HL16000037
HL16000037
    HLC(汇隆)
    SMD3225_4P
    SMD-S3225 16.000000MHz 12pF ±10ppm -40~+85℃±30ppm ≤35Ω 4PAD
HL16000037 数据手册
浙 江 汇 隆 晶 片 技 术 有 限 公 司 Zhejiang Huilong Crystals Technology Co.,Ltd SPECIFICATION FOR APPROVAL CUSTOMER 16.000000 MHz NOMINAL FREQUENCY HOLDER TYPE 3225 HL16000037 SPEC. NO. ( P/N ) CUSTOMER P/N Dec.16,2024 ISSUE DATE APPROVED SMD 2024.12.16 辜批林 PREPARED QA SMD SMD 2024.12.16 2024.12.16 张梅娟 韩丽丽 AVL Status APPROVED BY CUSTOMER: Please return one copy with approval toHLC 浙江省金华市婺城区秋滨街道新宏路895号 No. 895 Xinhong Road, Qiubin Street, Wucheng District, Jinhua City, Zhejiang Province,China TEL: 0086-579-82273331 FAX: 0086-579-82273198 http://www.cn-hlc.com RoHS Compliant ( Pb- Free ) H0-R-4-014 TYPE HL SEAM SEALED X'TAL ELECTRICAL SPECIFICATIONS HLC Parts Number : Item HL16000037 Symbol Specifications Min Type Max Notes Units Nominal frequency FO 16.000000 Mode of Oscillation OT Fundamental Load Capacitance CL 12 pF Frequency Tolerance FT ± 10 ppm at 25℃ ± 3℃ ± 30 ppm with working temperature Reference to 25℃ frequency Frequency Stability MHz Working temperature range TR -40~85 ℃ Drive Level DL 100 μW CI/RR 60 Ω Insulation Resistance IR >500 MΩ Shunt Capacitance C0 C0 3 pF ±3 ppm/yr. -55 ~ 125 ℃ Series Resonant Resistance RR Aging Storage temperature range Max. Max. Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL MARKING HLC * 16.05x HLC: HLC Use Code CL 0pf 6pf 8pf 10pf 12pf 15pf x: Code CL CL Code Code CL x: Code H a 0 1 11pf I 11.4pf b 2 8.5pf J 13.5pf d 3 7.1pf K 20.5pf e 5 19pf L 8.8pf f 6 12.5pf M 17pf g 7.5pf 11.2pf Date Code Jan-23 Feb-23 Mar-23 Apr-23 May-23 Jun-23 Jul-23 N 4.3pf h Aug-23 18pf 7 27pf 8 7.3pf O 9.9pf 20pf 9 13pf P 24pf 22pf 25pf A 11.5pf Q B 7pf R 28pf 30pf 16pf N P Q R S T U Jan-24 Feb-24 Mar-24 Apr-24 May-24 Jun-24 Jul-24 A B C D E F G Aug-24 i Sep-23 V W Sep-24 H J j Oct-23 X Oct-24 K 9.4pf m Nov-23 Y Nov-24 L 8.2pf n Dec-23 Z Dec-24 M q C 14pf S 6.8pf D 23pf T 90pf r CODE 32pf E 11.1pf U 5.6pf t 1 9.5pf F 33pf V G 10.5pf W 5pf u 6 9pf YEAR 7 9.2pf Y 8 50pf Z 9 备注:年份印字代码原则按奇偶年两年一个循环 0 1 2 L ### M N O P ### ### ### ### Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL RELIABILITY SPECIFICATIONS NO. TEST ITEM TEST METHODS 1 DROP TEST Device are dropped from a height of 150 cm onto 2 mm thickness stainless plate executing 3 times of random drops. 2 MECHANICAL SHOCK Device are shocked to half sine wave (1000 G) three mutually perpendicular axes each 3 times. 3 VIBRATION Frequency range Amplitude Sweep Time Test Time 4 SOLDERABILITY MIL - STD - 20E Method 208C Temperature Material Immersion depth Immersion time Flux 10 ~ 2000 Hz 1.5 mm 20 minute 2 hours 245℃±5℃ H63A (Silver 2 ~ 3 %) 0.5 mm minimum 3 ± 0.5 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) 5 RESISTANCE TO SOLDERING HEAT MIL - SLD -202, Method 210, Condition I or J 10 sec immersion into 260 ± 5℃ solder pot, above 180℃ is 90 ~ 120 sec. 6 LOW TEMP. STORAGE Leave at - 40 ℃ ± 2℃ for 16 hours 7 HIGH TEMP. STORAGE Leave at 125 ℃ ± 3℃ for 72 hours 8 THERMAL SHOCK Total 100 cycles of the following temperature cycle 1 cycle 125 ℃ ± 3 ℃ 25 ℃ - 55 ℃ ± 3 ℃ 30 min 30 min 10 min Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL DIMENSIONS Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL SUGGESTED IR REFLOW PROFILE Total Time:200 Sec.Max Solder melting point :185℃ PACKING 1. 230mm minimum leafer which consist of carrier and/or tape followed by a minimum of 160mm of empty carrier tape sealed with cover tape. 2. 160mm minimum trailer of empty carrier tape sealed with cover tape. Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014 TYPE HL SEAM SEALED X'TAL PACKING Begin Close Start LABEL 3000pcs-Product Tape End inner packing carton blue qualified label storeroom label storeroom label storeroom label deliver packing carton (L29*W24*H30) Green qualified label Zhejiang Huilong Crystals Technology Co.,Ltd H0-R-4-014
HL16000037 价格&库存
很抱歉,暂时无法提供与“HL16000037”相匹配的价格&库存,您可以联系我们找货
HL16000037
  • 5+0.55671
  • 50+0.44344
  • 150+0.38681
  • 500+0.34433
  • 3000+0.31036
  • 6000+0.29333
库存:2947
