8W10000J33XCT
8W10000J33XCT
    SJK(晶科鑫)
    SMD3225_4P
    封装:TCXO 3225 频率:10.000MHz 电压:3.3V 常温频差:±0.5ppm 工作温度:-40~+85℃
8W10000J33XCT 数据手册
] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 8W Series .. Approved by: 刘惠光 Checked by : 李相同 贺丹斌 Issued by: SPECIFICATION PN: 8W10000J33XCT 深圳市晶科鑫实业有限公司 SHENZHEN CRYSTAL TECHNOLOGY INDUSTRIAL CO., LTD. VER DESIGNED CHECKED APPROVED A1 CUSTOMER APPROVAL SPECIFICATION : 晶振 / 3225 TCXO / 10.000MHz 8W10000J33XCT SJK PN. : CUSTOMER PN. : CHECKED 1 CHECKED 2 APPROVED Result: □ PASS □ FAIL DATE □ OTHER Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 1/7 ] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 7T Series .. ELECTRICAL SPECIFICATIONS Parmeters Condition Electrical Specifications MIN TYP MAX 10.000 Nominal Frequency Operating Temperature Rangequency -40 Supply Voltage 3.135 3.3 Supply Current Output Voltage MHZ 85 ℃ 3.465 V 2 MA 0.8 Output Type UNITS Vp-p Clipped sine wave Output Load Resistance 10 kΩ Capacitance 10 pF @25℃ ±1.0 ppm vs:Temperature -40 ~ 85 ℃ ±0.5 ppm vs:Load 10kΩ/10pF ±10% ±0.2 ppm ±0.2 ppm 85 ℃ Start-up Time 2.0 ms Harmonics -5 dBc SSB Phase Noise(@1KHz Carrier Offset) -128 dBc/Hz Aging ±1.0 ppm/5year Frequency Tolerance Frequency Stability vs:Supply Voltage Vcc±5% Storage Temperature -40 Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 2/7 ] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 7T Series DIMENSION(Unit:mm) MARK SJK .10.000 Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 3/7 .. ] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 7T Series MEASUREMENT CIRCUIT REFLOW CONDITION The reflow temperature profile may vary depending on the product model, specifications and frequency range.Refer to the individual product specifications for details Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 4/7 .. ] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 7T Series CARRIER TYPE REEL Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 5/7 .. ] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 7T Series .. RELIABILITY TEST SPECIFICA TIONS Test item Equipment Condition Specification TP:260℃ TsMax:200℃ TsMin:150℃ 2 time 1.SOLDERABILITY TEST SJK-REL001、RC-328A 2. HERMETICITY TEST HELIOT-306S MIL-STD-883E Method 2003.7 Pressurized 0.4~0.5Mpa ethanol sealed tank for 10 minutes MIL-STD-883E Method 1014.10 3. VIBRATION TEST HG-V4、S&A 250B Enable Crystal(10g) from 10-5510Hz,X、Y、Z horizontal,1 Minute vibration/time, 1time/ 2 hours. 4. MECHANICAL SHOCK HPC-200、S&A 250B Enable Crystal 50G(490m/s2) time=11 ms speed=3.4 m/s half sine JIS C6701 wave oscillation 5. DROP TEST HARD BOARD.S&A250B 75cm High,3 times on hard board 6. HIGH&LOW TEMP STORAGE TEST(Static test) H-PTH-80CK & HM1013ABN,S&A 350B/250B 7. TEMP &HUM CYCLING TEST Temperature:-10℃±2℃~65℃±2 H-PTH-80CK CHAMBE, ℃,Humidity:93±3%,1 cycle need 24 S&A 350B/250B hrs. 5cycles. MIL-STD-202F Method 213B High temperature: 125℃±2 MIL-STD883C, ℃,1000hr;Low temperature:-40℃±3 METHOD 1011.8 ℃,1000hrs 8. HIGH TEM. H-PTH-80CK CHAMBE, Temperature:85℃±2, & HUM.STORAGE S&A350B/250B Humidity:85+3,-2%,Store 96 hrs TEST 9. AGING TEST MIL-STD-883E Method 2007.3 H-PTH-80CK CHAMBE, Temperature:85℃±2,Store 1000 S&A350B/250 hrs MIL-STD-883E Method 1005.8 JIS C6701 JIS C5023 Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 6/7 ] . Crystal oscillator SMD TCXO Module 3.2×2.5×1.2 7T Series .. REVISION RECORD (SJK-7T10000M3C04K0J1) Rev Revise contents Reason Reviser Checked Approved A1 Initial released -- 贺丹斌 李相同 刘惠光 Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China Fax: (86) 755 88353718 Tel: (86) 755 82507042 Http://www.q-crystal.com.cn E-mail: sjk@q-crystal.com Page: 7/7
8W10000J33XCT 价格&库存
很抱歉,暂时无法提供与“8W10000J33XCT”相匹配的价格&库存,您可以联系我们找货
8W10000J33XCT
库存:15
