SWOCCV12S8-38.400000
    STARWAVE(思大)
    SMD3225_4P
    低电压1.2V、高可靠性、38.4MHz、3225-4P、工业级-40℃~+85℃、3.3V
SWOCCV12S8-38.400000 数据手册
B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-8327-9247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com Specification for Approval Customer : Product Type : SMD CXO 3 . 2 × 2.5 Nominal Freq. : 38.4MHz STARWAVE P/N : SWOCCV12S8-38.400000 Revision : A1 Customer P/N : PM / Sales : Date : Customer Confirmation : (Singnature) (Date) (1) STARWAVE requires one copy returned with signature and titl e of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by STARWAVE after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. MSL:Level 1 RoHS Compliant B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-8327-9247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com Product Specication Sheet Product Type : SMD CXO 3 . 2 × 2 . 5 Nominal Freq. : 38.4MHz STARWAVE P/N : SWOCCV12S8-38.400000 Revision : A1 PE/RD Zhang fen qi 05-Feb-26 QA MFG Xu wen tao Luo jun jie 05-Feb-26 05-Feb-26 Note: (1) The green product standard set by STARWAVE is based upon the international standards. Related information is publicly described on the STARWAVE's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2) Revision "Sx" is for engineering samples only. PE/RD's approval required. (3) Revision "Ax" is production ready. PE, QA and MFG's approval required. MSL:Level 1 RoHS Compliant P/N:SWOCCV12S8-38.400000 Rev Revise Page A1 N/A Revise Contents Initial Released Revision: A1 Page: Date Ref.No. Reviser 05-Feb-26 N/A Zhang fen qi 1 P/N:SWOCCV12S8-38.400000 Revision: A1 ■ Electrical Specifications Standard Atmospheric Conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure Equipment Electrical characteristics measured by MD600F or equivalent. Crystal Cutting Type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.015±0.002 g/pcs Parameters Symbol Electrical Spec. Min. Typ. Max. Notes Units 1 Nominal Frequency - 38.400000 MHz 2 Frequency Stability - ±30 ppm ±10PPM@25℃ - 3 Operating Temperature Topr -40 25 85 ℃ - 4 Storage Temperature Tstg -55 ~ 125 ℃ - 5 Supply Voltage VDD V - mA - Icc 6 Input Current 7 Enable Control 8 Output Load : CMOS 1.2V±10% - - 10 - Yes - CL 15 pF - Pad 1 9 Output Voltage High VoH 90%Vdd - - V - 10 Output Voltage Low VoL - - 10%Vdd V - Tr - - 5 ns 10%→90%VDD Level 90%→10%VDD Level 11 Rise Time Tf - - 5 ns 13 Symmetry (Duty ratio) TH/T 45 ~ 55 % - 14 Start-up Time Tosc - - 10 ms - 15 Enable Voltage High Vhi 70%Vdd - - V - 16 Disable Voltage Low Vlo - - 30%Vdd V - 12 Fall Time 17 Aging - ±3 ppm/yr. 1st. Year at 25℃ Page: 2 P/N:P/N:SWOCCV12S8-38.400000 Revision:A1 ■ DIMENSIONS (Unit:mm) 1.00±0.10 3.20±0.10 3 PAD FUNCTION: 2.50±0.10 4 2: GND 3: OUT 4: VDD 1 1.20±0.15 2 4 3 1.40 0.80 1.40 1.20 0.50 1 Suggested Layout 1.20 0.65±0.15 2 1.00±0.15 0.90±0.15 1: ENABLE CONTROL ■ MARKING   Starwave Logo Pin 1 Location STAR 38.400 Frequency Code ex:38.400000MHz=38.400 Production Location:NINGBO According to the Customer Marking Rule, the product has no traceability. Page: 3 P/N:P/N:SWOCCV12S8-38.400000 ■ TEST DIAGRAM Control input (output enable/disable) Logic 1 or open on pad 1: Oscillator output Logic 0 on pad 1 : Disable output to high impedance ■ WAVEFORM CONDITIONS Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. Revision:A1 Page: 4 P/N:P/N:SWOCCV12S8-38.400000 Revision:A1 Page: ■ OUTPUT ENABLE / DISABLE DELAY The following figure shows the oscillator timing during normal operation . Note that when the device is in standby, the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a short delay. ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ 5 P/N:P/N:SWOCCV12S8-38.400000 Revision:A1 Page: ■ STRUCTURE ILLUSTRATION 6 5 3 4 NO 1 7 COMPONENTS 8 2 MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Base (Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu - 3 IC chip - - 4 Crystal blank SiO2 - 5 Conductive adhesive Ag - Silicon resin 6 Electrode Noble Metal - 7 Die attached Conductive (Ag) Epoxy resin 8 Bonding wire Au Pad 1 options : NC is 5 wires , EN is 6 wires. 6 P/N:P/N:SWOCCV12S8-38.400000 ■ PACKING REMARK : Revision:A1 Page: 7 P/N:P/N:SWOCCV12S8-38.400000 Revision:A1 Page: ■ Reliability Specifications 1.Mechanical Endurance No. Test Item Test Methods 1 Drop Test 75 cm height,3 times on concrete floor . 1 Mechanical Shock Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time 1 Vibration Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes perpendicular axes each test time 4 Hrs REF. DOC JIS C6701 MIL-STD-202 MIL-STD-883 (Total test time 12 Hrs) 1 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2kg / cm2 MIL-STD-883 2 Fine Leak Helium Bomging 4.5 kgf / cm 2 for 2 Hrs MIL-STD-883 2 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux MIL-STD-883 Rosin resin methyl alcohol solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs REF. DOC MIL-STD-202 MIL-STD-883 Total 100 cycles of the following temperature cycle 2 Thermal Shock MIL-STD-883 3 High Temp&Humidity 85℃ ± 3℃, RH 85% , 1000 Hrs EIA-JESD22 3 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240 Hrs EIA-JESD22 8
SWOCCV12S8-38.400000 价格&库存
很抱歉,暂时无法提供与“SWOCCV12S8-38.400000”相匹配的价格&库存,您可以联系我们找货
库存:47
