AS5600L-ASOM
AS5600L-ASOM
    AMSOSRAM(艾迈斯半导体)
    SOIC-8
    AS5600L-ASOM SOIC8 LF T&RDP
AS5600L-ASOM 数据手册
Product Document Published by ams OSRAM Group AS5600L 12-Bit Programmable On-Axis Magnetic Rotary Position Sensor General Description The AS5600L is an easy to program magnetic rotary position sensor with a high-resolution 12-bit I²C or PWM output. This contactless system measures the absolute angle of a diametric magnetized on-axis magnet. This AS5600L is designed for contactless potentiometer applications and its robust design eliminates the influence of any homogenous external stray magnetic fields. The industry-standard I²C interface supports simple user programming of non-volatile parameters without requiring a dedicated programmer. By default the output represents a range from 0 to 360 degrees. It is also possible to define a smaller range to the output by programming a zero angle (start position) and a maximum angle (stop position). The AS5600L is also equipped with a smart low power mode feature to automatically reduce the power consumption. An input pin (DIR) selects the polarity of the output with regard to rotation direction. If DIR is connected to ground, the output value increases with clockwise rotation. If DIR is connected to VDD, the output value increases with counterclockwise rotation. The AS5600L is available in a standard SOIC-8 package and in a WL-CSP for applications requiring small-sized sensing solutions with a size of 2.07mm x 2.63mm x 0.6mm. Both variants are qualified for a temperature range from -40°C to 125°C. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS5600L, 12-bit Programmable Contactless Potentiometer are listed below: Figure 1: Added Value of Using AS5600L Benefits Features • Highest reliability and durability • Contactless magnetic angle measurement • Simple programming • Easy programming of start and stop positions in 3-wire mode (no programmer needed) or over the I²C interface • Multiple sensors on one I²C bus • User programmable I²C address ams Datasheet [v1-12] 2020-May-14 Page 1 Document Feedback AS5600L − General Description Benefits Features • Great flexibility on angular excursion • Maximum angle programmable from 18° up to 360° • High-resolution output signal • 12-bit output resolution available on I²C and PWM output • Low-power consumption • Automatic entry into low-power mode • Easy setup • Automatic magnet detection • Very small form factor • WL-CSP (2.07mm x 2.63mm) or SOIC-8 package • Robust environmental tolerance • Wide temperature range: -40°C to 125°C Applications The AS5600L is ideally suited for contactless potentiometers, contactless knobs, pedals, RC servos and other angular position measurement solutions. Block Diagram The functional blocks of this device are shown below: Figure 2: Functional Blocks of AS5600L VDD3V3 VDD5V SDA SCL DIR Low-Dropout (LDO) Regulator (internal load only) Register Setting I²C I2C Address Automatic low power mode Hall Sensors One-Time Programmable (OTP) Memory Analog Front-End AFE 12-bit A/D ATAN (CORDIC) Automatic Digital Processing and Filtering Automatic Gain Control (AGC) PWM Driver OUT PWM AS5600L Magnetic Core GND Page 2 Document Feedback ams Datasheet [v1-12] 2020-May-14 AS5600L − Pin Assignments Pin Assignments VDD5V 1 VDD3V3 2 OUT 3 GND 4 AS5600/ Figure 3: SOIC-8 Pin Diagram 8 DIR 7 SCL 6 SDA 5 PGO Figure 4: SOIC-8 Pin Description Pin Number Name Type Description 1 VDD5V Supply Positive voltage supply in 5V mode (requires 100 nF decoupling capacitor) 2 VDD3V3 Supply Positive voltage supply in 3.3V mode (requires an external 1-μF decoupling capacitor in 5V mode) 3 OUT Digital output 4 GND Supply 5 PGO Digital input 6 SDA Digital input/output I²C Data (consider external pull-up) 7 SCL Digital input I²C Clock (consider external pull-up) 8 DIR Digital input Direction polarity (GND = values increase clockwise, VDD = values increase counterclockwise) PWM output. Fixed to VDD default. Enable in CONF register. Ground Program option (internal pull-up, connected to GND = Programming Option B) Note(s): 1. In case of 5V operation the VDD3V3 output is intended for internal use only. It must not be loaded with an external load. ams Datasheet [v1-12] 2020-May-14 Page 3 Document Feedback AS5600L − Pin Assignments Figure 5: WL-CSP Pin Diagram (Top View) 1 2 3 A ',5 7(67 9''9 B 6&/ 1& 1& C 7(67 1& 9''9 D 6'$ 1& 287 E 3*2 7(67 *1' Figure 6: WL-CSP Pin Description Pin Number Name Type Description A1 DIR Digital input A2 TEST Test pin Connect to ground A3 VDD5V Supply Positive voltage supply in 5V mode (requires 100 nF decoupling capacitor) B1 SCL Digital input C1 TEST Test pin Connect to ground C3 VDD3V3 Supply Positive voltage supply in 3.3V mode (requires an external 1 μF decoupling capacitor in 5V mode)(1) D1 SDA Digital input/output I²C data (consider external pull-up) D3 OUT Digital output PWM output. Fixed to VDD default. Enable in CONF register. E1 PGO Digital input E2 TEST Test pin Connect to ground E3 GND Supply Connect to ground B2,B3,C2,D2 NC Not connected Direction polarity (GND = values increase clockwise, VDD = values increase counterclockwise) I²C clock (consider external pull-up) Program option (internal pull-up, connected to GND = programming option B) Do not connect Note(s): 1. In case of 5V operation the VDD3V3 output is intended for internal use only. It must not be loaded with an external load. Page 4 Document Feedback ams Datasheet [v1-12] 2020-May-14 AS5600L − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 7: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD5V DC supply voltage at VDD5V pin -0.3 6.1 V VDD3V3 DC supply voltage at VDD3V3 pin -0.3 4.0 V VIO DC supply voltage at all digital or analog pins -0.3 VDD+0.3 V ISCR Input current (latch-up immunity) -100 100 mA JESD78 Continuous Power Dissipation (TA = 70°C) PT Continuous power dissipation 50 mW Electrostatic Discharge ESDHBM Electrostatic discharge HBM ams Datasheet [v1-12] 2020-May-14 ±1 kV AEC-Q100-002E Page 5 Document Feedback AS5600L − Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Temperature Ranges and Storage Conditions TSTRG TBODY Storage temperature range -55 125 Package body temperature 260 °C °C SOIC-8: ICP/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is “Matte Tin” (100% Sn) WL-CSP: ICP/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” RHNC Relative humidity (non-condensing) MSL Moisture sensitivity level Page 6 Document Feedback 5 85 % 3 SOIC-8: ICP/JEDEC J-STD-033 1 WL-CSP: ICP/JEDEC J-STD-033 ams Datasheet [v1-12] 2020-May-14 AS5600L − Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with minimum and maximum values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Operating Conditions Figure 8: System Electrical Characteristics and Temperature Range Symbol Parameter VDD5V Positive supply voltage in 5.0V mode VDD3V3 Positive supply voltage in 3.3V mode Conditions Min Typ Max Units 4.5 5.0 5.5 V 3.3V operation mode 3.0 3.3 3.6 V During OTP burn procedure (2) 3.3 3.4 3.5 V 5.0V operation mode During OTP burn procedure (2) IDD Supply current in NOM (1) PM = 00 Always on 6.4 mA lDD_LPM1 Supply current in LPM1 (1) PM = 01 Polling time = 5ms 3.3 mA lDD_ LPM2 Supply current in LPM2 (1) PM = 10 Polling time = 20ms 1.8 mA lDD_ LPM3 Supply current in LPM3 (1) PM = 11 Polling time = 100ms 1.5 mA Supply current per bit for burn procedure Initial peak, 1 μs 100 mA IDD_BURN Steady burning,
AS5600L-ASOM 价格&库存
很抱歉,暂时无法提供与“AS5600L-ASOM”相匹配的价格&库存,您可以联系我们找货
AS5600L-ASOM
  • 2+27.36757
  • 126+26.77398
  • 250+26.19601
库存:28
