DATA SHEET
THIN FILM CHIP RESISTORS
AUTOMOTIVE GRADE
NT series
0.1% TO 1%, TC10 TO TC50
sizes 0402/0603/0805/1206/2010
Product specification – February 12, 2026 V.3
RoHS compliant
Chip Resistor Surface Mount
NT
SERIES
2
9
0402 to 2010
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes NT0402 to
NT2010 high precision-high stability
chip resistors made by thin film
process.
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel, resistance value and
termination.
GLOBAL PART NUMBER
APPLICATIONS
Automotive electronics
Industrial and medical equipment
Test and measuring equipment
Telecommunications
NT XXXX X X X XX XXXXX X
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0402 / 0603 / 0805 / 1206 / 2010
(2) TOLERANCE
B = ± 0.1%
FEATURES
C = ± 0.25%
AEC-Q200 qualified
D = ± 0.5%
Halogen free epoxy
F = ± 1%
Superior resistance against sulfur
containing surroundings
Moisture sensitivity level: MSL 1
Environmental hazards Reduction
Non-forbidden materials used in
products / production
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
B = ± 10 ppm/°C
D = ± 25 ppm/°C
E = ± 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value.
Letter R/K/M is decimal point
Example: 100R = 100Ω
1K = 1,000Ω
(7) DEFAULT CODE
Letter L indicates Pb-Free with pure matte tin termination. (NOTE)
Letter S indicates Sn/Pb termination.
O RDERING EXAMPLE
The ordering code of a NT0402 chip resistor, TCR 50, value 100Ω with
± 0.5% tolerance, Pb-Free with pure matte tin termination, supplied in 7inch tape reel, is: NT0402DRE07100RL.
NOTE
1. All our Rchip products meet RoHS compliant and Halogen Free. "LFP" of the
internal 2D reel label mentions "Lead Free Process".
2. On customized label, "LFP" or specific symbol can be printed.
www.yageo.com
Feb. 12, 2026 V.3
NT
SERIES
3
9
0402 to 2010
MARKING
NT0402
No marking
ynsc007
Fig. 1
NT0603
E-96 series: including values 10/11/13/15/20/75 of E -24 series, 3 digits
Fig. 2
Value = 12.4 KΩ
563
ynsc003
Fig. 3
Value = 56 KΩ
E-24 series: exception values 10/11/13/15/20/75 of E -24 series, one short bar
under marking letter
NT0805 / NT1206 / NT2010
00
YNSC004
Fig. 4 Value = 10 KΩ
Both E-24 and E-96 series: 4 digits
First three digits for significant figure and 4th digit for number of zeros
NOTE
For further marking information, please see special data sheet “Chip resistors marking”.
CONSTRUCTION
OUTLINES
The resistors are constructed out of a high
grade ceramic body. Internal metal
electrodes are added at each end
connected by a resistive layer.
This resistive layer is trimmed to its
nominal value and on both ends a contact
is made which will guarantee optimum
solderability. This is achieved by applying
several layers and for ease of soldering the
outer layer consists of pure matte Tin or
Sn/Pb.
Fig. 5 Chip resistor outlines
www.yageo.com
Feb. 12, 2026 V.3
NT
SERIES
4
9
0402 to 2010
DIMENSIONS
Table 1
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
NT0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.20 ± 0.10
0.25 ± 0.10
NT0603
1.60 ± 0.10
0.80 ± 0.10
0.45 ± 0.10
0.25 ± 0.15
0.25 ± 0.15
NT0805
2.00 ± 0.10
1.25 ± 0.10
0.50 ± 0.10
0.35 ± 0.20
0.35 ± 0.20
NT1206
3.10 ± 0.10
1.60 ± 0.10
0.55 ± 0.10
0.45 ± 0.20
0.40 ± 0.20
NT2010
5.00 ± 0.10
2.50 ± 0.15
0.55 ± 0.10
0.60 ± 0.20
0.50 ± 0.20
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
Operating
Temperature Range
Power
Rating
Max.
Working
Voltage
Max.
Overload
Voltage
Resistance Range (E-24/E-96 series)(Ω) & Tolerance(1)
T.C.R.
(ppm/°C)(2)
± 10 (B)
NT0402
1/20W
75 V
150 V
± 25 (D)
± 50 (E)
± 10 (B)
NT0603
3/20W
75V
150 V
± 25 (D)
± 50 (E)
NT0805
–55 °C to +155 °C
± 10 (B)
1/5W
150 V
300 V
± 25 (D)
± 50 (E)
± 10 (B)
NT1206
2/5W
200 V
400 V
± 25 (D)
± 50 (E)
NT2010
4/5W
200 V
500 V
± 25 (D)
± 50 (E)
±0.1%
(B)
±0.25%
(C)
±0.5%
(D)
±1%
(F)
100 ≤ R ≤ 12K
10 ≤ R ≤ 63K4
100 ≤ R ≤ 60K
10 ≤ R ≤ 189K
100 ≤ R ≤ 60K
10 ≤ R ≤ 370K
100 ≤ R ≤ 100K
10 ≤ R ≤ 1M
100 ≤ R ≤ 1M
NOTE : 1. Global part number (code 7)
2. Global part number (code 9)
www.yageo.com
Feb. 12, 2026 V.3
NT
SERIES
5
9
0402 to 2010
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
REEL DIMENSION
QUANTITY PER REEL
Paper taping reel
7" (178 mm)
10,000 Units
NT0603
Paper taping reel
7" (178 mm)
5,000 Units
NT0805
Paper taping reel
7" (178 mm)
5,000 Units
NT1206
Paper taping reel
7" (178 mm)
5,000 Units
NT2010
7" (178 mm)
4,000 Units
PRODUCT TYPE
PATKING STYLE
NT0402
RESISTANCE
NOTE: for
paper tape and reel specification/dimensions, please see the special data sheet “packing” document.
RANGE
100 mΩ to 910 mΩ
PT040
FUNCTIONAL DESCRIPTION
2
± 200 ppm/°C
OPERATING TEMPERATURE RANGE
PT060
Range:
–55 °C to +155 °C ± 200 ppm/°C
3
POWER RATING
PT080
± 200 ppm/°C
5
Each type rated power at 70 °C:
100 MΩ TO 910 MΩ
NT0402=1/20W
PT120
100 mΩ
NT0603=3/20W
6
NT0805=1/5W
PT201
NT1206=2/5W
± 100 ppm/°C
NT2010=4/5W
PT251
2
R ATED VOLTAGE
± 100 ppm/°C
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
handbook, halfpage
P
MLB206_1
(%Prated )
100
50
> 100 mΩ
0 ± 75
55
ppm/°C
70
100
155
o
Tamb ( C)
± 75 ppm/°C
Fig. 6 Maximum dissipation (P max) in percentage of rated power
as a function of the operating ambient temperature (T amb)
(PxR)
Or max. working voltage whichever is less
Where
V=Continuous rated DC
or AC (rms) working voltage (v)
P=Rated power
R=Resistance value (Ω)
www.yageo.com
Feb. 12, 2026 V.3
NT
SERIES
6
9
0402 to 2010
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Short Time
Overload
IEC60115-1 4.13
2.5 times of rated voltage or maximum
± (0.05%+0.05Ω)
High
Temperature
Exposure
AEC-Q200 Test 3
Biased
Humidity
overload voltage, the less of the above, for 5 sec
at room temperature
1,000 hours at Tamb = 155 °C, unpowered
± (0.3%+0.05Ω)
AEC-Q200 Test 7
1,000 hours; 85 °C / 85% RH
± (0.1%+0.05Ω)
MIL-STD-202 Method 103
10% of operating power
MIL-STD-202 Method 108
Measurement at 24± 4 hours after test conclusion
Life
AEC-Q200 Test 8
Resistance to
Soldering Heat
AEC-Q200 Test 15
Temperature
Cycling
AEC-Q200 Test 4
Solderability
AEC-Q200 Test 18
MIL-STD-202-method 210
JESD22-A104
J-STD-002
1,000 hours at 70± 2 °C, Rated power applied for
1.5 hours on, 0.5 hour off, still air required
± (0.1%+0.05Ω)
Specimen passed 3 times reflow temperature at
260°C, with solder.
± (0.05%+0.05Ω)
-55/+155°C, 1000 cycles
Dwell time is 15 minutes.
Devices mounted Air – Air.
± (0.3%+0.05Ω)
(a) Baking 4 hours @155 ºC dry heat,
dipping at @245 ± 3 ºC for 5± 0.5 second.
(b) Baking 4 hours @155 ºC dry heat,
dipping at @260 ± 3 ºC for 30± 0.5 second.
Well tinned
No visible damage
(>95% covered)
No visible damage
www.yageo.com
Feb. 12, 2026 V.3
TEST
NT
SERIES
TEST METHOD
PROCEDURE
REQUIREMENTS
Board Flex /
Bending
AEC-Q200 Test 21
Chips mounted on a glass epoxy resin
PCB (FR4)
Bending for 0402: 5 mm
0603/0805: 3 mm
1206/2010: 2mm
Holding time: minimum 60 second
± (0.1%+0.05Ω)
Temperature
Coefficient of
Resistance
(T.C.R.)
IEC 60115-1 4.8
At +25/–55 °C and
+25/+125°C Formula:
Refer to table 2
AEC-Q200-005
T.C.R=
7
9
0402 to 2010
R2 - R1
× 106(ppm/°C)
R1(t 2 − t1)
Where
t1 = +25 °C or specified room temperature
t2 = –55 °C (25, 50 ppm/°C ) or +125 °C
(10, 25, 50 ppm/°C ) test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Flower of
Sulfur
ASTM-B-809-95*
Sulfur 750 hours, 105°C, unpowered.
± (2.0%+0.05Ω)
* Modified
Application guidance and safety reminders are provided in the“YAGEO Group SMD Chip Resistor Application & Safety
Guide”, available on the YAGEO Group official website.
www.yageo.com
Feb. 12, 2026 V.3
NT
SERIES
0402 to 2010
8
9
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 3
Feb. 12, 2026
- Add application guidance and safety reminders
Version 2
Dec. 15, 2025
- Extend R value, TCR and add NT2010
Version 1
Apr. 02, 2025
- Extend R value and add Sn/Pb termination
Version 0
Oct. 31, 2023
- First issue of this specification
www.yageo.com
Feb. 12, 2026 V.3
NT
SERIES
9
9
0402 to 2010
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum extent permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates
do not recommend the use of commercial, automotive, and/or COTS grade products for high
reliability applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
Feb. 12, 2026 V.3
