05-12-D-0076-A-4-06-4-T 数据手册
PRODUCT SPECIFICATION
Part
Number
Product
Description
Doc
Number
Flat Flex Cables
Rev
A
FFC general product specification
FFC_PS
Prepared
YR
www.gct.co
Checked
KL
Date
07/07/23
Page
1
Approved
PH
Part
Number
Product
Description
Doc
Number
Flat Flex Cables
Rev
A
FFC_PS
Prepared
YR
Checked
KL
Date
07/07/23
Page
2
Approved
PH
1. SCOPE
This specification covers tolerances and characteristics of standard Flat Flex Cables, applicable to
FFC Cable drawing rev.B or later.
2. GENERAL TOLERANCES
No.
Description
1
Overall Length (L)
2
Conductor Thickness
3
Conductor Width
4
Pitch
5
Cable Width (W)
6
Exposed Conductor Length
7
Support Strip Length
Size (mm)
≤50
51 – 100
101 – 300
301 – 800
>800
0.035
0.05
0.1
0.3
0.65
0.5
1.0
0.5
1.0
≤6
4–6
6–7
>8
www.gct.co
FFC pitch & tolerance (mm)
0.5
1.0
±1.5
±2
±3
±5
±1%
±0.005
±0.005
±0.01
±0.03
±0.03
±0.05
±0.05
±0.08
±0.1
±1
±1
±1.5
±2
Part
Number
Product
Description
Doc
Number
Flat Flex Cables
Rev
A
FFC_PS
Prepared
YR
Checked
KL
Date
07/07/23
Page
3
Approved
PH
3. CHARACTERISTICS
Item
Conductor
Resistance
(0.5mm pitch)
Conductor
Resistance
(1.0mm pitch)
Insulation Resistance
Rated Current
(0.5mm pitch)
Rated Current
(1.0mm pitch)
Electrical
Test Condition
Requirement
2.2Ω/m Max.
JIS-C-3102 (at 20°C)
1.1Ω/m Max.
Apply 500Vdc for 1 min
1000MΩ Min
0.5A
1.0A
500Vac, 0.5mA, 1 min, adjacent
conductors in air
Dielectric Strength
No breakdown
1000Vac, 0.5mA, 1 min, adjacent
conductors in water
Physical
Continuity
DC3V tester
Rated Voltage and
Temperature
UL 758
Operating
Temperature
Fixed wiring
Flammability
UL 758 VW-1
Resistance to Heat
+85°C or +110°C (depending on UL
style) for 96hrs
Resistance to
Humidity
+40°C, 95% RH for 96hrs
www.gct.co
No open circuit with
each conductor, no
short circuit to
adjacent conductors
60V, +80°C or
+105°C depending on
UL style
-40°C to +80°C or
+105°C depending on
UL style
Pass
No negative impact
on insulation
resistance or
dielectric strength
No negative impact
on insulation
resistance or
dielectric strength
Part
Number
Product
Description
Doc
Number
Flat Flex Cables
Rev
A
FFC_PS
Temperature and
Humidity Cycling
Flex Life
(Folding Test)
Flex Life
(Reciprocating Test)
Abrasion
Insulation Elongation
Insulation Tensile
Strength
Adhesive Strength
Durability
Prepared
YR
Checked
-40°C (0% RH) → +25°C (65% RH)
→ +85°C (95% RH) → +25°C (65%
RH), 5 cycles
600g weight, 0.5mm R, 180°, 60
cycles/min
10mm R, 180mm stroke, 70
cycles/min
Ø0.5mm, 600g, 60 cycles/min
JIS-K-6732
Between conductor and insulator
Between insulator and insulator
Between support strip and insulator
Insertion and withdrawal
www.gct.co
KL
Date
07/07/23
Page
4
Approved
PH
No negative impact
on insulation
resistance or
dielectric strength
100 cycles Min.
100,000 cycles Min.
100,000 cycles Min.
70% Min.
3.5kg/mm² Min.
0.2kg/cm Min.
0.6kg/cm Min.
0.2kg/cm Min.
30 cycles Min.
Part
Number
Product
Description
Doc
Number
Flat Flex Cables
Rev
A
FFC_PS
Prepared
YR
Checked
KL
Date
07/07/23
Page
5
Approved
Revision details:
Revision
Information
Page
Release Date
0.1
Initial draft
23/06/2023
0.2
Revised draft
05/07/2023
A
Formal release
07/07/2023
www.gct.co
PH
05-12-D-0076-A-4-06-4-T 价格&库存
很抱歉,暂时无法提供与“05-12-D-0076-A-4-06-4-T”相匹配的价格&库存,您可以联系我们找货
