文件编码: MDH3-01-03-023
新品
版次:
A3
MDH2009001
变更
产 品 规 格 书
SPECIFICATION FOR APPROVAL
产品名称
石英晶体谐振器
Product Name:
Quartz crystal unit
产品型号
SMD3225
Product Type:
标称频率
27.000000 MHz
Nominal Freq:
明德亨料号
3126270001
MDH P/N:
客户料号
Customer P/N:
客户承认
Approved By Customer
签章
日期
Signature:
Date:
Date: 2024年8月26日
批准
Accepted
审核
Checked
拟制
Issued
烟台明德亨电子科技有限公司
四川明德亨电子科技有限公司
YanTai MDH Technology Co.,Ltd
SiChuan MDH Technology Co.,Ltd
ADD.:中国山东烟台开发区黑龙江路6号
ADD.:中国四川泸州纳溪区东兴路6号
No.6 Heilongjiang Road Yantai Development Zone,
Shandong, China
TEL:86-535-6372640
FAX:86-535-6394876
E-Mail:dynamic@public.ytptt.sd.cn
No.6 Dongxing Road Naxi Zone, Luzhou,
Sichuan,China
TEL:86-830-2800890
MSL:Level 1
http://www.mingdeheng.com
RoHS Compliant
Revision Record
VE 修订页面
R Rev.page
01
N/A
变更内容
Revise Contents
修改日期
Revise Date
修订者
Reviser
Initial released
N/A
Xiao
Dongrun
SMD3225
QUARTZ CRYSTAL UNIT
MDH P/N
REV.
3126270001
01
PAGE 3/10
CONTENT
ITEM
N0.
1
2
3
4
5
石英晶体产品规格及特性
PAGE
4
Product specification and features
石英晶体外观尺寸
5
Product outline dimension
石英晶体内部结构及印字
6
Product internal structure and marking
石英晶体之可靠性
7-9
Product reliability
生产商及产地说明
Manufacturer and origin
10
SMD3225
MDH P/N
REV.
QUARTZ CRYSTAL UNIT
3126270001
PAGE 4/10
01
1 石英晶体产品规格及特性 / Product specification and features
1.1 电气特性 / Electrical Specifications
Electrical Characteristics measured by S&A250B or equivalent.
Parametars
Electrical spec.
Unit
Notes
27.000000
MHz
Fundamental
AT-CUT
Min.
1.Frequency(FL)
2.Mode of oscillation
3.Crystal Cutting Type
4.Frequency tolerance
(△F/F0)
-10
5.Loading capacitance(CL)
6.Equivalent Series resistance
Typ.
Max.
10
12
ppm
At 25℃±3℃
pF
40
Ω
7.Drive Level(DL)
0.01
100
150
uW
8.Storage temperature range
-55
125
9.Operating temperature range
-20
70
Ref. to 25℃
-10
10
ppm
Ref. to 25℃
11.Shut Capacitance(C0)
3
pF
12.RLD2
40
Ω
13.Aging
±3
14.SPDB
-3
dB
500
MΩ
(ESR)
10.Temperature stability
(over operating temperature)
15.Insulation Resistance
ppm/Year 1st Year
-200 ~ +400kHz / 20points
At DC 100±15V
NOTE:Storage Temperature is only for the product itself,the temperature for the packing material is 5~35℃.
SMD3225
QUARTZ CRYSTAL UNIT
MDH P/N
REV.
2.0 外形尺寸、外观 / Outline dimensions、Appearances
2.1 产品外形尺寸(mm)/ Product outline dimension(mm)
2.2 载带外形尺寸图(mm)/Carrier Dimensional Drawing (mm)
2.3编带盘外形尺寸图(mm) /Reel Dimensional Drawing (mm)
3126270001
01
PAGE 5/10
SMD3225
MDH P/N
REV.
QUARTZ CRYSTAL UNIT
3126270001
01
PAGE 6/10
2.4 印字 / Marking
M27.00
CH 51
⑴
⑶
⑴
⑵
⑶
代表公司Logo
Company Logo
代表标称频率
Nominal Freq
代表批次号
Batch number
⑵
3.0 内部构造图 / Product internal structure
Unit Weight:0.014±0.002g/pcs
COMPONENETS
NO.
MATERIALS
SPECIFICATIONS
1
LID
Kovar (Fe/Co/Ni)
2
Package
Ceramic (AI2O3) + Au/Ni
Ni plating + Au plating
3
Pad
Au/Ni/W
Tungsten metalize + Ni plating + Au plating
4
Crystal blank
SiO2
5
Conductive adhesive
Resin+Ag
Silicon resin
6
Electrode
Ag
SMD3225
QUARTZ CRYSTAL UNIT
MDH P/N
REV.
3126270001
01
PAGE 7/10
4.0 石英晶体之可靠性 / Product reliability
项目
(Item)
条 件 (Condition)
结 果
(Result)
耐低温性(耐寒性)测试 (Cold resistance)
(Ⅰ)
A.1
Stored at -55±2℃ for 500±2 hrs then 25±2℃ 2 hrs before testing
耐高温性(耐热性)测试 (Heat resistance)
(Ⅰ)
A.2
Stored at 125±2℃ for 500±2 hrs then 25±2℃ 2 hrs before testing
耐湿热性 (Humidity Resistance Result)
A.3 稳态温度:85±2℃;湿度:85±3%RH;时间:500±2 hrs
(Ⅰ)
Steady temperature: 85±2℃;humidity: 85±3%RH; time:500±2 hrs
老化测试(Aging)
A.4 Stored at 85±2℃ for 720±2Hrs then 25±2℃ 2 Hrs before testing
(Ⅰ)
Stored at 25±2℃ for 1year
气密性 (Leakage)
A.5
细漏Fine leak: Put the product in the Helium pressure tank, 4 ~
5kgf/cm2, 0.5hrs.
(Ⅳ)
冷热冲击实验 温度循环 (Temperature Cycle)
–55℃ ~ 125℃,Retain 30Min, 100 cycles
A.6
(Ⅰ)
SMD3225
QUARTZ CRYSTAL UNIT
MDH P/N
REV.
3126270001
01
PAGE 8/10
4.1机械性能 / Mechanism characteristics
跌落测试(Drop Test)
B.1
Device are dropped from a height of 150 cm onto 2cm thickness
stainless plate executing 3 times of random drops.
(Ⅱ)
耐振性(Resistance of Vibration)
B.2 Frequency:10~55Hz,amplitude(total excursion):1.5mm±15%,3
direction (X,Y,Z) each 2 hrs then 25±2℃ 2 hrs before testing
(Ⅰ)
可焊性试验(Solderability)
B.3
(Ⅲ)
245±5℃,5±1s
耐焊接热(Reflow)Resistance to soldering heat(Reflow)
B.4
参考曲线图(Reference Curve):
(Ⅱ)
SMD3225
项目
Item
结果编号
Result NO.
QUARTZ CRYSTAL UNIT
规格要求
MDH P/N
REV.
3126270001
01
PAGE 9/10
Specification Requirements
频率变化
很抱歉,暂时无法提供与“3126270001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30791
- 100+0.24052
- 300+0.20682
- 1000+0.18155
- 4000+0.16136
- 8000+0.15120
