Q-SC32SC3220C5AAAF
Q-SC32SC3220C5AAAF
    SIISEMICONDUCTORCORPORATION(精工电子)
    SMD3215_2P
Q-SC32SC3220C5AAAF 数据手册
Specifications No. Messrs. CONFIDENTIAL   (first ・ revised) Delivery Specifications Product No. : Quartz Crystal Unit SC-32S Item code : Product form: 32.768kHz ±20 × 10-6 / 12.5pF The number of copies :1copy Data of registration : Receipt Column Note 〈NOTICE〉 1. Advance agreement will be needed before changing any contents of the specification herein. 2. Provided that the information herein is subject to change, only revised pages shall be reissued. 3. When the product described herein includes Regulated Products subject The Wassenaar Arrangement   etc, they may not be exported without authorization form the appropriate governmental authorities. 4. The contents of this specification including all figures and illustrations are proprietary information ( copyright or know-how ) of Seiko Instruments Inc. It is strictly prohibited to copy all or part of these specifications to third parties without permission. 5. In the case that the products described herein are used as part of any devices or equipment which might influence any one of the human body, human life and property, such as physical exercise equipment, medical equipment or vehicles, please let us know that. Dept. of Control Dept. of Issue Seiko Instruments Inc. Quality Assurance Section Sales Section Quartz Crystal Division           1-8, Nakase, Mihamaku, Chiba shi, Chiba 261-8507 Japan 1/11 Delivery Specifications 1.Scope These specifications apply to QUARTZ CRYSTAL RESONATORS ( hereinafter referred to as RESONATORS ) to be manufactured by Seiko Instruments Inc. ( hereinafter referred to as SII ) to 2.Designation RESONATORS are designated"SC-32S" ( 32.768 kHz ). 3.Shape and dimensions As per the SC-32S drawing shown on page 5 . 4.Electrical characteristics Specified on page 2 through 3 . 5.Shipment and packaging 5.1 ( 3,000 ) pcs are the standard lot size to which the lot number shall be allotted 5.2 The packaging shall conform to the resonator packaging standards. 6.Outgoing inspection 6.1 When mutually agreed, the outgoing inspection shall be conducted as per the standard on page 4. 6.2 The outgoing inspection slip is not basically affixed to each packaging. 7.Warranty In the event that any defective RESONATORS or defective lot is found at incoming inspection at and that any defect resulting from failures in process-control at SII after incoming inspection is found, good RESONATORS shall be supplied to free of charge as a replacement. In the event that any trouble or problems rising directly from RESONATORS occurs, it will be amicably settled between both parties, provided that warranty shall be done within the score of replacement of good RESONATORS. 8.Amendment or abolition of the specifications Amendment or abolition of the specifications shall be made upon mutual consent between and SII. If any problem arises, it shall be amicably settled between both parties. 9.Effectiveness of the specifications These specifications are effective after receipt of returned copies with your approved sign. 10.Others This product is completely Pb-free and Halogen-free. 2/11 [1] The maximum rating Item 1 Storage temperature range 2 Maximum drive level Symbol T_stg DL max. Rating -55~+125℃ 0.5 μW max. Note Rating -40~+85℃ 0.1 μW typ. Note [2] Recommended Operating Condition Item 1 Operating temperature range 2 Drive level Symbol T_use DL [3] Electrical-Characteristics Item 1 Nominal frequency Symbol f_nom Specifications 32.768 kHz f_tol ± 20 × 10-6 3 Load capacitance CL 12.5 pF 4 Motional resistance R1 70 kΩ max. 5 Motional capacitance C1 3 fF typ. 6 Shunt capacitance C0 1 pF typ. 7 Turnover temperature Ti 25 ± 5℃ 8 Parabolic coefficient B (-3±1) × 10-8/℃2 f_age ± 3 × 10-6 /year IR 500 MΩ min. 2 Frequency tolerance 9 Frequency aging 10 Insulation resistance Measurement temperature :25±2℃ Conditions Measured with ATI 4192A Impedance analyzer OSC LEVEL = 0.1V Measured with ATI 4192A Impedance analyzer OSC LEVEL = 0.1V Measure this coefficient at 3 points of 10℃、25℃、40℃ using C-MOS circuit 25±3℃、First year Measured with ATI 4329A Insulation Resistance Meter Apply DC100V 3/11 [4] Environment and Mechanical characteristics Item 1 High temperature storage 2 Low temperature storage 3 High temperature and Specifications Conditions -6 Δf/f0 = ±10×10 -6 Δf/f0 = ±10×10 -6 Δf/f0 = ±10×10 high humidity storage After storage under 125℃ for 1000 hours, *1 measure at room temperature. *3 After storage under -40℃ for 1000 hours, *1 measure at room temperature. *3 After storage under +85±2℃ , *1 85 % RH for 1000h, measure at room *3 temperature. 4 Thermal shock resistance -6 Δf/f0 = ±10×10 Measure at room temperature after *1 100 cycles. *3 -55℃ ⇔ +125℃ for 30 minutes. 5 Mechanical shock -6 Δf/f0 = ±10×10 Measure after 100g-dummy(SII Standard) drop from 1500mm height on the concrete 3directions 10times. Δf/f0 = ±10×10-6  Amplitude 1.5mm and 10~60Hz with resistance 6 Vibration resistance *2 *2 cycle time 2~3 minutes in 3 direction (X,Y,and Z axis) each for 2 h. 7 IR Reflow 8 Shear strength -6 Δf/f0 = ±10×10 No peeling-off Measure after 2 time reflow under *1 reflow profile specified in page 10   Pressuring force 10N×10±1sec. *2 according to IEC60068-2-21 9 Peel strength No peeling-off Pressuring force 10N×10±1sec. *2 according to IEC60068-2-21 10 Bending test No peeling-off Bending: 3mm×5±1sec. Thickness of the testing board: 1mm Note: 1. Each test shall be done independently. (not in series tests) 2. *1: Measure after 24 hours left at room temperature. 3. *2: Measure after 2 hours left at room temperature. 4. *3: Pre conditions (1) IR Reflow : 2 times (2) Initial values shall be measured after 24 hours at room temperature. 5. Shift in series resistance after the above tests shall be less than ±20% or less than ±15kΩ.  In case of resistance to IR reflow and high temperature storage(±125℃ for 1000 hours), shift in  series resistance after the above tests shall be less than ±30% or ±20kΩ. *2 4/11 [5] Precautions (1) Recommended mounting conditions Reflow profile As per reflow profile shown in page 10. Manual soldering 350℃max. for 4 sec. Max. (2) Cleaning The crystal resonator may be destroyed by ultrasonic cleaning. We don't guarantee the quality of the product with that cleaning method because such conditions as type of the washing machine, power, time,position in the bath, etc. can not be specified. Please confirm ultrasonic cleaning is not giving any damage to the product before use when that cleaning method must be used. [6] Outgoing inspection standard ・The outgoing inspection shall be conducted as per the following standard. ・The sampling shall be performed according to the ANSI/ASQC Z1.4-1996. NO 1 2 3 4 Item Frequency tolerance Equivalent series resistance Outer appearance Others characteristics Sampling level AQL(%)  Ⅰ 1.0  Ⅰ 1.0  Ⅰ 1.5 Periodical quality inspection 5/11 [7] Dimensions and marking layout 1. Out Line Drawing #1 #2 1.5±0.1 0.80±0.1 T * * * * * * C0.2 1.7 Typ. 3.2+0.1 2. Marking Unit = mm   3. Lead Connection T □ □ □ □ □ □ *1 *2 *3  *4  *5 *6 *7 *1 *2 *3 *4 *5 *6,7 Product name #1 Type of product Specification CL Year of Production( Last digit of year ) Week of Production(01~ 52) #2 #1 1.0 #2 1.5 1.0 Materials :  Case:Alumina ceramics、Ni-plated、Au-plated Lead :Kovar material、Ni-plated 1.8 4. Recommended PAD lay-out Unit = mm 6/11 [8] Taping specification 1.Drawing of tape dimensions ① Carrier tape    : Refer to page 8. ② Taping reel    : Refer to page 9. 2.Material ① Carrier tape ② Taping reel : PC black conductive : PS conductive 3.Taping method (1) Taping shall be placed in tapes in such manner as to assure that marking of the components is visible as per Fig.1 marking marking marking User direction of feed Fig. 1 (2) Reel ① On the side of reel there shall be more than 40 blocks of "No components". ② The beginning of Carrier Tape shall be bent vertically and hooked on groove of reel. (3) Leader ① On the side of leader, there shall be more than 40 blocks of "No components" ② The length of Leader shall be over 400 mm. ③ The Length of Stick Tape for Cover Tape shall be about 100 mm and Stick Tape shall never be detached. Cover Tape Carrier Tape 空部 No Components リール側 No 空部 Components 製品装着部 Fig. 2 User direction of feed リーダー部 Leader Stick Tape 7/11 (4) Gap between Carrier Tape and Cover Tape ① Cover Tape protrudes from Carrier Tape by 0.5mm max. Fig. 3 0.5mm max. Carrier Tape Cover Tape ② Holes of Carrier Tape are covered with Cover Tape by 0.75mm max. Carrier Tape 0.75mm Fig. 4 カバーテープ Cover Tape (5) Peel strength ① The method of testing is done as shown below. ② The value of force is at the beginning of desealing. ③ The Cover Tape peel forth shall be 0.1~1.3N at a peel speed of 300±10mm/min. Fig.5 Cover Tape 165~180° Direction of Pulling Carrier Tape Direction of Moving 8/11 Carrier tape (1) Conforms with EIA-481 (2) Tolerance : ±0.2 Unit=mm 9/11 Taping reel (1) Conforms with EIAJ ET-7200B (2) Quantity per reel : 3,000pcs./for a reel Torrance:±0.2mm Item Specification Materials PS(anti statics) inside reel wise W1 13.0+0.3/-0 outside reel wise W2 15.4±1.0 Unit mm mm Unit = mm 10/11 [9] Reflow Profile Pre-Heating temperature:+170℃   Pre-Heating time:120sec Heating temperature :+220℃   Heating time : 50sec +260 ℃ peak 10±1 sec. +250±10 ℃ T e m p +220 ℃ ( ) ℃ +170±10 ℃ 50±10 sec. 120±20 sec. Time(sec) Note: (1) The temperature used herein means the temperature on the circuit board. (2) Reflow is permitted 2 times.   11/11 [10] Outside box packing specification Label 1) The label is attached on each reel. Packing to   antistatic bag 2) 10 reels are put into each antistatic polyethylene bag. Label 【Figure 1】 3)  Packing 10 reels are put into each inner box. 4 inner boxes are put into each shipping carton. Inner Box Reel 【Figure 2】 Inner Box x 4 Inner Box Shipping Carton 【Top View】 4) Storage quantity It makes N = 3,000 pcs/Lot 5) Sample of the label display (Please refer to【 Figure 1 】【 Figure 2 】) Product bar code Item bar code * Part SC-32S : Our company product name Lot No. 000001 : Lot No. Quantity 3,000 pcs : Quantity Spec. 32.768kHz : Frequency, CL value, F0 deviation -6 12.5pF/±20×10 Quantity Lot.No.bar code Remarks RoHS Compliant 3,000 Pb Free XXXX 6) Storage environment Please keep the product under the following condition ﹡ No direct rays ﹡ Temperature condition : 5~30℃ ﹡ Humidity condition : below 80% :Remarks
Q-SC32SC3220C5AAAF 价格&库存
很抱歉,暂时无法提供与“Q-SC32SC3220C5AAAF”相匹配的价格&库存,您可以联系我们找货
