Q65113A7467
Q65113A7467
    AMSOSRAM(艾迈斯半导体)
    发光二极管/LED 红色 624nm 1.95V 0603
Q65113A7467 数据手册
www.osram-os.com KR EELP41. 22 DATASHEET KR EELP41.22 Datasheet   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All reserved | Version 1.1 | 2024-08-30 1 rights KR EELP41. 22 DATASHEET SMARTLED® 0603 KR EELP41.22 The SMARTLED® 0603 is the product of choice for status indication and symbol backlighting in electronics. The small package size allows compact designs. The improved corrosion robustness and increased junction temperature range makes the devices from this series suitable for professional industrial equipment and applications. Applications - Appliances & Tools - Projection & Display - Display Backlighting - Static Signaling - Factory Automation - Transportation - Home & Building Automation Features  - Package: SMT package 0603, colorless diffused resin - Chip technology: Volume emitter (InGaAlP ) - Typ. Radiation: 130° (horizontal = 0°), 130° (vertical = 90°) - Color: λdom = 624 nm (● red) - Corrosion Robustness Class: 3B  - ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM) 2 | Version 1.1 | 2024-08-30 KR EELP41. 22 DATASHEET Ordering Information  Type Luminous Intensity 1) IF = 20 mA Iv KR EELP41.22-Q1S1-36-A8J8   3 | Version 1.1 | 2024-08-30 71 ... 224 mcd Ordering Code Q65113A7467 KR EELP41. 22 DATASHEET Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -40 °C 105 °C Storage Temperature Tstg min. max. -40 °C 105 °C Junction Temperature Tj max. 110 °C Forward current TS = 25 °C IF min. max. 0.5 mA 30 mA Forward Current pulsed D = 0.05 ; TS = 25 °C IF pulse max. 100 mA Surge Current t ≤ 10 µs; D = 0.05 ; TS = 25 °C IFS max. 250 mA Reverse voltage 2) TS = 25 °C VR max. 10 V ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM) VESD   4 | Version 1.1 | 2024-08-30 Values 2 kV KR EELP41. 22 DATASHEET Characteristics IF = 20 mA; TS = 25 °C Parameter Symbol Peak Wavelength λpeak typ. 636 nm Dominant Wavelength 3) λdom min. typ. max. 616 nm 624 nm 630 nm Spectral Bandwidth at 50% Irel,max ∆λ typ. 20 nm Viewing angle at 50% IV values for 0°, 90° 2φ typ. 130 ° 130 ° Forward Voltage 4) IF = 20 mA VF min. typ. max. 1.60 V 1.95 V 2.40 V Reverse current 2) VR = 10 V IR typ. max. 0.01 µA 10 µA Real thermal resistance junction/solderpoint 5) RthJS real typ. max. 550 K / W 670 K / W   5 | Version 1.1 | 2024-08-30 Values KR EELP41. 22 DATASHEET Brightness Groups  Group Luminous Intensity 1) IF = 20 mA min. Iv Luminous Intensity. 1) IF = 20 mA max. Iv Luminous Flux 6) IF = 20 mA typ. ΦV Q1 71 mcd 90 mcd 290 mlm Q2 90 mcd 112 mcd 360 mlm R1 112 mcd 140 mcd 450 mlm R2 140 mcd 180 mcd 580 mlm S1 180 mcd 224 mcd 730 mlm Forward Voltage Groups  Group Forward Voltage 4) IF = 20 mA min. VF Forward Voltage 4) IF = 20 mA max. VF A8 1.60 V 2.00 V J8 2.00 V 2.40 V Wavelength Groups  Group Dominant Wavelength 3) min. λdom  Dominant Wavelength 3) max. λdom 3 616 nm 620 nm 4 620 nm 624 nm 5 624 nm 627 nm 6 627 nm 630 nm Group Name on Label  Example: Q1-3-A8 Brightness  Q1 6 | Version 1.1 | 2024-08-30 Wavelength 3 Forward Voltage A8 KR EELP41. 22 DATASHEET Relative Spectral Emission 6) Irel = f (λ); IF = 20 mA; TS = 25 °C Irel KR EELP41.22 1,0 : Vλ : red 0,8 0,6 0,4 0,2 0,0 350 400 Radiation Characteristics 450 500 550 600 650 700 750 800 λ / nm 6) Irel = f (φ); TS = 25 °C KR EELP41.22 ϕ/°  -40° -50° -20° -30° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 : 0° : 90° 0,8 0,6 -60° -70° 0,4 -80° 0,2 -90° 0,0  -100° 7 | Version 1.1 | 2024-08-30 Irel Relative Luminous Intensity 6) IF = f(VF); TS = 25 °C IF / mA 6), 7) 30 Forward current 25 KR EELP41. 22 DATASHEET Iv/Iv(20 mA) = f(IF); TS = 25 °C KR EELP41.22 30 IV KR EELP41.22 1,6 IV(20mA) 1,4 25 1,2 20 1,0 0,8 15 0,6 10 0,4 5   8 | Version 1.1 | 2024-08-30 20 2,0 2,1 VF / V 15 1,9 10 1,8 5 0,0 1,7 0, 5 0,5 1,6 0,2 IF / mA KR EELP41. 22 DATASHEET Forward Voltage Relative Luminous Intensity 6) ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF / V Iv/Iv(25 °C) = f(Tj); IF = 20 mA KR EELP41.22 0,3 6) Iv KR EELP41.22 1,6 Iv(25°C) 1,4 0,2 1,2 0,1 1,0 0,8 0,0 0,6 -0,1 0,4 -0,2 -0,3 -40 -20 0,2 0 20 Dominant Wavelength 40 60 80 100 Tj / °C 6) Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA KR EELP41.22  dom / nm 8  6 4 2 0 -2 -4 -6 -8 0 20  -10 -40 -20 9 | Version 1.1 | 2024-08-30 40 60 80 100 Tj / °C 0,0 -40 -20 0 20 40 60 80 100 Tj / °C KR EELP41. 22 DATASHEET Max. Permissible Forward Current 5) IF = f(T) KR EELP41.22 IF / mA 30 25 20 15 10 5 0 0 20 40 60 80 100 Ts / °C Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C IF = f(tp); D: Duty cycle; TS = 85 °C KR EELP41.22 KR EELP41.22 TS = 0°C ... 65°C IF / A 0,12 0,10 TS = 105°C IF / A 0,12  0,08 0,06 0,10 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005  10 | Version 1.1 | 2024-08-30 0,06 0,04 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,02 0,04 10-6 10-5 10-4 10-3 0,01 0,1 0,08 1 10 Pulse time / s 10-6 10-5 10-4 10-3 0,01 0,1 1 10 Pulse time / s KR EELP41. 22 DATASHEET Dimensional Drawing 8) Further Information: Approximate Weight: 1.3 mg Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43)   11 | Version 1.1 | 2024-08-30 KR EELP41. 22 DATASHEET Electrical Internal Circuit Recommended Solder Pad 8) 0.7 (0.028) 0.8 (0.031) 0.8 (0.031)  0.8 (0.031) OHAPY606  For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. 12 | Version 1.1 | 2024-08-30 KR EELP41. 22 DATASHEET Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 13 | Version 1.1 | 2024-08-30 °C 480 s K/s s KR EELP41. 22 DATASHEET Taping 8)   14 | Version 1.1 | 2024-08-30 KR EELP41. 22 DATASHEET Tape and Reel 9) Reel Dimensions A 180 mm W Nmin 8 + 0.3 / - 0.1 mm   15 | Version 1.1 | 2024-08-30 W1 58 mm W2 max 8.4 + 1,5 mm 14.4 mm Pieces per PU 4000 KR EELP41. 22 DATASHEET Barcode-Product-Label (BPL) Dry Packing Process and Materials 8) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 16 | Version 1.1 | 2024-08-30 KR EELP41. 22 DATASHEET 7\SH'HVLJQDWLRQ6\VWHP :DYHOHQJWK  (λGRPW\S    % QP 7  QP * QP
Q65113A7467 价格&库存
很抱歉,暂时无法提供与“Q65113A7467”相匹配的价格&库存,您可以联系我们找货
