YC18432MLBCD2XT
YC18432MLBCD2XT
    YJX(雅晶鑫)
    SMD3225_4P
    全国产 频率:18.432MHz 负载:20pF 常温频差:±10ppm 工作温度:-40~+85℃
YC18432MLBCD2XT 数据手册
3.2×2.5 mm 晶体谐振器(SMD) 特性(Features) ●尺寸(Dimensions):3.2×2.5×0.7mm ●标准频率(Standard Frequency):8 ~ 64MHz ●无铅且符合RoHS/绿色环保标准(Pb-free and RoHS/Green compliant) ●高温、高精度和高可靠性特性(High temperature, high precision and reliability Characteristics) 应用(Applications) ●物联网 IOT ●通信 Communication ●智能可穿戴设备 Smart Wearable 电性能参数(Electrical Specifications) Item Specifications 频率范围(Frequency Range) 振动模式(Mode of Oscillation) 负载电容(Load Capacitance) 调整频差(FrequencyTolerance)(at25°C) 温度频差(Stability over operation temperance) 工作温度(Operating Temperature) 储存温度(Storage Temperature) 静态电容(Shunt Capacitance) 激励功率(Drive Level) 老化(Aging)(at25°C) 8~64MHz Fundamental 8pF,12pF,or specify ±10ppm,or specify ±20ppm,or specify - 40~+85℃or specify - 55~+125℃ 3 pF Max 10~200μW Max (100μW typical) ±3ppm/year Max 谐振电阻(Equivalent Resistance) Frequency Range 8~10MHz 11.0592~24MHz 24~32MHz 32~64MHz 外形尺寸(单位:mm)OUTLINE DIMENSIONS(UNIT:mm) http://www.taesz.cn ESR(Max.) 200 Ω 80 Ω 50 Ω 30 Ω
YC18432MLBCD2XT 价格&库存
很抱歉,暂时无法提供与“YC18432MLBCD2XT”相匹配的价格&库存,您可以联系我们找货
YC18432MLBCD2XT
  • 10+0.23527
  • 100+0.23013
  • 300+0.22665
  • 1000+0.22326
库存:193
