WM02P06G
P-Channel MOSFET
Features
Way-on Small Signal MOSFETs
VDS= -20 V, ID = -0.66 A
RDS(on) < 0.52Ω @ VGS = -4.5V
RDS(on) < 0.78Ω @ VGS = -2.5V
Trench LV MOSFET Technology
ESD protected
SOT-323
Mechanical Characteristics
SOT-323 Package
Marking : Making Code
RoHS Compliant
Schematic & PIN Configuration
D
G
D
G
S
S
Device symbol
S
SOT-323(Top View)
Absolute Maximum Rating (TA=25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
-20
V
Gate-Source Voltage
VGS
±10
V
ID
-0.66
A
IDM
-2.64
A
PD
200
mW
TJ ,TSTG
–55 to 150
°C
Symbol
Value
Unit
RθJA
625
°C/W
Continuous Drain Current
TA=25°C
Pulsed Drain Current1
Power Dissipation
TA=25°C
Operating Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance from Junction to Ambient2
Rev.C.2023
Doc:W0803110
1/4
WM02P06G
Electrical Characteristics (TJ=25°C unless otherwise noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Static Characteristics
V(BR)DSS
VGS = 0V, ID = -250µA
-20
V
Gate-body Leakage Current
IGSS
VDS = 0 V, VGS = ±10V
±20
µA
Zero Gate Voltage Drain Current
IDSS
VDS = -20V, VGS = 0V
-1
µA
VDS = VGS, ID = -250µA
-0.3
-0.6
-1.1
V
VGS = -4.5V, ID = -0.66A
0.45
0.52
VGS = -2.5V, ID = -0.6A
0.65
0.78
VGS = -1.8V, ID = -0.5A
0.95
76
12
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Drain-Source On-state Resistance3
VGS(th)
RDS(on)
Ω
Dynamic Characteristics4
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
9
Turn-On Delay Time
td(on)
9
Turn-On Rise Time
tr
5.7
Turn-Off Delay Time
td(off)
32.6
20.3
-1.2
V
-0.66
A
VGS = 0V, VDS = -10V,
f = 1MHz
pF
Switching Characteristics4
Turn- Off Fall Time
VDS = -10V, VGS = -4.5V,
RG=3Ω, ID = -0.66A,
tf
ns
Source-Drain Diode Characteristics
Diode Forward Voltage3
Continuous Source Current
VDS
IS= -0.66A, VGS = 0V
IS
Notes:
1. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C.
2. The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper, The value in any given application depends on the
user's specific board design.
3. Pulse Test: Pulse width≤300μs, duty cycle≤2%.
4. This value is guaranteed by design hence it is not included in the production test.
Rev.C.2023
www.way-on.com
2/4
WM02P06G
Typical Characteristics
1
VGS = -10V
VGS = -4.5V
0.8
Drain current -ID (A)
1.5
VGS = -2.0V
1
VGS = -1.5V
0.5
VDS= -3V
VGS = -2.5V
2
0.6
0.4
0.2
1
1.5
2
Drain−source voltage -VDS (V)
1
1.5
2
Gate−source voltage -VGS (V)
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
3.0
1
ID=-0.66A
On-Resistance RDS (on) (Ω)
Source current -IS (A)
2.5
0.1
0.01
2.0
1.5
1.0
0.5
0.0
0.0
0.3
0.6
0.9
1.2
Figure 3. Forward Characteristics of Reverse
1.5
4
6
8
Source−drain voltage -VSD (V)
10
Figure 4. RDS(ON) vs. VGS
1000
1.2
Capacitance(pF)
VGS = -1.8V
0.9
VGS = -2.5V
0.6
VGS = -4.5V
0.3
0.6
0.9
1.2
1.5
100
Ciss
Coss
10
Crss
1
F=1MHz
Figure 5. RDS(ON) vs. ID
Rev.C.2023
5
10
15
Drain-source voltage -VDS(V)
Figure 6. Capacitance Characteristics
www.way-on.com
3/4
WM02P06G
Outline Drawing – SOT-323
PACKAGE OUTLINE
3
D
1
2
SOT-323
3
DIMENSIONS
E1 E
θ
1
c
L
SYMBOL
2
A
e
b
A
A1
M
C
e
e1
MIN
MAX
0.90
1.10
0.035
0.043
0.00
0.10
0.000
0.004
D
2.00
2.20
0.079
0.087
b
0.20
0.40
0.008
0.016
c
0.08
0.15
0.003
0.006
E
2.15
2.45
0.085
0.096
E1
1.15
1.35
0.045
0.053
e
0.65TYP
L
0.525 REF
0.026TYP
8
0.021 REF
Notes
DIMENSIONS
Z
INCHES
MAX
A1
θ
b
MILLIMETER
MIN
DIM
INCHES
MILLIMETERS
M
0.076
1.90
C
0.036
0.9
Z
0.110
2.8
e
0.026
0.65
e1
0.052
1.30
b
0.028
0.7
1. Dimensioning and tolerances per ANSI Y14.5M,
1985.
2. Controlling Dimension: Inches
3. Pin 3 is the cathode (Unidirectional Only).
4. Dimensions are exclusive of mold flash and metal
burrs.
Marking Codes
Part Number
WM02P06G
Marking Code
06K
Package Information
Qty:3k/Reel
CONTACT INFORMATION
No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademark of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
Rev.C.2023
www.way-on.com
4/4
很抱歉,暂时无法提供与“WM02P06G”相匹配的价格&库存,您可以联系我们找货
