AS5116-HSOM
AS5116-HSOM
    AMSOSRAM(艾迈斯半导体)
    SOIC-8
    磁性 霍尔效应 磁体 模拟 鸥翼 8-SOIC(0.154",3.90mm 宽)
AS5116-HSOM 数据手册
Product Document Published by ams OSRAM Group Datasheet DS000686 AS5116 On-Axis Magnetic Position Sensor with Analog Sine-Cosine Outputs v4-00 • 2022-Feb-18 Document Feedback AS5116 Content Guide Content Guide 1 General Description ...................... 3 8.1 Safety Manual ............................................. 21 1.1 1.2 1.3 Key Benefits & Features............................... 3 Applications .................................................. 3 Block Diagram .............................................. 4 9 Application Information............... 22 9.1 9.2 Differential Mode ........................................ 22 Single Ended Mode .................................... 23 2 Ordering Information .................... 5 10 Configuration and Programming 26 3 Pin Assignment ............................. 6 11 Preconfigured Versions .............. 27 3.1 3.2 Pin Diagram AS5116 .................................... 6 Pin Description AS5116 ............................... 6 11.1 11.2 AS5116A..................................................... 27 AS5116B..................................................... 28 4 Absolute Maximum Ratings ......... 7 12 Package Drawings & Markings ... 30 5 Electrical Characteristics.............. 8 13 Mechanical Data ........................... 32 6 Functional Description................ 11 14 Revision Information ................... 33 6.1 6.2 6.3 IC Power Management ............................... 11 Gain Configuration ..................................... 12 Behavior of Sensor Outputs ....................... 13 15 Legal Information ......................... 34 7 Digital Interface – UART.............. 15 7.1 Register Description ................................... 17 8 Functional Safety ........................ 21 Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 2 Document Feedback 1 AS5116 General Description General Description The AS5116 is a contactless magnetic position sensor for accurate angular measurement over a full mechanical turn of 360°. Based on the Hall sensor technology, this device has a robust architecture that measures the orthogonal component of the flux density (Bz), over a full-turn rotation. To measure the angle, only a simple two-pole magnet rotating over the center of the package is required. The magnet can be placed above or below the device. The absolute angle measurement provides an instant indication of the magnet’s angular position. The angle information is provided by means of buffered differential sine and cosine voltages. The AS5116 operates at a supply voltage of 5 V or 3.3 V. 1.1 Key Benefits & Features The benefits and features of AS5116, On-Axis Magnetic Position Sensor with Analog Sine-Cosine Outputs, are listed below: Figure 1: Added Value of Using AS5116 1.2 Benefits Features Highest reliability and durability Contactless angle measurement Accurate angle measurement Low output noise Low system costs – no shielding required Low inherent INL Enabler for safety critical applications Magnetic stray field immunity overachieves ISO 11452-8 High precision analog output Developed according to ISO26262 Small form factor Fully differential buffered sine and cosine output signals Fully automotive qualified AEC – Q100, Grade 0 Applications ● ● ● ● Rotor angle sensing of electric commutated motors Electric power steering systems Electric pumps Actuators in transmission systems Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 3 Document Feedback ● ● 1.3 AS5116 General Description Starter/Generator systems Other 360° angle measurement solutions Block Diagram Figure 2 shows the block diagram of the AS5116 sensor. Figure 2: Functional Blocks of AS5116 VDD3 AS5116 VDD5 Timing Generator Oscillator LDO POR Biasing UART DIAG OTP Hall Biasing Digital Part SINP DMOD Hall FE PGA DRV PGA DRV SIN Channel SINN CM_SIN COS Channel COSP DMOD Hall sensor array COSN CM_COS VSS Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 4 Document Feedback 2 AS5116 Ordering Information Ordering Information Ordering Code Package Marking Delivery Form Delivery Quantity AS5116-HSOT SOIC8 AS5116 13” Tape & Reel 2500 pcs/reel AS5116-HSOM SOIC8 AS5116 7” Tape & Reel 500 pcs/reel AS5116A-HSOT SOIC8 AS5116A 13” Tape & Reel 2500 pcs/reel AS5116A-HSOM SOIC8 AS5116A 7” Tape & Reel 500 pcs/reel AS5116B-HSOT SOIC8 AS5116B 13” Tape & Reel 2500 pcs/reel AS5116B-HSOM SOIC8 AS5116B 7” Tape & Reel 500 pcs/reel Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 5 Document Feedback 3 Pin Assignment 3.1 Pin Diagram AS5116 AS5116 Pin Assignment Figure 3: Pin Diagram of AS5116 in SOIC8 Package 3.2 1 8 COSP SINN CM_SIN 2 7 COSN CM_COS VSS 3 6 UART DIAG VDD5 4 5 VDD3 AS5116 SINP Pin Description AS5116 Figure 4: Pin Description of AS5116 in SOIC8 Package Pin Number Pin Name Pin Type Description 1 SINP Analog Out Buffered sine channel, positive output 2 SINN CM_SIN Analog Out Buffered sine cannel, inverted output (default). Common mode level for sine channel (optional). 3 VSS Supply Common ground 4 VDD5 Supply Supply voltage 5 VDD3 Analog Out On chip low-dropout regulator output voltage. Requires an external 1 µF decoupling capacitor UART DIAG Digital I/O Digital Out 7 COSN CM_COS Analog Out Buffered cosine channel, inverted output (default). Common mode level for cosine channel (optional). 8 COSP Analog Out Buffered cosine channel, positive output 6 Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 Communication Pin for OTP programming (default). Diagnostic output for on-chip diagnostic functions. This pin always has to be tied to VDD5 with the pull up resistor Rpu. 34 │ 6 Document Feedback 4 AS5116 Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings of AS5116 Symbol Parameter Min Max Unit Comments Electrical Parameters VDD5 DC Voltage at VDD5 pin -0.3 7 V VREG DC Voltage at VDD3 pin -0.3 5 V VSS DC Voltage at VSS pin -0.3 0.3 V VIN Input Pin Voltage to Ground -0.3 VDD5 + 0.3 V ISCR Input Current (latch-up immunity) ± 100 mA AEC-Q100-004 Continuous Power Dissipation PT Total Power Dissipation 150 mW Electrostatic Discharge ESDHBM Electrostatic Discharge HBM ± 2000 V AEC-Q100-002 ESDCDM Electrostatic Discharge CDM ± 500 V AEC-Q100-011 Temperature Ranges and Storage Conditions TA Operating Ambient Temperature TJ Operating Junction Temperature TA_PROG Ambient Temperature during OTP Programming TSTRG Storage Temperature Range TBODY Package Body Temperature RHNC Relative Humidity (non-condensing) MSL Moisture Sensitivity Level -40 150 °C 165 °C 0 45 °C - 55 150 °C 260 °C 85 % 5 IPC/JEDEC J-STD-020 (1) Represents a maximum floor lifetime of 168 h 3 Temperature Soldering TPEAK Peak Temperature tWELL Well Time above 217 °C (1) 30 260 °C 45 s IPC/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is “Matte Tin” (100 % Sn) Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 7 Document Feedback 5 AS5116 Electrical Characteristics Electrical Characteristics All limits are guaranteed over the operating temperature range (-40°C to 150°C) and lifetime, unless otherwise noticed. The parameters with Min and Max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 6: Electrical Characteristics of AS5116 Symbol Parameter Conditions Min Typ Max Unit VDD5 Positive Supply Voltage 5.0 V operation mode 4.5 5.0 5.5 V VDD3 3.3 V operation mode, LDO shorted Supply voltage required for programming in 3V3 operation 3.0 3.3 3.6 V VDDBURN Positive Supply Voltage in 3V3 Mode Positive Supply Voltage 3.5 V VREG Regulated Voltage 3.6 V VSS Negative Supply Voltage 0 V IDD Supply Current 17 mA TPOWER_ON Power Up Time 10 ms 10 100 mT Operating Conditions Voltage at Vreg if sensor is in 5 V operation mode 3.3 3.2 3.4 0 Depends on gain setting Input Parameter BIN Limit for Target Bz Peak Field At the Hall element position inside the sensor VMAX Maximum Rotation Speed -30000 30000 RPM VOUT Analog Output Voltage Amplitude Limits GND + 0.25 VDD – 0.5 V VCM1 Output Common Mode Level VCM2 Output Parameter Default level 1.275 1.375 1.475 V Output Common Mode Level 1.975 2.125 2.275 V IOUT Analog Output Load Current -1 1 mA CLOAD Analog Output Capacitive Load 10 nF Digital IO Parameter - DIAG V_IH High Level Input Voltage UART mode enabled (default) V_IL Low Level Input Voltage UART mode enabled (default) V_OH High Level Output Voltage V_OL Low Level Output Voltage VSS + 0.4 V C_L Capacitive Load 50 pF I_OUT_5V Output Current 5V Operation 4 mA Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 0.7 * VDD5 V 0.3 * VDD5 VDD5 0.5 V V 34 │ 8 Document Feedback Symbol Parameter I_OUT_3V Output Current 3V3 Operation Conditions AS5116 Electrical Characteristics Min Typ Max Unit 2 mA External Components Rpu Pull up resistor in Figure 28 and Figure 29 10 100 kΩ Cout Output capacitors C1, C2, C3 and C4 in Figure 28 and Figure 29 0.5 10 nF Typ Max Unit Figure 7: Key Performance Parameters Symbol Parameter Conditions Min INL_error (1) Based on Sensor -40 °C to 150 °C 0.5 1 degree Assuming N35H 0.6 1.2 degree Internal Imperfections INL_error + Magnet (1) Non-Linearity @ Displacement of Magnet and Temperature -40 °C to 150 °C Magnet (D=8 mm, H=3 mm) 500 μm displacement in x and y. Package to magnet gap 1700 μm SINCOS_ORT_error (2) Orthogonality Error. Defines deviation of ideal phase shift of 90° between SIN and COS output signals Based on maximum INL_error. -2 2 degree SINCOS_GAIN_error (2) Gain Mismatch between SIN and COS channel Based on maximum INL_error -3.5 3.5 % NOISE5V Maximum RMS Noise. Depending on Gain Configuration (see Figure 10). VDD = 5 V (5 V operation) 2.47 mVrms NOISE3V3 Maximum RMS Noise. Depending on Gain Configuration (see Figure 10). VDD = 3.3 V (3V3 operation) 2.61 mVrms TD Propagation Delay 12 20 µs M Magnetic Sensitivity Differential Output Mode 8 60 mV/mT GV Gain Variation at 25 °C -16 16 % Variation of selected absolute GAIN 16 (Part to Part Variation) GV_Temp_AS5116 (3) GV_Temp_AS5116A (4) Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 Gain Variation Over Temperature -40°C to 150 °C Gain Variation Over Temperature -40 °C to 150 °C -0.105 -0.05 0 %/°C -0.075 -0.03 0 %/°C (Gain drift of one single sensor) (Gain drift of one single sensor) 34 │ 9 Document Feedback AS5116 Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit GV_Temp_AS5116B (5) Gain Variation Over Temperature -40 °C to 150 °C -0.075 -0.03 0 %/°C Hall Radius Radius of circular Hall array HR (1) (2) (3) (4) (Gain drift of one single sensor) 1.1 mm Valid for Differential Output Mode. Assuming a minimum VoutP2P voltage of 3000 mV. Differential consideration of output signals required. Worst case linearity error is limited and guaranteed by INL_max parameter. Parameter guaranteed by design. Worst case figure, valid for Gain_Code 24. Parameter guaranteed by design. Worst case figure, valid for Gain_Code 12. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 10 Document Feedback 6 AS5116 Functional Description Functional Description The Hall-based magnetic position sensor, uses an array of planar sensors that convert the magnetic field component Bz perpendicular to the surface of the chip into a voltage. The signals coming from the Hall sensors are amplified, filtered and buffered before the information is available as sine and cosine voltages on the output. Gain respectively sensitivity of the complete signal path, can be defined by programming the Gain_Code in CONFIG2 register. The sensor is as well programmable to provide a full differential or single ended signal on the output. Settings are in system programmable through an UART single wire interface. For achieving a high ASIL in the application, the sensor is fully supporting the ISO26262 implementation process (Detailed information on request). 6.1 IC Power Management The AS5116 can be either powered from a 5.0 V supply using the on-chip low-dropout regulator (LDO) or from a 3.3 V voltage supply. The LDO (low-dropout) regulator is not intended to power any other loads, and it needs a 1 μF capacitor to ground located close for decoupling as shown Figure 8. In 3V3 operation, VDD and VREG tied together. Figure 8: Pin Configuration in 5 V Operation Mode SINP SINN AS5116 VSS Figure 9: Pin Configuration in 3V3 Operation Mode COSP SINP COSN SINN UART VSS 4.5 – 5.5 V COSP AS5116 COSN UART 3.0 – 3.6 V VDD5 100 nF Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 LDO VDD3 1 µF VDD5 LDO VDD3 100 nF 34 │ 11 Document Feedback 6.2 AS5116 Functional Description Gain Configuration The amplitudes of the output voltages are directly proportional to the Bz field of the magnet above the sensor. The user can select the appropriate Gain Setting out of 25 possible steps. Figure 10: Gain Table(1) Gain_Code GAIN [mV/mT] Maximum RMSNoise [mV] GAIN [mV/mT] Maximum RMSNoise [mV] CONFIG2 Register 0x17 5V Operation Mode 0 8 0.51 8 0.51 1 10 0.51 10 0.68 2 12 0.51 12 0.72 3 13.5 0.68 13 1.53 4 16 0.68 16 0.96 5 18 0.72 18 1.08 6 20 0.96 19.5 1.14 7 22.5 1.08 21.5 1.35 8 24 0.96 23 1.35 9 26.5 1.25 26 1.53 10 26.5 1.65 26.5 1.65 11 29 1.35 28.5 1.65 12 31.5 1.25 30 1.74 13 32.5 2.02 32.5 2.02 14 35 1.35 35 2.02 15 35.5 1.65 35.5 2.20 16 39 1.53 38 2.20 17 40 2.47 40 2.47 18 42.5 1.65 42.5 2.47 19 45 1.74 45 2.61 20 47.5 2.20 45 2.61 21 52 2.02 45 2.61 22 53.5 2.47 45 2.61 23 57 2.20 45 2.61 24 60 2.32 45 2.61 (1) 5V Operation Mode 3V3 Operation Mode 3V3 Operation Mode Gain table representing typical values, maximum Part-to-Part gain variation GV is separately specified. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 12 Document Feedback 6.3 AS5116 Functional Description Behavior of Sensor Outputs Following graphs show the behavior at different output settings over one mechanical 360° rotation. 6.3.1 Differential Output Mode (Default Setting) Positive SINP and COSP signals in combination with inverted SINN and COSN are provided via the output pins of the sensor. High immunity against common cause errors, evoked by the environment of the sensor, is given due to the differential signal transmission. Fully differential signal inputs are required to digitize the analog outputs. VCM is defined via OTP programming. Vout Figure 11: Differential Output Behavior 2π 90° SINP 6.3.2 180° SINN 360° 270° COSP COSN VoutP2P VCM Angle Position Single-Ended Output Mode Positive SINP and COSP signals in combination with the configured VCM level on CM_SIN and CM_COS are provided via the output pins of the sensor. To achieve best accuracy performance, fully differential signal inputs are recommended to digitize the analog outputs. As an alternative, singleended measurement of all output signals with associated data processing (SINP - CM_SIN, COSP CM_COS) is as well possible. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 13 Document Feedback AS5116 Functional Description Vout Figure 12: Single-Ended Output Behavior VCM 2π 90° SINP Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 180° CM_SIN 270° COSP 360° CM_COS Angle Position 34 │ 14 Document Feedback 7 AS5116 Digital Interface – UART Digital Interface – UART The AS5116 is equipped with an UART interface, which allows reading and writing the registers as well as permanently programming the non-volatile memory (OTP). By default (Diag_EN = 0) the AS5116 is in the so-called Communication Mode and the UART is connected to pin 6. In this mode, it is possible to configure the register settings. The UART interface allows reading and writing two consecutive addresses. The standard UART sequence consists of four frames. Each frame begins with a start bit (START), which is followed by 8 data bits (D[0:7]), one parity bit (PAR), and a stop bit (STOP), as shown in Figure 13. Figure 13: UART Frame START D[0] D[1] D[2] D[3] D[4] D[5] D[6] D[7] PAR STOP The PAR bit is and Even Parity, calculated over the data bits (D[0:7]). Each frame is transferred LSB first. Figure 14: Standard UART Sequence Frame Number D[7] 1 2 D[6] D[5] D[4] D[3] D[2] D[1] D[0] 0x55 R/W ADDRESS 3 DATA1 4 DATA2 The first frame is the synchronization frame and consists of D[0:7] = 0x55 followed by the parity bit (PAR = 0) and the stop bit. This frame synchronizes the baud rate between the AS5116 and the UART Master. The UART baud rate have to stay in a range of 1.1 – 70 kbit/s. The second frame contains the read/write command (Write: D[7] = 0; Read: D[7] = 1) and the address of the register (ADDRESS: D[0:6]). The content of the third and fourth frames (DATA1 and DATA2) will be written to or read from the location specified by ADDRESS and ADDRESS+1. Figure 15 and Figure 16 show examples of Read and Write UART frame. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 15 Document Feedback AS5116 Digital Interface – UART Figure 15: UART – Write Example 0x55 0x16 0x68 0xA2 MSB PAR STOP MSB PAR STOP START LSB MSB WRITE PAR STOP START LSB START LSB MSB PAR STOP START LSB 0 1 0 1 0 1 0 1 0 0 1 0 0 1 1 0 1 0 0 0 1 1 0 0 0 0 1 0 1 1 0 1 1 0 0 1 0 0 0 1 0 1 1 1 In this UART – Write example the UART Master writes to CONFIG1 register 0x16 – 0x68 and to CONFIG2 register 0x17 – 0xA2. Figure 16: UART – Read Example Content of register 0x16 MSB READ PAR STOP START LSB MSB PAR STOP START LSB START LSB 0 1 0 1 0 1 0 1 0 0 1 0 0 1 1 0 1 0 0 1 0 1 0 Content of register 0x17 1 0 1 MSB PAR STOP 0x16 MSB PAR STOP START LSB 0x55 In this UART – Read example the UART Master reads from CONFIG1 register 0x16 and CONFIG2 register 0x17. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 16 Document Feedback 7.1 AS5116 Digital Interface – UART Register Description The table below shows all accessible digital registers implemented in the AS5116 sensor. Figure 17: Register Overview 7.1.1 Address Name Function Default Description 0x01 UART_ERROR R 0x00 Indication of framing and parity errors 0x03 P2RAM_CONTROL R/W 0x00 P2RAM handling 0x16 CONFIG1 R/W/P 0x00 Configuration of output setting 0x17 CONFIG2 R/W/P 0x00 Configuration of gain and diagnostic mode 0x18 CUST_CHIP_ID1 R/W/P 0x00 Spare bits for custom chip ID 0x19 CUST_CHIP_ID2 R/W/P 0x00 Spare bits for custom chip ID 0x1A CUST_CHIP_ID3 R/W/P 0x00 Spare bits for custom chip ID 0x1B ECC R/W/P 0x00 Configuration of ECC function 0x50 ECC_CHECKSUM R 0x00 Calculated ECC checksum based on actual register settings 0x51 ECC_STATUS R 0x00 Indicates actual ECC status if ECC function is enabled UART_ERROR Register – 0x01 In the UART_ERROR Register problems during UART communication are indicated. Error bits are sticky and clear on read. UART_SYNC Bit indicates a problem with the synchronization frame. This is usually the case if the Baudrate was not defined correctly. Baudrate window is defined from 1.1 kbit/s to 70 kbit/s. UART_PARITY bit indicates a parity error during a UART-Write command. UART_FRAME bit indicates an error, if after synchronization the UART line stays low for more than twice the usual expected time (too long frame). Figure 18: UART_ERROR Register – 0x01 Bit Position Bit Name Default Description 0 UART_SYNC 0 UART synchronization error 1 UART_PARITY 0 UART parity error 2 UART_FRAME 0 UART frame too long error Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 17 Document Feedback 7.1.2 AS5116 Digital Interface – UART P2RAM_CONTROL Register – 0x03 The P2RAM_CONTROL Register handles all processes in combination with the OTP memory. Description of OTP related commands and definition of the programming flow chart is given in section Configuration and Programming. Figure 19: P2RAM_CONTROL Register 7.1.3 Bit Position Bit Name Default Description 0:1 State 0 P2RAM state 2 LOAD 0 Load latch from fuse array 3 BURN 0 6 GLOAD Burn command to permanently store setting within OTP memory Enabled guard band mode to check burn quality CONFIG1 Register – 0x16 In CONFIG1 Register includes several possible configurations of the sensor outputs, like common mode level and pin configuration Figure 20: CONFIG1 Register Bit Position Bit Name Default Description 0:2 n.a. 0 Not applicable 3 VCM_Level 0 4 n.a. 0 5 CM_COS 0 6 CM_SIN 0 7 INVERT_CH 0 Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 Output common mode level (0: VCM = 1.375 V, 1: VCM =2.125 V) Not applicable Defines the output function of pin 7 (0: COSN, 1: CM_COS) Defines the output function of pin 2 (0: SINN, 1: CM_SIN) Inverts the sign of the output channels 34 │ 18 Document Feedback 7.1.4 AS5116 Digital Interface – UART CONFIG2 Register – 0x17 CONFIG 2 Register includes the sensitivity settings and a bit to enable the diagnostic mode. Figure 21: CONFIG2 Register 7.1.5 Bit Position Bit Name Default Description 0 Diag_EN 0 Enables diagnostic mode when the bit is set to “1” 1:5 Gain_Code 0 Defines the sensitivity of the sensor 6:7 n.a. 0 Not applicable CUST_CHIP_ID1 Register – 0x18 Figure 22: CUST_CHIP_ID1 7.1.6 Bit Position Bit Name Default Description 0:7 CUST_CHIP_ID1 0 Spare bits for customized tracking information CUST_CHIP_ID2 Register – 0x19 Figure 23: CUST_CHIP_ID2 7.1.7 Bit Position Bit Name Default Description 0:7 CUST_CHIP_ID2 0 Spare bits for customized tracking information CUST_CHIP_ID3 Register – 0x1A Figure 24: CUST_CHIP_ID3 Bit Position Bit Name Default Description 0:7 CUST_CHIP_ID3 0 Spare bits for customized tracking information Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 19 Document Feedback 7.1.8 AS5116 Digital Interface – UART ECC Register – 0x1B Within ECC (Error-Correction Code) register, the ECC function is configured and enabled. Figure 25: ECC Register Bit Position Bit Name Default Description 0:6 ECC_Chsum 0 ECC checksum programmed by user 7 ECC_EN 0 Enables ECC function Figure 26: ECC CHECKSUM Bit Position Bit Name Default Description 0:6 ECC_Chsum_calc 0 Internal calculated ECC checksum Figure 27: ECC STATUS Bit Position Bit Name Default Description 0 ECC_EN_after_check 0 ECC_EN after error correction ECC Error code: 0: P2RAM bytes in customer area are correct (or ECC_EN = 0) 1:2 ECC_Error 0 1: Single bit error in P2RAM. P2RAM output corrected by ECC function 2: Two or more bits are defect in P2RAM block. No correction possible - major system error Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 20 Document Feedback 8 AS5116 Functional Safety Functional Safety AS5116 is fully supporting the ISO26262 and enables applications to fulfill Automotive Safety Integrity Levels up to ASIL C. 8.1 Safety Manual The safety manual, available upon request, contains all the necessary information for the system integrator, to integrate AS5116 in a safety related item. AS5116 is supporting the ISO26262 as Safety Element out of Context (SEooC). The safety manual includes the following information: ● ● ● Product development lifecycle Description of the technical safety concept on system level Detailed information of Assumption of Use of the element with respect to its intended use, which includes ● ● ● System Safe State information Fault Tolerant Time Interval Coverage information As part of the Safety Manual, the Verification and Safety Analysis Report includes following information: ● ● ● HW architectural metric results (Single Point Fault Metric) Description of verifications based on the ISO26262 Detailed FMEDA Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 21 Document Feedback 9 AS5116 Application Information Application Information Several wiring options and configurations of AS5116 are possible. The most likely used options are shown in the following section. 9.1 Differential Mode By default, the configuration of the sensor is in differential output mode. Positive SINP and COSP signals, as well as the inverted SINN and COSN signals are provided. This is the recommended output configuration, due to the best common mode rejection. Fully differential inputs are required on controller side. To improve the angle accuracy, a one-time end of line calibration of offset and gain error is recommended before calculating the angle position. 9.1.1 Minimum Wiring Diagram Figure 28: AS5116 Minimum Wiring Diagram, Differential Output Mode Controller Unit in/out Angle Calcualation Diff. Input ADC COS Diff. Input ADC SIN UART COSN COSP SINP SINP SINN C1 C2 C3 C4 SINN COSP AS5116 COSN Rpu VSS UART VDD5 VDD3 Recommended (1) (2) 4.5 – 5.5 V VDD5 GND GND C5 100 nF C6 1 µF C1=C2=C3=C3=C4=Cout Parameters for Cout and Rpu are described in chapter “Electrical Characteristics” Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 22 Document Feedback 9.2 AS5116 Application Information Single Ended Mode In single-ended configuration, all voltage measurements are reverenced to VSS level. For safety reasons, it is recommended to check as well the levels of CM_SIN and CM_COS with separate analog inputs. The measured common mode voltages should be used to calculate the differential sine/cosine values. Otherwise, the signal common mode level has to be determined in the controller based on one sine/cosine period. To improve the angle accuracy, a one-time end of line calibration of offset and gain error is recommended before calculating the angle position. 9.2.1 Minimum Wiring Diagram Figure 29: AS5116 Minimum Wiring Diagram, Single Ended Output Mode Controller Unit Angle Calcualation in/out UART ADC IN1 CM_COS ADC IN2 COSP ADC IN3 SINP ADC IN4 SINP CM_SIN C1 C2 C3 C4 CM_SIN COSP AS5116 CM_COS Rpu VSS UART VDD5 VDD3 Recommended (1) (2) 9.2.2 4.5 – 5.5 V VDD5 GND GND C5 100 nF C6 1 µF C1=C2=C3=C3=C4=Cout Parameters for Cout and Rpu are described in chapter “Electrical Characteristics” Output Amplitude Calculation The output amplitude of sine and cosine signals are directly proportional to the selected GAIN setting and the Bz-Field of the available target magnet. Following equations explain how the calculation is done based on a typical example. Using that approach, a very convenient estimation of the output amplitudes is possible. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 23 Document Feedback Equation 1: Vout Peak to Peak – Single Ended Input AS5116 Application Information Equation 2: Vout Peak to Peak – Differential Input 𝑉𝑜𝑢𝑡𝑆𝐸_𝑃2𝑃 = 2 ∙ 𝐵𝑧𝑚𝑎𝑥 ∙ 𝐺𝐴𝐼𝑁 𝑉𝑜𝑢𝑡𝐷𝐼𝐹_𝑃2𝑃 = 4 ∙ 𝐵𝑧𝑚𝑎𝑥 ∙ 𝐺𝐴𝐼𝑁 Output Amplitude Calculation – Example Assumptions: Gain Setting = 30 mV/mT, Bzmax = 30 mT +Bz -Bz Equation 3: Vout Vout SE_P2P = 2 ∙ 30 ∙ 30 = 1800 mV 1800 mV VCM 2π 90° SINP 180° SINN 360° 270° COSP COSN Angle Position Equation 4: Vout 𝑉𝑜𝑢𝑡𝐷𝐼𝐹_𝑃2𝑃 = 4 ∙ 30 ∙ 30 = 3600 𝑚𝑉 90° 180° SIN Differential Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 270° 360° Angle Position 3600 mV 0V COS Differential 34 │ 24 Document Feedback 9.2.3 AS5116 Application Information Diagnostic Mode In default configuration, the sensor is in communication mode. Pin 6 acts as single wire UART interface connection and can be used to configure all relevant customer setting. During the programming process, it is possible to enable the diagnostic function by programming the “Diag_EN” bit in the CONFIG2 Register – 0x17. In that case, pin 6 is acting as diagnostic output after the next power on reset of the sensor. The diagnostic function checks if the status of the OTP register is still valid and correct. It is directly linked to the ECC_error status 1 and 2 (ECC_STATUS Register – 0x51). Figure 30: DIAG Output State Definition State of DIAG Pin 6 Output Level Description 0 GND OTP status ok 1 VDD OTP error One or more bits flipped in OTP section. As result unexpected behavior of the sensor could occur. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 25 Document Feedback 10 AS5116 Configuration and Programming Configuration and Programming The non-volatile memory is used to permanently program the configuration. To program the nonvolatile memory, the UART interface is used. The programming could be performed either in 5 V or in 3V3 operation mode operation. Tighter limits of the supply voltage in 3V3 operation has to be considered (VDDBURN). Figure 31: AS5116 Programming Flow Start Write: CONFIG Start internal programming procedure Write: P2RAM_CONTROL CONFIG1 (0x16) CONFIG2 (0x17) CUST_CHIP_ID1 (0x18) CUST_CHIP_ID2 (0x19) CUST_CHIP_ID3 (0x1A) Write all required configuratios to the sensor P2RAM_CONTROL (0x03) = 0x08 Read P2RAM_CONTROL register to check if programming is already finished. Read: P2RAM_CONTROL P2RAM_CONTROL (0x03) Write: ECC Enable Enable ECC function ECC (0x1B) = 0x80 Read the sensor internal generated ECC-Checksum Read: ECC_CHECKSUM FAIL Check if register content == 0x01. If so, internal programming process is finished. If not, programming is ongoing (it takes 10 ms maximum). Verify: P2RAM_CONTROL == 0x01 ECC_Chsum_calc (0x50) PASS Write the previously read ECC-Checksum into ECC register Write: ECC ECC (0x1B) = 0xXX Read content of ECC_STATUS register to check if ECC function is working correctly If ECC_STATUS register content = 0x01, ECC functionality is working correctly. Otherwise go back to step ECC Enable Read: ECC_STATUS ECC_STATUS (0x51) FAIL Verify: ECC_STATUS == 0x01 PASS Read: CONFIG CONFIG1 (0x16) CONFIG2 (0x17) CUST_CHIP_ID1 (0x18) CUST_CHIP_ID2 (0x19) CUST_CHIP_ID3 (0x1A) Read again all configuration registers, to check content with previously written data Compare read data with written data. Regsiter contant has to match Verify: FAIL Compare with written data Write: CONFIG CONFIG1 (0x16) = 0x00 CONFIG2 (0x17) = 0x00 CUST_CHIP_ID1 (0x18) = 0x00 CUST_CHIP_ID2 (0x19) = 0x00 CUST_CHIP_ID3 (0x1A) = 0x00 ECC (0x1B) = 0x00 Set all previously written and programmed registers to 0x00. Trigger guard band load process, which is proofing the OTP fuse quality. Write: P2RAM_CONTROL P2RAM_CONTROL (0x03) = 0x40 Reflash register content with programmed configuration Write: P2RAM_CONTROL P2RAM_CONTROL (0x03) = 0x04 Read: CONFIG CONFIG1 (0x16) CONFIG2 (0x17) CUST_CHIP_ID1 (0x18) CUST_CHIP_ID2 (0x19) CUST_CHIP_ID3 (0x1A) ECC (0x1B) Read all written and programmed configuration registers. Compare read datae with previously written content. If the content is eqal, programming is finished and valid. PASS Verify: Unlock programming features within P2RAM_CONTROL register Compare with written data FAIL Write: P2RAM_CONTROL P2RAM_CONTROL (0x03) = 0x01 PASS Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 END END PASSED Programming Process FAILED Programming Process 34 │ 26 Document Feedback 11 AS5116 Preconfigured Versions Preconfigured Versions Beside the fully flexible AS5116 version, further preconfigured variants with fixed CONFIG Register settings are available. By using an already programmed AS5116, no further OTP configuration of the sensor is possible. 11.1 AS5116A AS5116A is configured in Single-Ended mode. SINN and COSN outputs represent the common mode voltage. A fixed gain configuration of 31.5 mV/mT is chosen (Gain_Code 12). OTP Diagnostic and internal ECC check are enabled and show the actual status on UART/DIAG pin. Figure 32: AS5116A – Register Settings Gain_Code DIAG_EN VCM_Level CM_COS, CM_SIN INVERT_CH CONFIG2 CONFIG2 CONFIG1 CONFIG1 CONFIG1 12 – 31.5 mV/mT Enabled 2.125 V Enabled Disabled Vout Figure 33: AS5116A – Output Behavior VCM 2π 90° SINP Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 180° CM_SIN 270° COSP 360° CM_COS Angle Position 34 │ 27 Document Feedback AS5116 Preconfigured Versions Figure 34: AS5116A – Wiring Diagram, Single Ended Output Mode Controller Unit Angle Calcualation DIAG in ADC IN1 CM_COS ADC IN2 COSP ADC IN3 SINP ADC IN4 SINP CM_SIN C1 C2 C3 CM_SIN C4 COSP AS5116 CM_COS Rpu VSS DIAG VDD5 VDD3 Recommended (1) (2) 11.2 4.5 – 5.5 V VDD5 GND GND C5 100 nF C6 1 µF C1=C2=C3=C3=C4=Cout Parameters for Cout and Rpu are described in chapter “Electrical Characteristics” AS5116B AS5116B is configured in Differential mode. A fixed gain configuration of 31.5 mV/mT is chosen (Gain_Code 12). OTP Diagnostic and internal ECC check are enabled and show the actual status on UART/DIAG pin. Figure 35: AS5116B – Register Settings Gain_Code DIAG_EN VCM_Level CM_COS, CM_SIN INVERT_CH CONFIG2 CONFIG2 CONFIG1 CONFIG1 CONFIG1 12 – 31.5 mV/mT Enabled 2.125 V Disabled Disabled Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 28 Document Feedback AS5116 Preconfigured Versions Figure 36: AS5116B – Output Behavior Figure 37: AS5116B – Wiring Diagram, Differential Output Mode Controller Unit in/out Angle Calcualation Diff. Input ADC COS Diff. Input ADC SIN UART COSN COSP SINP SINP SINN C1 C2 C3 C4 SINN COSP AS5116 COSN Rpu VSS UART VDD5 VDD3 Recommended 4.5 – 5.5 V GND (1) (2) VDD5 GND C5 100 nF C6 1 µF C1=C2=C3=C3=C4=Cout Parameters for Cout and Rpu are described in chapter “Electrical Characteristics” Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 29 Document Feedback 12 AS5116 Package Drawings & Markings Package Drawings & Markings Figure 38: SOIC8 Package Outline Drawing Ref. Min Nom Max A - - 1.75 A1 0.10 - 0.25 A2 1.25 - - b 0.31 - 0.51 c 0.17 - 0.25 D 4.90 BSC E 6.00 BSC E1 3.90 BSC e 1.27 BSC L 0.40 - 1.27 L1 1.04 REF L2 0.25 BSC R 0.07 - - R1 0.07 - - h 0.25 - 0.50 0° - 8° 2 5° - 15° 3 0° - - aaa - 0.10 - bbb - 0.20 - ccc - 0.10 - ddd - 0.25 - eee - 0.10 - fff - 0.15 - ggg - 0.15 - N 8 RoHS Green (1) (2) (3) (4) (5) (6) All dimensions are in millimeters (angles in degrees). Dimensioning and tolerances conform to ASME Y14.5M-1994. N is the total number of terminals. Datum A&B to be determined by datum H. This package contains no lead (Pb). This drawing is subject to change without notice. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 30 Document Feedback AS5116 Package Drawings & Markings Figure 39: SOIC8 Package Marking/Code for AS5116 YY WW M ZZ @ Manufacturing Year Manufacturing Week Assembly Plant Identifier Assembly Traceability Code Sublot Identifier YY WW M ZZ @ Manufacturing Year Manufacturing Week Assembly Plant Identifier Assembly Traceability Code Sublot Identifier YY WW M ZZ @ Manufacturing Year Manufacturing Week Assembly Plant Identifier Assembly Traceability Code Sublot Identifier Figure 40: SOIC8 Package Marking/Code for AS5116A Figure 41: SOIC8 Package Marking/Code for AS5116B Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 31 Document Feedback 13 AS5116 Mechanical Data Mechanical Data Figure 42: SOIC8 Die Placement and Hall Array Position (1) (2) (3) (4) (5) (6) All dimensions in micrometers The Hall array center is located in the center of the IC package. Hall array radius is 1.1 mm. Die thickness is 356 µm nominal Adhesive thickness 20 ± 10 µm Leadframe downset 200 ± 25 µm Leadframe thickness 200 ± 8 µm Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 32 Document Feedback 14 AS5116 Revision Information Revision Information ● ● Changes from previous version to current revision v4-00 Page Updated Ordering information 2 Added Chapter 11.2 AS5116B 28 Added Figure 41 31 Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. Correction of typographical errors is not explicitly mentioned. Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 33 Document Feedback 15 AS5116 Legal Information Legal Information Copyrights & Disclaimer Copyright ams-OSRAM AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams-OSRAM AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams-OSRAM AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams-OSRAM AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams-OSRAM AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams-OSRAM AG for each application. This product is provided by ams-OSRAM AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams-OSRAM AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams-OSRAM AG rendering of technical or other services. RoHS Compliant & ams Green Statement RoHS Compliant: The term RoHS compliant means that ams-OSRAM AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories plus additional 4 substance categories (per amendment EU 2015/863), including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br/Cl): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) and do not contain Chlorine (Cl not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams-OSRAM AG knowledge and belief as of the date that it is provided. ams-OSRAM AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams-OSRAM AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams-OSRAM AG and ams-OSRAM AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Headquarters Please visit our website at www.ams.com ams-OSRAM AG Buy our products or get free samples online at www.ams.com/Products Tobelbader Strasse 30 Technical Support is available at www.ams.com/Technical-Support 8141 Premstaetten Provide feedback about this document at www.ams.com/Document-Feedback Austria, Europe For sales offices, distributors and representatives go to www.ams.com/Contact Tel: +43 (0) 3136 500 0 For further information and requests, e-mail us at ams_sales@ams.com Datasheet • PUBLIC DS000686 • v4-00 • 2022-Feb-18 34 │ 34
AS5116-HSOM 价格&库存
很抱歉,暂时无法提供与“AS5116-HSOM”相匹配的价格&库存,您可以联系我们找货
