DRV8837DSGR-MS
Product specification
DRV8837DSGR-MS
GENERAL DESCRIPTION
DRV8837DSGR-MS are low voltage DC IC.motor driver Internal integration 650mΩ(HS+LS typical) H bridge N
MOS switch, whichcan support the 1.8V~11V input voltage range.The Peak current capacityis up to1.5A,suppo
rt for ultra-low power sleep mode; built-inUVLO, Thermal Shutdown, OCP protectioncircuit. DRV8837DSGR-MS
can be used in camera, toys and consumer products.
FEATURES
Support the input voltage range:
Built-in UVLO Protection
Motor power: 1.8V~11V
Built-in Over Temperature Protection
Control power supply: 1.8V~7V
Built-in Short Circuit Protection
LDMOS RDS(ON) (HS+LS) 650mΩ (typical)
Built-in Over Current Protection
Ultra-low power sleep mode
Built-in Charge Pump
45nA (typical) VM sleep mode current
WSON-8-EP(2*2) package
17nA (typical) VCC sleep mode current
Up to 1.5A Peak current output capacity
APPLICATION
Cameras
Toys
Consumer Products
Reference News
WSON-8-EP(2*2)
Pin Configuration
MARKING
TFC*
Order information
P/N
PKG
QTY
DRV8837DSGR-MS
WSON-8-EP(2*2)
3000PCS
Copyright© Msksemi Incorporated
www.msksemi.com
DRV8837DSGR-MS
PIN FUNCTIONS
Pin
Name
Function
Power Supply for Driver. Connect a 0. 1μF bypass ceramic capacitor to GND. A bulk
capacitor with at least 22μF capacitance on VM to GND is needed and helpful to
1
VM
2
OUT1
Motor Driver output 1
3
OUT2
Motor Driver output 2
4
GND
Ground pin
5
IN2
PWM input2
6
IN1
PWM input1
stabilize VM voltage during motor operation.
Chip Enable Input Pin. When this pin is in logic low, the device enters low-power
7
EN
sleep mode. The device operates normally when this pin is logic high. The pin has
8
VCC
Power Supply for Logic Input. Connect a 0. 1μF bypass ceramic capacitor to GND
an internal pull-down resistor to GND.
YPICAL APPILCATION
Figure 1. Basic Application Circuit
www.msksemi.com
DRV8837DSGR-MS
ABSOLUTE MAXIMUM RATINGS
Parameter
Value
Unit
VM Voltage Range
-0.3~ 11
V
VCC, IN1, IN2, EN Voltages Range
-0.3~7
V
OUT1, OUT2 Voltage Range
-0.3~Vin+0.3
V
Storage Temperature Range
-50~ 150
°C
Junction Temperature
-40~ 150
°C
Package Thermal Resistance θ JA of DFN2x2-8
70
°C/W
90
°C/W
of SOP8
ESD RATING
Items
Description
Human Body Model for all pins
VESD
Value
Unit
±2000
V
JEDEC specification JS-001
RECOMMENDED OPERATING CONDITIONS
Itms
Descriptione
Min Max
Unit
Voltage Range
VM
1.8
11
V
TJ
Operating Junction Temperature Range
-40
125
°C
www.msksemi.com
DRV8837DSGR-MS
ELECTRICAL CHARACTERISTICS
(VM=5V, TA = 25°C, unless otherwise noted.)
Parameter
Symbol
Conditions
Min
Typ
Max
Unit
11
V
Input Power Supplies (VM and VCC)
VM Voltage Range
VM Supply Current
IVM
VM sleep mode supply current
IVMQ
VCC Voltage Range
V VCC
VCC Supply Current
VCC sleep mode supply current
1.8
V VM
IVCC
IVCCQ
VM=5V, VCC=3V
No PWM
124
μA
VM=5V, VCC=3V
50kHz PWM
0.53
mA
VM=5V, VCC=3V
Sleep Mode
45
1.8
95
nA
7
V
VM=5V, VCC=3V
No PWM
180
μA
VM=5V, VCC=3V
50kHz PWM
0.32
mA
VM=5V, VCC=3V
Sleep Mode
17
35
nA
PWM Control Logic Inputs (IN1, IN2 and EN)
0.25x
VCC
0.4x
VCC
Input Logic Low Voltage Falling
Threshold
VIL_F
Input Logic High Voltage Rising
Threshold
VIH_R
0.5x
VCC
Input logic Hysteresis
VHYS
0.1x
VCC
Input Logic Low Current
IIL
Input Logic High Current
IIH
Input Pull Down Resistor
RIN
-5
V
0.6x
VCC
V
V
5
μA
40
μA
100
kΩ
0.65
Ω
Motor Driver Outputs ( OUT1 and OUT2)
Output Switch
On-Resistance (HS+LS)
Output Switch Leakage Current
RON
ILEAK
-200
200
nA
Protection Function
VCC UVLO Voltage
UVLO Hysteresis
VUVLO
1.7
V
VUVLO_HY
100
mV
1.75
A
IOCP
Over Current Retry Time
TOCP_RT
1
ms
Thermal Shutdown Threshold
TSDN
160
°C
Thermal Shutdown Hysteresis
TSDN_HY
°C
1.6
www.msksemi.com
DRV8837DSGR-MS
ELECTRICAL CHARACTERISTICS(continued)
(VIN=5V, TA = 25°C, unless otherwise noted.)
Parameter
Symbol
Conditions
Min
Typ
Max
Unit
Output Enable time
T1
180
265
ns
Output Disable time
T2
70
100
ns
T3
140
215
ns
IN2 high to OUT1 low
IN1 high to OUT2 low
T4
160
240
ns
Output rise time
T5
60
120
ns
Output fall time
T6
38
100
ns
Delay Time
IN1 low to OUT2 high
IN2 low to OUT1 high
Delay Time
FUNCTIONAL BLOCK DIAGRAM
Figure 2. DRV8837DSGR-MS Block Diagram
www.msksemi.com
DRV8837DSGR-MS
INPUT OUTPUT LOGIC
EN
IN1
IN2
OUT1
OUT2
Function
X
X
Z
Z
Coast
1
Z
Z
Coast
1
1
H
L
Forward
1
L
H
Reverse
1
1
1
L
L
Brake
www.msksemi.com
DRV8837DSGR-MS
PACKAGE INFORMATION
WSON-8-EP(2*2)
Unit: mm
Symbol
Dimensions In Millimeters
Min
Typ
Max
A
0.70
0.75
0.80
A1
A3
b
0.19
Symbol
Min
Typ
Max
L
0.30
0.35
0.40
0.05
K
0.20
0.20 REF
aaa
0.15
0.24
0.29
bbb
0.10
D
2.00 BSC
ccc
0.10
E
2.00 BSC
ddd
0.05
D2
1.25
1.30
1.35
eee
0.08
E2
0.75
0.80
0.85
fff
0.10
e
0.50 BSC
Note:
1) All dimensions are in millimeters.
www.msksemi.com
DRV8837DSGR-MS
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not
handle applications that require extremely high levels of reliability, such as life-support
have specifications
that can
systems, aircraft's control systems, or
other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with
your MSKSEMI Semiconductor representative
nearest
you before using any MSKSEMI Semiconductor products described
or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in
products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the
performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To
verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test
devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could
endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing
equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are
not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained
herein are controlled under any of applicable local export control laws and regulations, such products must not be exported
without obtaining the export license from theauthorities
concerned
in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior
written permission of MSKSEMI Semiconductor.
Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume
production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or
implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties.
Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI
Semiconductor productthat you intend to use.
www.msksemi.com
