NO.
ECAB2102037
Acknowledgement Book
Customer
Production name : SMD SEAM SEALING X'TAL 3.2*2.5
Nominal Freq.
Customer P/N
ECEC P/N
: 12.000000MHz
: M12000E350
Receiver
Please return one after acknowledgement
JinHua East Crystal Electronic Co.,Ltd.
Approved By
MFG
QA
PE/RD
总经理:骆红利
副总:林土全
副总:黄文俊
部长:王晓东
2021/2/23
2021/2/23
2021/2/23
2021/2/23
公司名称:东晶电子金华有限公司
Corporation:JinHua East Crystal Electronic Co.,Ltd.
地址: 浙江省金华市宾虹路二段555号
ADD:No 555,Sec 2,Binghong Road Jinhua Zhejiang , P.R.C
电话(TEL):0086-0579-89186666 0086-579-89186777
FAX: 0086-579-89186677
http://www.ecec.com.cn
P: 1/9
BOOK OF MODIFICATION
No.
DATE
CONTENT OF
MODIFICATION
INTIAL RELEASED
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
REASON OF
MODIFICATION
PAGE
ITEM
APPROVE
P: 2/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
M12000E350
SPECIFICATION OF QUARTZ CRYSTAL UNITS
1.HOLDER TYPE:
12.000000MHz
2. ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise spcified, the standard range of atmospheric conditions for making measurement
Ambient temperature
:25±3℃
Relative humidity
: 40% ~ 70%
If there is any doubt about the results ,measurement shall be made within the following limits .
Ambient temperature
:25±3℃
Relative humidity
: 40% ~ 70%
Electriacal characteristics measured by S&A250B or equivalent .
The crystal is using AT CUT (thinkness shear mode).
3.ELECTRICAL CHARACTERISTICS
Parameters
Electrical Spec
SYM
MIN
Notes
TYP MAX UNITS
1
Nominal Frequency
FL
12.000000
MHz
2
Oscillation mode
Fundamental
3
Load Capacitance
CL
12
pF
4
Frequency Tolerance
±10
5
Operating Temperature
Temperature drift (TC)
6
7
Equivalent Resistance Rr
8
9
ppm at 25±3℃
ppm -40℃~85℃
-40
±20
85
Rr
80
Ω
Drive Level
DL
0.01
100
200
uW
Shunt Capacitance C0
Insulation Resistance
C0
3.00
10
500
pF
MΩ at DC 100V
11
Aging
12
Storage Temperature Range
±2
-55
ppm Year
125
▓ FACTORY LOCATION
ECEC CORPOTATION
DESIGN
INSPECTION
郑紫薇
王晓东
P: 3/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
DESIGN
INSPECTION
郑紫薇
王晓东
M12000E350
4.DIMENSIONS AND MARKING
4-1 HOLDER TYPE
12.000000MHz
4-2 DIMENSION (mm)
P: 4/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
DESIGN
INSPECTION
郑紫薇
王晓东
M12000E350
4-3 MARKING
Year/Month Code
LOT NO
EC
Frequency
P: 5/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
M12000E350
4-4 PACKING
4-4-1 Dimensions of the tape
4-4-2 Dimensions of the reel
4-4-3 Packing and Label
1 Reel=3000pcs
Box type(Reel quantity)
Box size(L×W×H) mm
Atype
(Reel x 5pcs max)
200×200×140
Btype
(Reel x 6~15pcs)
200×200×255
Ctype
(Reel x 16~30pcs)
395×200×255
Dtype
(Reel x 31~60pcs)
395×400×255
DESIGN
INSPECTION
郑紫薇
王晓东
P: 6/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
M12000E350
5.RELIABLITY TEST
Provided that measurement shall be carried out after letting it alone in the room
temperature for 1 hour.(Test SPEC as list 1)
5-1.SHOCK
Electrical charateristics shall be satisfied after dropping three times from the
height of 75cm onto the board of the 3cm thickness.
5-2.VIBRATION
Electrical charateristics shall be satisfied after supplying following vibration.
a).ENTIRE FREQUENCY RANGE
10~55Hz
b).REPEATED PERIOD
1~2min
c).AMPLITUDE
1.5mm
d).DIRECTION
X.Y.Z
e).PERIOD
2hours/Each Direction
5-3.SUBSTRATE BENDING TEST
Resonator is soldered into the ceater of PCB which is laid on the 2 small
supporters spaced 90cm. PCB deflected to 3mm below from horizontal level by
the pressing force with stick. The force is supplied for 10 second by 0.5mm/s speed.
After above test there is no observation of any visual damages on specimen
and the electical characteristic shall be satisfied.
R230
45±2mm
45±2mm
R5
5-4.ADHESION TEST
A static load of 5N using a R0.5 scrach tool shall be applied on the center at long direction side
of the component and for 10sec.
After above test a),there is no observation of any visual damages on the specimen.
R0.5
DESIGN
INSPECTION
郑紫薇
王晓东
P: 7/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
DESIGN
INSPECTION
郑紫薇
王晓东
M12000E350
5-5.REFLOW(WAVE)SOLDERING
Following profile of heat stress is applied to resonator,then being place in the natural
condition for 1 hour,resonator shall be measured.
260±5℃ 10~20sec
150~190℃ 120sec
5-6.SOLDERING DIP
Terminals/lead-wires of specimen shall be dipped into solder melter tank
at +260℃±5℃ for 3 sec.
Dipping depth shall be 2mm from the bottom of specimens body.(After
applying ROSIN FLUX) soldering portion shall be covered in over 95% of
Terminals/lead-wires dipped.
5-7.HUMIDITY
Electrical characteristics shall be satisfied after letting it alone at 65±2℃
in humidity of 90~95% for 500 hours.
5-8.STORAGE IN LOW TEMPRATURE
Electrical characteristics shall be satisfied after letting it alone at -40±2℃
for 500 hours.
5-9.STORAGE IN HIGH TEMPRATURE
Electrical characteristics shall be satisfied after letting it alone at 85±2℃
for 500 hours.
P: 8/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
DESIGN
INSPECTION
郑紫薇
王晓东
M12000E350
5-10.TEMPERATURE CYCLE
Electrical characteristics shall be satisfied after supplying the following temperature
cycle(30cycle).Temperature shift from low to high, high to low shall be done in
1℃/sec.
+85 ±3
25±5℃
30min
-30 ±3 ℃
1 cycle
Spec of the reliability test
List 1
P: 9/9
ECEC P/N:
No:
ECAB2102037
Date:
2021/2/23
M12000E350
6.Structure Illustration
1
4
2
5
6
3
No.
Items
Materials
1
LID(Cap)
Fe ALLOY
2
PKG(Base)
CERAMIC+Au PLATING
3
External Electrode
Au PLATING
4
Conductive Adhesive
Ag+Slicon
5
Internal Electrode
Ag
6
Element(Blank)
SiO2
DESIGN
INSPECTION
郑紫薇
王晓东
很抱歉,暂时无法提供与“M12000E350”相匹配的价格&库存,您可以联系我们找货
