HL26000152
HL26000152
    HLC(汇隆)
    SMD3225_4P
    SMD-S3225 26.000000MHz 7.3pF ±10ppm -40~+105℃±20ppm ≤20Ω 4PAD
HL26000152 数据手册
浙 江 汇 隆 晶 片 技 术 有 限 公 司 Zhejiang Huilong Crystals Technology Co.,Ltd SPECIFICATION FOR APPROVAL CUSTOMER 26.000000 MHz NOMINAL FREQUENCY HOLDER TYPE 3225 HL26000152 SPEC. NO. ( P/N ) CUSTOMER P/N Nov.27,2025 ISSUE DATE APPROVED SMD 2025.11.27 辜批林 PREPARED QA SMD SMD 2025.11.27 2025.11.27 张梅娟 韩丽丽 AVL Status APPROVED BY CUSTOMER: Please return one copy with approval toHLC 浙江省金华市婺城区秋滨街道新宏路895号 No. 895 Xinhong Road, Qiubin Street, Wucheng District, Jinhua City, Zhejiang Province,China TEL: 0086-579-82273331 FAX: 0086-579-82273198 http://www.cn-hlc.com RoHS Compliant ( Pb- Free ) H0-R-4-014 TYPE HL SEAM SEALED X'TAL ELECTRICAL SPECIFICATIONS HLC Parts Number : HL26000152 Specifications Item Symbol Notes Min Type Max Units Nominal frequency FO 26.000000 Mode of Oscillation OT Fundamental Load Capacitance CL 7.3 pF Frequency Tolerance FT ± 10 ppm at 25℃ ± 3℃ ± 30 ppm with working temperature Reference to 25℃ frequency Frequency Stability MHz Working temperature range TR -20~70 ℃ Drive Level DL 100 μW CI/RR 40 Ω Insulation Resistance IR >500 MΩ Shunt Capacitance C0 C0 3 pF ±3 ppm/yr. -55 ~ 125 ℃ Series Resonant Resistance RR Aging Storage temperature range Max. Max. Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL MARKING HLC *26.0Ox HLC: HLC Use Code CL x: Code CL CL Code Code CL x: Code Date Code Jan-25 N Jan-26 A 0pf 0 7.5pf H 11.2pf a Feb-25 P Feb-26 B 6pf 1 11pf I 11.4pf b Mar-25 Q Mar-26 C 8pf 2 8.5pf J 13.5pf d Apr-25 R Apr-26 D 10pf 3 7.1pf K 20.5pf e May-25 S May-26 E 12pf 5 L 8.8pf f Jun-25 T Jun-26 F 15pf 6 12.5pf M 17pf g Jul-25 U Jul-26 G 16pf 7 27pf N 4.3pf h Aug-25 V Aug-26 H 18pf 8 7.3pf O 9.9pf i Sep-25 W Sep-26 J 20pf 9 13pf P 24pf j Oct-25 X Oct-26 K 22pf A 11.5pf Q 9.4pf m Nov-25 Y Nov-26 L 25pf B 7pf R 8.2pf n Dec-25 Z Dec-26 M 28pf C 14pf S 6.8pf q 30pf D 23pf T 90pf r CODE 32pf E 11.1pf U 5.6pf t 1 9.5pf F 33pf 5pf u 6 9pf 19pf V G 10.5pf W 10.7pf v 9.2pf Y 50pf Z 7.2pf YEAR y 备注:年份印字代码原则按奇偶年两年一个循环 7 8 9 0 1 2 L ### M ### N ### O ### P ### Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL RELIABILITY SPECIFICATIONS NO. TEST ITEM TEST METHODS 1 DROP TEST Device are dropped from a height of 150 cm onto 2 mm thickness stainless plate executing 3 times of random drops. 2 MECHANICAL SHOCK Device are shocked to half sine wave (1000 G) three mutually perpendicular axes each 3 times. 3 VIBRATION Frequency range Amplitude Sweep Time Test Time 4 SOLDERABILITY MIL - STD - 20E Method 208C Temperature Material Immersion depth Immersion time Flux 10 ~ 2000 Hz 1.5 mm 20 minute 2 hours 245℃±5℃ H63A (Silver 2 ~ 3 %) 0.5 mm minimum 3 ± 0.5 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) 5 RESISTANCE TO SOLDERING HEAT MIL - SLD -202, Method 210, Condition I or J 10 sec immersion into 260 ± 5℃ solder pot, above 180℃ is 90 ~ 120 sec. 6 LOW TEMP. STORAGE Leave at - 40 ℃ ± 2℃ for 16 hours 7 HIGH TEMP. STORAGE Leave at 125 ℃ ± 3℃ for 72 hours 8 THERMAL SHOCK Total 100 cycles of the following temperature cycle 1 cycle 125 ℃ ± 3 ℃ 25 ℃ - 55 ℃ ± 3 ℃ 30 min 30 min 10 min Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL DIMENSIONS Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL SUGGESTED IR REFLOW PROFILE Total Time:200 Sec.Max Solder melting point :185℃ PACKING 1. 230mm minimum leafer which consist of carrier and/or tape followed by a minimum of 160mm of empty carrier tape sealed with cover tape. 2. 160mm minimum trailer of empty carrier tape sealed with cover tape. Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL PACKING Begin Close Start LABEL End 3000pcs-Product Tape inner packing carton blue qualified label storeroom label storeroom label storeroom label deliver packing carton (L29*W24*H30) Green qualified label Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014
HL26000152 价格&库存
很抱歉,暂时无法提供与“HL26000152”相匹配的价格&库存,您可以联系我们找货
HL26000152
  • 5+0.58093
  • 50+0.46273
  • 150+0.40363
  • 500+0.35931
  • 3000+0.32381
  • 6000+0.30616
库存:2756
