ESP32-C3 Series
Datasheet
Ultra-Low-Power SoC with RISC-V Single-Core CPU
2.4 GHz Wi-Fi (802.11 b/g/n) and Bluetooth® 5 (LE)
Optional 4 MB flash in the chip’s package
QFN32 (5×5 mm) Package
Including:
ESP32-C3
ESP32-C3FN4 – Not Recommended for New Designs (NRND)
ESP32-C3FH4
ESP32-C3FH4AZ
Version 1.5
Espressif Systems
Copyright © 2023
www.espressif.com
Product Overview
ESP32-C3 is an low-power and highly-integrated MCU-based solution that supports 2.4 GHz Wi-Fi and
Bluetooth® Low Energy (Bluetooth LE).
The functional block diagram of the SoC is shown below.
Espressif ESP32-C3 Wi-Fi + Bluetooth® Low Energy SoC
CPU and Memory
JTAG
ROM
RF
Synthesizer
SRAM
2.4 GHz
Transmitter
Cache
2.4 GHz Balun +
Switch
2.4 GHz
Receiver
RISC-V 32-bit
Microprocessor
RF
Wireless Digital Circuits
External
Main Clock
Fast RC
Oscillator
Bluetooth LE Link Controller
Phase Lock
Loop
Bluetooth LE Baseband
Peripherals
GDMA
RMT
SPI0/1
SPI2
I2C
I2S
UART
TWAI®
World
Controller
Debug
Assistant
Generalpurpose
Timers
Wi-Fi
Baseband
Wi-Fi MAC
Security
GPIO
eFuse
Controller
DIG ADC
Temperature
Sensor
LED PWM
USB Serial/
JTAG
System
Timer
Main System
Watchdog
Timers
SHA
RSA
RNG
HMAC
Digital
Signature
Secure Boot
Flash
Encryption
RTC
Watchdog
Timer
Super
Watchdog
AES
RTC
RTC
Memory
PMU
Brownout Detector
Power consumption
Normal
Low power consumption components capable of working in Deep-sleep mode
ESP32-C3 Functional Block Diagram
For more information on power consumption, see Section 3.7 Power Management.
Espressif Systems
2
Submit Documentation Feedback
ESP32-C3 Series Datasheet v1.5
Features
Wi-Fi
• IEEE 802.11 b/g/n-compliant
• Supports 20 MHz, 40 MHz bandwidth in 2.4 GHz band
• 1T1R mode with data rate up to 150 Mbps
• Wi-Fi Multimedia (WMM)
• TX/RX A-MPDU, TX/RX A-MSDU
• Immediate Block ACK
• Fragmentation and defragmentation
• Transmit opportunity (TXOP)
• Automatic Beacon monitoring (hardware TSF)
• 4 × virtual Wi-Fi interfaces
• Simultaneous support for Infrastructure BSS in Station mode, SoftAP mode, Station + SoftAP mode, and
promiscuous mode
Note that when ESP32-C3 scans in Station mode, the SoftAP channel will change along with the Station
channel
• Antenna diversity
• 802.11mc FTM
Bluetooth®
• Bluetooth LE: Bluetooth 5, Bluetooth mesh
• High power mode (20 dBm)
• Speed: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
• Advertising extensions
• Multiple advertisement sets
• Channel selection algorithm #2
• Internal co-existence mechanism between Wi-Fi and Bluetooth to share the same antenna
CPU and Memory
• 32-bit RISC-V single-core processor, up to 160 MHz
• CoreMark® score:
– 1 core at 160 MHz: 407.22 CoreMark; 2.55 CoreMark/MHz
• 384 KB ROM
• 400 KB SRAM (16 KB for cache)
Espressif Systems
3
• 8 KB SRAM in RTC
• In-package flash (see details in Chapter 1 ESP32-C3 Series Comparison)
• SPI, Dual SPI, Quad SPI, and QPI interfaces that allow connection to multiple off-package flash
• Access to flash accelerated by cache
• Supports flash in-Circuit Programming (ICP)
Advanced Peripheral Interfaces
• 22 or 16 programmable GPIOs
• Digital interfaces:
– 3 × SPI
– 2 × UART
– 1 × I2C
– 1 × I2S
– Remote control peripheral, with 2 transmit channels and 2 receive channels
– LED PWM controller, with up to 6 channels
– Full-speed USB Serial/JTAG controller
– General DMA controller (GDMA), with 3 transmit channels and 3 receive channels
– 1 × TWAI® controller compatible with ISO 11898-1 (CAN Specification 2.0)
• Analog interfaces:
– 2 × 12-bit SAR ADCs, up to 6 channels
– 1 × temperature sensor
• Timers:
– 2 × 54-bit general-purpose timers
– 3 × digital watchdog timers
– 1 × analog watchdog timer
– 1 × 52-bit system timer
Power Management
• Fine-resolution power control through a selection of clock frequency, duty cycle, Wi-Fi operating modes,
and individual power control of internal components
• Four power modes designed for typical scenarios: Active, Modem-sleep, Light-sleep, Deep-sleep
• Power consumption in Deep-sleep mode is 5 µA
• RTC memory remains powered on in Deep-sleep mode
Espressif Systems
4
Security
• Secure boot - permission control on accessing internal and external memory
• Flash encryption - memory encryption and decryption
• 4096-bit OTP, up to 1792 bits for users
• Cryptographic hardware acceleration:
– AES-128/256 (FIPS PUB 197)
– SHA Accelerator (FIPS PUB 180-4)
– RSA Accelerator
– Random Number Generator (RNG)
– HMAC
– Digital signature
RF Module
• Antenna switches, RF balun, power amplifier, low-noise receive amplifier
• Up to +21 dBm of power for an 802.11b transmission
• Up to +20 dBm of power for an 802.11n transmission
• Up to -105 dBm of sensitivity for Bluetooth LE receiver (125 Kbps)
Applications
With low power consumption, ESP32-C3 is an ideal choice for IoT devices in the following areas:
• Smart Home
• POS machines
• Industrial Automation
• Service robot
• Health Care
• Audio Devices
• Consumer Electronics
• Generic Low-power IoT Sensor Hubs
• Smart Agriculture
• Generic Low-power IoT Data Loggers
Espressif Systems
5
Contents
Note:
Check the link or the QR code to make sure that you use the latest version of this document:
https://www.espressif.com/documentation/esp32-c3_datasheet_en.pdf
Contents
Product Overview
2
Features
3
Applications
5
1
11
1.1
Nomenclature
11
1.2
Comparison
11
2
Pins
12
2.1
Pin Layout
12
2.2
Pin Overview
14
2.3
IO Pins
17
2.3.1
IO MUX and GPIO Functions
17
2.3.2
Analog Functions
19
2.3.3
Restrictions for GPIOs
Analog Pins
21
2.5
Power Supply
22
2.5.1
Power Pins
22
2.5.2
Power Scheme
22
2.5.3
Chip Power-up and Reset
23
2.6
Strapping Pins
24
2.6.1
Chip Boot Mode Control
25
2.6.2
ROM Messages Printing Control
25
2.7
Pin Mapping Between Chip and Flash
27
3
Functional Description
28
3.1
CPU and Memory
28
3.1.1
CPU
28
3.1.2
Internal Memory
28
3.1.3
Off-package Flash
28
3.1.4
Address Mapping Structure
29
3.1.5
Cache
29
System Clocks
30
3.2.1
CPU Clock
30
3.2.2
RTC Clock
30
Analog Peripherals
30
3.2
3.3
Espressif Systems
6
Contents
3.4
3.3.1
Analog-to-Digital Converter (ADC)
30
3.3.2
Temperature Sensor
31
Digital Peripherals
31
3.4.1
General Purpose Input / Output Interface (GPIO)
31
3.4.2
Serial Peripheral Interface (SPI)
31
3.4.3
Universal Asynchronous Receiver Transmitter (UART)
32
3.4.4
I2C Interface
32
3.4.5
I2S Interface
33
3.4.6
Remote Control Peripheral
33
3.4.7
LED PWM Controller
33
3.4.8
General DMA Controller
34
3.4.9
USB Serial/JTAG Controller
34
3.5
3.6
3.4.10 TWAI Controller
34
Radio and Wi-Fi
35
3.5.1
2.4 GHz Receiver
35
3.5.2
2.4 GHz Transmitter
35
3.5.3
Clock Generator
35
3.5.4
Wi-Fi Radio and Baseband
36
3.5.5
Wi-Fi MAC
36
3.5.6
Networking Features
36
Bluetooth LE
36
3.6.1
Bluetooth LE Radio and PHY
37
3.6.2
Bluetooth LE Link Layer Controller
37
3.7
Power Management
37
3.8
Timers
39
3.8.1
General Purpose Timers
39
3.8.2
System Timer
39
3.8.3
Watchdog Timers
40
3.9
Cryptographic Hardware Accelerators
40
3.10
Physical Security Features
41
3.11
Peripheral Pin Configurations
41
4
Electrical Characteristics
43
4.1
Absolute Maximum Ratings
43
4.2
Recommended Power Supply Characteristics
43
4.3
VDD_SPI Output Characteristics
44
4.4
DC Characteristics (3.3 V, 25 °C)
44
4.5
ADC Characteristics
45
4.6
Current Consumption
45
4.6.1
RF Current Consumption in Active Mode
45
4.6.2
Current Consumption in Other Modes
46
4.7
Reliability
46
4.8
Wi-Fi Radio
47
4.8.1
Wi-Fi RF Transmitter (TX) Specifications
47
4.8.2
Wi-Fi RF Receiver (RX) Specifications
48
4.9
Bluetooth LE Radio
Espressif Systems
49
7
Contents
4.9.1
Bluetooth LE RF Transmitter (TX) Specifications
49
4.9.2
Bluetooth LE RF Receiver (RX) Specifications
51
5
Packaging
54
6
Related Documentation and Resources
55
Appendix A – ESP32-C3 Consolidated Pin Overview
56
Revision History
57
Espressif Systems
8
List of Tables
List of Tables
1-1 ESP32-C3 Series Comparison
11
2-1 Pin Overview
15
2-2 Power-Up Glitches on Pins
16
2-3 IO MUX Pin Functions
17
2-4 RTC and Analog Functions
19
2-5 Analog Pins
21
2-6 Power Pins
22
2-7 Voltage Regulators
22
2-8 Description of Timing Parameters for Power-up and Reset
23
2-9 Default Configuration of Strapping Pins
24
2-10 Description of Timing Parameters for the Strapping Pins
24
2-11 Chip Boot Mode Control
25
2-12 ROM Messages Printing Control
26
2-13 Pin Mapping Between Chip and In-package Flash
27
3-1 Components and Power Domains
39
3-2 Peripheral Pin Configurations
41
4-1 Absolute Maximum Ratings
43
4-2 Recommended Power Characteristics
43
4-3 VDD_SPI Internal and Output Characteristics
44
4-4 DC Characteristics (3.3 V, 25 °C)
44
4-5 ADC Characteristics
45
4-6 ADC Calibration Results
45
4-7 Wi-Fi Current Consumption Depending on RF Modes
45
4-8 Current Consumption in Modem-sleep Mode
46
4-9 Current Consumption in Low-Power Modes
46
4-10 Reliability Qualifications
46
4-11 Wi-Fi Frequency
47
4-12 TX Power with Spectral Mask and EVM Meeting 802.11 Standards
47
4-13 TX EVM Test
47
4-14 RX Sensitivity
48
4-15 Maximum RX Level
48
4-16 RX Adjacent Channel Rejection
49
4-17 Bluetooth LE Frequency
49
4-18 Transmitter Characteristics - Bluetooth LE 1 Mbps
49
4-19 Transmitter Characteristics - Bluetooth LE 2 Mbps
50
4-20 Transmitter Characteristics - Bluetooth LE 125 Kbps
50
4-21 Transmitter Characteristics - Bluetooth LE 500 Kbps
50
4-22 Receiver Characteristics - Bluetooth LE 1 Mbps
51
4-23 Receiver Characteristics - Bluetooth LE 2 Mbps
51
4-24 Receiver Characteristics - Bluetooth LE 125 Kbps
52
4-25 Receiver Characteristics - Bluetooth LE 500 Kbps
52
Espressif Systems
9
List of Figures
List of Figures
1-1 ESP32-C3 Series Nomenclature
11
2-1 ESP32-C3 Pin Layout (Top View)
12
2-2 ESP32-C3FH4AZ Pin Layout (Top View)
13
2-3 ESP32-C3 Power Scheme
23
2-4 Visualization of Timing Parameters for Power-up and Reset
23
2-5 Visualization of Timing Parameters for the Strapping Pins
25
3-1 Address Mapping Structure
29
3-2 Components and Power Domains
38
5-1 QFN32 (5×5 mm) Package
54
Espressif Systems
10
1.1 Nomenclature
ESP32-C3
H
F
x
AZ
Other Identification Code
Flash
Flash temperature
H: High temperature
N: Normal temperature
Flash
Chip series
Figure 1-1. ESP32-C3 Series Nomenclature
1.2 Comparison
Table 1-1. ESP32-C3 Series Comparison
Ordering Code1
In-Package Flash
Ambient Temp.2(°C)
–40 ∼ 105
ESP32-C3FN4 (NRND)
4 MB
ESP32-C3FH4
ESP32-C33
ESP32-C3FH4AZ
4
GPIO No.
Chip Revision5
QFN32 (5*5)
22
v0.4
–40 ∼ 85
QFN32 (5*5)
22
v0.4
4 MB
–40 ∼ 105
QFN32 (5*5)
22
v0.4
4 MB
–40 ∼ 105
QFN32 (5*5)
16
v0.4
Package (mm)
1
For details on chip marking and packing, see Section 5 Packaging.
2
Ambient temperature specifies the recommended temperature range of the environment immediately outside an Espressif chip.
3
ESP32-C3 requires an SPI flash off the chip’s package. For details about SPI modes, see Section 2.7 Pin Mapping
Between Chip and Flash.
4
For ESP32-C3FH4AZ, SPI0/SPI1 pins for flash connection are not bonded.
5
For how to identify chip revisions, please refer to ESP32-C3 Series SoC Errata.
Espressif Systems
11
2 Pins
2 Pins
25 GPIO18
26 GPIO19
27 U0RXD
28 U0TXD
29 XTAL_N
30 XTAL_P
31 VDDA
32 VDDA
2.1 Pin Layout
LNA_IN
1
24 SPIQ
VDD3P3
2
23 SPID
VDD3P3
3
22 SPICLK
XTAL_32K_P
4
21 SPICS0
XTAL_32K_N
5
20 SPIWP
GPIO2
6
CHIP_EN
7
GPIO3
8
ESP32-C3
19 SPIHD
18 VDD_SPI
17 VDD3P3_CPU
GPIO10 16
GPIO9 15
GPIO8 14
MTDO 13
MTCK 12
VDD3P3_RTC 11
MTDI 10
MTMS
9
33 GND
Figure 2-1. ESP32-C3 Pin Layout (Top View)
Espressif Systems
12
25 GPIO18
26 GPIO19
27 U0RXD
28 U0TXD
29 XTAL_N
30 XTAL_P
31 VDDA
32 VDDA
2 Pins
LNA_IN
1
24 NC
VDD3P3
2
23 NC
VDD3P3
3
22 NC
XTAL_32K_P
4
21 NC
XTAL_32K_N
5
20 NC
GPIO2
6
CHIP_EN
7
GPIO3
8
ESP32-C3FH4AZ
19 NC
18 VDD_SPI
17 VDD3P3_CPU
GPIO10 16
GPIO9 15
GPIO8 14
MTDO 13
MTCK 12
VDD3P3_RTC 11
MTDI 10
MTMS
9
33 GND
Figure 2-2. ESP32-C3FH4AZ Pin Layout (Top View)
Espressif Systems
13
2 Pins
2.2 Pin Overview
The ESP32-C3 chip integrates multiple peripherals that require communication with the outside world. To keep
the chip package size reasonably small, the number of available pins has to be limited. So the only way to route
all the incoming and outgoing signals is through pin multiplexing. Pin muxing is controlled via software
programmable registers (see ESP32-C3 Technical Reference Manual > Chapter IO MUX and GPIO Matrix).
All in all, the ESP32-C3 chip has the following types of pins:
• IO pins with the following predefined sets of functions to choose from:
– Each IO pin has predefined IO MUX and GPIO functions – see Table 2-3 IO MUX and GPIO Functions
– Some IO pins have predefined analog functions – see Table 2-4 Analog Functions
Predefined functions means that each IO pin has a set of direct connections to certain on-chip components.
During run-time, the user can configure which component from a predefined set to connect to a certain pin
at a certain time via memory mapped registers (see the TRM).
• Analog pins that have exclusively-dedicated analog functions – see Table 2-5 Analog Pins
• Power pins supply power to the chip components and non-power pins – see Table 2-6 Power Pins
Notes for Table 2-1 Pin Overview (see below):
1. For more information, see respective sections below. Alternatively, see Appendix A – ESP32-C3
Consolidated Pin Overview.
2. Bold marks the pin function set in which a pin has its default function in the default boot mode. See
Section 2.6.1 Chip Boot Mode Control.
3. In column Pin Providing Power, regarding pins powered by VDD_SPI:
• Power actually comes from the internal power rail supplying power to VDD_SPI. For details, see
Section 2.5.2 Power Scheme.
4. In column Pin Providing Power, regarding pins powered by VDD3P3_CPU / VDD_SPI:
• Pin Providing Power (either VDD3P3_CPU or VDD_SPI) can be configured via a register, see
ESP32-C3 Technical Reference Manual > Chapter IO MUX and GPIO pins.
5. Except for GPIO18 and GPIO19 whose default drive strength is 40 mA, the default drive strength for all the
other pins is 20 mA.
6. Column Pin Settings shows predefined settings at reset and after reset with the following abbreviations:
• IE – input enabled
• WPU – internal weak pull-up resistor enabled
• WPD – internal weak pull-down resistor enabled
• USB_PU – USB pull-up resistor enabled
– By default, the USB function is enabled for USB pins (i.e., GPIO18 and GPIO19), and the pin
pull-up is decided by the USB pull-up resistor. The USB pull-up resistor is controlled by
USB_SERIAL_JTAG_DP/DM_PULLUP and the pull-up value is controlled by
Espressif Systems
14
2 Pins
USB_SERIAL_JTAG_PULLUP_VALUE. For details, see ESP32-C3 Technical Reference Manual >
Chapter USB Serial/JTAG Controller)
– When the USB function is disabled, USB pins are used as regular GPIOs and the pin’s internal
weak pull-up and pull-down resistors are disabled by default (configurable by IO_MUX_FUN_
WPU/WPD)
7. Depends on the value of EFUSE_DIS_PAD_JTAG
• 0 - default value. Input enabled, and internal weak pull-up resistor enabled (IE & WPU)
• 1 - input enabled (IE)
8. Output enabled
9. By default VDD_SPI is the power supply pin for in-package and off-package flash. It can be reconfigured as
a GPIO pin, if the chip is connected to an off-package flash, and this flash is powered by an external power
supply. For details about reconfiguration, please refer to ESP32-C3 Technical Reference Manual > Chapter
IO MUX and GPIO Matrix.
10. For ESP32-C3FH4AZ, pins within the frame (namely pin 19 ∼ pin 24) are not bonded, and are labelled as
”not connected”.
Table 2-1. Pin Overview
Pin
Pin
Pin
Pin Settings 6
Pin Providing
1
Power
3-5
No.
Name
Type
At Reset
After Reset
1
LNA_IN
Analog
2
VDD3P3
Power
3
VDD3P3
Power
4
XTAL_32K_P
IO
VDD3P3_RTC
5
XTAL_32K_N
IO
VDD3P3_RTC
6
GPIO2
IO
VDD3P3_RTC
IE
IE
7
CHIP_EN
8
GPIO3
IO
VDD3P3_RTC
IE
9
MTMS
IO
VDD3P3_RTC
10
MTDI
IO
11
VDD3P3_RTC
12
MTCK
13
Pin Function Sets 1,2
IO MUX
Analog
IO MUX
Analog
IO MUX
Analog
IO MUX
Analog
IE
IO MUX
Analog
IE
IO MUX
Analog
VDD3P3_RTC
IE
IO MUX
Analog
IO
VDD3P3_CPU
IE 7
IO MUX
MTDO
IO
VDD3P3_CPU
IE
IO MUX
14
GPIO8
IO
VDD3P3_CPU
IE
IE
IO MUX
15
GPIO9
IO
VDD3P3_CPU
IE, WPU
IE, WPU
IO MUX
16
GPIO10
IO
VDD3P3_CPU
IE
IO MUX
17
VDD3P3_CPU
Power
18
VDD_SPI 9 10
Power
19
SPIHD
IO
VDD_SPI / VDD3P3_CPU
WPU
IE, WPU
IO MUX
SPIWP
IO
WPU
IE, WPU
IO MUX
21
SPICS0
IO
WPU
IE, WPU
IO MUX
22
SPICLK
IO
WPU
IE, WPU
IO MUX
23
SPID
IO
WPU
IE, WPU
IO MUX
24
SPIQ
IO
WPU
IE, WPU
IO MUX
25
GPIO18
IO
VDD3P3_CPU
Analog
Power
VDD3P3_CPU
IO MUX
IO MUX
Analog
Cont’d on next page
Espressif Systems
15
2 Pins
Table 2-1 – cont’d from previous page
Pin
Pin
Pin
Type
Pin Settings 6
Pin Providing
1
No.
Name
26
GPIO19
IO
27
U0RXD
28
U0TXD
29
XTAL_N
Analog
30
XTAL_P
Analog
31
VDDA
Power
32
VDDA
Power
33
GND
Power
Power
3-5
At Reset
After Reset
IO MUX
Analog
VDD3P3_CPU
USB_PU
IO MUX
Analog
IO
VDD3P3_CPU
IE, WPU
IO MUX
IO
VDD3P3_CPU
WPU 8
IO MUX
Some pins have glitches during power-up. See details in Table 2-2.
Table 2-2. Power-Up Glitches on Pins
Pin
Glitch1
MTCK
Low-level glitch
5
MTDO
Low-level glitch
5
GPIO10
Low-level glitch
5
U0RXD
Low-level glitch
5
GPIO18
High-level glitch
50000
1
Typical Time Period(ns)
Low-level glitch: the pin is at a low level output status during the time
period;
High-level glitch: the pin is at a high level output status during the time
period;
Pull-down glitch: the pin is at an internal weak pulled-down status during
the time period;
Pull-up glitch: the pin is at an internal weak pulled-up status during the
time period.
Please refer to Table 4-4 for detailed parameters about low/high-level
and pull-down/up.
Espressif Systems
16
2 Pins
2.3 IO Pins
2.3.1 IO MUX and GPIO Functions
The pins of ESP32-C3 can be assigned any function (F0-F2) from their respective sets of IO MUX functions as
listed in Table 2-3 IO MUX and GPIO Functions.
Each set of the IO MUX functions has a general purpose input/output (GPIO0, GPIO1, etc.) function. If a pin is
assigned a GPIO function, this pin’s signal is routed via the GPIO matrix, which incorporates internal signal
routing circuitry for mapping signals programmatically. It gives the pin access to almost any IO MUX function.
However, the flexibility of programmatic mapping comes at a cost as it might affect speed and latency of routed
signals.
Notes for Table 2-3 IO MUX and GPIO Functions:
1. Bold marks the default pin functions in the default boot mode. See Section 2.6.1 Chip Boot Mode Control.
2. Regarding highlighted cells, see Section 2.3.3 Restrictions for GPIOs.
3. Each IO MUX function (Fn, n = 0 ~ 2) is associated with a type. The description of type is as follows:
• I – input. O – output. T – high impedance.
• I1 – input; if the pin is assigned a function other than Fn, the input signal of Fn is always 1.
• I0 – input; if the pin is assigned a function other than Fn, the input signal of Fn is always 0.
4. Function names:
GPIO…
General-purpose input/output with signals routed via the GPIO matrix. For
more details on the GPIO matrix, see ESP32-C3 Technical Reference Manual
U…RXD
> Chapter IO MUX and GPIO Matrix.
U…TXD
UART0/1 receive/transmit signals.
5. Groups of functions (see the markings in the table):
a. JTAG interface for debugging.
b. UART interface for debugging.
c. SPI0/1 interface for connection to in-package or off-package flash via SPI bus. It supports 1-, 2-, 4-line
SPI modes. See also Section 2.7 Pin Mapping Between Chip and Flash.
d. SPI2 main interface for fast SPI connection. It supports 1-, 2-, 4-line SPI modes.
Table 2-3. IO MUX Pin Functions
Pin
No.
IO MUX /
GPIO
Name
IO MUX Function
Type
1
Type
4
GPIO0
GPIO0
I/O/T
GPIO0
I/O/T
5
GPIO1
GPIO1
I/O/T
GPIO1
I/O/T
2
Type
Cont’d on next page
Espressif Systems
17
2 Pins
Table 2-3 – cont’d from previous page
Pin
No.
Espressif Systems
IO MUX /
GPIO
Name
IO MUX Function
Type
1
Type
2
Type
5d
I/O/T
GPIO2
I/O/T
I/O/T
GPIO3
I/O/T
MTMS
I1
GPIO4
GPIO5
MTDI
I1
12
GPIO6
MTCK
13
GPIO7
14
6
GPIO2
GPIO2
FSPIQ
I1/O/T
8
GPIO3
GPIO3
9
GPIO4
I/O/T
FSPIHD
I1/O/T
10
GPIO5
I/O/T
FSPIWP
I1/O/T
I1
GPIO6
I/O/T
FSPICLK
I1/O/T
MTDO
O/T
GPIO7
I/O/T
FSPID
I1/O/T
GPIO8
GPIO8
I/O/T
GPIO8
I/O/T
15
GPIO9
GPIO9
I/O/T
GPIO9
I/O/T
16
GPIO10
GPIO10
I/O/T
GPIO10
I/O/T
FSPICS0
I1/O/T
18
GPIO11
GPIO11
I/O/T
GPIO11
I/O/T
19
GPIO12
SPIHD
I1/O/T
GPIO12
I/O/T
GPIO13
SPIWP
I1/O/T
GPIO13
I/O/T
21
GPIO14
SPICS0
O/T
GPIO14
I/O/T
22
GPIO15
SPICLK
O/T
GPIO15
I/O/T
23
GPIO16
SPID
I1/O/T
GPIO16
I/O/T
24
GPIO17
SPIQ
I1/O/T
GPIO17
I/O/T
25
GPIO18
GPIO18
I/O/T
GPIO18
I/O/T
26
GPIO19
GPIO19
I/O/T
GPIO19
I/O/T
27
GPIO20
U0RXD
I1
GPIO20
I/O/T
28
GPIO21
U0TXD
O
GPIO21
I/O/T
5a
5c
5b
18
2 Pins
2.3.2 Analog Functions
Notes for Table 2-4 Analog Functions:
3. Function names:
XTAL_32K_P
XTAL_32K_N
ADC1_CH…
ADC2_CH…
USB_DUSB_D+
32 kHz external clock input/output connected to ESP32-C3’s oscillator.
P/N means differential clock positive/negative.
Analog to digital conversion channel for ADC1 or ADC2.
USB Serial/JTAG function. USB signal is a differential signal transmitted
over a pair of D+ and D- wires.
Table 2-4. RTC and Analog Functions
Espressif Systems
Pin
Analog
No.
IO Name
Analog Function
1
4
GPIO0
XTAL_32K_P
ADC1_CH0
5
GPIO1
XTAL_32K_N
ADC1_CH1
6
GPIO2
ADC1_CH2
8
GPIO3
ADC1_CH3
9
GPIO4
ADC1_CH4
10
GPIO5
ADC2_CH0
25
GPIO18
USB_D-
26
GPIO19
USB_D+
19
2 Pins
All IO pins of the ESP32-C3 have GPIO pin functions. However, the IO pins are multiplexed and have other
important pin functions. This should be taken into account while certain pins are chosen for general purpose
input output.
In Table 2-3 IO MUX and GPIO Functions and Table 2-4 Analog Functions some pin functions are highlighted .
The non-highlighted GPIO pins are recommended for use first. If more pins are needed, the highlighted GPIOs
should be chosen carefully to avoid conflicts with important pin functions.
The highlighted IO pins have the following important pin functions:
• GPIO – allocated for communication with in-package flash and NOT recommended for other uses. For
details, see Section 2.7 Pin Mapping Between Chip and Flash.
• GPIO – have one of the following important functions:
– Strapping pins – need to be at certain logic levels at startup. See Section 2.6 Strapping Pins.
– USB_D+/- – by default, connected to the USB Serial/JTAG Controller. To function as GPIOs, these
pins need to be reconfigured by referring to ESP32-C3 Technical Reference Manual > Chapter IO MUX
and GPIO Matrix.
– JTAG interface – often used for debugging. See Table 2-3 IO MUX and GPIO Functions, note 5a. To
free these pins up, the pin functions USB_D+/- of the ESP32-C3 Technical Reference Manual USB
Serial/JTAG Controller can be used instead.
– UART interface – often used for debugging. See Table 2-3 IO MUX and GPIO Functions, note 5b.
– ADC2 – no restrictions, unless there is an on-going Wi-Fi connection. ADC2_CH… analog functions
(see Table 2-4 Analog Functions) cannot be used with Wi-Fi simultaneously.
See also Appendix A – ESP32-C3 Consolidated Pin Overview.
Espressif Systems
2 Pins
2.4 Analog Pins
Table 2-5. Analog Pins
Pin
Pin
Pin
Pin
No.
Name
Type
Function
1
LNA_IN
I/O
Low Noise Amplifier (RF LNA) input / output signals
7
CHIP_EN
I
High: on, the chip is started up.
Low: off, the chip is shut down.
Note: Do not leave the CHIP_EN pin floating.
29
XTAL_N
External clock input/output connected to ESP32-C3’s oscillator.
30
XTAL_P
Espressif Systems
21
2 Pins
2.5 Power Supply
2.5.1 Power Pins
The chip is powered via the power pins described in Table 2-6 Power Pins.
Table 2-6. Power Pins
Power Supply 1,2
Pin
Pin
No.
Name
Direction
Power Domain / Other
2
VDD3P3
Input
Analog power domain
3
VDD3P3
Input
Analog power domain
11
VDD3P3_RTC
Input
RTC and part of Digital power domains
RTC IO
17
VDD3P3_CPU
Input
Digital IO
18
VDD_SPI 3
Input
In-package flash (backup power line)
Output
Off-package flash
31
VDDA
Input
Analog power domain
32
VDDA
Input
Analog power domain
33
GND
External ground connection
IO Pins 4
SPI IO
1
See in conjunction with Section 2.5.2 Power Scheme.
2
For recommended and maximum voltage and current, see Section 4.1 Absolute Maximum Ratings and Section 4.2 Recommended Power Supply Characteristics.
3
To configure VDD_SPI as input or output, see ESP32-C3 Technical Reference Manual >
Chapter Low-power Management.
4
Digital IO pins are those powered by VDD3P3_CPU, and RTC IO pins are those powered
by VDD3P3_RTC and so on, as shown in Figure 2-3 ESP32-C3 Power Scheme. See
also Table 2-1 Pin Overview > Column Pin Providing Power.
2.5.2 Power Scheme
The power scheme is shown in Figure 2-3 ESP32-C3 Power Scheme.
The components on the chip are powered via voltage regulators.
Table 2-7. Voltage Regulators
Voltage Regulator
Espressif Systems
Output
Power Supply
Digital
1.1 V
Low-power
1.1 V
RTC power domain
22
2 Pins
Figure 2-3. ESP32-C3 Power Scheme
2.5.3 Chip Power-up and Reset
Once the power is supplied to the chip, its power rails need a short time to stabilize. After that, CHIP_EN – the
pin used for power-up and reset – is pulled high to activate the chip. For information on CHIP_EN as well as
power-up and reset timing, see Figure 2-4 and Table 2-8.
tST BL
tRST
2.8 V
VDDA,
VDD3P3,
VDD3P3_RTC,
VDD3P3_CPU
VIL_nRST
CHIP_EN
Figure 2-4. Visualization of Timing Parameters for Power-up and Reset
Table 2-8. Description of Timing Parameters for Power-up and Reset
Parameter
Description
Min (µs)
Time reserved for the power rails of VDDA, VDD3P3, VDD3P3_RTC,
tST BL
and VDD3P3_CPU to stabilize before the CHIP_EN pin is pulled high
50
tRST
Espressif Systems
Time reserved for CHIP_EN to stay below VIL_nRST to reset the
chip (see Table 4-4)
23
50
2 Pins
2.6 Strapping Pins
At each startup or reset, a chip requires some initial configuration parameters, such as in which boot mode to
load the chip, etc. These parameters are passed over via the strapping pins. After reset, the strapping pins
operate as regular IO pins.
The parameters controlled by the given strapping pins at chip reset are as follows:
• Chip boot mode – GPIO2, GPIO8, and GPIO9
• ROM messages printing – GPIO8
GPIO9 connected to the chip’s internal weak pull-up resistor at chip reset. This resistor determines the default bit
value of GPIO9. Also, this resistor determines the bit value if GPIO9 is connected to an external high-impedance
circuit.
Table 2-9. Default Configuration of Strapping Pins
Strapping Pin
Bit Value
GPIO2
Floating
GPIO8
Floating
GPIO9
Pull-up
1
To change the bit values, the strapping pins should be connected to external pull-down/pull-up resistances. If the
ESP32-C3 is used as a device by a host MCU, the strapping pin voltage levels can also be controlled by the host
MCU.
All strapping pins have latches. At system reset, the latches sample the bit values of their respective strapping
pins and store them until the chip is powered down or shut down. The states of latches cannot be changed in
any other way. It makes the strapping pin values available during the entire chip operation, and the pins are freed
up to be used as regular IO pins after reset.
Regarding the timing requirements for the strapping pins, there are such parameters as setup time and hold time.
For more information, see Table 2-10 and Figure 2-5.
Table 2-10. Description of Timing Parameters for the Strapping Pins
Parameter
tSU
Description
Min (ms)
Setup time is the time reserved for the power rails to stabilize before
the CHIP_EN pin is pulled high to activate the chip.
Hold time is the time reserved for the chip to read the strapping pin
tH
values after CHIP_EN is already high and before these pins start
3
operating as regular IO pins.
Espressif Systems
24
2 Pins
tSU
tH
VIL_nRST
CHIP_EN
VIH
Strapping pin
Figure 2-5. Visualization of Timing Parameters for the Strapping Pins
GPIO2, GPIO8, and GPIO9 control the boot mode after the reset is released. See Table 2-11 Chip Boot Mode
Control.
Table 2-11. Chip Boot Mode Control
Boot Mode
Default configuration
GPIO2 a
GPIO8
GPIO9
– (Floating)
– (Floating)
1 (Pull-up)
1
Any value
1
1
1
SPI Boot (default)
Joint Download Boot
a
b
GPIO2 actually does not determine SPI Boot and Joint Download Boot mode, but it is recommended to pull this pin up due
to glitches.
b
Joint Download Boot mode supports the following download
methods:
• USB-Serial-JTAG Download Boot
• UART Download Boot
In SPI Boot mode, the ROM bootloader loads and executes the program from SPI flash to boot the
system.
In Joint Download Boot mode, users can download binary files into flash using UART0 or USB interface. It is also
possible to download binary files into SRAM and execute it from SRAM.
2.6.2 ROM Messages Printing Control
During boot process the messages by the ROM code can be printed to:
• USB Serial/JTAG controller. For this, set EFUSE_USB_PRINT_CHANNEL and
EFUSE_DIS_USB_SERIAL_JTAG to 0.
• UART. For this, set EFUSE_DIS_USB_SERIAL_JTAG to 1. In this case, EFUSE_UART_PRINT_CONTROL
and GPIO8 control ROM messages printing as shown in Table 2-12 ROM Messages Printing Control.
Espressif Systems
25
2 Pins
Table 2-12. ROM Messages Printing Control
eFuse1
GPIO8
Ignored
Always enabled
1
2
3
1
Espressif Systems
Enabled
1
Disabled
Disabled
1
Enabled
Ignored
Always disabled
eFuse: EFUSE_UART_PRINT_CONTROL
26
2 Pins
Table 2-13 lists the pin mapping between the chip and flash for all SPI modes.
For chip variants with in-package flash (see Table 1-1 Comparison), the pins allocated for communication with
in-package flash can be identified depending on the SPI mode used.
For off-package flash, these are the recommended pin mappings.
For more information on SPI controllers, see also Section 3.4.2 Serial Peripheral Interface (SPI).
Notice:
It is not recommended to use the pins connected to flash for any other purposes.
Table 2-13. Pin Mapping Between Chip and In-package Flash
Pin
Pin
Single SPI
Dual SPI
Quad SPI / QPI
No.
Name
Flash
Flash
Flash
22
SPICLK
CLK
CLK
CLK
CS#
CS#
CS#
21
SPICS0
23
SPID
DI
DI
DI
24
SPIQ
DO
DO
DO
SPIWP
WP#
WP#
WP#
19
SPIHD
HOLD#
HOLD#
HOLD#
1
Espressif Systems
1
CS0 is for in-package flash
27
3 Functional Description
This chapter describes the functions of ESP32-C3.
3.1 CPU and Memory
3.1.1 CPU
ESP32-C3 has a low-power 32-bit RISC-V single-core microprocessor with the following features:
• four-stage pipeline that supports a clock frequency of up to 160 MHz
• RV32IMC ISA
• 32-bit multiplier and 32-bit divider
• up to 32 vectored interrupts at seven priority levels
• up to 8 hardware breakpoints/watchpoints
• up to 16 PMP regions
• JTAG for debugging
For more information, please refer to Chapter ESP-RISC-V CPU in ESP32-C3 Technical Reference Manual.
3.1.2 Internal Memory
ESP32-C3’s internal memory includes:
• 384 KB of ROM: for booting and core functions.
• 400 KB of on-chip SRAM: for data and instructions, running at a configurable frequency of up to 160
MHz. Of the 400 KB SRAM, 16 KB is configured for cache.
• RTC FAST memory: 8 KB of SRAM that can be accessed by the main CPU. It can retain data in
Deep-sleep mode.
• 4 Kbit of eFuse: 1792 bits are reserved for your data, such as encryption key and device ID.
• In-package flash : See details in Chapter 1 ESP32-C3 Series Comparison.
For more information, please refer to Chapter System and Memory in ESP32-C3 Technical Reference
Manual.
3.1.3 Off-package Flash
ESP32-C3 supports SPI, Dual SPI, Quad SPI, and QPI interfaces that allow connection to multiple off-package
flash, i.e. flash outside the chip’s pacakge.
CPU’s instruction memory space and read-only data memory space can map into the off-package flash of
ESP32-C3, whose size can be 16 MB at most. ESP32-C3 supports hardware encryption/decryption based on
XTS-AES to protect developers’ programs and data in flash.
Through high-speed caches, ESP32-C3 can support at a time up to:
• 8 MB of instruction memory space which can map into flash as individual blocks of 64 KB. 8-bit, 16-bit and
32-bit reads are supported.
Espressif Systems
28
• 8 MB of data memory space which can map into flash as individual blocks of 64 KB. 8-bit, 16-bit and
Note:
After ESP32-C3 is initialized, software can customize the mapping of off-package flash into the CPU address space.
Manual.
3.1.4 Address Mapping Structure
Figure 3-1. Address Mapping Structure
Note:
The memory space with gray background is not available for use.
3.1.5 Cache
ESP32-C3 has an eight-way set associative cache. This cache is read-only and has the following features:
• size: 16 KB
Espressif Systems
29
• block size: 32 bytes
• pre-load function
• lock function
• critical word first and early restart
3.2 System Clocks
For more information, please refer to Chapter Reset and Clock in ESP32-C3 Technical Reference Manual.
3.2.1 CPU Clock
The CPU clock has three possible sources:
• external main crystal clock
• fast RC oscillator (typically about 17.5 MHz, and adjustable)
• PLL clock
The application can select the clock source from the three clocks above. The selected clock source drives the
CPU clock directly, or after division, depending on the application. Once the CPU is reset, the default clock
source would be the external main crystal clock divided by 2.
Note:
ESP32-C3 is unable to operate without an external main crystal clock.
3.2.2 RTC Clock
The RTC slow clock is used for RTC counter, RTC watchdog and low-power controller. It has three possible
sources:
• external low-speed (32 kHz) crystal clock
• internal slow RC oscillator (typically about 136 kHz, and adjustable)
• internal fast RC oscillator divided clock (derived from the fast RC oscillator divided by 256)
The RTC fast clock is used for RTC peripherals and sensor controllers. It has two possible sources:
• external main crystal clock divided by 2
• internal fast RC oscillator divide-by-N clock (typically about 17.5 MHz, and adjustable)
3.3 Analog Peripherals
For more information, please refer to Chapter On-Chip Sensors and Analog Signal Processing in ESP32-C3
3.3.1 Analog-to-Digital Converter (ADC)
ESP32-C3 integrates two 12-bit SAR ADCs.
• ADC1 supports measurements on 5 channels, and is factory-calibrated.
Espressif Systems
30
• ADC2 supports measurements on 1 channel, and is not factory-calibrated.
Note:
ADC2 of some chip revisions is not operable. For details, please refer to ESP32-C3 Series SoC Errata.
For ADC characteristics, please refer to Table 4.5.
For GPIOs assigned to ADC, please refer to Table 3-2.
3.3.2 Temperature Sensor
The temperature sensor generates a voltage that varies with temperature. The voltage is internally converted via
an ADC into a digital value.
The temperature sensor has a range of –40 °C to 125 °C. It is designed primarily to sense the temperature
changes inside the chip. The temperature value depends on factors like microcontroller clock frequency or I/O
load. Generally, the chip’s internal temperature is higher than the operating ambient temperature.
3.4 Digital Peripherals
3.4.1 General Purpose Input / Output Interface (GPIO)
ESP32-C3 has 22 or 16 GPIO pins which can be assigned various functions by configuring corresponding
registers. Besides digital signals, some GPIOs can be also used for analog functions, such as ADC.
All GPIOs have selectable internal pull-up or pull-down, or can be set to high impedance. When these GPIOs are
configured as an input, the input value can be read by software through the register. Input GPIOs can also be set
to generate edge-triggered or level-triggered CPU interrupts. All digital IO pins are bi-directional, non-inverting
and tristate, including input and output buffers with tristate control. These pins can be multiplexed with other
functions, such as the UART, SPI, etc. For low-power operations, the GPIOs can be set to holding state.
The IO MUX and the GPIO matrix are used to route signals from peripherals to GPIO pins. Together they provide
highly configurable I/O. Using GPIO Matrix, peripheral input signals can be configured from any IO pins while
peripheral output signals can be configured to any IO pins.
For more information, please refer to Chapter IO MUX and GPIO Matrix (GPIO, IO_MUX) in ESP32-C3 Technical
Reference Manual.
ESP32-C3 has the following SPI interfaces:
• SPI0 used by ESP32-C3’s GDMA controller and cache to access in-package or off-package flash
• SPI1 used by the CPU to access in-package or off-package flash
• SPI2 is a general purpose SPI controller with access to a DMA channel allocated by the GDMA controller
Features of SPI0 and SPI1
• Supports Single SPI, Dual SPI, and Quad SPI, QPI modes
• Configurable clock frequency with a maximum of 120 MHz in Single Transfer Rate (STR) mode
Espressif Systems
31
• Data transmission is in bytes
Features of SPI2
• Supports operation as a master or slave
• Connects to a DMA channel allocated by the GDMA controller
• Configurable clock polarity (CPOL) and phase (CPHA)
• Configurable read and write data bit order: most-significant bit (MSB) first, or least-significant bit (LSB) first
• As a master
– Supports 2-line full-duplex communication with clock frequency up to 80 MHz
– Supports 1-, 2-, 4-line half-duplex communication with clock frequency up to 80 MHz
– Provides six SPI_CS pins for connection with six independent SPI slaves
– Configurable CS setup time and hold time
• As a slave
– Supports 2-line full-duplex communication with clock frequency up to 60 MHz
– Supports 1-, 2-, 4-line half-duplex communication with clock frequency up to 60 MHz
For GPIOs assigned to SPI, please refer to Table 3-2.
For more information, please refer to Chapter SPI Controller (SPI) in ESP32-C3 Technical Reference
Manual.
3.4.3 Universal Asynchronous Receiver Transmitter (UART)
ESP32-C3 has two UART interfaces, i.e. UART0 and UART1, which support IrDA and asynchronous
communication (RS232 and RS485) at a speed of up to 5 Mbps. The UART controller provides hardware flow
control (CTS and RTS signals) and software flow control (XON and XOFF). Both UART interfaces connect to
GDMA via UHCI0, and can be accessed by the GDMA controller or directly by the CPU.
For GPIOs assigned to UART, please refer to Table 3-2.
For more information, please refer to Chapter UART Controller (UART) in ESP32-C3 Technical Reference
Manual.
3.4.4 I2C Interface
ESP32-C3 has an I2C bus interface which is used for I2C master mode or slave mode, depending on your
configuration. The I2C interface supports:
• standard mode (100 Kbit/s)
• fast mode (400 Kbit/s)
Espressif Systems
32
• up to 800 Kbit/s (constrained by SCL and SDA pull-up strength)
• 7-bit and 10-bit addressing mode
• double addressing mode
• 7-bit broadcast address
You can configure instruction registers to control the I2C interface for more flexibility.
For GPIOs assigned to I2C, please refer to Table 3-2.
For more information, please refer to Chapter I2C Controller (I2C) in ESP32-C3 Technical Reference
Manual.
3.4.5 I2S Interface
ESP32-C3 includes a standard I2S interface. This interface can operate as a master or a slave in full-duplex
mode or half-duplex mode, and can be configured for 8-bit, 16-bit, 24-bit, or 32-bit serial communication. BCK
clock frequency, from 10 kHz up to 40 MHz, is supported.
The I2S interface connects to the GDMA controller. The interface supports TDM PCM, TDM MSB alignment,
TDM standard, and PDM standard.
For GPIOs assigned to I2S, please refer to Table 3-2.
For more information, please refer to Chapter I2S Controller (I2S) in ESP32-C3 Technical Reference Manual.
3.4.6 Remote Control Peripheral
The Remote Control Peripheral (RMT) supports two channels of infrared remote transmission and two channels
of infrared remote reception. By controlling pulse waveform through software, it supports various infrared and
other single wire protocols. All four channels share a 192 × 32-bit memory block to store transmit or receive
waveform.
For GPIOs assigned to the Remote Control Peripheral, please refer to Table 3-2.
For more information, please refer to Chapter Remote Control Peripheral (RMT) in ESP32-C3 Technical Reference
Manual.
3.4.7 LED PWM Controller
The LED PWM controller can generate independent digital waveform on six channels. The LED PWM
controller:
• can generate digital waveform with configurable periods and duty cycle. The accuracy of duty cycle can be
up to 18 bits.
• has multiple clock sources, including APB clock and external main crystal clock.
• can operate when the CPU is in Light-sleep mode.
• supports gradual increase or decrease of duty cycle, which is useful for the LED RGB color-gradient
generator.
For GPIOs assigned to LED PWM, please refer to Table 3-2.
Espressif Systems
33
For more information, please refer to Chapter LED PWM Controller (LEDC) in ESP32-C3 Technical Reference
Manual.
3.4.8 General DMA Controller
ESP32-C3 has a general DMA controller (GDMA) with six independent channels, i.e. three transmit channels and
three receive channels. These six channels are shared by peripherals with DMA feature. The GDMA controller
implements a fixed-priority scheme among these channels, whose priority can be configured.
The GDMA controller controls data transfer using linked lists. It allows peripheral-to-memory and
memory-to-memory data transfer at a high speed. All channels can access internal RAM.
Peripherals on ESP32-C3 with DMA feature are SPI2, UHCI0, I2S, AES, SHA, and ADC.
For more information, please refer to Chapter GDMA Controller (GDMA) in ESP32-C3 Technical Reference
Manual.
3.4.9 USB Serial/JTAG Controller
ESP32-C3 integrates a USB Serial/JTAG controller. This controller has the following features:
• CDC-ACM virtual serial port and JTAG adapter functionality
• USB 2.0 full speed compliant, capable of up to 12 Mbit/s transfer speed (Note that this controller does not
support the faster 480 Mbit/s high-speed transfer mode)
• programming in-package/off-package flash
• CPU debugging with compact JTAG instructions
• a full-speed USB PHY integrated in the chip
For GPIOs assigned to USB Serial/JTAG, please refer to Table 3-2.
For more information, please refer to Chapter USB Serial/JTAG Controller (USB_SERIAL_JTAG) in ESP32-C3
3.4.10 TWAI® Controller
ESP32-C3 has a TWAI® controller with the following features:
• compatible with ISO 11898-1 protocol (CAN Specification 2.0)
• standard frame format (11-bit ID) and extended frame format (29-bit ID)
• bit rates from 1 Kbit/s to 1 Mbit/s
• multiple modes of operation: Normal, Listen Only, and Self-Test (no acknowledgment required)
• 64-byte receive FIFO
• acceptance filter (single and dual filter modes)
• error detection and handling: error counters, configurable error interrupt threshold, error code capture,
arbitration lost capture
For GPIOs assigned to TWAI, please refer to Table 3-2.
Espressif Systems
34
For more information, please refer to Chapter Two-wire Automotive Interface (TWAI) in ESP32-C3 Technical
Reference Manual.
3.5 Radio and Wi-Fi
ESP32-C3 radio consists of the following blocks:
• 2.4 GHz receiver
• 2.4 GHz transmitter
• bias and regulators
• balun and transmit-receive switch
• clock generator
3.5.1 2.4 GHz Receiver
The 2.4 GHz receiver demodulates the 2.4 GHz RF signal to quadrature baseband signals and converts them to
the digital domain with two high-resolution, high-speed ADCs. To adapt to varying signal channel conditions,
ESP32-C3 integrates RF filters, Automatic Gain Control (AGC), DC offset cancelation circuits, and baseband
filters.
3.5.2 2.4 GHz Transmitter
The 2.4 GHz transmitter modulates the quadrature baseband signals to the 2.4 GHz RF signal, and drives the
antenna with a high-powered CMOS power amplifier. The use of digital calibration further improves the linearity of
the power amplifier.
Additional calibrations are integrated to cancel any radio imperfections, such as:
• carrier leakage
• I/Q amplitude/phase matching
• baseband nonlinearities
• RF nonlinearities
• antenna matching
These built-in calibration routines reduce the cost, time, and specialized equipment required for product
testing.
3.5.3 Clock Generator
The clock generator produces quadrature clock signals of 2.4 GHz for both the receiver and the transmitter. All
components of the clock generator are integrated into the chip, including inductors, varactors, filters, regulators
and dividers.
The clock generator has built-in calibration and self-test circuits. Quadrature clock phases and phase noise are
optimized on chip with patented calibration algorithms which ensure the best performance of the receiver and the
transmitter.
Espressif Systems
35
3.5.4 Wi-Fi Radio and Baseband
ESP32-C3 Wi-Fi radio and baseband support the following features:
• 802.11b/g/n
• 802.11n MCS0-7 that supports 20 MHz and 40 MHz bandwidth
• 802.11n MCS32
• 802.11n 0.4 µs guard interval
• data rate up to 150 Mbps
• RX STBC (single spatial stream)
• adjustable transmitting power
• antenna diversity
ESP32-C3 supports antenna diversity with an external RF switch. This switch is controlled by one or more
GPIOs, and used to select the best antenna to minimize the effects of channel imperfections.
3.5.5 Wi-Fi MAC
ESP32-C3 implements the full 802.11 b/g/n Wi-Fi MAC protocol. It supports the Basic Service Set (BSS) STA
and SoftAP operations under the Distributed Control Function (DCF). Power management is handled
automatically with minimal host interaction to minimize the active duty period.
ESP32-C3 Wi-Fi MAC applies the following low-level protocol functions automatically:
• infrastructure BSS in Station mode, SoftAP mode, Station + SoftAP mode, and promiscuous mode
• RTS protection, CTS protection, Immediate Block ACK
• fragmentation and defragmentation
• transmit opportunity (TXOP)
• Wi-Fi multimedia (WMM)
• GCMP, CCMP, TKIP, WAPI, WEP, BIP, WPA2-PSK/WPA2-Enterprise, and WPA3-PSK/WPA3-Enterprise
• automatic beacon monitoring (hardware TSF)
• 802.11mc FTM
3.5.6 Networking Features
Espressif provides libraries for TCP/IP networking, ESP-WIFI-MESH networking, and other networking protocols
over Wi-Fi. TLS 1.0, 1.1 and 1.2 is also supported.
3.6 Bluetooth LE
ESP32-C3 includes a Bluetooth Low Energy subsystem that integrates a hardware link layer controller, an
RF/modem block and a feature-rich software protocol stack. It supports the core features of Bluetooth 5 and
Espressif Systems
36
Bluetooth mesh.
3.6.1 Bluetooth LE Radio and PHY
Bluetooth Low Energy radio and PHY in ESP32-C3 support:
• 1 Mbps PHY
• 2 Mbps PHY for higher data rates
• coded PHY for longer range (125 Kbps and 500 Kbps)
• HW Listen before talk (LBT)
3.6.2 Bluetooth LE Link Layer Controller
Bluetooth Low Energy Link Layer Controller in ESP32-C3 supports:
• LE advertising extensions, to enhance broadcasting capacity and broadcast more intelligent data
• multiple advertisement sets
• simultaneous advertising and scanning
• multiple connections in simultaneous central and peripheral roles
• adaptive frequency hopping and channel assessment
• LE channel selection algorithm #2
• connection parameter update
• high duty cycle non-connectable advertising
• LE privacy 1.2
• LE data packet length extension
• link layer extended scanner filter policies
• low duty cycle directed advertising
• link layer encryption
• LE Ping
The ESP32-C3 has an advanced Power Management Unit (PMU). It can be flexibly configured to power up
different power domains of the chip to achieve the best balance between chip performance, power consumption,
and wakeup latency.
Configuring the PMU is a complex procedure. To simplify power management for typical scenarios, there are the
following predefined power modes that power up different combinations of power domains:
• Active mode – The CPU, RF circuits, and all peripherals are on. The chip can process data, receive,
transmit, and listen.
• Modem-sleep mode – The CPU is on, but the clock frequency can be reduced. The wireless connections
can be configured to remain active as RF circuits are periodically switched on when required.
Espressif Systems
37
• Light-sleep mode – The CPU stops running, and can be optionally powered on. The chip can be woken
up via all wake up mechanisms: MAC, RTC timer, or external interrupts. Wireless connections can remain
active. Some groups of digital peripherals can be optionally shut down.
• Deep-sleep mode – Only RTC is powered on. Wireless connection data is stored in RTC memory.
For power consumption in different power modes, see Section 4.6 Current Consumption.
Figure 3-2 Components and Power Domains and the following Table 3-1 show the distribution of chip
components between power domains and power subdomains .
Espressif’s ESP32-C3 Wi-Fi + Bluetooth® Low Energy SoC
Digital Power Domain
CPU
RISC-V
32-bit
Microprocessor
World
Controller
ROM
JTAG
GPIO
I2S
UART
RNG
LED PWM
Flash
Encryption
DIG ADC
RMT
Temperature
Sensor
Generalpurpose
Timers
SPI0/1
Cache
Debug
Assistant
TWAI®
I2C
SRAM
USB Serial/
JTAG
System
Timer
Main System
Watchdog
Timers
Optional Digital Peripherals
Bluetooth LE Link
Controller
Wi-Fi MAC
SHA
RSA
HMAC
Digital Signature
Bluetooth LE
Baseband
Wi-Fi
Baseband
AES
SPI2
Secure Boot
GDMA
Analog Power Domain
RTC Power Domain
PMU
eFuse
Controller
Brownout
Detector
RTC Memory
Super
Watchdog
RTC Timer
RTC
Watchdog
Timer
RF Circuits
2.4 GHz
Receiver
2.4 GHz
Transmitter
RF
Synthesizer
2.4 GHz Balun
+ Switch
PLL
RC_FAST_CLK
XTAL_CLK
Phase Lock
Loop
Fast RC
Oscillator
External Main
Clock
Power distribution
Power domain
Power subdomain
Figure 3-2. Components and Power Domains
Espressif Systems
38
Table 3-1. Components and Power Domains
Power
RTC
Digital
Analog
Domain
Power
CPU
Mode
Active
Modem-sleep
ON
ON
ON
ON
Optional
Wireless
Digital
Digital
Periph
Circuits
ON
ON
ON
ON
ON
1
1
FOSC_
XTAL_
CLK
CLK
PLL
RF
Circuits
ON
ON
ON
ON
ON
1
ON
ON
ON
ON
OFF2
1
ON
Light-sleep
ON
ON
OFF
ON
OFF
ON
OFF
OFF
OFF
OFF2
Deep-sleep
ON
OFF
OFF
OFF
OFF
ON
OFF
OFF
OFF
OFF
1
Configurable, see the TRM.
2
If Wireless Digital Circuits are on, RF circuits are periodically switched on when required by internal operation to
keep active wireless connections running.
For more information, please refer to Chapter Low-Power Management (RTC_CNTL) in ESP32-C3 Technical
Reference Manual.
3.8 Timers
3.8.1 General Purpose Timers
ESP32-C3 is has with two 54-bit general-purpose timers, which are based on 16-bit prescalers and 54-bit
auto-reload-capable up/down-timers.
The timers’ features are summarized as follows:
• a 16-bit clock prescaler, from 1 to 65536
• a 54-bit time-base counter programmable to be incrementing or decrementing
• able to read real-time value of the time-base counter
• halting and resuming the time-base counter
• programmable alarm generation
• level interrupt generation
For more information, please refer to Chapter Timer Group (TIMG) in ESP32-C3 Technical Reference
Manual.
3.8.2 System Timer
ESP32-C3 integrates a 52-bit system timer, which has two 52-bit counters and three comparators. The system
timer has the following features:
• counters with a fixed clock frequency of 16 MHz
• three types of independent interrupts generated according to alarm value
• two alarm modes: target mode and period mode
• 52-bit target alarm value and 26-bit periodic alarm value
• automatic reload of counter value
Espressif Systems
39
• counters can be stalled if the CPU is stalled or in OCD mode
For more information, please refer to Chapter System Timer (SYSTIMER) in ESP32-C3 Technical Reference
Manual.
3.8.3 Watchdog Timers
For more information, please refer to Chapter Watchdog Timers (WDT) in ESP32-C3 Technical Reference
Manual.
Digital Watchdog Timers
ESP32-C3 contains three digital watchdog timers: one in each of the two timer groups (called Main System
Watchdog Timers, or MWDT) and one in the RTC module (called the RTC Watchdog Timer, or RWDT).
During the flash boot process, RWDT and the MWDT in timer group 0 (TIMG0) are enabled automatically in order
to detect and recover from booting errors.
Digital watchdog timers have the following features:
• four stages, each with a programmable timeout value. Each stage can be configured, enabled and
disabled separately
• interrupt, CPU reset, or core reset for MWDT upon expiry of each stage; interrupt, CPU reset, core reset, or
system reset for RWDT upon expiry of each stage
• 32-bit expiry counter
• write protection, to prevent RWDT and MWDT configuration from being altered inadvertently
• flash boot protection
If the boot process from an SPI flash does not complete within a predetermined period of time, the
watchdog will reboot the entire main system.
Analog Watchdog Timer
ESP32-C3 also has one analog watchdog timer: RTC super watchdog timer (SWD). It is an ultra-low-power
circuit in analog domain that helps to prevent the system from operating in a sub-optimal state and resets the
system if required.
SWD has the following features:
• Ultra-low power
• Interrupt to indicate that the SWD timeout period is close to expiring
• Various dedicated methods for software to feed SWD, which enables SWD to monitor the working state of
the whole operating system
3.9 Cryptographic Hardware Accelerators
ESP32-C3 is equipped with hardware accelerators of general algorithms, such as AES-128/AES-256 (FIPS PUB
197), ECB/CBC/OFB/CFB/CTR (NIST SP 800-38A), SHA1/SHA224/SHA256 (FIPS PUB 180-4), and RSA3072.
The chip also supports independent arithmetic, such as large-number modular multiplication and large-number
Espressif Systems
40
multiplication. The maximum operation length for RSA and large-number modular multiplication is 3072 bits. The
maximum operand length for large-number multiplication is 1536 bits.
3.10
• Transparent off-package flash encryption (AES-XTS algorithm) with software inaccessible key prevents
unauthorized readout of your application code or data.
• Secure boot feature uses a hardware root of trust to ensure only signed firmware (with RSA-PSS signature)
can be booted.
• HMAC module can use a software inaccessible MAC key to generate MAC signatures for identity
verification and other purposes.
• Digital Signature module can use a software inaccessible secure key to generate RSA signatures for identity
verification.
• World Controller provides two running environments for software. All hardware and software resources are
sorted to two groups, and placed in either secure or general world. The secure world cannot be accessed
by hardware in the general world, thus establishing a security boundary.
3.11
Table 3-2. Peripheral Pin Configurations
Interface
Signal
Pin
Function
ADC
ADC1_CH0
XTAL_32K_P
Two 12-bit SAR ADCs
ADC1_CH1
XTAL_32K_N
ADC1_CH2
GPIO2
ADC1_CH3
GPIO3
ADC1_CH4
MTMS
ADC2_CH0
MTDI
MTDI
MTDI
MTCK
MTCK
MTMS
MTMS
MTDO
MTDO
U0RXD_in
Any GPIO pins
JTAG
UART
JTAG for software debugging
U0CTS_in
Two UART channels with hardware flow control
and GDMA
U0DSR_in
U0TXD_out
U0RTS_out
U0DTR_out
U1RXD_in
U1CTS_in
U1DSR_in
U1TXD_out
U1RTS_out
U1DTR_out
Espressif Systems
41
Interface
Signal
Pin
Function
I2C
I2CEXT0_SCL_in
Any GPIO pins
One I2C channel in slave or master mode
I2CEXT0_SDA_in
I2CEXT1_SCL_in
I2CEXT1_SDA_in
I2CEXT0_SCL_out
I2CEXT0_SDA_out
I2CEXT1_SCL_out
I2CEXT1_SDA_out
LED PWM
ledc_ls_sig_out0~5
Any GPIO pins
Six independent PWM channels
I2S
I2S0O_BCK_in
Any GPIO pins
Stereo input and output from/to the audiocodec
Any GPIO pins
Two channels for an IR transceiver of various
I2S_MCLK_in
I2SO_WS_in
I2SI_SD_in
I2SI_BCK_in
I2SI_WS_in
I2SO_BCK_out
I2S_MCLK_out
I2SO_WS_out
I2SO_SD_out
I2SI_BCK_out
I2SI_WS_out
I2SO_SD1_out
Remote Control
RMT_SIG_IN0~1
Peripheral
RMT_SIG_OUT0~1
SPI0/1
SPICLK_out_mux
SPICLK
Support Standard SPI, Dual SPI, Quad SPI, and
SPICS0_out
SPICS0
QPI that allow connection to off-package flash
SPICS1_out
Any GPIO pins
SPID_in/_out
SPID
SPIQ_in/_out
SPIQ
SPIWP_in/_out
SPIWP
SPIHD_in/_out
SPIHD
FSPICLK_in/_out_mux
Any GPIO pins
SPI2
waveforms
FSPICS0_in/_out
• Connection to off-package flash, RAM, and
FSPICS1~5_out
other SPI devices
FSPID_in/_out
USB Serial/JTAG
TWAI
• Master mode and slave mode of SPI, Dual
FSPIQ_in/_out
• Four modes of SPI transfer format
FSPIWP_in/_out
• Configurable SPI frequency
FSPIHD_in/_out
• 64-byte FIFO or GDMA buffer
USB_D+
GPIO19
USB-to-serial converter, and USB-to-JTAG
USB_D-
GPIO18
converter
twai_rx
Any GPIO pins
Compatible with ISO 11898-1 protocol
twai_tx
twai_bus_off_on
twai_clkout
Espressif Systems
42
4 Electrical Characteristics
Stresses above those listed in Table 4-1 Absolute Maximum Ratings may cause permanent damage to the device.
These are stress ratings only and normal operation of the device at these or any other conditions beyond those
indicated in Section 4.2 Recommended Power Supply Characteristics is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
Table 4-1. Absolute Maximum Ratings
Parameter
Description
Input power pins
Ioutput
2
TST ORE
1
Min
Allowed input voltage
Max
Unit
–0.3
3.6
1000
mA
–40
150
°C
Cumulative IO output current
Storage temperature
V
1
For more information on input power pins, see Section 2.5.1 Power Pins.
2
The product proved to be fully functional after all its IO pins were pulled high
while being connected to ground for 24 consecutive hours at ambient temperature of 25 °C.
For recommended ambient temperature, see Section 1 ESP32-C3 Series Comparison.
Table 4-2. Recommended Power Characteristics
Parameter 1
Description
Min
Typ
Max
Unit
Recommended input voltage
3.0
3.3
3.6
V
3.0
3.3
3.6
V
VDD_SPI (as input)
3.0
3.3
3.6
V
IV DD
Cumulative input current
0.5
A
VDD3P3_CPU
2, 3
1
See in conjunction with Section 2.5 Power Supply.
2
If VDD3P3_CPU is used to power VDD_SPI (see Section 2.5.2 Power Scheme), the voltage drop
on RSP I should be accounted for. See also Section 4.3 VDD_SPI Output Characteristics.
3
If writing to eFuses, the voltage on VDD3P3_CPU should not exceed 3.3 V as the circuits responsible for burning eFuses are sensitive to higher voltages.
Espressif Systems
43
Table 4-3. VDD_SPI Internal and Output Characteristics
Parameter
Description 1
Typ
VDD_SPI powered by VDD3P3_CPU via RSP I
RSP I
Unit
7.5
for 3.3 V flash_CPU 2
1
2
VDD3P3_CPU must be more than VDD_flash_min + I_flash_max * RSP I ;
Ω
where
• VDD_flash_min – minimum operating voltage of flash_CPU
• I_flash_max – maximum operating current of flash_CPU
4.4 DC Characteristics (3.3 V, 25 °C)
Table 4-4. DC Characteristics (3.3 V, 25 °C)
Parameter
Description
CIN
Pin capacitance
VIH
High-level input voltage
VIL
Low-level input voltage
IIH
IIL
VOH
VOL
2
2
Min
Typ
Max
Unit
2
pF
VDD1+ 0.3
V
–0.3
0.25 × VDD1
V
High-level input current
50
nA
Low-level input current
50
nA
V
0.75 × VDD1
High-level output voltage
0.8 × VDD
Low-level output voltage
1
1
0.1 × VDD
V
40
mA
28
mA
1
IOH
IOL
High-level source current (VDD = 3.3 V, VOH
>= 2.64 V, PAD_DRIVER = 3)
Low-level sink current (VDD1= 3.3 V, VOL =
0.495 V, PAD_DRIVER = 3)
RP U
Internal weak pull-up resistor
45
kΩ
RP D
Internal weak pull-down resistor
45
kΩ
VDD1+ 0.3
V
0.25 × VDD1
V
VIH_nRST
VIL_nRST
Chip reset release voltage CHIP_EN voltage is
within the specified range)
0.75 × VDD1
Chip reset voltage (CHIP_EN voltage is within
1
VDD – voltage from a power pin of a respective power domain.
2
VOH and VOL are measured using high-impedance load.
Espressif Systems
44
–0.3
4.5 ADC Characteristics
Table 4-5. ADC Characteristics
Symbol
Parameter
Min
ADC connected to an external
DNL (Differential nonlinearity) 1
100 nF capacitor; DC signal input;
Ambient temperature at 25 °C;
INL (Integral nonlinearity)
Wi-Fi off
Sampling rate
Max
Unit
–7
7
LSB
–12
12
LSB
100
kSPS 2
1
To get better DNL results, you can sample multiple times and apply a filter, or calculate the average value.
2
kSPS means kilo samples-per-second.
The calibrated ADC results after hardware calibration and software calibration are shown in Table 4-6. For higher
accuracy, you may implement your own calibration methods.
Table 4-6. ADC Calibration Results
Parameter
Description
Total error
Min
Max
Unit
ATTEN0, effective measurement range of 0 ~ 750
–10
10
mV
ATTEN1, effective measurement range of 0 ~ 1050
–10
10
mV
ATTEN2, effective measurement range of 0 ~ 1300
–10
10
mV
ATTEN3, effective measurement range of 0 ~ 2500
–35
35
mV
4.6.1 RF Current Consumption in Active Mode
The current consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF
port. All transmitters’ measurements are based on a 100% duty cycle.
Table 4-7. Wi-Fi Current Consumption Depending on RF Modes
Work Mode 1
Description
TX
Active (RF working)
RX
Espressif Systems
Peak (mA)
802.11b, 1 Mbps, @21 dBm
335
802.11g, 54 Mbps, @19 dBm
285
802.11n, HT20, MCS7, @18.5 dBm
276
802.11n, HT40, MCS7, @18.5 dBm
278
802.11b/g/n, HT20
84
802.11n, HT40
87
45
4.6.2 Current Consumption in Other Modes
Table 4-8. Current Consumption in Modem-sleep Mode
CPU Frequency
Mode
(MHz)
160
Modem-sleep2,3
80
Typ
Description
All Peripherals Clocks
Disabled (mA)
Enabled (mA)1
CPU is running
23
28
CPU is idle
16
21
CPU is running
17
22
CPU is idle
13
18
1
In practice, the current consumption might be different depending on which peripherals are enabled.
2
In Modem-sleep mode, Wi-Fi is clock gated.
3
In Modem-sleep mode, the consumption might be higher when accessing flash. For a flash rated at 80
Mbit/s, in SPI 2-line mode the consumption is 10 mA.
Table 4-9. Current Consumption in Low-Power Modes
Mode
Description
Typ (µA)
Light-sleep
VDD_SPI and Wi-Fi are powered down, and all GPIOs are high-impedance
Deep-sleep
RTC timer + RTC memory
5
Power off
CHIP_EN is set to low level, the chip is powered off
1
130
4.7 Reliability
Table 4-10. Reliability Qualifications
Test Item
HTOL (High Temperature
Operating Life)
ESD (Electro-Static
Discharge Sensitivity)
Latch up
Test Conditions
Test Standard
125 °C, 1000 hours
JESD22-A108
HBM (Human Body Mode)1± 2000 V
JS-001
2
CDM (Charge Device Mode) ± 1000 V
JS-002
Current trigger ± 200 mA
JESD78
Voltage trigger 1.5 × VDDmax
Bake 24 hours @125 °C
Preconditioning
Moisture soak (level 3: 192 hours @30 °C, 60% RH)
IR reflow solder: 260 + 0 °C, 20 seconds, three times
TCT (Temperature Cycling
Test)
J-STD-020, JESD47,
JESD22-A113
–65 °C / 150 °C, 500 cycles
JESD22-A104
130 °C, 85% RH, 96 hours
JESD22-A118
150 °C, 1000 hours
JESD22-A103
uHAST (Highly
Accelerated Stress Test,
unbiased)
HTSL (High Temperature
Storage Life)
Cont’d on next page
Espressif Systems
46
Submit Documentation Feedback
ESP32-C3 Series Datasheet v1.5
Table 4-10 – cont’d from previous page
Test Item
LTSL (Low Temperature
Storage Life)
Test Conditions
Test Standard
–40 °C, 1000 hours
JESD22-A119
1
JEDEC document JEP155 states that 500 V HBM allows safe manufacturing with a standard ESD control process.
2
JEDEC document JEP157 states that 250 V CDM allows safe manufacturing with a standard ESD control process.
4.8 Wi-Fi Radio
Table 4-11. Wi-Fi Frequency
Parameter
Center frequency of operating channel
Min
Typ
Max
(MHz)
(MHz)
(MHz)
2412
2484
4.8.1 Wi-Fi RF Transmitter (TX) Specifications
Table 4-12. TX Power with Spectral Mask and EVM Meeting 802.11 Standards
Min
Typ
Max
(dBm)
(dBm)
(dBm)
802.11b, 1 Mbps
21.0
802.11b, 11 Mbps
21.0
802.11g, 6 Mbps
21.0
802.11g, 54 Mbps
19.0
802.11n, HT20, MCS0
20.0
802.11n, HT20, MCS7
18.5
802.11n, HT40, MCS0
20.0
802.11n, HT40, MCS7
18.5
Rate
Table 4-13. TX EVM Test
Rate
Typ
SL1
(dB)
(dB)
(dB)
–24.5
–10
802.11b, 11 Mbps, @21 dBm
–25.0
–10
802.11g, 6 Mbps, @21 dBm
–23.0
–5
–27.5
–25
802.11n, HT20, MCS0, @20 dBm
–22.5
–5
–29.0
–27
802.11n, HT40, MCS0, @20 dBm
–22.5
–5
–28.0
–27
1
Espressif Systems
Min
SL stands for standard limit value.
47
4.8.2 Wi-Fi RF Receiver (RX) Specifications
Table 4-14. RX Sensitivity
Min
Typ
Max
(dBm)
(dBm)
(dBm)
802.11b, 1 Mbps
–98.4
802.11b, 2 Mbps
–96.0
802.11b, 5.5 Mbps
–93.0
802.11b, 11 Mbps
–88.6
802.11g, 6 Mbps
–93.8
802.11g, 9 Mbps
–92.2
802.11g, 12 Mbps
–91.0
802.11g, 18 Mbps
–88.4
802.11g, 24 Mbps
–85.8
802.11g, 36 Mbps
–82.0
802.11g, 48 Mbps
–78.0
802.11g, 54 Mbps
–76.6
802.11n, HT20, MCS0
–93.6
802.11n, HT20, MCS1
–90.8
802.11n, HT20, MCS2
–88.4
802.11n, HT20, MCS3
–85.0
802.11n, HT20, MCS4
–81.8
802.11n, HT20, MCS5
–77.8
802.11n, HT20, MCS6
–76.0
802.11n, HT20, MCS7
–74.8
802.11n, HT40, MCS0
–90.0
802.11n, HT40, MCS1
–88.0
802.11n, HT40, MCS2
–85.2
802.11n, HT40, MCS3
–82.0
802.11n, HT40, MCS4
–78.8
802.11n, HT40, MCS5
–74.6
802.11n, HT40, MCS6
–73.0
802.11n, HT40, MCS7
–71.4
Rate
Table 4-15. Maximum RX Level
Min
Typ
Max
(dBm)
(dBm)
(dBm)
802.11b, 1 Mbps
5
802.11b, 11 Mbps
5
802.11g, 6 Mbps
5
802.11g, 54 Mbps
802.11n, HT20, MCS0
5
Rate
Cont’d on next page
Espressif Systems
48
Table 4-15 – cont’d from previous page
Min
Typ
Max
(dBm)
(dBm)
(dBm)
802.11n, HT20, MCS7
802.11n, HT40, MCS0
5
802.11n, HT40, MCS7
Rate
Table 4-16. RX Adjacent Channel Rejection
Rate
Min
Typ
Max
(dB)
(dB)
(dB)
802.11b, 1 Mbps
35
802.11b, 11 Mbps
35
802.11g, 6 Mbps
31
802.11g, 54 Mbps
802.11n, HT20, MCS0
31
802.11n, HT20, MCS7
16
802.11n, HT40, MCS0
25
802.11n, HT40, MCS7
11
4.9 Bluetooth LE Radio
Table 4-17. Bluetooth LE Frequency
Parameter
Min
Typ
Max
(MHz)
(MHz)
(MHz)
2402
2480
4.9.1 Bluetooth LE RF Transmitter (TX) Specifications
Table 4-18. Transmitter Characteristics - Bluetooth LE 1 Mbps
Parameter
RF transmit power
Carrier frequency offset and drift
Modulation characteristics
Description
Min
Typ
Max
Unit
–24.00
Gain control step
3.00
dB
Max |fn |n=0, 1, 2, ..k
17.00
kHz
Max |f0 − fn |
1.75
kHz
Max |fn − fn−5 |
1.46
kHz
|f1 − f0 |
0.80
kHz
∆ f 1avg
250.00
kHz
190.00
kHz
0.83
RF power control range
Min ∆ f 2max (for at least
99.9% of all ∆ f 2max )
∆ f 2avg /∆ f 1avg
dBm
Cont’d on next page
Espressif Systems
49
Table 4-18 – cont’d from previous page
Parameter
Description
In-band spurious emissions
Min
Typ
Max
Unit
± 2 MHz offset
–37.62
dBm
± 3 MHz offset
–41.95
dBm
> ± 3 MHz offset
–44.48
dBm
Table 4-19. Transmitter Characteristics - Bluetooth LE 2 Mbps
Parameter
Description
Min
Max
Unit
–24.00
Gain control step
3.00
dB
20.80
kHz
Max |f0 − fn |
1.30
kHz
Max |fn − fn−5 |
1.33
kHz
|f1 − f0 |
0.70
kHz
∆ f 1avg
498.00
kHz
430.00
kHz
∆ f 2avg /∆ f 1avg
0.93
± 4 MHz offset
–43.55
dBm
± 5 MHz offset
–45.26
dBm
> ± 5 MHz offset
–45.26
dBm
RF transmit power
Typ
dBm
Table 4-20. Transmitter Characteristics - Bluetooth LE 125 Kbps
Parameter
Description
Min
Unit
Gain control step
3.00
dB
17.50
kHz
Max |f0 − fn |
0.45
kHz
|fn − fn−3 |
0.70
kHz
|f0 − f3 |
0.30
kHz
∆ f 1avg
250.00
kHz
235.00
kHz
± 2 MHz offset
–37.90
dBm
± 3 MHz offset
–41.00
dBm
> ± 3 MHz offset
–42.50
dBm
Min ∆ f 1max (for at least
99.9% of all∆ f 2max )
Max
–24.00
RF transmit power
Typ
dBm
Table 4-21. Transmitter Characteristics - Bluetooth LE 500 Kbps
Parameter
RF transmit power
Description
Min
Typ
Max
–24.00
3.00
Gain control step
Unit
dBm
dB
Cont’d on next page
Espressif Systems
50
Table 4-21 – cont’d from previous page
Parameter
Description
Min
Max
Unit
17.00
kHz
Max |f0 − fn |
0.88
kHz
|fn − fn−3 |
1.00
kHz
|f0 − f3 |
0.20
kHz
∆ f 2avg
208.00
kHz
190.00
kHz
± 2 MHz offset
–37.90
dBm
± 3 MHz offset
–41.30
dBm
> ± 3 MHz offset
–42.80
dBm
Typ
4.9.2 Bluetooth LE RF Receiver (RX) Specifications
Table 4-22. Receiver Characteristics - Bluetooth LE 1 Mbps
Parameter
Description
Sensitivity @30.8% PER
–97
dBm
Maximum received signal @30.8% PER
5
dBm
Co-channel C/I
8
dB
F = F0 + 1 MHz
–3
dB
F = F0 – 1 MHz
–4
dB
F = F0 + 2 MHz
–29
dB
F = F0 – 2 MHz
–31
dB
F = F0 + 3 MHz
–33
dB
F = F0 – 3 MHz
–27
dB
F ≥ F0 + 4 MHz
–29
dB
F ≤ F0 – 4 MHz
–38
dB
–29
dB
F = Fimage + 1 MHz
–41
dB
F = Fimage – 1 MHz
–33
dB
30 MHz ~ 2000 MHz
–5
dBm
2003 MHz ~ 2399 MHz
–18
dBm
2484 MHz ~ 2997 MHz
–15
dBm
3000 MHz ~ 12.75 GHz
–5
dBm
–30
dBm
Adjacent channel selectivity C/I
Image frequency
Adjacent channel to image frequency
Out-of-band blocking performance
Intermodulation
Min
Typ
Max
Unit
Table 4-23. Receiver Characteristics - Bluetooth LE 2 Mbps
Parameter
Description
Min
Co-channel C/I
Typ
Max
Unit
–93
dBm
3
dBm
10
dB
Cont’d on next page
Espressif Systems
51
Table 4-23 – cont’d from previous page
Parameter
Description
Image frequency
Intermodulation
Min
Typ
Max
Unit
F = F0 + 2 MHz
–7
dB
F = F0 – 2 MHz
–7
dB
F = F0 + 4 MHz
–28
dB
F = F0 – 4 MHz
–26
dB
F = F0 + 6 MHz
–26
dB
F = F0 – 6 MHz
–27
dB
F ≥ F0 + 8 MHz
–29
dB
F ≤ F0 – 8 MHz
–28
dB
–28
dB
F = Fimage + 2 MHz
–26
dB
F = Fimage – 2 MHz
–7
dB
30 MHz ~ 2000 MHz
–5
dBm
2003 MHz ~ 2399 MHz
–19
dBm
2484 MHz ~ 2997 MHz
–16
dBm
–5
dBm
–29
dBm
Table 4-24. Receiver Characteristics - Bluetooth LE 125 Kbps
Parameter
Description
–105
dBm
5
dBm
Co-channel C/I
3
dB
F = F0 + 1 MHz
–6
dB
F = F0 – 1 MHz
–6
dB
F = F0 + 2 MHz
–33
dB
F = F0 – 2 MHz
–43
dB
F = F0 + 3 MHz
–37
dB
F = F0 – 3 MHz
–47
dB
F ≥ F0 + 4 MHz
–40
dB
F ≤ F0 – 4 MHz
–50
dB
–40
dB
F = Fimage + 1 MHz
–50
dB
F = Fimage – 1 MHz
–37
dB
Image frequency
Min
Typ
Max
Unit
Table 4-25. Receiver Characteristics - Bluetooth LE 500 Kbps
Parameter
Description
Min
Typ
Max
Unit
–100
dBm
5
dBm
Co-channel C/I
3
dB
F = F0 + 1 MHz
–2
dB
Cont’d on next page
Espressif
Systems
Adjacent
52
Table 4-25 – cont’d from previous page
Parameter
Image frequency
Espressif Systems
Description
Min
Typ
Max
Unit
F = F0 – 1 MHz
–3
dB
F = F0 + 2 MHz
–32
dB
F = F0 – 2 MHz
–33
dB
F = F0 + 3 MHz
–23
dB
F = F0 – 3 MHz
–40
dB
F ≥ F0 + 4 MHz
–34
dB
F ≤ F0 – 4 MHz
–44
dB
–34
dB
F = Fimage + 1 MHz
–46
dB
F = Fimage – 1 MHz
–23
dB
53
5 Packaging
5 Packaging
• For information about tape, reel, and chip marking, please refer to Espressif Chip Packaging Information.
• The pins of the chip are numbered in anti-clockwise order starting from Pin 1 in the top view. For pin
numbers and pin names, see also Figure 2-1 ESP32-C3 Pin Layout (Top View).
• The source file of recommended PCB land pattern is provided for your reference. You can view it with
Autodesk Viewer.
• For reference PCB layout, please refer to ESP32-C3 Hardware Design Guidelines.
Figure 5-1. QFN32 (5×5 mm) Package
Espressif Systems
54
6 Related Documentation and Resources
• ESP32-C3 Technical Reference Manual – Detailed information on how to use the ESP32-C3 memory and peripherals.
• ESP32-C3 Hardware Design Guidelines – Guidelines on how to integrate the ESP32-C3 into your hardware product.
• ESP32-C3 Series SoC Errata – Descriptions of known errors in ESP32-C3 series of SoCs.
• Certificates
https://espressif.com/en/support/documents/certificates
• ESP32-C3 Product/Process Change Notifications (PCN)
https://espressif.com/en/support/documents/pcns?keys=ESP32-C3
• ESP32-C3 Advisories – Information on security, bugs, compatibility, component reliability.
https://espressif.com/en/support/documents/advisories?keys=ESP32-C3
• Documentation Updates and Update Notification Subscription
https://espressif.com/en/support/download/documents
Developer Zone
• ESP-IDF Programming Guide for ESP32-C3 – Extensive documentation for the ESP-IDF development framework.
• ESP-IDF and other development frameworks on GitHub.
https://github.com/espressif
• ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions,
share knowledge, explore ideas, and help solve problems with fellow engineers.
https://esp32.com/
• The ESP Journal – Best Practices, Articles, and Notes from Espressif folks.
https://blog.espressif.com/
• See the tabs SDKs and Demos, Apps, Tools, AT Firmware.
https://espressif.com/en/support/download/sdks-demos
Products
• ESP32-C3 Series SoCs – Browse through all ESP32-C3 SoCs.
https://espressif.com/en/products/socs?id=ESP32-C3
• ESP32-C3 Series Modules – Browse through all ESP32-C3-based modules.
https://espressif.com/en/products/modules?id=ESP32-C3
• ESP32-C3 Series DevKits – Browse through all ESP32-C3-based devkits.
https://espressif.com/en/products/devkits?id=ESP32-C3
• ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters.
https://products.espressif.com/#/product-selector?language=en
Contact Us
• See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples
(Online stores), Become Our Supplier, Comments & Suggestions.
https://espressif.com/en/contact-us/sales-questions
Espressif Systems
55
56
Pin
No.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
Pin
Name
LNA_IN
VDD3P3
VDD3P3
XTAL_32K_P
XTAL_32K_N
GPIO2
CHIP_EN
GPIO3
MTMS
MTDI
VDD3P3_RTC
MTCK
MTDO
GPIO8
GPIO9
GPIO10
VDD3P3_CPU
VDD_SPI
SPIHD
SPIWP
SPICS0
SPICLK
SPID
SPIQ
GPIO18
GPIO19
U0RXD
U0TXD
XTAL_N
XTAL_P
VDDA
VDDA
GND
Pin
Type
Analog
Power
Power
IO
IO
IO
Analog
IO
IO
IO
Power
IO
IO
IO
IO
IO
Power
Power
IO
IO
IO
IO
IO
IO
IO
IO
IO
IO
Analog
Analog
Power
Power
Power
Pin Providing
Power
VDD3P3_RTC
VDD3P3_RTC
VDD3P3_RTC
VDD3P3_RTC
VDD3P3_RTC
VDD3P3_RTC
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
VDD3P3_CPU
Pin Settings
At Reset After Reset
Analog Function
1
XTAL_32K_P
XTAL_32K_N
IE
IE
ADC1_CH0
ADC1_CH1
ADC1_CH2
IE
IE
IE
IE
ADC1_CH3
ADC1_CH4
ADC2_CH0
IE
IE, WPU
WPU
WPU
WPU
WPU
WPU
WPU
IE
IE
IE
IE, WPU
IE
IE, WPU
IE, WPU
IE, WPU
IE, WPU
IE, WPU
IE, WPU
USB_DUSB_D+
IE, WPU
WPU
For details, see Section 2 Pins. Regarding highlighted cells, see Section 2.3.3 Restrictions for GPIOs.
IO MUX Function
1
Type 2
Type
Type
GPIO0
GPIO1
GPIO2
I/O/T
I/O/T
I/O/T
GPIO0
GPIO1
GPIO2
I/O/T
I/O/T
I/O/T
FSPIQ
I1/O/T
GPIO3
MTMS
MTDI
I/O/T
I1
I1
GPIO3
GPIO4
GPIO5
I/O/T
I/O/T
I/O/T
FSPIHD
FSPIWP
I1/O/T
I1/O/T
MTCK
MTDO
GPIO8
GPIO9
GPIO10
I1
O/T
I/O/T
I/O/T
I/O/T
GPIO6
GPIO7
GPIO8
GPIO9
GPIO10
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
FSPICLK
FSPID
I1/O/T
I1/O/T
FSPICS0
I1/O/T
GPIO11
SPIHD
SPIWP
SPICS0
SPICLK
SPID
SPIQ
GPIO18
GPIO19
U0RXD
U0TXD
I/O/T
I1/O/T
I1/O/T
O/T
O/T
I1/O/T
I1/O/T
I/O/T
I/O/T
I1
O
GPIO11
GPIO12
GPIO13
GPIO14
GPIO15
GPIO16
GPIO17
GPIO18
GPIO19
GPIO20
GPIO21
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
I/O/T
Espressif Systems
Revision History
Revision History
Date
Version
Release notes
• Marked ESP32-C3FN4 as (NRND)
• Improved the content in the following sections:
– Section Product Overview
– Section 2 Pins
– Section 3.7 Power Management
– Section 3.4.2 Serial Peripheral Interface (SPI)
2023-08-11
v1.5
– Section 4.1 Absolute Maximum Ratings
– Section 4.2 Recommended Power Supply Characteristics
– Section 4.3 VDD_SPI Output Characteristics
– Section 4.5 ADC Characteristics
• Added Appendix A
• Updated the maximum value of ”RF power control range” to 20 dBm in
Section 4.9 Bluetooth LE Radio
• Other minor updates
• Deleted feature ”Antenna diversity” from Section 3.6.1 Bluetooth LE Radio
2022-12-15
v1.4
and PHY
• Deleted feature ”Supports external power amplifier”
• Updated the glitch type of GPIO18 to high-level glitch in Table Pin Overview
• Updated notes for Table Pin Overview
• Added links to the Technical Reference Manual and Peripheral Pin Configurations in Chapter 3 Functional Description
• Added a note about ADC2 error in Section 3.3.1 Analog-to-Digital Converter
(ADC)
2022-11-15
v1.3
• Updated Section 3.8.3 Watchdog Timers
• Added Table ADC Characteristics
• Updated Section 4.6.2 Current Consumption in Other Modes
• Updated RF transmit power in Section 4.9 Bluetooth LE Radio
• Updated the typo in Section 5 Packaging
• Updated Chapter 6 Related Documentation and Resources
• Added a new chip variant ESP32-C3FH4AZ;
2022-04-13
v1.2
• Updated Figure ESP32-C3 Functional Block Diagram;
• Added the wake up source for Deep-sleep mode in Section 3.7 Power
Management.
Cont’d on next page
Espressif Systems
57
Revision History
Cont’d from previous page
Date
Version
Release notes
• Updated Figure ESP32-C3 Functional Block Diagram to show power
modes;
• Added CoreMark score in Features;
2021-10-26
v1.1
• Updated Table Pin Description to show default pin functions;
• Updated Figure ESP32-C3 Power Scheme and related descriptions;
• Added Table SPI Signals;
• Added note 3 to Table Recommended Power Supply Characteristics;
• Other updates to wording.
• Updated power modes;
• Updated Section 2.6 Strapping Pins;
• Updated some clock names and their frequencies in Section 3.2 System
Clocks;
• Added clarification about ADC1 and ADC2 in Section 3.3.1 Analog-to-Digital
2021-05-28
v1.0
Converter (ADC);
• Updated the default configuration of U0RXD and U0TXD after reset in Table
IO MUX;
• Updated sampling rate in Table ADC Characteristics;
• Updated Table Reliability;
• Added the link to recommended PCB land pattern in Chapter 5 Packaging.
2021-04-23
v0.8
Updated Wi-Fi Radio and Bluetooth LE Radio data.
• Updated information about USB Serial/JTAG Controller;
• Added GPIO2 to Section 2.6 Strapping Pins;
• Updated Figure Address Mapping Structure;
• Added Table IO MUX and Table Pin Overview in Section 3.4.1 General Pur-
2021-04-07
v0.7
pose Input / Output Interface (GPIO);
• Updated information about SPI2 in Section 3.4.2 Serial Peripheral Interface
(SPI);
• Updated fixed-priority channel scheme in Section 3.4.8 General DMA Controller;
• Updated Table Reliability.
• Clarified that of the 400 KB SRAM, 16 KB is configured as cache;
2021-01-18
v0.6
• Updated maximum value to standard limit value in Table Wi-Fi RF Transmitter
(TX) Specifications in Section 4.8.1 Wi-Fi RF Transmitter (TX) Specifications.
Cont’d on next page
Espressif Systems
58
Revision History
Date
Version
Release notes
• Updated information about Wi-Fi;
• Added connection between in-package flash ports and chip pins to table
notes in Section Pin Definitions;
• Updated Figure ESP32-C3 Power Scheme, added Figure Visualization of
Timing Parameters for Power-up and Reset and Table Description of Timing
Parameters for Power-up and Reset in Section 2.5.2 Power Scheme;
2021-01-13
v0.5
• Added Figure Visualization of Timing Parameters for the Strapping Pins and
Table Description of Timing Parameters for the Strapping Pins in Section 2.6
Strapping Pins;
• Updated Table Peripheral Pin Configurations in Section 3.11 Peripheral Pin
Configurations;
• Added Chapter 4 Electrical Characteristics;
• Added Chapter 5 Packaging.
2020-11-27
v0.4
Espressif Systems
Preliminary version.
59
Disclaimer and Copyright Notice
Information in this document, including URL references, is subject to change without notice.
ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO
WARRANTIES TO ITS AUTHENTICITY AND ACCURACY.
NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY
OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE.
All liability, including liability for infringement of any proprietary rights, relating to use of information
in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any
intellectual property rights are granted herein.
The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a
registered trademark of Bluetooth SIG.
www.espressif.com
All trade names, trademarks and registered trademarks mentioned in this document are property
of their respective owners, and are hereby acknowledged.
Copyright © 2023 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
