MB10S
MB10S
    HONGJIACHENG(宏嘉诚)
    MBS
    桥式整流器/整流桥 1KV 1A MBS
MB10S 数据手册
MB2S THRU MB10S MBS 1.0 AMP Plastic-Encapsulate Bridge Rectifier MBS Plastic-Encapsulate Bridge Rectifier Features Reverse Voltage 200-1000 V Forward Current 1.0 Ampere •Ideal for printed circuit board •Small size, simple installation •High surge current capability •Reliable low cost construction utilizing molded plastic technique •High temperature soldering guaranteed: 260/10 seconds at 5lbs., (2.3kg) tension Applications MBS General purpose 1 phase Bridgerectifier applications Mechanical Data •Case: MBS Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end + ~ Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT MB2S MB4S MB6S MB8S MB10S Maximum Repetitive Peak Reverse Voltage VRRM V 200 400 600 800 1000 Maximum DC blocking Voltage VDC Device marking code Maximum RMS Voltage Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Rating for fusing (t=8.3ms, Ta=25 ℃ ) Storage temperature Junction temperature Typical Thermal Resistance Rev:2.0 〜 ~ XXXX 〜 − − + Function Diagram VRMS V IF(AV) A I²t A²S Tj ℃ IFSM Tstg RθJ-A RθJ-L V MB2S MB4S 140 200 A 280 400 MB6S 420 600 1.0 800 700 1000 5.08 -55 ~ +150 ℃ /W 85 Zhuhai Hongjiacheng Technology co., Ltd 560 MB10S 35 ℃ ℃ /W MB8S -55 ~ +150 20 1 of 3 MB2S THRU MB10S MBS 1.0 AMP Plastic-Encapsulate Bridge Rectifier Electrical Characteristics (Ta=25℃ Unless otherwise noted) PARAMETER Maximum instantaneous forward voltage TEST CONDITIONS SYMBOL VR=VDC,TA=25℃ IR1 4.0V DC,1MHz CJ IF=1.0A Maximum DC reverse currentat rated DC blocking voltage VR=VDC,TA=100℃ Typical junction capacitance VF IR2 UNIT V MB2S MB4S MB6S 1.1 500 pF 35 1.0 25 PEAKFORWARDSURGECURRENT(A) AVERAGERECTIFIELDOUTPUTCURRENT(A) 1.2 18 15 0.4 10 0.2 0 20 40 60 80 100 LEADTEMPERATURE(℃) 120 140 1 10 100 NUMBEROFCYCLES Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle Tj=125℃ 10 1.0 0.1 0.01 0.2 0 INSTANTANEOUSREVERSECURRENT(μA)  INSTANTANEOUSFORWARDCURRENT(A) 10 5 160 Fig.1 Forward Current Derating Curve 1 Tj=25℃ 0.1 0.4 0.6 0.8 1.0 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) Fig.3 Typical Forward Voltage Rev:2.0 8.3msSingleHalfSineWave (JEDECMethod) 20 0.6 0 MB10S 5.0 μA Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 0.8 MB8S 1.4 1.6 0.01 0 20 40 60 80 100 120 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 140 Fig.4 Typical Reverse Characteristics Zhuhai Hongjiacheng Technology co., Ltd 2 of 3 MB2S THRU MB10S MBS 1.0 AMP Plastic-Encapsulate Bridge Rectifier Ordering Information PACKAGE PACKAGE CODE MBS R3 REEL(pcs) Package Outline Dimensions (MBS) 3000 BOX(pcs) CARTON(pcs) 6000 Symbol A A1 48000 Millimeters Max. - 0.2 4.5 2.3 E 3.6 - 0.193 2.7 0.09 0.106 4.0 0.142 1.1 0.027 7.0 0.35 b 0.5 0.8 e 2.3 Max. 0.177 0.15 0.7 Min. Inches 4.9 N L 13'' Dimensions Min. B C DELIVERY MODE 2.7 - 0.008 - 0.275 0.157 0.006 0.014 0.043 0.019 0.031 0.090 0.106 Suggested Pad Layout M Symbol X Y N N M X Y Rev:2.0 Millimeters Dimensions Min. Max. 2.4 2.6 1.2 1.4 6.0 1.84 Zhuhai Hongjiacheng Technology co., Ltd Min. Inches Max. 6.2 0.236 0.244 2.0 0.072 0.079 0.094 0.047 0.102 0.055 3 of 3
MB10S 价格&库存
很抱歉,暂时无法提供与“MB10S”相匹配的价格&库存,您可以联系我们找货
