RNE32768069
RNE32768069
    TROQ(创捷)
    SMD3215_2P
    SEAM 3215-2P/32.768KHZ/9PF/20/-40℃+85℃
RNE32768069 数据手册
TROQ Electronic Co.,Ltd. CRYSTAL UNIT SPECIFICATIONS Customer Production Name Tuning Fork 3.2*1.5 TROQ P/N RNE32768069 Revision A Print Date 2023/6/17 Drawn Checked Approved RoHS Compliant No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com TROQ P/N: ● RNE32768069 REV: A ELECTRICAL PARAMETERS 谐振器产品技术指标 Min 1.Holder Type(型号规格) Max Tuning Fork 3.2*1.5 2.Mode of Oscillation(振动模式) 3.Frequency(标称频率) Fundamental 32.768000 KHZ 9 pF 4.Load Capacitance (CL)(负载电容) 5.Shunt Capacitance (Co)(静态电容) 0 6.Equivalent Resistance(谐振电阻) 7.Frequency Tolerance at 25℃(调整频差) -20 8.Temperature Coefficient (K)(温度系数) 9.Insulation Resistance (at DC 100V)(绝缘电阻) Units 2 pF 70 kΩ 20 ppm -0.04 ppm/(△℃)2 MΩ 1 uw 500 10.Drive Level(激励功率) 11.Operating Temperature Range(工作温度范围) -40 85 ℃ 12.Storage Temperature Range(储存温度范围) -55 125 ℃ ppm/year 13.Aging(老化率) ±3 14.Other(其他) *Note 1: F(T)= K*(T-t0)*(T-t0);t0=25℃ OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com TROQ P/N: RNE32768069 REV: ● Marking (标记) TROQ代码 标称频率 ● 生产批号 负载电容 负载电容 负载电容(CL) 6 7 9 12.5 代码 A B C D No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-89168688 FAX:86-579-89168699 http://www.troq.com A TROQ P/N: ● RNE32768069 REV: A SUGGESTED REFLOW PROFILE (回流焊曲线图) Total time:200sec.Max. (总时间:200秒 最大) Solder melting point:220℃(熔点220 ℃ ) Profiles Feature(特性) Pb-Free Assembly Average Ramp-up Rate(Ts max to Tp)  平均升温速度 3℃/second Max Preheat 预热 ■ Temperature Min (Ts min) 最低温度 125℃ ■ Temperature Max (Ts max) 最高温度 200℃ ■ Time (ts min to ts max ) 从最低到最高时间 Time maintained above 维持上述时间 ■ Temperature(T1) 温度 217℃ ■ Time(tp) 时间 (60~150) seconds Peak/Classification Temperature(Tp) 最高点温度 Time within 5℃ of actual Peak Temperature(tp) 高温维持时间 (20~40) seconds Ramp-down rate 降温速度 6℃/second max Time 25℃ to Peak Temperature 从25℃到最高温度的时间 8 minutes max Suggest reflow times 建议 reflow次数 (60~180) seconds 260 ℃ 3 Times max No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-83921892 FAX:86-579-83921880 http://www.troq.com TROQ P/N: RNE32768069 REV: ● PACKING(包装) 3Kpcs/REEL feeding No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-89168688 FAX:86-579-89168699 http://www.troq.com A TROQ P/N: RNE32768069 REV: No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-89168688 FAX:86-579-89168699 http://www.troq.com A TROQ P/N: RNE32768069 REV: ● BOM List(材质清单) 项次 组件名称 材质名称 供应厂商 1 上盖(Lid) 可伐合金 (表面镀镍) 南平三金 2 3 基材 陶瓷 引脚 钨(表面镀金) 基座 三环 4 晶片 二氧化硅(表面镀银) 泰美克 5 导电胶 银胶 日本藤仓 6 电极 银 上海永胜 No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-89168688 FAX:86-579-89168699 http://www.troq.com A TROQ P/N: RNE32768069 REV: A ● RELIABILITY SPECIFICATIONS(信赖度试验) No 1 2 3 4 5 6 7 8 9 10 Test Item(测试项目) Test Conditions(测试条件) Temperature: 85℃±3℃ 温度: 85℃±3℃ High Temperature Relative Humidity:85%RH High Humidity Storage 相对湿度: 85%RH (高温、高湿、储存) Time: 96 Hours 时间: 96小时 Temperature: 125℃±3℃ High Temperature Storage 温度:125℃±3℃ Time: 96 Hours (高温储存) 时间:96 小时 Temperature: -40℃±3℃ Low Temperature Storage 温度:-40℃±3℃ Time: 96Hours (低温储存) 时间:96小时 Temperature1:-55℃±5℃ 温度1:-55℃±5℃ Temperature2:85℃±5 ℃ Thermal Shock 温度2: 85℃±5 ℃ Temperature change between T1 and T2 5 min (温度冲击) T1和T2温度在5分钟内改变 10cycles maintain T1 and T2 for 30 minutes each mone c 每次循环30分钟共10次 Solder Temperature: 265℃±5℃ RESISTANCE TO SOLDER 焊槽温度:265℃±5℃ HEAT Time: 10±1 Seconds (耐焊接热) 时间: 10±1秒 The solder pot temperature is 245±5℃ , dwell time 5±0.5sec Solderability(可焊性) 245±5℃焊锡槽浸润5±0.5秒 3 Times Free Fall from 50cm height table to 3cm Drop Test thickness hard wood board (落下试验) 从50cm高度3次跌落到3cm厚硬质木板上 Half sine wave,1000 G MECHANICAL SHOCK 半正弦波,加速度1000G 3 Times for all 3 directions (机械冲击) X、Y、Z 三个相互垂直方向各三次 Frequency Range: 10Hz~55Hz 频率范围: 10Hz~55Hz Vibration Amplitude: 0.75mm  振幅:0.75mm (机械振动) 2 Hours in each direction, total 6 Hours X、Y、Z 三个相互垂直方向各振动2小时 Take measurements with a helium Leakage detector Leakage Test 氦质检漏  (气密性) Leakage Rate≤1×10-3Pa cm3/s -3 3 漏率≤1×10 Pa cm /s Reference(参考) JIS C5023 MIL-STD-883E Method 1005.8 MIL-STD-883E Method 1013 MIL-STD-202F Method 107 Condition A MIL-STD-202F Method 210E J-STD-002B JIS C6701 MIL-STD-202F Method 213B MIL-STD-883E Method 2007.3 MIL-STD-883E No.777 Xianhua South Street Jinhua,Zhejiang,China TEL:86-579-89168688 FAX:86-579-89168699 http://www.troq.com
RNE32768069 价格&库存
很抱歉,暂时无法提供与“RNE32768069”相匹配的价格&库存,您可以联系我们找货
RNE32768069
    • 5+1.08387
    • 50+0.84604
    • 150+0.74406
    • 500+0.61694
    • 3000+0.58391
    • 6000+0.54984
    库存:2049
