5.0SMDJ43CA
5.0SMDJ43CA
    HONGJIACHENG(宏嘉诚)
    SMC(DO-214AB)
    ESD抑制器/TVS二极管 双向 43V 72A 5KW SMC(DO-214AB)
5.0SMDJ43CA 数据手册
5.0SMDJ SERIES 5000W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Description Transient Voltage Suppressors (TVS) Data Sheet Breakdown Voltage 11.0 to 180 V Peak Pulse Power 5000 W The 5.0SMDJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events Features •For surface mounted applications in order to optimize board space •Low leakage DO-214AB(SMC) •Glass passivated junction •Low inductance •Excellent clamping capability •5000W peak pulse power capability at 10/1000μs waveform •Fast response time •Typical IR less than 5μA above 22V •High Temperature soldering: 260℃ /10 seconds at terminals •Typical maximum temperature coefficient ΔVBR = 0.1% ×VBR@25℃ ×ΔT •Plastic package has Underwriters Laboratory Flammability 94V-0 •Matte tin lead–free Plated •Meets MSL level 1, per J-STD-020 •Halogen free and RoHS compliant Bi-directional •Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c Uni-directional •IEC 61000-4-2 ESD 30KV(Air),30KV(contact) Applications TVS devices are ideal for the protection of I/O interfaces, AC/DC power supply, Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2) Peak Pulse Current with a 10/1000μs waveform.(Note1,Fig.3) Power Dissipation on Infinite Heat Sink at Ta=75° C(Fig.5) Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3,Fig.5) Operating junction and Storage Temperature Range Typical thermal resistance junction to lead SYMBOL VALUE SYMBOL IPP See Next Table A IFSM 300 PPPM PM(AV) W 6.5 W TJ , TSTG -55 to +150 ℃ RθJ-A 75 Typical thermal resistance junction to ambient Note : (1) Non-repetitive current pulse, per Fig. 3 and derated above Ta = 25℃ per Fig. 2. (2) Mounted on 8.0mm x 8.0mm Copper Pads to each terminal. (3) 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Rev:2.0 5000 Zhuhai Hongjiacheng Technology co., Ltd RθJ-L 15 A ℃ /W ℃ /W 1 of 5 5.0SMDJ SERIES 5000W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Package Outline Dimensions (SMC/DO-214AB) Symbol A C A C H G J J Symbol M M J K Electrical Characteristics (Ta=25℃ Unless otherwise specified) Part Number Uni Marking Bi Uni Bi 5.0SMDJ11A 5.0SMDJ11CA 5PEN 5BEN 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 5.0SMDJ12A 5.0SMDJ14A 5.0SMDJ15A 5.0SMDJ16A 5.0SMDJ17A 5.0SMDJ18A 5.0SMDJ20A 5.0SMDJ22A 5.0SMDJ24A 5.0SMDJ26A 5.0SMDJ28A 5.0SMDJ30A 5.0SMDJ33A 5.0SMDJ36A Rev:2.0 5.0SMDJ12CA 5.0SMDJ14CA 5.0SMDJ15CA 5.0SMDJ16CA 5PEP 5PER 5PES 5PET 5BEP 5BER 5BES 5BET 5.0SMDJ17CA 5PEU 5BEU 5.0SMDJ20CA 5PEW 5BEW 5.0SMDJ24CA 5PEZ 5BEZ 5.0SMDJ28CA 5PFG 5BFG 5.0SMDJ33CA 5PFM 5BFM 5.0SMDJ18CA 5.0SMDJ22CA 5.0SMDJ26CA 5.0SMDJ30CA 5.0SMDJ36CA 5PEV 5PEX 5PFE 5PFK 5PFP 5BEV 5BEX 5BFE 5BFK 5BFP Reverse Stand-Off Voltage VRWM(V) Breakdown Voltage VBR (V) @IT 15 16 17 18 15.60 16.70 17.80 18.90 20.0 22.20 24 26.70 28 31.10 26 30 33 36 - Test Current 10 20 22 3.03 14.70 14.40 14 Max. - 24.4 28.90 33.30 36.70 40.0 15.90 17.20 18.50 19.70 20.90 22.10 24.50 26.90 29.50 31.90 34.40 36.80 40.60 44.20 Zhuhai Hongjiacheng Technology co., Ltd 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 0.261 0.281 0.078 0.103 0.030 0.060 - 0.008 0.306 0.321 0.006 Dimensions Min. 13.30 13 0.246 Millimeters IT(mA) 13.50 0.221 0.31 Max. 12.20 12 6.22 8.13 Min. 11 0.129 0.20 3.82 Max. 0.112 1.52 0.15 Min. Inches 3.27 2.61 7.75 H K 7.11 - G Suggested Pad Layout 6.60 0.76 F F Max. 1.99 E E Min. 5.59 D D Millimeters 2.85 B B Dimensions Min. - 0.151 3.84 - 0.012 Inches 0.120 Max. - 0.152 Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM 18.2 274.7 800 VC(V) 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 IPP (A) 251.3 232.6 215.5 204.9 192.3 181.2 171.2 154.3 140.8 128.5 118.8 110.1 103.3 93.8 86.1 IR(μA) 800 500 200 100 50 20 10 5 5 5 5 5 5 5 5 2 of 5 5.0SMDJ SERIES 5000W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Electrical Characteristics (Ta=25℃ Unless otherwise specified) Part Number Uni Marking Bi Uni Bi 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 5.0SMDJ43A 5.0SMDJ48A 5.0SMDJ51A 5.0SMDJ54A 5.0SMDJ58A 5.0SMDJ60A 5.0SMDJ64A 5.0SMDJ70A 5.0SMDJ75A 5.0SMDJ78A 5.0SMDJ85A 5.0SMDJ90A 5.0SMDJ43CA 5.0SMDJ48CA 5.0SMDJ51CA 5.0SMDJ54CA 5PFT 5PFX 5PFZ 5PGE 5BFT 5BFX 5BFZ 5BGE 5.0SMDJ58CA 5PGG 5BGG 5.0SMDJ64CA 5PGM 5BGM 5.0SMDJ75CA 5PGR 5BGR 5.0SMDJ85CA 5PGV 5BGV 5.0SMDJ60CA 5.0SMDJ70CA 5.0SMDJ78CA 5.0SMDJ90CA 5PGK 5PGP 5PGT 5PGX 5BGP 5BGT 5BGX 5.0SMDJ100A 5.0SMDJ100CA 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 5.0SMDJ150CA 5PHM 5BHM 5.0SMDJ170CA 5PHR 5BHR 5.0SMDJ110A 5.0SMDJ110CA 5.0SMDJ130A 5.0SMDJ130CA 5.0SMDJ160A 5.0SMDJ160CA 5.0SMDJ150A 5.0SMDJ170A 5.0SMDJ180A 5.0SMDJ180CA 5PGZ 5BGK 5PHE 5PHK 5PHP 5PHT 5BGZ Reverse Stand-Off Voltage VRWM(V) Test Current Min. Max. IT(mA) 43 47.80 52.80 1 48 53.30 54 60.0 40 45 51 44.40 50.0 56.70 58 64.40 64 71.10 60 70 75 78 85 90 100 66.70 77.80 49.10 55.30 58.90 62.70 66.30 71.20 73.70 78.60 86.0 83.30 92.10 94.40 104.0 86.70 100.0 111.0 95.80 111.0 123.0 1 1 1 1 1 1 1 1 1 1 1 1 5BHK 130 144.0 159.0 1 5BHP 160 167.0 5BHT 150 170 180 155.0 178.0 189.0 72.7 77.4 82.4 87.1 93.6 96.8 113.0 126.0 137.0 146.0 68.8 64.6 60.7 57.4 53.4 51.7 48.5 44.2 41.3 39.7 36.5 34.2 162.0 30.9 193.0 26.0 5 5 5 5 5 5 5 5 5 5 5 5 5 24.0 5 1 243.0 20.6 1 275.0 18.2 1 177.0 5 209.0 197.0 Zhuhai Hongjiacheng Technology co., Ltd 5 72.0 IR(μA) 5 1 209.0 77.5 69.4 IPP (A) 28.2 1 171.0 185.0 64.5 VC(V) 121.0 135.0 147.0 Reverse Leakage @VRWM 1 1 122.0 133.0 Peak Pulse Current 103.0 110 120 Maximum Clamping Voltage@IPP 1 5BHE Note : (1)Suffix 'A ' denotes 5% tolerance device. (2)Add suffix ' CA ' after part number to specify Bi-directional devices. (3)For Bi-Directional devices having VR of 18 volts and less, the IR limit is double. Rev:2.0 Breakdown Voltage VBR (V) @IT 226.8 259.0 22.0 19.3 5 5 5 5 5 3 of 5 5.0SMDJ SERIES 5000W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 100 PeakPulsePower(PPP)orCurrent(IPP) Derating inPercentage% 1000 PPPM-PeakPuslePower(kW) 100 10 1 0.1 0.1 1 10 tp-PulseDuration(μs) 100 80 60 40 20 0 1000 0 25 100 10000 CJ-JunctionCapacitance(pF) I PPM-PeakPulseCurrent,%I RSM PeakvalueIPPM HalfValueI PPM (I PMM /2) 0 10/1000μsWaveformas definedbyR.E.A 0 td 1 2 Bi-directional 10 1 1 10 100 VBR-ReverseBreakdownVoltage(V) 1000 350 6 300 Tj=Tjmax. 8.3msSingleHalfSine-Wave IFSM-PeakForwardSurgeCurrent(A) PM(AV),SteadystatePowerDissipation(W) 7 5 250 4 200 3 150 2 100 1 50 0 25 50 75 100 125 Ta-Ambienttemperature(℃) 150 Fig.5 Steady State Power Dissipation Derating Curve Rev:2.0 Measuredat 1.0MHz 100mV,0Vbias Fig.4 Typical Junction Capacitance Fig.3 Pulse Waveform 0 175 100 4 3 t-Time(ms) 150 Uni-directional 1000 50 125 100000 T J =25℃ PulseWidth(t d )isdefinedas thepointwherethepeak currentdecaysto50%ofI PPM t r =10μs 100 Ta-Ambienttemperature(℃) Fig.2 Pulse Derating Curve Fig. 1 Peak Pulse Power Rating Curve 150 75 50 175 0 1 10 NumberofCyclesat60Hz 100 Fig.6 Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Zhuhai Hongjiacheng Technology co., Ltd 4 of 5 5.0SMDJ SERIES 5000W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS Ordering Information PACKAGE SMC PACKAGE CODE UNIT WEIGHT(g) R3 Part Numbering REEL(pcs) 0.257 BOX(pcs) 3000 5.0SMDJ XXX XXX 5.0SMDJ C C 6000 A A CARTON(pcs) DELIVERY MODE 48000 13'' 5%VBRVoltageTolerance Bidirectional VRWMVoltage SeriesCode Soldering Parameters U1 51 3BNQVQ 5FNQFSBUVSF 5- Profile Feature $SJUJDBM;POF 5-UP5 1 Pre-heat U- Pb-Free Assembly Temperature Min (Ts(min)) +150℃ Time (Min to Max) (ts) 60-180 secs. Temperature Max(Ts(max)) +200℃ Average ramp up rate (Liquid us Temp (TL) to peak) 54 NBY 3℃ /sec. Max Ts(max) to TL - Ramp-up Rate Reflow 54 NJO Peak Temp (TP) 3BNQEPXO U4 60-150 secs. +260(+0/-5)℃ 30 secs. Max Ramp-down Rate U℃UP1FBL 5JNF P1 +260℃ Symbol Dimension (mm) P0 4.00±0.10 W D0 B T E F A 8 min. Max Do not exceed P2 A 6℃ /sec. Max Time 25℃ to Peak Temp (TP) Packaging (SMC/DO-214AB) P0 +217℃ Temperature(tL) Time within 5℃ of actual Peak Temp (tP) 1SFIFBU  3℃ /sec. Max Temperature(TL)(Liquid us) D1 B W P1 P2 B0 K0 SECTIONB-B E 1.75±0.10 D1 F K0 T Rev:2.0 Zhuhai Hongjiacheng Technology co., Ltd 2.00±0.10 Φ1.5±0.10 B0 SECTIONA-A 8.00±0.10 D0 A0 A0 16.00±0.20 Φ1.5±0.10 7.50±0.10 6.27±0.10 8.30±0.10 3.15±0.15 0.30±0.05 5 of 5
5.0SMDJ43CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ43CA”相匹配的价格&库存,您可以联系我们找货
