浙 江 汇 隆 晶 片 技 术 有 限 公 司
Zhejiang Huilong Crystals Technology Co.,Ltd
SPECIFICATION
FOR
APPROVAL
CUSTOMER
24.000000 MHz
NOMINAL FREQUENCY
HOLDER TYPE
3225
HL24000015-A
SPEC. NO. ( P/N )
CUSTOMER P/N
Nov.27,2025
ISSUE DATE
APPROVED
PREPARED
QA
SMD
SMD
SMD
2025.11.27
2025.11.27
2025.11.27
辜批林
张梅娟
韩丽丽
AVL Status
APPROVED BY CUSTOMER:
Please return one copy with approval toHLC
浙江省金华市婺城区秋滨街道新宏路895号
No. 895 Xinhong Road, Qiubin Street, Wucheng District,
Jinhua City, Zhejiang Province,China
TEL: 0086-579-82273331
FAX: 0086-579-82273198
http://www.cn-hlc.com
RoHS Compliant ( Pb- Free )
H0-R-4-014
TYPE HL SEAM SEALED X'TAL
ELECTRICAL SPECIFICATIONS
HLC Parts Number :
HL24000015-A
Specifications
Item
Symbol
Notes
Min
Type
Max
Units
Nominal frequency
FO
24.000000
Mode of Oscillation
OT
Fundamental
Load Capacitance
CL
9
pF
Frequency Tolerance
FT
± 10
ppm
at 25℃ ± 3℃
± 10
ppm
with working temperature
Reference to 25℃ frequency
Frequency Stability
MHz
Working temperature range
TR
-20~70
Drive Level
DL
100
μW
CI/RR
40
Ω
Insulation Resistance
IR
>500
MΩ
Shunt Capacitance C0
C0
3
pF
±3
ppm/yr.
-55 ~ 125
Series Resonant Resistance RR
Aging
Storage temperature range
Max.
Max.
H0-R-4-014
MARKING
HLC
*24.0Gx
HLC: HLC Use Code
CL
x:
Code CL
CL Code
Code CL
x:
Code
Date Code
Jan-25
N
Jan-26
A
0pf
0 7.5pf
H 11.2pf a
Feb-25
P
Feb-26
B
6pf
1
11pf
I
11.4pf
b
Mar-25
Q
Mar-26
C
8pf
2 8.5pf
J
13.5pf
d
Apr-25
R
Apr-26
D
10pf
3 7.1pf
K 20.5pf e
May-25
S
May-26
E
12pf
5
L
8.8pf
f
Jun-25
T
Jun-26
F
15pf
6 12.5pf M
17pf
g
Jul-25
U
Jul-26
G
16pf
7
27pf
N
4.3pf
h
Aug-25
V
Aug-26
H
18pf
8 7.3pf
O
9.9pf
i
Sep-25
W
Sep-26
J
20pf
9
13pf
P
24pf
j
Oct-25
X
Oct-26
K
22pf
A 11.5pf Q
9.4pf
m
Nov-25
Y
Nov-26
L
25pf
B
7pf
R
8.2pf
n
Dec-25
Z
Dec-26
M
28pf
C 14pf
S
6.8pf
q
30pf
D 23pf
T
90pf
r
CODE
32pf
E 11.1pf U
5.6pf
t
1
9.5pf
F 33pf
5pf
u
6
9pf
19pf
V
G 10.5pf W 10.7pf v
9.2pf
Y
50pf
Z
7.2pf
YEAR
y
备注:年份印字代码原则按奇偶年两年一个循环
7
8
9
2
L
M
N
O
P
H0-R-4-014
RELIABILITY SPECIFICATIONS
NO.
TEST ITEM
TEST METHODS
1
DROP TEST
Device are dropped from a height of 150 cm onto
2 mm thickness stainless plate executing 3 times
of random drops.
2
MECHANICAL SHOCK
Device are shocked to half sine wave (1000 G)
three mutually perpendicular axes each 3 times.
3
VIBRATION
Frequency range
Amplitude
Sweep Time
Test Time
4
SOLDERABILITY
MIL - STD - 20E Method 208C
Temperature
Material
Immersion depth
Immersion time
Flux
10 ~ 2000 Hz
1.5 mm
20 minute
2 hours
245℃±5℃
H63A (Silver 2 ~ 3 %)
0.5 mm minimum
3 ± 0.5 seconds
Rosin resin methyl
alcohol solvent ( 1 : 4 )
5
RESISTANCE TO
SOLDERING HEAT
MIL - SLD -202, Method 210, Condition I or J
10 sec immersion into 260 ± 5℃ solder pot,
above 180℃ is 90 ~ 120 sec.
6
LOW TEMP. STORAGE
Leave at - 40 ℃ ± 2℃ for 16 hours
7
HIGH TEMP. STORAGE
Leave at 125 ℃ ± 3℃ for 72 hours
8
THERMAL SHOCK
Total 100 cycles of the following temperature
cycle
1 cycle
125 ℃ ± 3 ℃
25 ℃
- 55 ℃ ± 3 ℃
30 min
30 min
10 min
H0-R-4-014
DIMENSIONS
H0-R-4-014
SUGGESTED IR REFLOW PROFILE
Total Time:200 Sec.Max
Solder melting point :185℃
PACKING
1. 230mm minimum leafer which consist of carrier and/or tape followed by a minimum of 160mm
of empty carrier tape sealed with cover tape.
2. 160mm minimum trailer of empty carrier tape sealed with cover tape.
H0-R-4-014
PACKING
Begin
Close
Start
LABEL
End
3000pcs-Product Tape
inner packing carton
blue qualified label
storeroom label
storeroom label
storeroom label
deliver packing carton
(L29*W24*H30)
Green qualified label
H0-R-4-014
很抱歉,暂时无法提供与“HL24000015-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.55671
- 50+0.44344
- 150+0.38681
- 500+0.34433
- 3000+0.31036
- 6000+0.29333
