AS5070B-HSOM
AS5070B-HSOM
    AMSOSRAM(艾迈斯半导体)
    SOIC-8
    磁性 霍尔效应传感器 磁体 数字 鸥翼 8-SOIC(0.154",3.90mm 宽)
AS5070B-HSOM 数据手册
Product Document Published by ams OSRAM Group AS5070 High-Resolution On-Axis Magnetic Angular Position Sensor General Description The AS5070 is a high-resolution angular position sensor for precise absolute angle measurement. The AS5070 is available with an analog output interface (AS5070A) or a digital output interface (AS5070B). The latter can be programmed as a PWM or a SENT-compliant output interface. Based on a Hall sensor technology, this device measures the orthogonal component of the flux density (Bz) over a full-turn rotation and compensates for external stray magnetic fields with a robust architecture based on a 14-bit sensor array and analog front-end (AFE). A sub-range can be programmed to achieve the best resolution for the application. To measure the angle, only a simple two-pole magnet rotating over the center of the package is required. The magnet may be placed above or below the device. The absolute angle measurement provides an instant indication of the magnet’s angular position. The AS5070 operates at a supply voltage of 5V, and the supply and output pins are protected against overvoltage up to +20V. In addition the supply pins are protected against reverse polarity up to –20V. Figure 1: Typical Arrangement of AS5070 and a Magnet Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-00] 2020-Aug-13 Page 1 Document Feedback AS5070 − General Description Key Benefits and Features The benefits and features of this device are listed below: Figure 2: Added Value of Using AS5070 Benefits Features • Resolve small angular excursion with high accuracy • 12-bit resolution @90° minimum arc • Accurate angle measurement • Low output noise, low inherent INL • Higher durability and lower system costs (no shield needed) • Magnetic stray field immunity Applications The AS5070 is ideal for applications like: • Rotary button angle sensors • Liquid-level measurement systems • Contactless potentiometers Page 2 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − General Description Block Diagram The functional blocks of the AS5070A, AS5070B are shown below: Figure 3: Functional Blocks of the AS5070A VDD Register Setting LDO Reverse Polarity Protection VDD3V3 UART OTP Hall Sensors OUT Analog Front-End ATAN (CORDIC) 14-bit A/D Digital Filter 12-bit D/A AGC Linearizator Driver AS5070A GND Figure 4: Functional Blocks of the AS5070B VDD Register Setting LDO Reverse Polarity Protection VDD3V3 UART OTP PWM Hall Sensors OUT Analog Front-end 14-bit A/D ATAN (CORDIC) Digital Filter Linearizator Driver SENT AGC AS5070B GND ams Datasheet [v1-00] 2020-Aug-13 Page 3 Document Feedback AS5070 − Pin Assignments Pin Assignments VDD 1 TP1 2 TP2 3 TP3 4 AS5070x Figure 5: AS5070 Pin Assignment (Top View, SOIC8) 8 GND 7 VDD3V3 6 TP4 5 OUT Figure 6: AS5070 Pin Description Pin Number SOIC-8 Pin Name Pin Type Description Comments 1 VDD Supply Positive supply 2 TP1 NA Test pin Connected to ground 3 TP2 NA Test pin Leave open 4 TP3 NA Test pin Connected to ground 5 OUT Analog output (AS5070A) Digital output (AS5070B) Output interface AS5070A: Analog output AS5070B: PWM or SENT output 6 TP4 NA Test pin To be connected to OUT 7 VDD 3V3 Supply 8 GND Supply Page 4 Document Feedback 3.3V on-chip low-dropout (LDO) output. Requires an external decoupling capacitor (100nF). Ground ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 7: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD DC Supply Voltage at VDD Pin -20 20 V Not operational VOUT External DC Voltage at OUT Pin -0.3 20 V Permanent VDIFF DC Voltage difference between VDD and OUT -20 20 DC Voltage at the VDD3V3 Pin -0.3 5.0 V Input Current (latch-up immunity) -100 100 mA VREGOUT ISCR Continuous Power Dissipation (TAMB = 70°C) PT Continuous Power Dissipation 300 mW Electrostatic Discharge ESDHBM Electrostatic Discharge HBM ams Datasheet [v1-00] 2020-Aug-13 ±2 kV Page 5 Document Feedback AS5070 − Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Temperature Ranges and Storage Conditions TAMB Operating Temperature Range -40 125 °C Ambient temperature TSTRG Storage Temperature Range -55 125 °C 125°C for 1000h 260 °C The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is “Matte Tin” (100% Sn) 85 % TBODY Package Body Temperature RHNC Relative Humidity (non-condensing) MSL Moisture Sensitivity Level Page 6 Document Feedback 5 3 Represents a maximum floor life time of 168 hours ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Electrical Characteristics Electrical Characteristics All tolerances that are defined for external components in this datasheet, are needed to be assured over the whole operation conditions range and also over lifetime. Overall condition: T AMB = -40°C to 125°C, VDD=4.5V to 5.5V; Components spec; unless otherwise noted. Figure 8: Operating Conditions Symbol Parameter Conditions Min Typ Max Unit 4.5 5.0 5.5 V 3.3 3.45 3.6 V VDD Positive supply voltage VREG Regulated voltage VDD3V3 should not be loaded by any external DC current IDD_A Supply current AS5070A AGC=255 (no magnet placed) 4 12 mA lDD_B Supply current AS5070B AGC=255 (no magnet placed) 4 10 mA ISTART Supply current at start-up VREG = 2.25V 10 mA Start-up time Functional mode 10 ms Max Unit 14 bit 12 bit 12 bit TSUP 2.5 5 Figure 9: Electrical System Characteristics Symbol Parameter CRES Core resolution ARES Analog resolution (AS5070A) DRES Digital resolution (AS5070B) Conditions Min Typ Range > 90° INLopt Integral non-linearity (optimum) Best aligned reference magnet(1) at 25°C over full turn 360° -0.5 0.5 deg INLtemp Integral non-linearity (optimum) Best aligned reference magnet(1) over temperature -40°C to 125°C over full turn 360° -0.9 0.9 deg INL Integral non-linearity Best aligned reference magnet(1) over temperature -40°C to 125°C over full turn 360° and displacement -1.4 1.4 deg ON Output noise peak to peak Static conditions - filter on 1 LSB ST Sampling time 125 μs Note(s): 1. Reference magnet: NdFeB, 8mm diameter, 2.5mm thickness ams Datasheet [v1-00] 2020-Aug-13 Page 7 Document Feedback AS5070 − Electrical Characteristics Figure 10: Power Management - Supply Monitor - Timing Symbol Parameter Conditions Min Typ Max Unit VDDUVTH VDD undervoltage upper threshold 3.5 4.0 4.5 V VDDUVTL VDD undervoltage lower threshold 3.0 3.5 4.0 V VDDUH VDD undervoltage hysteresis 300 500 900 mV UVDT VDD undervoltage detection time Time devices detects undervoltage VDD< VDDUVTH 10 50 250 μs UVRT Undervoltage recovery time Time device return into normal mode from failure band VDD > VDDUVTH 10 50 250 μs VDDOVTH VDD overvoltage upper threshold 6.0 6.5 7.0 V VDDOVTL VDD overvoltage lower threshold 5.5 6.0 6.5 V VDDOH VDD overvoltage hysteresis 300 500 900 V OVDT VDD overvoltage detection time Time devices detects overvoltage VDD> VDDOVTL 500 1000 2000 μs OVRT VDD overvoltage recovery time Time device return into normal mode from failure band VDD < VDDOVTL 500 1000 2000 μs TDETWD WatchDog error detection time Time device detects oscillator failure till output is in failure band 12 ms Page 8 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Electrical Characteristics T AMB = -40°C to 125°C, VDD = 4.5V to 5.5V, unless otherwise noted. Two-pole cylindrical diametrically magnetized source: Figure 11: Magnetic Characteristics Symbol Parameter Conditions Min Bz Orthogonal magnetic field strength Required orthogonal component of the magnetic field strength measured at the package surface along a circle of 1.25mm MFER = 0 BzE Orthogonal magnetic field strength – Extended mode Required orthogonal component of the magnetic field strength measured at the package surface along a circle of 1.25mm MFER = 1 Disp(1) Displacement radius Offset between defined device center and magnet axis. Dependent on the selected magnet. Typ Max Unit 30 70 mT 10 90 mT 0.5 mm Note(s): 1. Reference magnet: NdFeB, 6mm diameter, 2.5mm thickness Figure 12: Electrical and Timing Characteristics Analog Output (AS5070A) Symbol Parameter Conditions Min Typ Max Unit INLOS INL output stage -6 +6 LSB DNLOS DNL output stage -5 +5 LSB -0.5% 0.5% VDD RERR Ratiometricity error BVPU Output voltage broken VDD with pull-up resistor Pull-up resistor must be in the specified range (see Figure 31) 96 100 %VDD BGPD Output voltage broken ground with pull-down resistor Pull-down resistor must be in the specified range (see Figure 31) 0 4 %VDD OSSCG Output short-circuit current GND OUT = GND 5 10 20 mA OSSCV Output short-circuit current VDD OUT = VDD -20 -10 -5 mA OSSDT Output short-circuit detection time OUT = GND or OUT = VDD 20 200 600 μs ams Datasheet [v1-00] 2020-Aug-13 Page 9 Document Feedback AS5070 − Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit 2 5 20 ms OSSRT Output short-circuit recovery time OLCH Output level clamping high Output current at OUT pin -3mA OLCL Output level clamping low Output current at OUT pin 3mA 4 %VDD OSPSR Output stage positive step response (driver only) From 0 to 90%VDD, measured at OUT pin, with RPUOUT = 4.7kΩ, CLOAD = 1nF, VDD = 5V 250 μs OSNSR Output stage negative step response (driver only) From VDD to 10%VDD, measured at OUT pin, with RPUOUT = 4.7kΩ, CLOAD = 1nF, VDD = 5V 250 μs OSTD Output stage temperature drift Of value at mid code, info parameter not tested in production 0.2 % 96 %VDD -0.2 Note(s): 1. For each code the ratiometricity error is defined as follows: VOUTRATE=((VOUTact – (VOUTtyp*(VDDact/ VDDtyp)))/VDDtyp)*100 Where - VOUTact is the actual output voltage - VOUTtyp is the typical output voltage - VDDact is the actual supply voltage - VDDtyp is the typical supply voltage Figure 13: Electrical and Timing Characteristics PWM Output (AS5070B) Symbol Parameter Conditions Min Typ Max Unit PWMSSOCG Short-circuit output current OUT = GND 5 10 20 mA PWMSSOCV Short-circuit output current OUT = VDD -20 -10 -5 mA PWMSSDT PWM short-circuit detection time OUT = GND or OUT = VDD 5 PWM clock cycles PWMSSRT PWM short-circuit recovery time PWM clock cycles 6 BKPWMVOH PWM output voltage high in broken condition Broken VDD or broken GND, OUT = high, RPU = 10kΩ, PWMVOH=VDD-VOUT 0 0.4 V BKPWMVOL PWM output voltage low in broken condition Broken VDD or broken GND, OUT = low, RPD = 10kΩ 0 0.4 V PWM frequency PWMFR = 111 137.5 Hz PWMF7 Page 10 Document Feedback 112.5 125 ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit PWMF6 PWM frequency PWMFR = 110 180 200 220 Hz PWMF5 PWM frequency PWMFR = 101 225 250 275 Hz PWMF4 PWM frequency PWMFR = 100 360 400 440 Hz PWMF3 PWM frequency PWMFR = 011 450 500 550 Hz PWMF2 PWM frequency PWMFR = 010 720 800 880 Hz PWMF1 PWM frequency PWMFR = 001 900 100 1100 Hz PWMF0 PWM frequency PWMFR = 000 1800 2000 2200 Hz PWMVOH PWM output voltage level high IOUT = 5mA, PWMVOH = VDD - VOUT 0 0.4 V PWMVOL PWM output voltage level low IOUT = 5mA 0 0.4 V PWMSRF PMM slew rate fast Between 25% and 75% of VDD, RPUOUT = 4.7kΩ, CLOUT1 = 1nF, PWMSR = 0 1 2 4 V/μs PWMSRS PMM slew rate slow Between 25% and 75% of VDD, RPUOUT = 4.7kΩ, CLOUT1 = 1nF, PWMSR = 1 0.5 1 2 V/μs ams Datasheet [v1-00] 2020-Aug-13 Page 11 Document Feedback AS5070 − Electrical Characteristics Timing Characteristics Figure 14: Electrical and Timing Characteristics SENT Output (AS5070B) Symbol Parameter SENTSSOC SENT short-circuit output current SENTSSOC BKSENTVOH Conditions Min Typ Max Unit OUT = 20V 10 20 40 mA SENT short-circuit output current OUT = 0V -40 -20 -10 mA SENT output voltage in broken condition Broken VDD or broken GND, RPU = 50kΩ, SENT constantly high 1.2 V 0 SENTVOH SENT output voltage high SENTVOL SENT output voltage low 0.5 V SENTFT SENT fall time 6.5 μs SENTRT SENT rise time 18 μs 4.1 Figure 15: Electrical and Timing Characteristics UART Interface Symbol Parameter UARTVIH UART high level input voltage UARTVIL UART low level input voltage UARTVOH UART high level output voltage UARTVOL UART low level output voltage UARTBRLIM UART baud rate Page 12 Document Feedback Conditions Min Typ Max 70 %VDD 30 VDD - 0.5V 2400 Unit %VDD %VDD 0.5 %VDD 9600 Baud ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Detailed Description Detailed Description The AS5070 is a Hall-based rotary magnetic position sensor using a CMOS technology. The lateral Hall sensor array converts the magnetic field component perpendicular to the surface of the chip into a voltage. The signals coming from the Hall sensors are first amplified and filtered before being converted by the analog-to-digital converter (ADC). The output of the ADC is processed by the CORDIC block (Coordinate-Rotation Digital Computer) to compute the angle and magnitude of the magnetic field vector. The sensor and analog front-end (AFE) section works in a closed loop alongside an AGC to compensate for temperature and magnetic field variations. The calculated magnetic field strength (MAG), the automatic gain control (AGC) and the angle can be read through the output pin (OUT) in UART mode. The magnetic field coordinates provided by the CORDIC block are fed to a digital filter which reduces noise. A linearization block generates the transfer function, including linearization. The AS5070 is available with three different output interfaces: analog ratiometric (AS5070A), digital PWM or SENT (AS5070B). The output of the AS5070 can be programmed to define a starting position (zero angle) and a stop position (maximum angle). An embedded linearization algorithm allows reducing the system INL error due, for example, to mechanical misalignment, magnet imperfections, etc. The AS5070 can be programmed through the OUT pin with a UART interface which allows writing an on-chip non-volatile memory (OTP) where the specific settings are stored. The AS5070 can be programmed by the ams programming tool, both at the component and board level. ams Datasheet [v1-00] 2020-Aug-13 Page 13 Document Feedback AS5070 − Register Description Register Description Figure 16: Non-Volatile Memory Register Description Address Bit Position 0x0A 7:0 CUSTID0 Customer ID byte 0 0x0B 7:0 CUSTID1 Customer ID byte 1 0x0C 7:0 CUSTID2 Customer ID byte 2 0x0D 7:0 CUSTID3 Customer ID byte 3 0 PWMINV PWM inverted 1 PWMSR PWM slew rate (0 = PWM slew rate fast PWMSRF, 1 = PWM slew rate slow PWMSRS) 3:2 DIGOS Digital output stage (00 = PWM push-pull 01 = PWM pull-down 10 = PWM pull-up 11 = SENT) Only applicable to AS5070B 6:4 RBKDEB Read-back debouncing 7 NA No use 0 FBS Failure band selection (0 = lower failure band, 1 = upper failure band) 2:1 HYST Hysteresis across the brake point 4:3 QUAD Quadrant selection 7:5 PWMFR PWM frequency selection 1:0 PWMRTH PWM rising threshold 3:2 PWMFTH PWM falling threshold 7:4 SENTMID SENT Message ID 4:0 SENTTK SENT tick 5 SENTESM Enable SENT serial message 6 SENTPP SENT pause pulse enable (0 = disable, 1 = enable) 7 SENTRC SENT rolling counter enable (0 = disable, 1 = enable) 3:0 NA No use. Default 0 7:4 NA No use. Default 0 Field 0x0E 0x0F 0x10 Description 0x11 0x12 Page 14 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description Address Bit Position Field Description 3:0 NA No use. Default 0 7:4 NA No use. Default 0 CLMPH Clamping level high Reg 0x14[0] =LSB Reg 0x15[3]=MSN CLMPL Clamping level low Reg 0x15[4] =LSB Reg 0x16[7]=MSN PPOFFSET Post processing offset Reg 0x17[0] =LSB Reg 0x19[3]=MSB PPGAIN Post processing gain Reg 0x19[4] =LSB Reg 0x1B[3]=MSB BP Break point Reg 0x1B[5] =LSB Reg 0x1D[2]=MSB 3 MFER Magnetic field extended range (1 = Bz, 0= BzE) 4 AER Angle extended range (set to 1 if the maximum angle excursion is smaller than 22 degree) FILTER Post processing filter CUSLOCK Customer settings lock SIGN Signature for error correction code 0x13 0x14 7:0 3:0 0x15 7:4 0x16 7:0 0x17 7:0 0x18 7:0 3:0 0x19 7:4 0x1A 7:0 4:0 0x1B 7:5 0x1C 7:0 2:0 0x1D 6:5 7 0x1E ams Datasheet [v1-00] 2020-Aug-13 7:0 Page 15 Document Feedback AS5070 − Register Description Figure 17: Volatile Memory Register Description Address Bit Position 0x22 7:0 Field R/W R/W DAC12IN 3:0 R/W Description Input word of the 12-bit output DAC (Reg0x23[3] = MSB, Reg0x22[0] = LSB) 4 DAC12INSEL R/W DAC 12 input buffer selection 5 DSPRN R/W Digital signal processing reset 6 GLOAD R/W Enable of gload 7 - - Not used ANGLECORDIC R Angle of the CORDIC output block. (Reg0x33[5] = MSB, Reg0x32[0] = LSB) 7:6 - - Not used 0x34 7:0 MAG R CORDIC magnitude 0x35 7:0 AGC R AGC value 0x36 7:0 ANGLEFILTER R Angle of the digital filter output block (Reg0x37[3] = MSB, Reg0x36[0] = LSB) - - Not used 0x23 0x32 7:0 5:0 0x33 0x37 3:0 0x37 7:4 Figure 18: Special Functions Address Bit Position 0x60 7:0 0x61 7:0 0x62 7:0 0x63 7:0 Field P2F BURNOTP Page 16 Document Feedback Description Pass-to-functions, see UART Permanently burn OTP, see UART ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description UART Interface The AS5070 is equipped with a UART interface, which allows reading and writing the registers as well as permanently programming the non-volatile memory (OTP). By default (factory setting) the AS5070 is in the so-called Communication Mode and the UART is connected at the output pin (OUT). In this mode, it is possible to configure the register settings. In this mode, the device is in open-drain mode and therefore a pull-up resistor has to be connected on the output. The UART interface allows reading and writing two consecutive addresses. The standard UART sequence consists of four frames. Each frame begins with a start bit (START), which is followed by 8 data bits (D[0:7]), one parity bit (PAR), and a stop bit (STOP), as shown in Figure 19. Figure 19: UART Frame START D[0] D[1] D[2] D[3] D[4] D[5] D[6] D[7] PAR STOP The PAR bit is even parity calculated over the data bits (D[0:7]). Each frame is transferred from LSB to MSB. The four frames are shown in Figure 20. Figure 20: UART Frame Sequence Frame Number D[7] 1 2 D[6] D[5] D[4] D[3] D[2] D[1] D[0] 0x55 R/W ADDRESS 3 DATA1 4 DATA2 The first frame is the synchronization frame and consists of D[0:7] = 0x55 followed by the parity bit (PAR=0) and the stop bit. This frame synchronizes the baud rate between the AS5070 and the host microcontroller. The second frame contains the read/write command (D[7] = 0 Write, D[7] = 1 Read) and the address of the register (D[6:0] = ADDRESS). The content of the third and fourth frames (DATA1 and DATA2) will be written to or read from the location specified by ADDRESS and ADDRESS+1, respectively. ams Datasheet [v1-00] 2020-Aug-13 Page 17 Document Feedback AS5070 − Register Description Figure 21 and Figure 22 show examples of read and write. Figure 21: Example of Write (Reg[0x22] = 0x18, Reg[0x23] = 0xA2) 0x55 0x22 0x18 0xA2 MSB PAR STOP MSB PAR STOP START LSB MSB WRITE PAR STOP START LSB MSB PAR STOP START LSB START LSB 0 1 0 1 0 1 0 1 0 0 1 0 0 1 0 0 0 1 0 0 0 1 0 0 0 0 1 1 0 0 0 0 1 0 0 1 0 0 0 1 0 1 1 1 Figure 22: Example of Read (Reg[0x2B], Reg[0x2C]) Content of register 0x2B MSB READ PAR STOP START LSB MSB PAR STOP START LSB START LSB 0 1 0 1 0 1 0 1 0 0 1 0 1 1 0 1 0 1 0 1 1 1 0 Content of register 0x2C 1 0 1 MSB PAR STOP 0x2B MSB PAR STOP START LSB 0x55 Exiting Communication Mode Communication mode is exited and operational mode is entered with a Pass-to-function (P2F) command, by writing to the virtual registers 0x60 and 0x61: P2F: write(0x60) = 0x70, write(0x61) = 0x51 No more commands can be sent after sending this command, because the device is permanently placed in operational mode. Burning the OTP Registers The BURNOTP command writes the OTP registers with their programmed values. The command is issued by writing to virtual registers 0x62 and 0x63: BURNOTP: write(0x62) = 0x70, write(0x63) = 0x51 Customer ID A specific identifier chosen by the user can be stored in the non-volatile memory. This identifier consists of 4 bytes and can be stored in the locations CUSTID0, CUSTID1, CUSTID2 and CUSTID3. Page 18 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description Output Linear Transfer Function A linear transfer function controls the state of the output in response to the absolute orientation of the external magnet. The parameters which control this function are shown in Figure 24. Figure 23: Transfer Function Control Parameters Symbol Parameter Resolution [bit] T1 Mechanical angle starting point 14 T2 Mechanical angle stop point 14 OT1 Output at the starting point (T1) 12 OT2 Output at the stop point (T2) 12 CLMPL Clamping level low 12 CLMPH Clamping level high 12 BP Breakpoint 14 As shown in the Figure 24, the parameters T1, T2, OT1, and OT2 define the input-to-output linear transfer function. The dedicated programmer for the AS5070 uses the parameters from Figure 23 to generate the corresponding settings CLMPL, CLMPH, PPOFFSET, PPGAIN and BP (see Figure 24). The clamping level parameters CLMPL and CLMPH define the absolute minimum and maximum level of the output. Both clamping levels can be set with the 9 LSBs out of the 12-bit output resolution. This means that the maximum value for CLMPL is one eighth, while CLMPH minimum value is seven-eighths of the output diagnostic. CLMPL and CLMPH must always be set outside of the lower and upper diagnostic failure band defined by the output broken wire voltage (see Figure 24: BGPD and BVPU). ams Datasheet [v1-00] 2020-Aug-13 Page 19 Document Feedback AS5070 − Register Description Figure 24: Output Transfer Function Measured angle Mechanical range Max out Upper failure band BVPU Upper clamping band CLMPH OT2 OT1 CLMPL Lower clamping band BGPD Lower failure band Mechanical angle T1 T2 BP Electrical range The breakpoint BP sets the discontinuity point where the output jumps from one clamping level to the other. It is strongly recommended to set the breakpoint at the maximum distance from the start and stop position (T1 and T2). To handle the case of a full turn, a hysteresis function across the breakpoint can be used to avoid sudden jumps between the lower and upper clamping level. Figure 25: Hysteresis Setting Page 20 Document Feedback HYST Hysteresis LSBs 00 0 01 56 10 91 11 137 ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description The hysteresis LSB is based on the core resolution (14-bit). The AS5070 features a programmable digital filter. As shown in Figure 25 in a static condition (no change of the input), the static error band is ±0.5 LSB (at 12-bit resolution). Whenever an input step occurs, the output (measured angle) follows the input (mechanical angle) entering a certain error band within the step response time. From the time when the output is within the static error band the output takes 1000 ms to settle to the static error band achieving again ±0.5 LSB output noise. The filter is not usable in 360° range, if the Hysteresis setting is on. Figure 26: Step Response Measured Angle Dynamic Error Band Static Error Band Input Output response Static Error Band Sampling Frequency time Step Response Time 1000ms Figure 27: FILTER Setting FILTER Dynamic Error Band [LSB] Step Response Time [µs] 00 Filter off Not applicable 01 23 5 CORDIC cycles The FBS setting allows selecting the failure band (lower or upper) when the output goes into diagnostic mode. Multiple Quadrants The multiple quadrants option allows repeating the same output control parameters up to 4 times over the full turn rotation as shown in the Figure 29, Figure 30 and Figure 31. The QUAD parameter sets the number of quadrants, as shown in the Figure 28. ams Datasheet [v1-00] 2020-Aug-13 Page 21 Document Feedback AS5070 − Register Description Figure 28: Number of Quadrants QUADEN Number of Quadrants 00 Single 01 Double 10 Triple 11 Quadruple Figure 29: Dual Quadrant Mode Measured angle Max out BVPU CLMPH Upper failure band Upper clamping band CLMPL Lower clamping band BGPD Lower failure band 360 Page 22 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description Figure 30: Triple Quadrant Mode Measured angle Max out BVPU CLMPH Upper failure band Upper clamping band CLMPL Lower clamping band BGPD Lower failure band 360 Figure 31: Quadruple Quadrant Mode Measured angle Max out BVPU CLMPH Upper failure band Upper clamping band CLMPL Lower clamping band BGPD Lower failure band 360 ams Datasheet [v1-00] 2020-Aug-13 Page 23 Document Feedback AS5070 − Register Description Extended Magnetic Input Range The magnetic input field range can be boosted with the MFER bit. The extended magnetic field allows increasing the maximum air gap between the AS5070 and the magnet. More information can be found in the Application Note. Analog Output (AS5070A) The AS5070A provides a linear analog ratiometric output signal. The output buffer features a push-pull analog output stage which can be loaded with a pull-down or a pull-up resistor. The output voltage represents the angular orientation of the magnet above the AS5070A on a linear absolute scale and is ratiometric to VDD. PWM Output (AS5070B) The AS5070B has a PWM output. With the DIGOS setting, the PWM output stage can be programmed as a push-pull, pull-down, or pull-up driver. The duty-cycle of each pulse is proportional to the absolute angular position of the external magnet. The PWM signal consists of a frame of 4096 clock periods as shown in Figure 32. The PWM frame begins with a certain number of clocks high, defined by the CLMPL, which is followed by the electrical angle information. The frame ends with a certain number of clock pulses low, as defined by the CLMPH. It is possible to invert the frame using the PWMINV setting. Figure 32: Pulse Width Modulation Frame n 1 2 3 4 5 PWM period Mechanical angle CMPL Electrical angle CMPH The PWMFR setting sets the duration of the PWM frequency. The PWMSR setting chooses between fast and slow steps. Page 24 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description SENT Output (AS5070B) The AS5070B provides a SENT-compatible output (Single Edge Nibble Transmission) interface which is compliant with the SAE-J2716 standard (Jan-2010) and features the Single Secure Sensor and the Single Sensor protocol (refer to SENT_J2716_ Standard - Appendix A.3 and A.4). SENT is a single-wire interface based on a unidirectional communication scheme from the sensor (transmitter) to the engine control unit (receiver). The sensor constantly transmits data to the receiver. The SENT interface can be enabled on the AS5070B with the DIGOS setting. The SENT frame consists of 8 nibbles in which each nibble is made up by 4 bits. The duration of the nibbles is variable and depends on its content and tick frequency. With the AS5070B, the tick frequency is selected by the SENTTK setting, as shown in Figure 33. Figure 33: SENT Tick Period ams Datasheet [v1-00] 2020-Aug-13 SENTTK SENT Tick Period (µs) 00000 3 00001 4 00010 4.5 00011 5 00100 5.5 00101 5.75 00110 6.5 00111 6.75 01000 7.5 01001 8 01010 8.5 01011 9 01100 9.5 01101 10 01110 10.25 01111 10.5 10000 10.75 10001 11 Page 25 Document Feedback AS5070 − Register Description SENTTK SENT Tick Period (µs) 10010 11.25 10011 11.5 10100 11.75 10101 12 10110 12.25 10111 12.5 11000 2.25 11001 2.5 11010 2.75 11011 3 11100 3.25 11101 3.5 11110 3.5 11111 3.5 The nibble protocol consists of: • 5 clock ticks low • 7 clock ticks + n clock ticks high Where n is the decimal representation of the 4 bit data. If the nibble data is zero (data = 0x00, n = 0) the nibble duration is 12 ticks, while if the nibble data is 15 (data = 0xFF, n = 15) its duration is 27 ticks. Page 26 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description Figure 34: PWM Clock Period and Frequency nibble = 0 5 ticks 7 ticks nibble = 15 5 ticks 22 ticks The SENT protocol consists of a 56-tick synchronization pulse followed by 8 nibbles. Each nibble is described in Figure 35. Figure 35: Nibble Description Nibble ams Datasheet [v1-00] 2020-Aug-13 Description 1 Status and communication 2 Angle data most significant nibble 3 Angle data middle significant nibble 4 Angle data least significant nibble 5 Rolling counter most significant nibble 6 Rolling counter least significant nibble 7 Inverted nibble #2 8 CRC checksum Page 27 Document Feedback AS5070 − Register Description The Status and Communication nibble includes diagnostic status and the Short Serial Message Format, as defined in the SAE J2716 protocol. Figure 36: Status and Communication Nibble Bit Description 0 Error bit: 0 = no sensor error, 1 = sensor error 1 0 (always) 2 Short Serial Message 3 Message Start The Short Serial Message is transmitted one bit per SENT frame in bit 2 of consecutive frames and consists of 16 bits. The starting bit of a Short Serial Message is indicated by a 1 in bit 3 (Message Start) of the Status and Communication Nibble. Figure 37: Serial Message SENT Message Number 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Message Start 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Short Serial Message[2] SENTMID MAG CRC The Short Serial Message consists of a message ID (SENTMID) and the magnitude of the magnetic field (MAG). The Short Serial Message is protected by a 4-bit CRC. The SENTESM bit enables the Short Serial Message, which is otherwise by default disabled. The angular information is contained in nibbles 2, 3 and 4. Nibbles 5 and 6 contain a rolling counter which counts the number of sent telegrams and rolls over to 0 after reaching the maximum value of 255. The rolling counter can be disabled, which is not needed in the Single Sensor mode, with the SENTRC bit. Because the tick clock period is 3μs, the minimum duration of a SENT telegram is 456μs, while the maximum duration is 816μs. the SENTPP bit enables the Pause Pulse, which creates a SENT transmission with a constant duration of 272 ticks. Page 28 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description Diagnostics The AS5070 has several self-diagnostic features (safety Mechanism), which are listed in Figure 38. Figure 38: Self Diagnostic Features SM Safety Mechanism Recoverable Safe State SM1 Watchdog failure No, if a watchdog error is detected, the sensor provides the error information till a sensor reset happens Output is going into HIZ --> failure band (depending on output resistor) SM2 Offset compensation not complete Yes, if the offset is below the specified threshold, sensor recovers the output Output is forced in failure band. Depending on FBS setting SM3 CORDIC overflow Yes, if the magnetic input field is below the specified threshold, sensor recovers the output Output is forced in failure band. Depending on FBS setting SM4 Magnetic input field too high/too low Yes, if the magnetic field is inside the specific range, after the recovery time the sensor leave the failure Output is forced in failure band. Depending on FBS setting SM5 Vreg undervoltage Yes Hi-z: Failure band related to the out load SM6 Reverse polarity Yes, if reverse polarity issue is solved. No direct safety mechanism, it’s a protection! Hi-z: Failure band related to the out load SM7 VDD overvoltage Yes, if the VDD is below the specified threshold. Hi-z: Failure band related to the out load SM8 VDD undervoltage Yes, if the VDD is above the specified threshold Hi-z: Failure band related to the out load SM9 Broken VDD Yes Hi-z: Failure band related to the out load SM10 ADC check No, sensor stays in failure band till the sensor is resetting. Hi-z: Failure band related to the out load SM11 Analog read fail Yes Hi-z: Failure band related to the out load SM12 Short circuit Yes Hi-z: Failure band related to the out load SM13 Signature No, sensor stays in failure band till the sensor is resetting Hi-z: Failure band related to the out load SM14 Broken GND Yes Hi-z: Failure band related to the out load The FBS setting allows selecting the failure band (lower or upper) when the output goes into diagnostic mode. ams Datasheet [v1-00] 2020-Aug-13 Page 29 Document Feedback AS5070 − Register Description Analog Read Fail (SM11) If an error occurs, the output will be set in a safe condition (high impedance) after a certain time. Digital Readout The device is measuring internally the time between rising and falling edge of the digital signal. The maximum duration of timeout until triggering an error condition is set by PWMRTH and PWMFTH. Figure 39: Timeout Setting for Rising Edge PWMRTH Delay (μs) 0 0 Disabled 0 1 24-28 1 0 56-60 1 1 112-120 Figure 40: Timeout Setting for Falling Edge PWMFTH Delay (μs) 0 0 Disabled 0 1 24-28 1 0 56-60 1 1 112-120 Page 30 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Register Description Analog Readout The device reads back the analog signal and compares it with the digital output value. If the difference is too high, the output driver is kept in high impedance. The maximum duration of timeout until triggering an error condition is set by RDBCKDEB. Figure 41: Timeout Setting for Analog Read Back RDBCKDEB02 RDBCKDEB01 RDBCKDEB00 CORDIC Cycles(1) 0 0 0 0 - Disabled 0 0 1 1 0 1 0 2 0 1 1 4 1 0 0 8 1 0 1 16 1 1 0 32 1 1 1 64 Note(s): 1. 1 CORDIC cycle typ.:111μs ams Datasheet [v1-00] 2020-Aug-13 Page 31 Document Feedback AS5070 − Application Information Application Information Signature Calculation The OTP of AS5070A and AS5070B uses a BIST technique with Multiple Input Signature Register circuits. To activate this BIST a calculation of the Signature Byte is necessary and has to store into the OTP during the programming sequence. For calculating the signature byte the content of the whole memory (0x02 to 0x1D) has to be read. Out of this information the following calculation has to be done. Byte: 0x02 = data2 …. Byte: 0x1D = data29 Unsigned int signature (unsigned int * content) { unsigned int misr,misr_shift,misr_xor,misr_msb; misr = 0; for (int i=0; i AS5070 Settings_Prog 13. Read reg(0x0000) to reg (0x001D) ---> Read register step 2 14. Calculation of Signature Byte out of Read register step 2 content: Signature Byte 15. Write 8Bit Signature to reg(0x001E) 16. Write reg(0x000A) to reg (0x001E) with the custom settings and the calculated values from point 7 + customer lock Bit + Signature byte. --> AS5070 Settings_ Prog_final ams Datasheet [v1-00] 2020-Aug-13 Page 33 Document Feedback AS5070 − Application Information 17. Read reg(0x000A) to reg (0x001E) ---> Read register step 3 18. Comparison of AS5070 Settings_Prog_final with content of read register step 3 19. If point 18 is correct, start the OTP burn procedure by writing: Reg(0x0062)=0x70 and Reg(0x0063)=0x51 20. Programming procedure is complete after 10ms 21. Clear the memory content writing 0x00 into reg (0x001E) 22. Write Reg0x23=0x40 to set the threshold for the guard band test (1) 23. 5ms wait time to refresh the non-volatile memory content with the OTP content 24. Read reg(0x000A) to reg (0x001E) ---> Read register step 4 25. If content from reg (0x001E) compares with content from “Signature Byte” refresh was successful 26. Comparison of AS5070 Settings_Prog_final with content of read register step 4. Mandatory: guard band test (1). 27. If point 26 fails, the test with the guard band (1) was not successful and the device is incorrectly programmed. A reprogramming is not allowed. 28. Clear the memory content writing 0x00 into reg (0x001E) 29. Write Reg0x23=0x00to set the threshold for the guard band test (1) 30. 5ms wait time to refresh the non-volatile memory content with the OTP content 31. Read reg(0x000A) to reg (0x001E) ---> Read register step 5 32. If content from reg (0x001E) compares with content from “Signature Byte” refresh was successful Page 34 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Application Information 33. Comparison of AS5070 Settings_Prog_final with content of read register step 5. Mandatory: Guard band test (1) 34. If point 33 fails, the test with the guard band (1) was not successful and the device is incorrectly programmed. A reprogramming is not allowed. 35. Reset of the device. After power on the Sensor starts in functional mode Note(s): 1. Guard band test: Restricted to temperature range: 25°C ± 20°C Right after the programming procedure (max. 1 hour with same Conditions 25°C ± 20°C) Same VDD voltage The guard band test is only for the verification of the burned OTP fuses during the programming sequence. A use of the guard band in other cases is not allowed. ams Datasheet [v1-00] 2020-Aug-13 Page 35 Document Feedback AS5070 − Application Information Figure 42: OTP Memory Burn and Verification Flowchart Start Write Reg(0x0062) = 0x70 Reg(0x0063) =0x51 Move to mechanical start position Wait 10ms Reset DSP Write reg (0x0023) = 0x10 Write Reg0x1E= 0x00 Write 0x00 into signature byte Read Cordic Value 1 14 Bit value Read Reg 0x33[5]=MSB Reg 0x32[0]=LSB Write Reg0x23= 0x40 Set Guardband 1 Move to mechanical end position Wait 5ms Reset DSP Write reg (0x0023) = 0x10 Read Reg 0x0A To Reg 0x1E Read Cordic Value 2 14 Bit value Read Reg 0x33[5]=MSB Reg 0x32[0]=LSB Reg 0x1F = 0x00 DLL Calculation for Gain; Offset; BP; Clamping Write parameter into DLL and calculate the OTP values Power on cycle Start OTP burning procedure correct Read register Step 3 Read content of signature byte Not correct Verify 3 Not correct Comparison of written content (Content A) with content of Read Register Step 3 Mandatory Guardband Test correct Read Registers Step 1 Read Reg 0x0A To Reg 0x1E Comparison of written content (Reg 0x0A to Reg 0x1E) with content of Read Register Step 1 Verify 1 Guardbandtest fails. Wrong programming Reprogramming not allowed Write Reg0x1E= 0x00 Write Reg 0x0A to Write Reg 0x1E ^ϱϭϳϬͬͬͬ Settings Write Reg0x23= 0x00 Not correct RESET Wait 5ms Write 0x00 into signature byte Set Guardband 2 correct correct correct Read Reg 0x0A To Reg 0x1E Programming Pass2Function Programming or Pass2Function Read register Step 4 pass2function Measurement Verification Read content of signature byte Reg 0x1E = 0x00 Programming Not correct Verify 5 Not correct Comparison of written content (Content A) with content of Read Register Step 4 MANDATORY GUARDBAND-TEST correct Write customer content + customer lock Bit Page 36 Document Feedback Write Reg 0x0A to Write Reg 0x1E Reading of full OTP content (customer area and ams area) Read Reg 0x00 To Reg 0x1D Signature Byte calculation Calculate Signature 8 Bit Signature Byte Write Reg 0x1E Writing again the full customer area content + signature byte (Content A) Write Reg 0x0A To Reg 0x1E Read Registers Step 2 Read Reg 0x0A To Reg 0x1E Comparison of written content (Content A) with content of Read Register Step 2 Verify 2 Reset Guardbandtest fails. Wrong programming Reprogramming not allowed END Correct: Device in functional mode Not correct Reset ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Application Information SOIC8 Figure 43: Application with Pull-Down Load Resistor (SOIC-8) Sensor PCB ECU VDD R1* RLPU VDD TP4 VDD3V3 OUT R2* OUT AS5070 C1 C4* C2 TP1 TP3 TP2 GND C3 CL GND Figure 44: Application with Pull-Up Load Resistor (SOIC-8) Sensor PCB ECU VDD R1* VDD TP4 VDD3V3 OUT R2* OUT AS5070 C1 C4* C2 TP1 TP3 TP2 GND CL C3 RLPD GND Figure 43 and Figure 44 show the recommended schematic in the application. All components marked with (*) are optional and can be used to further increase the EMC. ams Datasheet [v1-00] 2020-Aug-13 Page 37 Document Feedback AS5070 − Application Information External Components Figure 45: Recommended External Components for AS5070A Component Symbol Min Typ Max Unit VDD buffer capacitor C1 80 100 120 nF VDD3V3 regulator capacitor C2 80 100 120 nF OUT load capacitor (sensor PCB) C3 0 4.7 nF VDD capacitor (optional) C4* 4.7 nF VDD serial resistor (optional) R1* 10 Ω OUT load capacitor (ECU) CL OUT serial resistor (optional) R2* OUT pull-up resistance RLPU 4 10 kΩ OUT pull-down resistance RLPD 4 10 kΩ 0 20 Notes Do not increase due to programming over output. nF Ω 50 Figure 46: Recommended External Components for AS5070B with PWM Output Component Symbol Min Typ Max Unit VDD buffer capacitor C1 80 100 120 nF VDD3V3 regulator capacitor C2 80 100 120 nF OUT load capacitor (sensor PCB) C3 0 4.7 nF VDD capacitor (optional) C4* 4.7 nF VDD serial resistor (optional) R1* 10 Ω OUT load capacitor (ECU) CL OUT serial resistor (optional) R2* OUT pull-up resistance RLPU 1 10 kΩ OUT pull-down resistance RLPD 1 10 kΩ Page 38 Document Feedback 0 20 Notes Do not increase due to programming over output. nF Ω 50 ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Application Information Figure 47: Recommended External Components for the AS5070B with SENT Output Component Symbol Min Typ Max Unit VDD buffer capacitor C1 0.8 1 1.2 μF VDD3V3 regulator capacitor C2 80 100 120 nF OUT load capacitor (sensor PCB) C3 0 4.7 nF VDD capacitor (optional) C4* 4.7 nF VDD serial resistor (optional) R1* 10 kΩ OUT load capacitor (ECU) CL OUT serial resistor (optional) R2* OUT pull-up resistance RLPU 10 50 kΩ OUT pull-down resistance RLPD 10 50 kΩ ams Datasheet [v1-00] 2020-Aug-13 0 20 50 Notes Do not increase due to programming over output. nF kΩ Page 39 Document Feedback AS5070 − Application Information Mechanical Data The internal Hall elements are placed in the center of the package on a circle with a radius of 1.25mm. Figure 48: Hall Element Positions Note(s): 1. All dimensions in mm. 2. Die thickness 356μm nom. 3. Adhesive thickness 20 ± 10μm. 4. Lead frame downest 200 ± 25μm. 5. Lead frame thickness 200 ± 8μm. Page 40 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Package Drawings & Markings Package Drawings & Markings Figure 49: Packaging Outline Drawing (SOIC-8) RoHS Green ams Datasheet [v1-00] 2020-Aug-13 Page 41 Document Feedback AS5070 − Pack age Drawings & Mark ings Figure 50: Package Markings AS5070 - SOIC8 AS5070B YYWWMZZ AS5070A YYWWMZZ @ @ Figure 51: Packaging Code YYWWMZZ@ YY Last two digits of the manufacturing year Page 42 Document Feedback WW Manufacturing week M Plant identifier ZZ Free choice/ traceability code @ Sublot identifier ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Ordering & Contact Information Ordering & Contact Information Figure 52: Ordering Information Ordering Code Package Marking Delivery Form Delivery Quantity AS5070A-HSOT SOIC8 AS5070A 13” Tape & Reel in dry pack 2500 pcs/reel AS5070A-HSOM SOIC8 AS5070A 7” Tape & Reel in dry pack 500 pcs/reel AS5070B-HSOT SOIC8 AS5070B 13” Tape & Reel in dry pack 2500 pcs/reel AS5070B-HSOM SOIC8 AS5070B 7” Tape & Reel in dry pack 500 pcs/reel Buy our products or get free samples online at: www.ams.com/Products Technical Support is available at:   www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/Contact Headquarters ams AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v1-00] 2020-Aug-13 Page 43 Document Feedback AS5070 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories plus additional 4 substance categories (per amendment EU 2015/863), including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br/Cl): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) and do not contain Chlorine (Cl not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 44 Document Feedback ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v1-00] 2020-Aug-13 Page 45 Document Feedback AS5070 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 46 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v1-00] 2020-Aug-13 AS5070 − Revision Information Revision Information Changes from 0-01 (2020-Aug-11) to current revision 1-00 (2020-Aug-13) Updated note 1 under Figure 48 ams Datasheet [v1-00] 2020-Aug-13 Page 40 Page 47 Document Feedback AS5070 − Content Guide Content Guide Page 48 Document Feedback 1 2 2 3 General Description Key Benefits and Features Applications Block Diagram 4 5 Pin Assignments Absolute Maximum Ratings 7 12 Electrical Characteristics Timing Characteristics 13 Detailed Description 14 17 18 18 18 19 21 24 24 24 25 29 30 30 31 Register Description UART Interface Exiting Communication Mode Burning the OTP Registers Customer ID Output Linear Transfer Function Multiple Quadrants Extended Magnetic Input Range Analog Output (AS5070A) PWM Output (AS5070B) SENT Output (AS5070B) Diagnostics Analog Read Fail (SM11) Digital Readout Analog Readout 32 32 33 33 37 38 40 Application Information Signature Calculation Programming Parameter Burn and Verification of the OTP Memory SOIC8 External Components Mechanical Data 41 43 44 45 46 47 Package Drawings & Markings Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ams Datasheet [v1-00] 2020-Aug-13
AS5070B-HSOM 价格&库存
很抱歉,暂时无法提供与“AS5070B-HSOM”相匹配的价格&库存,您可以联系我们找货
AS5070B-HSOM
  • 500+16.06958
  • 1000+15.17683
  • 10000+14.28407
库存:500
