3.2×2.5 mm 晶体谐振器(SMD)
特性(Features)
●尺寸(Dimensions):3.2×2.5×0.7mm
●标准频率(Standard Frequency):8 ~ 64MHz
●无铅且符合RoHS/绿色环保标准(Pb-free and RoHS/Green
compliant)
●高温、高精度和高可靠性特性(High temperature, high
precision and reliability Characteristics)
应用(Applications)
●物联网 IOT
●通信 Communication
●智能可穿戴设备 Smart Wearable
电性能参数(Electrical Specifications)
Item
Specifications
频率范围(Frequency Range)
振动模式(Mode of Oscillation)
负载电容(Load Capacitance)
调整频差(FrequencyTolerance)(at25°C)
温度频差(Stability over operation temperance)
工作温度(Operating Temperature)
储存温度(Storage Temperature)
静态电容(Shunt Capacitance)
激励功率(Drive Level)
老化(Aging)(at25°C)
8~64MHz
Fundamental
8pF,12pF,or specify
±10ppm,or specify
±20ppm,or specify
- 40~+85℃or specify
- 55~+125℃
3 pF Max
10~200μW Max (100μW typical)
±3ppm/year Max
谐振电阻(Equivalent Resistance)
Frequency Range
8~10MHz
11.0592~24MHz
24~32MHz
32~64MHz
外形尺寸(单位:mm)OUTLINE DIMENSIONS(UNIT:mm)
http://www.taesz.cn
ESR(Max.)
200 Ω
80 Ω
50 Ω
30 Ω
很抱歉,暂时无法提供与“YC8MKBCD2XT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.44365
- 50+0.43389
- 150+0.42744
- 500+0.42087
