Datasheet V1.0a
TMR2905
Ultra High Sensitivity TMR linear sensor
General Description
The TMR2905 linear sensor utilizes a unique push-pull Wheatstone bridge composed of four unshielded TMR sensor elements.
The unique bridge design provides a high sensitivity differential output that is linearly proportional to a magnetic field applied
parallel to the surface of the sensor package, and it provides superior temperature compensation of the output. The TMR2905 is
packaged in 6mm X 5mm X 1.5mm SOP8 named TMR2905P, and packaged in3mmX3mmX0.75mm DFN8 named TMR2905D.
Features and Benefits
Tunneling Magneto resistance (TMR) Technology
Ultra High Sensitivity (50~60mV/V/Oe)
Large Dynamic Range
Very Low Power Consumption
Excellent Thermal Stability
Very Low Hysteresis
Compatible with wide Range of Supply Voltages
TMR2905
Ultra Low Noise Spectral Density(<2nT/sqrt(Hz)@1Hz)
PN series
Resistance
Package
TMR2905SP
5kOhm
SOP8
TMR2905BP
45kOhm
SOP8
Weak Magnetic Field Sensing
TMR2905SD
5kOhm
DFN8
Current Sensors
TMR2905BD
45kOhm
DFN8
Applications
Position and Displacement Sensing
Transfer Curve
The following figure shows the response of the TMR2905 to an applied magnetic field in the range of ±15 Oe and ±30 Oe when
the TMR2905 is biased at 1V.
1/5
Datasheet V1.0a
Pin Configuration
SOP8 Top view
DFN8 Bottom view
Pin No.
Pin Name
Pin Function
1,2,7,8
N/A
Not Connected
3
GND
Ground
4
V-
Analog Differential Output 2
5
V+
Analog Differential Output 1
6
Vcc
Supply Voltage
Absolute Maximum Ratings
Parameter
Symbol
Limit
Unit
Supply Voltage
VCC
7
V
Reverse Supply Voltage
VRCC
7
V
Max Exposed Field
HE
4000
Oe
ESD Voltage
VESD
4000
V
Operating Temperature
TA
-40~125
°C
Storage Temperature
Tstg
-50 ~150
°C
(1)
Specification (VCC=1.0V, TA=25°C,Differential Output)
Parameter
Symbol
Conditions
Supply Voltage
VCC
Operating
Supply Current
ICC
Output Open
R
Between Vcc and GND
Sensitivity
SEN
Fit @±5 Oe
Saturation Field
Hsat
Non-Linearity
NONL
Offset Voltage
Voffset
Hysteresis
Hys
Fit @±30 Oe
TCR
H = 0 Oe
Resistance
(3)
TMR2905S
TMR2905B
Temperature Coefficient of
Resistance
Sensitivity
Min
Typ
1
0.2,0.02
7
V
(2)
mA
5
8
KOhm
35
45
55
KOhm
65
mV/V/Oe
45
±10
Oe
2
%FS
-30
2/5
Unit
2
Fit @±5 Oe
TCS
Max
30
mV/V
1
Oe
-500
PPM/°C
-1100
PPM/°C
Datasheet V1.0a
Notes:
(1) 1 Oe (Oersted) = 1 Gauss in air = 0.1 millitesla = 79.8 A/m.
(2) ICC = VCC/R
(3)45Kohm be defined TMR2905B,5Kohm be defined TMR2905S,Custom resistance may be available upon request.
Package Information
SOP8 封装图
DFN8 package drawing
3/5
Datasheet V1.0a
TMR Sensor Position
SOP8 package
DFN8 package
Top view and side view (unit:mm)
4/5
Datasheet V1.0a
MultiDimension Technology Co., Ltd.
Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China
Web: www.dowaytech.com/en
Email: info@dowaytech.com
The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable.
Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the
right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not
assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in
appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to
fully indemnify MultiDimension for any damages resulting from such applications.
5/5
很抱歉,暂时无法提供与“TMR2905P”相匹配的价格&库存,您可以联系我们找货
