5.0SMDJ SERIES
5000W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS
Description
Transient Voltage Suppressors (TVS) Data Sheet
Breakdown Voltage
11.0 to 180 V
Peak Pulse Power
5000 W
The 5.0SMDJ series is designed specifically to protect sensitive electronic
equipment from voltage transients induced by lightning and other transient
voltage events
Features
•For surface mounted applications in order to optimize board space
•Low leakage
DO-214AB(SMC)
•Glass passivated junction
•Low inductance
•Excellent clamping capability
•5000W peak pulse power capability at 10/1000μs waveform
•Fast response time
•Typical IR less than 5μA above 22V
•High Temperature soldering: 260℃ /10 seconds at terminals
•Typical maximum temperature coefficient ΔVBR = 0.1% ×VBR@25℃ ×ΔT
•Plastic package has Underwriters Laboratory Flammability 94V-0
•Matte tin lead–free Plated
•Meets MSL level 1, per J-STD-020
•Halogen free and RoHS compliant
Bi-directional
•Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c
Uni-directional
•IEC 61000-4-2 ESD 30KV(Air),30KV(contact)
Applications
TVS devices are ideal for the protection of I/O interfaces, AC/DC power supply, Low frequency signal transmission line (RS232,
RS485, etc.)
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2)
Peak Pulse Current with a 10/1000μs waveform.(Note1,Fig.3)
Power Dissipation on Infinite Heat Sink at Ta=75° C(Fig.5)
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3,Fig.5)
Operating junction and Storage Temperature Range
Typical thermal resistance junction to lead
SYMBOL
VALUE
SYMBOL
IPP
See Next Table
A
IFSM
300
PPPM
PM(AV)
W
6.5
W
TJ , TSTG
-55 to +150
RθJ-A
75
Typical thermal resistance junction to ambient
Note :
(1) Non-repetitive current pulse, per Fig. 3 and derated above Ta = 25℃ per Fig. 2.
(2) Mounted on 8.0mm x 8.0mm Copper Pads to each terminal.
(3) 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
Rev:2.0
5000
Zhuhai Hongjiacheng Technology co., Ltd
RθJ-L
15
A
℃ /W
℃ /W
1 of 5
5.0SMDJ SERIES
Package Outline Dimensions (SMC/DO-214AB)
Symbol
A C
A
C
H
G
J
J
Symbol
M
M
J
K
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
Part Number
Uni
Marking
Bi
Uni
Bi
5.0SMDJ11A
5.0SMDJ11CA
5PEN
5BEN
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
5.0SMDJ12A
5.0SMDJ14A
5.0SMDJ15A
5.0SMDJ16A
5.0SMDJ17A
5.0SMDJ18A
5.0SMDJ20A
5.0SMDJ22A
5.0SMDJ24A
5.0SMDJ26A
5.0SMDJ28A
5.0SMDJ30A
5.0SMDJ33A
5.0SMDJ36A
Rev:2.0
5.0SMDJ12CA
5.0SMDJ14CA
5.0SMDJ15CA
5.0SMDJ16CA
5PEP
5PER
5PES
5PET
5BEP
5BER
5BES
5BET
5.0SMDJ17CA
5PEU
5BEU
5.0SMDJ20CA
5PEW
5BEW
5.0SMDJ24CA
5PEZ
5BEZ
5.0SMDJ28CA
5PFG
5BFG
5.0SMDJ33CA
5PFM
5BFM
5.0SMDJ18CA
5.0SMDJ22CA
5.0SMDJ26CA
5.0SMDJ30CA
5.0SMDJ36CA
5PEV
5PEX
5PFE
5PFK
5PFP
5BEV
5BEX
5BFE
5BFK
5BFP
Reverse
Stand-Off
Voltage
VRWM(V)
Breakdown Voltage
VBR (V) @IT
15
16
17
18
15.60
16.70
17.80
18.90
20.0
22.20
24
26.70
28
31.10
26
30
33
36
Test Current
10
3.03
14.70
14.40
14
Max.
24.4
28.90
33.30
36.70
40.0
15.90
17.20
18.50
19.70
20.90
22.10
24.50
26.90
29.50
31.90
34.40
36.80
40.60
44.20
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
0.261
0.281
0.078
0.103
0.030
0.060
0.008
0.306
0.321
0.006
Dimensions
Min.
13.30
13
0.246
Millimeters
IT(mA)
13.50
0.221
0.31
Max.
12.20
12
6.22
8.13
Min.
11
0.129
0.20
3.82
Max.
0.112
1.52
0.15
Min.
Inches
3.27
2.61
7.75
H
K
7.11
G
Suggested Pad Layout
6.60
0.76
F
F
Max.
1.99
E
E
Min.
5.59
D
D
Millimeters
2.85
B
B
Dimensions
Min.
0.151
3.84
0.012
Inches
0.120
Max.
0.152
Maximum
Clamping
Voltage@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
18.2
274.7
800
VC(V)
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
IPP (A)
251.3
232.6
215.5
204.9
192.3
181.2
171.2
154.3
140.8
128.5
118.8
110.1
103.3
93.8
86.1
IR(μA)
800
500
200
100
50
5
5
5
5
5
5
5
5
2 of 5
5.0SMDJ SERIES
Part Number
Uni
Marking
Bi
Uni
Bi
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
5.0SMDJ43A
5.0SMDJ48A
5.0SMDJ51A
5.0SMDJ54A
5.0SMDJ58A
5.0SMDJ60A
5.0SMDJ64A
5.0SMDJ70A
5.0SMDJ75A
5.0SMDJ78A
5.0SMDJ85A
5.0SMDJ90A
5.0SMDJ43CA
5.0SMDJ48CA
5.0SMDJ51CA
5.0SMDJ54CA
5PFT
5PFX
5PFZ
5PGE
5BFT
5BFX
5BFZ
5BGE
5.0SMDJ58CA
5PGG
5BGG
5.0SMDJ64CA
5PGM
5BGM
5.0SMDJ75CA
5PGR
5BGR
5.0SMDJ85CA
5PGV
5BGV
5.0SMDJ60CA
5.0SMDJ70CA
5.0SMDJ78CA
5.0SMDJ90CA
5PGK
5PGP
5PGT
5PGX
5BGP
5BGT
5BGX
5.0SMDJ100A
5.0SMDJ100CA
5.0SMDJ120A
5.0SMDJ120CA
5PHG
5BHG
5.0SMDJ150CA
5PHM
5BHM
5.0SMDJ170CA
5PHR
5BHR
5.0SMDJ110A
5.0SMDJ110CA
5.0SMDJ130A
5.0SMDJ130CA
5.0SMDJ160A
5.0SMDJ160CA
5.0SMDJ150A
5.0SMDJ170A
5.0SMDJ180A
5.0SMDJ180CA
5PGZ
5BGK
5PHE
5PHK
5PHP
5PHT
5BGZ
Reverse
Stand-Off
Voltage
VRWM(V)
Test Current
Min.
Max.
IT(mA)
43
47.80
52.80
1
48
53.30
54
60.0
40
45
51
44.40
50.0
56.70
58
64.40
64
71.10
60
70
75
78
85
90
100
66.70
77.80
49.10
55.30
58.90
62.70
66.30
71.20
73.70
78.60
86.0
83.30
92.10
94.40
104.0
86.70
100.0
111.0
95.80
111.0
123.0
1
1
1
1
1
1
1
1
1
1
1
1
5BHK
130
144.0
159.0
1
5BHP
160
167.0
5BHT
150
170
180
155.0
178.0
189.0
72.7
77.4
82.4
87.1
93.6
96.8
113.0
126.0
137.0
146.0
68.8
64.6
60.7
57.4
53.4
51.7
48.5
44.2
41.3
39.7
36.5
34.2
162.0
30.9
193.0
26.0
5
5
5
5
5
5
5
5
5
5
5
5
5
24.0
5
1
243.0
20.6
1
275.0
18.2
1
177.0
5
209.0
197.0
5
72.0
IR(μA)
5
1
209.0
77.5
69.4
IPP (A)
28.2
1
171.0
185.0
64.5
VC(V)
121.0
135.0
147.0
Reverse
Leakage
@VRWM
1
1
122.0
133.0
Peak
Pulse
Current
103.0
110
120
Maximum
Clamping
Voltage@IPP
1
5BHE
Note :
(1)Suffix 'A ' denotes 5% tolerance device.
(2)Add suffix ' CA ' after part number to specify Bi-directional devices.
(3)For Bi-Directional devices having VR of 18 volts and less, the IR limit is double.
Rev:2.0
Breakdown Voltage
VBR (V) @IT
226.8
259.0
22.0
19.3
5
5
5
5
5
3 of 5
5.0SMDJ SERIES
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
100
PeakPulsePower(PPP)orCurrent(IPP)
Derating
inPercentage%
1000
PPPM-PeakPuslePower(kW)
100
10
1
0.1
0.1
1
10
tp-PulseDuration(μs)
100
80
60
40
100
10000
CJ-JunctionCapacitance(pF)
I PPM-PeakPulseCurrent,%I RSM
PeakvalueIPPM
HalfValueI PPM (I PMM /2)
10/1000μsWaveformas
definedbyR.E.A
td
1
2
Bi-directional
10
1
1
10
100
VBR-ReverseBreakdownVoltage(V)
1000
350
6
300
Tj=Tjmax.
8.3msSingleHalfSine-Wave
IFSM-PeakForwardSurgeCurrent(A)
PM(AV),SteadystatePowerDissipation(W)
7
5
250
4
200
3
150
2
100
1
50
50
75
100
125
Ta-Ambienttemperature(℃)
150
Fig.5 Steady State Power Dissipation Derating Curve
Rev:2.0
Measuredat
1.0MHz
100mV,0Vbias
Fig.4 Typical Junction Capacitance
Fig.3 Pulse Waveform
100
4
3
t-Time(ms)
150
Uni-directional
1000
50
125
100000
T J =25℃
PulseWidth(t d )isdefinedas
thepointwherethepeak
currentdecaysto50%ofI PPM
t r =10μs
100
Fig.2 Pulse Derating Curve
Fig. 1 Peak Pulse Power Rating Curve
150
75
50
175
10
NumberofCyclesat60Hz
100
Fig.6 Maximum Non-Repetitive Forward Surge Current Uni-Directional Only
4 of 5
5.0SMDJ SERIES
Ordering Information
PACKAGE
SMC
PACKAGE CODE
UNIT WEIGHT(g)
R3
Part Numbering
REEL(pcs)
0.257
BOX(pcs)
3000
5.0SMDJ XXX
XXX
5.0SMDJ
C
C
6000
A
A
CARTON(pcs)
DELIVERY MODE
48000
13''
5%VBRVoltageTolerance
Bidirectional
VRWMVoltage
SeriesCode
Soldering Parameters
U1
51
3BNQVQ
5FNQFSBUVSF
5-
Profile Feature
$SJUJDBM;POF
5-UP5 1
Pre-heat
U-
Pb-Free Assembly
Temperature Min (Ts(min))
+150℃
Time (Min to Max) (ts)
60-180 secs.
Temperature Max(Ts(max))
+200℃
Average ramp up rate (Liquid us Temp (TL) to peak)
54 NBY
3℃ /sec. Max
Ts(max) to TL - Ramp-up Rate
Reflow
54 NJO
Peak Temp (TP)
3BNQEPXO
U4
60-150 secs.
+260(+0/-5)℃
30 secs. Max
Ramp-down Rate
U℃UP1FBL
5JNF
P1
+260℃
Symbol
Dimension (mm)
P0
4.00±0.10
W
D0
B
T
E
F
A
8 min. Max
Do not exceed
P2
A
6℃ /sec. Max
Time 25℃ to Peak Temp (TP)
Packaging (SMC/DO-214AB)
P0
+217℃
Temperature(tL)
Time within 5℃ of actual Peak Temp (tP)
1SFIFBU
3℃ /sec. Max
Temperature(TL)(Liquid us)
D1
B
W
P1
P2
B0
K0
SECTIONB-B
E
1.75±0.10
D1
F
K0
T
Rev:2.0
2.00±0.10
Φ1.5±0.10
B0
SECTIONA-A
8.00±0.10
D0
A0
A0
16.00±0.20
Φ1.5±0.10
7.50±0.10
6.27±0.10
8.30±0.10
3.15±0.15
0.30±0.05
5 of 5
很抱歉,暂时无法提供与“5.0SMDJ45CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.62440
- 10+2.04120
- 30+1.78200
- 100+1.46880
- 500+1.32840
- 1000+1.25280
