LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
KMW
Downsized snap-ins, 105℃
KMZ
Series
Downsized
・Downsized from KMR series
・Endurance with ripple current : 2,000 hours at 105℃
・Rated voltage range : 400 to 450Vdc, Capacitance range : 120 to 1,000µF
・Non solvent resistant type
・RoHS2 Compliant
KMW
Downsized
KMR
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-25 to +105℃
400 to 450Vdc
±20% (M)
I≦3 CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
400V
420 & 450V
tanδ(Max.)
0.15
0.20
Rated voltage (Vdc)
400 to 450V
Z(-25℃)/Z(+20℃)
8
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 5 minutes)
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
≦±15% of the initial value
D.F. (tanδ)
≦150% of the initial specified value
Leakage current
Endurance
Shelf Life
◆DIMENSIONS [mm]
Code : VS (φ22 to φ35) : Standard
Sleeve (PET : Brown)
●Terminal
PC board pin-out
(View from Solder side)
Negative mark
Code : LI (φ35)
Negative mark
2-1.2×6
Vent
φD+1max.
φD+1max.
10
2-φ2
4.0±0.5
L±2.5
Vent
PC board pin-out
4.2±0.5
●Terminal
5±0.5
L±2.5
4.5±1
14.2±1
The standard design has no plastic disc.
◆PART NUMBERING SYSTEM
1
2
3
4
E K MW
5
6
7
8
9
10
VS N
11
12
13
14
M
15
16
17
18
S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 180µF:181, 1,000µF:102)
Dummy terminal code
Terminal code (VS, LI)
Voltage code (ex. 400V:401, 450V:451)
Series code
Category
Please refer to "Product code guide (snap-in type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001X 2023
KMWSeries
◆STANDARD RATINGS
WV
(Vdc)
400
420
Cap
(µF)
150
180
220
220
270
330
330
330
390
390
390
390
470
470
560
560
680
680
680
820
1,000
120
150
180
220
270
270
270
330
330
330
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
22 ×25
22 ×30
22 ×35
25.4×25
25.4× 30
22 × 45
25.4× 35
30 ×25
22 ×50
25.4 ×40
30 ×30
35 ×25
25.4×45
30 ×35
30 ×40
35 ×30
30 ×45
30 ×50
35 ×35
35 ×40
35 ×50
22 ×25
22 ×30
25.4× 25
25.4× 30
22× 45
25.4×35
30 ×25
22×50
25.4 ×40
30 ×30
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.91
1.04
1.18
1.15
1.31
1.50
1.51
1.46
1.67
1.67
1.61
1.40
1.87
1.81
2.03
1.70
2.29
2.33
1.90
2.16
2.50
0.78
0.91
1.02
1.16
1.30
1.34
1.28
1.47
1.51
1.43
Part No.
EKMW401VSN151MP25S
EKMW401VSN181MP30S
EKMW401VSN221MP35S
EKMW401VSN221MQ25S
EKMW401VSN271MQ30S
EKMW401VSN331MP45S
EKMW401VSN331MQ35S
EKMW401VSN331MR25S
EKMW401VSN391MP50S
EKMW401VSN391MQ40S
EKMW401VSN391MR30S
EKMW401VSN391MA25S
EKMW401VSN471MQ45S
EKMW401VSN471MR35S
EKMW401VSN561MR40S
EKMW401VSN561MA30S
EKMW401VSN681MR45S
EKMW401VSN681MR50S
EKMW401VSN681MA35S
EKMW401VSN821MA40S
EKMW401VSN102MA50S
EKMW421VSN121MP25S
EKMW421VSN151MP30S
EKMW421VSN181MQ25S
EKMW421VSN221MQ30S
EKMW421VSN271MP45S
EKMW421VSN271MQ35S
EKMW421VSN271MR25S
EKMW421VSN331MP50S
EKMW421VSN331MQ40S
EKMW421VSN331MR30S
WV
(Vdc)
420
450
Cap
(µF)
330
390
390
390
470
470
560
560
680
120
150
150
180
180
220
220
220
270
270
270
330
330
390
390
390
470
470
560
560
680
820
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
35 × 25
25.4 × 45
25.4 × 50
30 × 35
30 × 40
35 × 30
30 × 45
35 × 35
35 × 40
22 × 25
22 × 30
25.4 × 25
22 × 35
25.4 × 30
22 × 40
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
25.4 × 45
30 × 35
25.4 × 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1.38
1.67
1.70
1.59
1.79
1.67
2.01
1.85
2.11
0.78
0.91
0.93
1.02
1.05
1.15
1.21
1.15
1.36
1.36
1.29
1.54
1.46
1.70
1.63
1.52
1.85
1.77
2.04
2.02
2.16
2.42
Part No.
EKMW421VSN331MA25S
EKMW421VSN391MQ45S
EKMW421VSN391MQ50S
EKMW421VSN391MR35S
EKMW421VSN471MR40S
EKMW421VSN471MA30S
EKMW421VSN561MR45S
EKMW421VSN561MA35S
EKMW421VSN681MA40S
EKMW451VSN121MP25S
EKMW451VSN151MP30S
EKMW451VSN151MQ25S
EKMW451VSN181MP35S
EKMW451VSN181MQ30S
EKMW451VSN221MP40S
EKMW451VSN221MQ35S
EKMW451VSN221MR25S
EKMW451VSN271MP50S
EKMW451VSN271MQ40S
EKMW451VSN271MR30S
EKMW451VSN331MQ45S
EKMW451VSN331MR35S
EKMW451VSN391MQ50S
EKMW451VSN391MR40S
EKMW451VSN391MA30S
EKMW451VSN471MR45S
EKMW451VSN471MA35S
EKMW451VSN561MR50S
EKMW451VSN561MA40S
EKMW451VSN681MA45S
EKMW451VSN821MA50S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
400 to 450Vdc
50
0.77
120
1.00
300
1.16
1k
1.30
10k
1.41
50k
1.43
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming
goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Part Numbering System
Part Numbering System (Appendix)
Standardization
Available Items by Manufacturing Locations
Environmental Measures
Technical Note
Precautions and Guidelines
Recommended Soldering Conditions
Taping, Lead-preforming and Packaging
Available Terminals for Snap-in and Screw Mount Type
很抱歉,暂时无法提供与“EKMW401VSN681MR45S”相匹配的价格&库存,您可以联系我们找货
