TMR9001
TMR9001
    MDT(多维)
    SOIC-8
    TMR SENSOR PICO-TESLA LOW-NOISE
TMR9001 数据手册
Datasheet V1.0a TMR2922 Ultra High Sensitivity TMR linear sensor General Description The TMR2922 linear sensor utilizes a unique push-pull Wheatstone bridge composed of four unshielded TMR sensor elements. The unique bridge design provides a high sensitivity differential output that is linearly proportional to a magnetic field applied parallel to the surface of the sensor package, and it provides superior temperature compensation of the output. The TMR2922 is available a 6mm X 5mm X 1.5mm SOP8 package. Features and Benefits  Tunneling Magneto resistance (TMR) Technology  High Sensitivity (7~15mV/V/Oe)  Large Dynamic Range  Very Low Power Consumption  Excellent Thermal Stability  Very Low Hysteresis  Compatible with wide Range of Supply Voltages  Ultra Low Noise Spectral Density(<1nT/sqrt(Hz)@1Hz) Applications  Weak Magnetic Field Sensing  Current Sensors TMR2922  Position and Displacement Sensing Transfer Curve The following figure shows the response of the TMR2922 to an applied magnetic field in the range of ±15 Oe when the TMR2922 is biased at 1V. 1/4 Datasheet V1.0a Pin Configuration (Arrow indicates direction of applied field that generates a positive output voltage.) SOP8 Top View Pin No. Pin Name Pin Function 5 Vcc Supply Voltage 6 V+ Analog Differential Output 1 7 V- Analog Differential Output 2 8 GND Ground 1,2,3,4 N/A Not Connected Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 7 V Reverse Supply Voltage VRCC 7 V Max Exposed Field HE 4000 Oe ESD Voltage VESD 4000 V Operating Temperature TA -40~125 °C Storage Temperature Tstg -50 ~150 °C (1) Specification (VCC=1.0V, TA=25°C,Differential Output) Parameter Symbol Conditions Supply Voltage VCC Supply Current ICC Resistance R Sensitivity SEN Saturation Field Hsat Non-Linearity NONL Offset Voltage Voffset Hysteresis Hys Min Typ Max Unit Operating 1 7 V Output Open 0.5 2 Fit @±15 Oe 7 Fit @±15 Oe -20 Fit @±15 Oe 2/4 mA (2) KOhm 18 mV/V/Oe ±30 Oe 2 %FS 20 mV/V 3 Oe Datasheet V1.0a Temperature Coefficient of Resistance Temperature Coefficient of Sensitivity TCR H = 0 Oe TCS Notes: (1) 1 Oe (Oersted) = 1 Gauss in air = 0.1 millitesla = 79.8 A/m. (2) Custom resistance may be available upon request. Package Information TMR Sensor Position Top view and side view (unit:mm) 3/4 -500 PPM/°C -1100 PPM/°C Datasheet V1.0a MultiDimension Technology Co., Ltd. Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 4/4
TMR9001 价格&库存
很抱歉,暂时无法提供与“TMR9001”相匹配的价格&库存,您可以联系我们找货
