UMW
R
PSD03-PSD36C
DESCRIPTION
The PSDxx and PSDxxC Series are transient voltage suppressor
arrays designed for ESD protection of SMART phones,
laptop computers and other portable electronics. These silicon
based diodes offer superior clamping voltage and performance
compared to other technologies such as MLVs.
The PSDxx and PSDxxC Series can be utilized as a
single line protector in either a unidirectional or
bidirectional configuration. The SOD-323 small package configuration offers designers the flexibility of placement on the printed
circuit
board for each I/O port or voltage bus. The PSDxx and PSDxxC
Series meets the IEC 61000-4-2 (ESD), 61000-4-4 (EFT)
and 61000-4-5 requirements.
1
UNIDIRECTIONAL
1
2
BIDIRECTIONAL
FEATURES
2
APPLICATIONS
Compatible with IEC 61000-4-2 (ESD): Air -15kV,
Contact - 8kV
Compatible with IEC 61000-4-4 (EFT): 40A -5/50ns
Compatible with IEC 61000-4-5 (Surge): 24A, 8/20µs
Level 2(Line-Gnd) & Level 3 (Line-Line)
Unidirectional: 500W Peak Pulse Power per Line
(tp = 8/20µs)
Bidirectional: 400W Peak Pulse Power per Line
(tp = 8/20µs)
Replacement for MLV (0805)
Unidirectional & Bidirectional Configurations
Protects One Power or I/O Port
ESD Protection > 25kV
Low Clamping Voltage
Available in Multiple Voltages Ranging From 3V to 36V
RoHS Compliant
REACH Compliant
Laptop Computers
SMART Phones
■ Portable Electronics
Mechanical Data
Molded JEDEC SOD-323 Package
Approximate Weight: 5 milligrams
Lead-Free Pure-Tin Plating (Annealed)
Solder Reflow Temperature:
Pure-Tin - Sn, 100: 260-270°C
8mm Tape and Reel Per EIA Standard 481
Flammability Rating UL 94V-0
TYPICAL DEVICE CHARACTERISTICS
MAXIMUM RATINGS @ 25°C Unless Otherwise Specified
PARAMETER
SYMBOL
VALUE
UNITS
Unidirectional: Peak Pulse Power (tp = 8/20µs) - See Figure 1
PPP
500
W
Bidirectional: Peak Pulse Power (tp = 8/20µs) - See Figure 1
PPP
400
W
Operating Temperature
TL
-55 to 150
°C
Storage Temperature
TSTG
-55 to 150
°C
www.umw-ic.com
1
UTD Semiconductor Co.,Limited
UMW
R
PSD03-PSD36C
ELECTRICAL CHARACTERISTICS PER LINE @ 25°C Unless Otherwise Specified
MINIMUM
RATED
STAND-OFF BREAKDOWN
VOLTAGE
VOLTAGE
PART
NUMBER
(Note 1)
VWM
VOLTS
MAXIMUM
LEAKAGE
CURRENT
@ 1mA
V(BR)
VOLTS
MAXIMUM
CLAMPING
VOLTAGE
(Fig. 2)
@ IP = 1A
VC
VOLTS
TYPICAL
CAPACITANCE
@VWM
ID
µA
@0V, 1MHz
C
pF
PSD03
3.3
4.0
6.5
125
500
PSD03C
3.3
4.0
7.0
125
200
PSD05
5.0
6.0
9.8
10
350
PSD05C
5.0
6.0
9.8
10
175
PSD08
8.0
8.5
13.4
10
250
PSD08C
8.0
8.5
13.4
10
150
PSD12
12.0
13.3
19.0
1
150
PSD12C
12.0
13.3
19.0
1
50
PSD15
15.0
16.7
24.0
1
100
PSD15C
15.0
16.7
24.0
1
40
PSD18
18.0
20.0
29.0
1
90
PSD18C
18.0
20.0
29.0
1
40
PSD24
24.0
26.7
43.0
1
88
PSD24C
24.0
26.7
43.0
1
40
PSD36
36.0
40.0
60.0
1
75
PSD36C
36.0
40.0
60.0
1
35
1. Part numbers with an additional “C” suffix are bidirectional devices, i.e., PSD05 C.
FIGURE 1
PEAK PULSE POWER VS PULSE TIME
PPP - Peak Pulse Power - Watts
10,000
1,000
400W, 8/20µs Waveform
100
10
0.1
www.umw-ic.com
500W, 8/20µs Waveform
1
10
100
t d - Pulse Duration - µs
2
1,000
10,000
UMW
R
PSD03-PSD36C
FIGURE 2
PULSE WAVE FORM
tf
100
Peak Value IPP
80
100
TEST
WAVEFORM
PARAMETERS
tf = 8µs
td = 20µs
e-t
60
40
td = t/(IPP/2)
60
40
10
15
Peak Pulse Power
8/20µs
80
% Of Rated Power
IPP - Peak Pulse Current - % of IPP
120
FIGURE 3
POWER DERATING CURVE
30
Average Power
t - Time - µs
25
50
75
100
125
TA - Ambient Temperature - °C
150
FIGURE 4
OVERSHOOT & CLAMPING VOLTAGE FOR PSD03
400
C - Capacitance - pF
5 Volts per Division
35
25
15
ESD Test Pulse - 25 kilovolt, 1/30ns (Waveshape)
www.umw-ic.com
200
100
5
-5
300
2
3
4
VR - Reverse Voltage - Volts
3
UMW
R
PSD03-PSD36C
SPICE MODEL
FIGURE 1
SPICE MODEL FOR
ABD
ABD
ABD
Lg
0.55nH
Lg
0.5nH
UNIDIRECTIONAL
BIDIRECTIONAL
ABD - Avalanche Breakdown Diode (TVS)
Lg - Lead Inductance
TABLE 1 - SPICE PARAMETERS
PARAMETER
UNIT
ABD(TVS)
BV
V
See Table 2
IBV
µA
Cjo
pF
See Table 2
IS
A
See Table 2
Vj
V
0.6
M
0.33
1
N
RS
Ohms
See Table 2
1
TT
s
1E-8
EG
eV
1.11
TABLE 2 - ABD SPECIFIC SPICE PARAMETERS
IS (AMPS)
PART NUMBER
B V(VOLTS)
C jo(pF)
Rs(OHMS)
PSD03
www.umw-ic.com
4.0
438
1E-11
0.21
PSD05
6.0
284
1E-11
0.14
PSD08
8.5
146
1E-11
0.28
PSD12
13.3
123
1E-13
0.40
PSD15
16.7
102
1E-13
0.52
PSD24
26.7
61
1E-13
1.54
PSD03C
4.5
219
1E-11
0.21
PSD05C
6.0
142
1E-11
0.14
PSD08C
8.5
73
1E-11
0.28
PSD12C
13.3
62
1E-13
0.40
PSD15C
16.7
51
1E-13
0.52
PSD24C
26.7
30
1E-13
1.54
4
UMW
R
PSD03-PSD36C
Outline Drawing –SOD-323
C
OUTLINE DIMENSIONS
A
DIM
E
B
F
H
D
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
A
1.60
1.90
0.063
0.075
B
1.15
1.45
0.045
0.057
C
2.39
2.70
0.094
0.106
D
0.80
1.10
0.031
0.043
E
0.25
0.40
0.010
0.016
F
0.10
0.20
0.004
0.008
H
0.10
0.004
L
0.20
0.008
L
Marking
A
1
2
Ordering information
Order code
Marking code
Package
UMW PSD03-LF-T7
A
SOD-323
3000
UMW PSD03C-LF-T7
G
SOD-323
3000
Tape and reel
UMW PSD05-LF-T7
B
SOD-323
3000
Tape and reel
UMW PSD05C-LF-T7
H
SOD-323
3000
Tape and reel
UMW PSD08-LF-T7
C
SOD-323
3000
Tape and reel
UMW PSD08C-LF-T7
J
SOD-323
3000
Tape and reel
UMW PSD12-LF-T7
D
SOD-323
3000
Tape and reel
UMW PSD12C-LF-T7
K
SOD-323
3000
Tape and reel
UMW PSD15-LF-T7
E
SOD-323
3000
Tape and reel
UMW PSD15C-LF-T7
L
SOD-323
3000
Tape and reel
UMW PSD18-LF-T7
18
SOD-323
3000
Tape and reel
UMW PSD18C-LF-T7
N
SOD-323
3000
Tape and reel
UMW PSD24-LF-T7
F
SOD-323
3000
Tape and reel
UMW PSD24C-LF-T7
M
SOD-323
3000
Tape and reel
UMW PSD36-LF-T7
R
SOD-323
3000
Tape and reel
UMW PSD36C-LF-T7
T
SOD-323
3000
Tape and reel
www.umw-ic.com
5
Baseqty
Deliverymode
Tape and reel
很抱歉,暂时无法提供与“PSD15C-LF-T7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19872
- 200+0.15585
- 600+0.13209
- 3000+0.10790
- 9000+0.09558
- 21000+0.08889
- 国内价格
- 1+0.53680
- 200+0.17930
- 1500+0.11220
- 3000+0.08877
- 国内价格
- 20+0.16560
- 300+0.13131
- 1200+0.11129
- 3000+0.09291
