R
DLL 德 利 来
Connectors
NH1.0
1.00mm Pitch Wire To Board Connector
技 术 特 性/ S p e c i f i c a t i o n s :
额定电压 Rated voltage: 125V AC,DC
额定电流 Rated current: 1A AC,DC
接触电阻 Contact resistance: 20mΩ max
绝缘电阻 Insulation resistance: 100MΩ min
耐压 Withstand volage: 500V AC/minute
环境温度 Ambient temperature:-40℃~+105℃
适用线规 Wire range: AWG#32~#28
电话/TEL:+86-577-62213798
传真/FAX:+86-577-62122577
http://www.zjdll.com
1
2
3
4
5
6
7
8
REVISION DESCRIPTION
REV.
DATE
APPD
NOTES
A
A
Available in 02 through 20 Circuits.
Mates with DL10006-Y Series Housing.
Material :LCP UL94V-0.
3
B
Material : Phosphor Bronze.
B
Finish : Over Ni;Tin-plated.
1
1.6
1.05
1.8
DL10006 - XX X - X XX - X X - X - XX
2 3 4 5
6 7
8 9
1
1.PART NO.
2..NO.OF CIRCUIT
3.CONN.TYPE
4.MATERIAL: 0:PA66 V0
1:PA66 V1
2:PA66 V2
3:PA66 V0 750
6:PA9T
7:9A6T
8:GF PA66
5.COLOR: NA:NATURE RE:RED
BR:BROWN
GY:GREY
BK:BLACK
YE:YELLOW
BL:BLUE
GR:GREEN
PU:PURPLE PI:PINK
OR:ORANGE TR:TRANSPARENT OT:OTHER
6.CONTACT MATERIAL: P:PHOSPJOR BRONZE B:BRASS
7.FINISH: T:TIN
MT:MATT TIN BG/QG:GOLD
S:SILVER
8.STYLE: Z:WITHOUT K
K:WITH K
D
E
Circuits Type
2
3
4
5
6
7
8
9
10
F
1
2
NH1.0-2AB
NH1.0-3AB
NH1.0-4AB
NH1.0-5AB
NH1.0-6AB
NH1.0-7AB
NH1.0-8AB
NH1.0-9AB
NH1.0-10AB
3
Dimension mm
A
1.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
B
3.5
4.5
5.5
6.5
7.5
8.5
9.5
10.5
11.5
C
Circuits
2.5
3.5
4.5
5.5
6.5
7.5
8.5
9.5
10.5
11
12
13
14
15
16
17
Type
NH1.0-11AB
NH1.0-12AB
NH1.0-13AB
NH1.0-14AB
NH1.0-15AB
NH1.0-16AB
NH1.0-17AB
NH1.0-20AB
1.15
3.9
ORDERING INFORMATION
CIRCUIT NO.1
C
3.5
C
0.6
0.55
D
PCB LAYOUT
LCP
1
3
3
2
2
2
1
1
N*
UL94-VO
E
Dimension mm
A
10.0
11.0
12.0
13.0
14.0
15.0
16.0
19.0
B
C
12.5
13.5
14.5
15.5
16.5
17.5
18.5
21.5
5
11.5
12.5
13.5
14.5
15.5
16.5
17.5
20.5
GENERAL TOLERANCES
(UNLESS SPECIFIED)
ZHE JIANG DELI CONNECTORS CO .,LTD
TITLE:
PRODUCT NAME:
.X:
DL10006-AB(NH1.0-AB)
.XX:
1.0mm Pitch
Wire To Board SMT Wafer
DR:Chen Quan Long DATE:20.12.31 PART NO:
.XXX:
DL10006-XXB-XXX-XX-X-XX
FINISH:
DRAWING NO:
GC-DL10006-XXB-XXX-XX-X-XX
6
CHKD: Wu Hui
DATE:20.12.31
APPD:Ren An De
DATE:20.12.31 UNITS:
7
SCALE:
N/A
PAGE: 1/1
mm
REV.:
8
A
F
1
2
3
4
5
6
7
8
REV.
DATE
APPD
NOTES
A
A
2
B
3
B
1
0.6
0.8
1.1
C
C
0.6
1.2
3.15
4.7
2 3 4 5
6 7
8 9
1
1.PART NO.
2..NO.OF CIRCUIT
3.CONN.TYPE
1:PA66 V1
2:PA66 V2
3:PA66 V0 750
6:PA9T
7:9A6T
8:GF PA66
BR:BROWN
GY:GREY
BK:BLACK
YE:YELLOW
BL:BLUE
GR:GREEN
PU:PURPLE PI:PINK
6.CONTACT MATERIAL: P:PHOSPHOR BRONZE B :BRASS
7.FINISH: T:TIN
S:SILVER
K:WITH K
D
E
Circuits Type
2
3
4
5
6
7
8
9
10
F
1
2
NH1.0-2AWB
NH1.0-3AWB
NH1.0-4AWB
NH1.0-5AWB
NH1.0-6AWB
NH1.0-7AWB
NH1.0-8AWB
NH1.0-9AWB
NH1.0-10AWB
3
Dimension mm
A
1.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
B
3.5
4.5
5.5
6.5
7.5
8.5
9.5
10.5
11.5
C
Circuits
2.5
3.5
4.5
5.5
6.5
7.5
8.5
9.5
10.5
11
12
13
14
15
16
17
Type
NH1.0-11AWB
NH1.0-12AWB
NH1.0-13AWB
NH1.0-14AWB
NH1.0-15AWB
NH1.0-16AWB
NH1.0-17AWB
NH1.0-20AWB
D
PCB LAYOUT
LCP
1
3
3
2
2
2
1
1
N*
UL94-VO
E
Dimension mm
A
10.0
11.0
12.0
13.0
14.0
15.0
16.0
19.0
B
12.5
13.5
14.5
15.5
16.5
17.5
18.5
21.5
5
C
11.5
12.5
13.5
14.5
15.5
16.5
17.5
20.5
GENERAL TOLERANCES
(UNLESS SPECIFIED)
TITLE:
PRODUCT NAME:
.X:
DL10006-AWB(NH1.0-AWB)
.XX:
1.0mm Pitch
.XXX:
DL10006-XXWB-XXX-XX-X-XX
FINISH:
CHKD: Wu Hui
DRAWING NO:
APPD:Ren An De
GC-DL10006-XXWB-XXX-XX-X-XX
6
DATE:20.12.31
SCALE:
7
N/A
PAGE: 1/1
mm
REV.:
8
A
F
1
2
4
3
5
7
6
A±0.2
1±0.1
A
8
REV.
DATE
APPD
NOTES
A
Match with DL10006 series housing
Material : Nylon UL94V-0(2).
Accepts DL10006-T Crimp Terminal.
B
B
C±0.25
1.7
C
6±0.3
7.3±0.3
C
DLXXXXX - XX X - X XX - XX
2 3
4 5
6
1
1.PART NO.
2..NO.OF CIRCUIT
3.CONN.TYPE
4.MATERIAL: 0: PA66 V0
1: PA66 V1
2: PA66 V2
3: PA66 V0 750 ℃
4:LCP
5: PBT
6:PA9T
7:9A6T
8:PA66 GF
BR:BROWN
GY:GREY
BK:BLACK
YE:YELLOW
BL:BLUE
GR:GREEN
PU:PURPLE PI:PINK
D
CIRCUIT NO.1
3.8±0.3
B±0.3
E
D
E
6.SERIAL NUMBER:00.01.02.....
Circuits
2
3
4
5
6
7
8
9
10
F
1
2
3
Type
NH1.0-2Y
NH1.0-3Y
NH1.0-4Y
NH1.0-5Y
NH1.0-6Y
NH1.0-7Y
NH1.0-8Y
NH1.0-9Y
NH1.0-10Y
Dimension mm
A
B
1.0
3.0
2.0
4.0
3.0
5.0
4.0
6.0
5.0
7.0
6.0
8.0
7.0
9.0
8.0
10.0
9.0
11.0
C
2.4
3.4
4.4
5.4
6.4
7.4
8.4
9.4
10.4
4
Circuits
Type
11
12
13
14
15
16
17
NH1.0-11Y
NH1.0-12Y
NH1.0-13Y
NH1.0-14Y
NH1.0-15Y
NH1.0-16Y
NH1.0-17Y
NH1.0-20Y
Dimension mm
A
B
10.0
12.0
11.0
13.0
12.0
14.0
13.0
15.0
14.0
16.0
15.0
17.0
16.0
18.0
19.0
21.0
5
C
11.4
12.4
13.4
14.4
15.4
16.4
17.4
20.4
GENERAL TOLERANCES
(UNLESS SPECIFIED)
X°:
.XX: ± 0.15
.X°: ± 2.0°
1.0 mm Pitch Housing
DL10006-Y(NH1.0-Y)
.XX°: ± 1.0° DR:Chen Quan Long DATE:20/10/12 PART NO:
FINISH:
DRAWING NO:
TITLE:
± 3.0° PRODUCT NAME:
.X: ± 0.25
.XXX: ± 0.01
GC-DL10006-XXY-XXX-XX
6
CHKD: Wu Hui
DATE:20/10/12
APPD:Ren An De
DATE:20/10/12 UNITS:
7
SCALE:
DL10006-XXY-XXX-XX
N/A
PAGE: 1/1
mm
REV.:
8
A
F
1
2
3
4
6
5
7
REV.
A
8
DATE
APPD
A
NOTES
Used in DL10006-Y Series Housing.
4
Accepts AWG #32 28 Wire Range.
0.032
0.08 mm2 .
Insulation O.D.=0.4 0.8 mm.
Material : Phosphor Bronze .
1.
5
T=0.12
2.8
B
Finish:
B
Tin plated.
0.12 mm.
0.55
Thickness:
A
A
C
B
1.35
B
0.85
2
C
D
0.5
0.3
DL10006 - T - X - X - X - XX
2
3
4 5
6
1
0.9
D
1.PART NO.
2.TERMINAL CODE
4: STAINLESS STEEL 5: OTHER
4.TECHNICS: 0: UNPLATED
1: FIRST PLATING 2: POST PLATING
3: OTHER
5.FINISH: 1: TIN-PLATED
2:MATTE PLATED 3:NICKEL PLATED
4:PICKLING
5: SILVER PLATED 6:GOLD PLATED
7: GALVANIZED 8:OTHER
E
GENERAL TOLERANCES
(UNLESS SPECIFIED)
SECTION A-A
SECTION B-B
SECTION C-C
F
.XX:
PRODUCT NAME:
DL10006-T(NH1.0-T)
.XXX:
DR:Chen Quan Long
DATE:20/10/12
CHKD: Wu Hui
DATE:20/10/12
.X:
FINISH:
APPD:Ren An De
DRAWING NO:
GC-DL10006-T-X-X-X-XX
1
2
3
4
5
6
E
DATE:20/10/12
7
TITLE:
1.0mm Pitch
Crimp Terminal
PART NO:
F
DL10006-T-X-X-X-XX
SCALE: N/A
PAGE: 1/1
UNITS:
REV.:
mm
8
A
很抱歉,暂时无法提供与“NH1.0-6AWB”相匹配的价格&库存,您可以联系我们找货
