四川索斯特电子有限公司
Sichuan Source-Set Electronics Co., Ltd
晶体振荡器XO3225
Crystal Oscillators
●特征Features:
- Package Size:3.2*2.5*0.85
- Frequency Range: 32.768KHz,1-125MHZ or specify .
- High precision and high frequency stability.- Extremely
good for reducing EMI effect.
●应用领域Applications:
- Smartphones, PC peripherals, Industrial Personal Computers
(IPC), servers, storage, Ethernet, audio and video processors, AI
vision processing units, FPGA, CPU, GPU, MCU, BMC, etc.
●电气规格Electrical Specifications
频率范围 Frequency Range
32.768KHz,1-125MHz
输出模式 Output Type
CMOS
供电电压 Supply voltage
1.8V,2.5V,3.3V,5V
频率偏差 Frequency Stability
±20ppm, ±50ppm,or specify
-40~+85℃,or specify
工作温度范围 Operating Temperature Range
输出电压 Output Voltage
VOH 90%VDD Min,VOL 10%VDD Max
输出负载 Output Load
15pF
占空比 Duty Cycle
40%-55%
上升/下降时间 Rise/fall time
5ns max
启动时间 Start-Up Time
3ms Max
储存温度 StorageTemperature
-55~+125℃
老化率 Aging(At25℃)
±3ppm/year
相位抖动 Phase Jitter(12KHz ~ 20MHz)
1ps Max
消耗电流 Current consumption
32.768KHz
1-40MHz
41-54MHz
55-125MHz
1mA max
5mA max
12mA max
35mA max
●尺寸和焊盘Package Dimensions & Recommended Land Pattern (Unit: mm)
SOSET
MARKING
H=0.85±0.1
Pin#
Connection
1
Tri-state
2
GND
3
Output
4
VDD
Web:www.scsstdz.com
To ensure optimal oscillator performance, place
a by-pass capacitor of 0.1uF as close to the
part as possible between Vdd and GND pads.
TEL:0830-8106299
很抱歉,暂时无法提供与“SCGYR38X4000018VRM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.74133
- 50+1.37936
- 150+1.22423
- 500+1.03062
- 3000+0.94444
- 6000+0.89272
