QHTF Series
MERCURY
Crystal Clock Oscillators
Since 1973
QHTF is one of the Mercury QuikXO family quick-turn CMOS output clock oscillators.
QuikXO™ products, either standard or custom frequencies are buit-to-order and shipped
from California USA in 3 to 5 days. QHTF is available in five different hermetically sealed
ceramic leadless SMD packages and three supply Voltage, covers frequency range from
1.0 MHz to 200 MHz. Pin 1 can be either Tri-State high enable or power down.
General Specifications: at Ta=+25°C
Product Series
Output Logic Type
HTF Series Models
Package Dimensions (mm)
QHTF21
2.0x1.6x0.8
Supply Voltage (VDD)
Frequency Range
Current Consumption
Rise / Fall Time (Tr; Tf)
QHTF22
2.5x2.0x0.8
QHTF Series
CMOS (code “T”)
QHTF32
QHTF53
3.2x2.5x1.0
5.0x3.2x1.2
QHTF57
7.0x5.0x1.3
+1.8 V ±5%
Voltage Code: “18”
1.0 ~ 125.0 MHz
20 mA typical
30 mA max.
+2.5 V ±10%
Voltage Code: “25”
1.0 ~ 200.0 MHz
28 mA typical
35 mA max.
+3.3 V ±10%
Voltage Code: “3”
1.0 ~ 200.0 MHz
30 mA typical
40 mA max.
2.0 n. sec. typical
5.0 n. sec. max.
1.4 n. sec. typical
3.0 n. sec. max.
1.1 n. sec. typical
3.0 n. sec. max.
10% ↔ 90% waveform.
15 pF load.
Frequency Stability
Aging at Ta=+25ºC
Output Load
Output Drive Strength
Output High Voltage; VOH
Output Low Voltage; VOL
Duty Cycle
±50 ppm over -40 to +85°C. Spec.
±3 ppm (max.) the first year; ±2 ppm (max.) per year thereafter
15 pF typical
8 mA typical
VDD – 0.4 V min.
0.4V max.
1.0~150.0 MHz: 50% ±5%. 150.01~200.0 MHz: 50% ±10%. At VDD /2.
Start-up Time
4.5 m. sec. typical; 10 m. sec. max.
Pin 1 Option: Output Enable (OE) / Disable
Output Enable / Disable
70% of VDD (min.) to Enable; 30% of VDD (max.) to Disable
Output Enable Time
10 n. sec. max. High Enable. Pin 1 option code: OE
Output Disable Current
18 mA typical; 22 mA max.
Pin 1 Option: Output Power Down (PD)
Output Enable Time
4.5 m. sec. typical. 10 m. sec. max. Pin 1 option code: PD
300 µA typical; 400 µA max.
Offset
10 Hz
100 Hz
MERCURY
1 kHz
10 kHz
100 kHz
1 MHz
10 MHz
www.mercury-crystal.com
Taiwan: TEL (886)-2-2406-2779, e-mail: sales-tw@mercury-crystal.com
U.S.A.: TEL (1)-909-466-0427, e-mail: sales-us@MercuryUnited.com
MERCURY
Page 1 of 4
Jan. 5, 2023
Version: a3
Single Sideband
dBc /
Phase Noise
Hz
(dBc / Hz; typical)
Integrated Phase Jitter,
RMS,12 kHz to 20 MHz
-61
-89
-110
-119
-119
-142
-149
3.3 V: 1.0 p. sec. typical; 2.5 V: 1.1 p. sec. typical; 1.8 V: 1.5 p. sec. typical
Absolute Maximum Rating:
Positive Supply Voltage (VDD)
Input Pin Voltage (Vin)
Output Pin Voltage (Vout)
Electrostatic Discharge (ESD)
-0.5 V ~ 7 V w.r.t. ground
-0.5 V to VDD+0.5 V
-0.5 V to VDD+0.5 V
Human Body Model (HBM): Exceeds 2000 V. Class 2 per MIL-STD-1686C
Machine Model (MM): Exceeds 120 V. Class M2 per MIL-STD-1686C.
Note: Power, ground, and outputs are 200 V.
Charged-Device Model (CDM): Exceeds 2000 V. Class C6 per MIL-STD-1686C
Environmental Performance Specifications
Moisture Sensitivity Level
RoHS compliant, Pb (lead) free per EU Directive 2002/95/EC
6/6 (2002/95/EC) and WEEE (2002/96/EC). Free of halide, cadmium, hexavalent
chromium, lead, mercury, PBB’s, and PBDE’s.
Level 1 per IPC/JEDEC J-STD-020D.1
Storage temperature range
-55 to +125°C
Humidity
85% RH, 85°C, 48 hours
Fine Leak / Gross Leak
MIL-Std-883, method 1014, condition A / MIL-Std-883, method 1014, condition C
Solderability
MIL-STD-202F method 208E
Reflow
260°C for 10 sec. 2X.
Vibration
MIL-STD-202F method 204, 35G, 50 to 2000 Hz
Shock
MIL-STD-202F method 213B, test condition. E, 1000GG ½ sine wave
Resistance to Solvent
MIL-STD-202, method 215
Temperature Cycling
MIL-STD-883, method 1010
Gold (0.3 um to 1.0 um) over nickel (1.27 um to 8.89 um)
Green Requirement
Pad Surface Finish
Part Number Format and Examples:
Example 1: 18QHTF57-25.000-PD
18
25
3
Voltage Code
“18” for 1.8V
“25” for 2.5V
“3” for 3.3V
QHTF
HTF Series
MERCURY
Example 2: 25QHTF53-100.000-OE
57
53
32
Package Code
“57”: 7.0x5.0x1.3 mm
“53”: 5.0x3.2x1.2 mm
“32”: 3.2x2.5x1.0 mm
“22”: 2.5x2.0x0.8 mm
“21”: 2.0x1.6x0.8 mm
Page 2 of 4
a dash
Example 3: 3QHTF32-200.000-PD
25.000
100.000
200.000
The nominal
Frequency in
a dash
MHz. 3 places or
more after the
decimal point
Jan. 5, 2023
PD
OE
PD
Pin 1 option:
“PD”: Power Down
“OE”: Output Enable
Version: a3
Test Circuits and Output Waveforms
𝑇1
Duty cycle=(𝑇2) ∗ 100%.
Measured at 50% VDD
CMOS
T2
CMOS
T1
VOH
90%VDD
50%VDD
10%VDD
Tri-State or Power Down
VOL
Tr
Package Dimensions and Recommended Solder Pad Layout
Tf
unit: (mm)
QHTF21
QHTF21
QHTF32
QHTF53
QHTF57
♦ To minimize EMI, a 10 to 100 Ω series resistor is
recommended at the output signal.
♦ To improve noise immunity: Do not float pin 1.
Connect it to VDD, if Tri-state or power down is not
used.
MERCURY
Page 3 of 4
Jan. 5, 2023
Version: a3
Output OE Function on pad 1 Note: Do not leave this pad floating. If “no-connection” is desired, please contact Mercury.
VDD
Pad 2
Pad
1
OE Function
OE function
VIH
VIL
Enable Time
Disable Time
High Impedance
Related Products:
QHTF series is the QuikXO (quick turn) equivalent to the HTF (click to view) series, they are manufactured at
different Mercury facilities using the identical designs, raw materials and production processes. Once either one is
approved, Mercury recommends to include both the QuikXO and the non-QuikXO part numbers of your referenced part on
your BOM to take advantage of the QuikXO short lead- times and the non-QuikXO low-cost high-volume production
offerings.
E.g. 1, if the QuikXO 18QHTF57-25.000-PD oscillator is qualified, then the non-QuikXO 18HTF57-ET-25.000-PD
should also be on the same BOM.
E.g. 2, if the QuikXO 25QHTF53-100.000-OE oscillator is qualified, then the non-QuikXO 25HTF53-ET-100.000-OE
E.g. 3, if the QuikXO 3QHTF32-200.000-PD oscillator is qualified, then the non-QuikXO 3HTF57-ET-200.000-PD
Recommended Solder Reflow Profile (per IPC/JEDEC J-STD-020D.1)
Tp
Tsmax
Te
m
pe
rat
ur
e
TL
Max. Ramp Up Rate=3°C/s
Max. Ramp Down Rate=6°C/s
Preheat Area
t
p
tL
Tc-5°C
User Tp≤Tc
Tc
Tsmin
Tc-5°C
User tp
t
s
25
Time 25°C to Peak
Time
Profile Feature
Sn-Pb Eutectic Assembly
Pb-free Assembly
100⁰C
150⁰C
60 to 120 seconds
3⁰C / sec. max.
150⁰C
200⁰C
60 to 180 seconds
3⁰C / sec. max.
Peak package body temperature (Tp)
183⁰C
60 to 150 seconds
235⁰C
217⁰C
60 to 150 seconds
260⁰C
Time (Tp) within 5⁰C of the classification temperature Tc
10 to 30 seconds
20 to 40 seconds
Ramp-down rate (Tp to TL)
6⁰C / second max.
6⁰C / second max.
Time 25⁰C to peak temperature
6 minutes max.
8 minutes max.
Preheat/Soak
- Temperature min. (Ts min.)
- Temperature max. (Ts max.)
- Time (ts) (Ts min. to Ts max.)
Ramp-up rate (TL to Tp)
Liquidous temperature ( TL )
Time (tL) maintained above TL
All temperatures refer to the topside of the package, measured on the package body surface.
MERCURY
Page 4 of 4
Jan. 5, 2023
Version: a3
很抱歉,暂时无法提供与“18QHTF32-57.200-OE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+57.43440
- 200+22.91760
- 500+22.16160
- 1000+21.77280
