v1-07] 2015-Feb-27 AS5510 − Revision Information Revision Information Changes from 1-06 (2014-Oct-30) to current revision 1-07 (2015-Feb-27) Page Updated Figure 19 19 Updated Figure 20 20 Note(s) and/or Footnote(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. ams Datasheet [v1-07] 2015-Feb-27 Page 29 Document Feedback AS5510 − Content Guide Content Guide 1 1 1 2 General Description Key Benefits & Features Applications Block Diagram 3 5 Pin Assignment Absolute Maximum Ratings 6 6 6 7 8 Electrical Characteristics DC Characteristics for Digital Inputs and Outputs CMOS Input: ADR CMOS I²C: SDA, SCL Electrical and Magnetic Specifications 10 10 11 12 13 13 13 13 13 14 14 15 16 17 17 17 17 17 Detailed Description Typical Application I²C Interface I²C Interface Data I²C Modes Bus Not Busy Start Data Transfer Stop Data Transfer Data Valid Acknowledge Data transfer from a Master Transmitter to a Slave Receiver. Data transfer from a Slave Transmitter to a Master Receiver. Slave Receiver Mode (Write Mode) Slave Transmitter Mode (Read Mode) Automatic increment of Address Pointer Invalid Addresses Reading Write SDA, SCL Input Filters 18 Register Description 20 20 22 Package Drawings & Markings WLCSP Package SOIC8 Package 24 25 26 27 28 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information 14 Page 30 Document Feedback ams Datasheet [v1-07] 2015-Feb-27
AS5510-DSOM 价格&库存
很抱歉,暂时无法提供与“AS5510-DSOM”相匹配的价格&库存,您可以联系我们找货
AS5510-DSOM
  • 1+16.887841+2.16605
  • 5+14.947725+1.91721
  • 10+14.2482510+1.82749
  • 25+13.4011825+1.71885
  • 50+12.8247150+1.64491
  • 100+12.29572100+1.57706
库存:997
AS5510-DSOM
  • 500+11.23370500+1.44085
  • 1000+10.838421000+1.39015
  • 1500+10.622651500+1.36247
  • 2500+10.365972500+1.32955
  • 3500+10.205633500+1.30898
  • 5000+10.042795000+1.28810
库存:997
AS5510-DSOM
    • 1000+8.193471000+1.05090
    库存:1000
