AB08000302
AB08000302
    TXC(台晶)
    SMD5032_4P
AB08000302 数据手册
TXC CORPORATION www.txccorp.com SPECIFICATION FOR APPROVAL CN: CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0 × 3.2 NOMINAL FREQ. : 8.000000MHz TXC P/N : AB08000302 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER CONFIRMATION : 1705008768 (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. MSL:Level 1 RoHS Compliant (for glass crystal only:Pb used in sealing glass material is exempt from EU directive) FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION www.txccorp.com PRODUCT SPECIFICATION SHEET CN: PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0 × 3.2 NOMINAL FREQ. : 8.000000MHz TXC P/N : AB08000302 REVISION : A1 PE/RD QA MFG Wen yuan Chang ZhongLin Wu Zhi jun Wu 9-Jan-17 9-Jan-17 9-Jan-17 1705008768 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required MSL:Level 1 RoHS Compliant (for glass crystal only:Pb used in sealing glass material is exempt from EU directive) FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION Rev Revise page S1 N/A Initial released A1 N/A S Turn A FMT-DOC015 VER.C TXC P/N: Revise contents AB08000302 A1 REVISION: PAGE: 1 Date Ref.No. Reviser 28-Sep-16 N/A Xiaoyan Jiang 9-Jan-17 N/A Xiaoyan Jiang TXC confidential and proprietary document TXC CORPORATION TXC P/N: AB08000302 REVISION: S1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 DIMENSIONS P.4 3 MARKING P.4 4 FACTORY LOCATION P.4 5 SUGGESTED REFLOW PROFILE & MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS P.8 FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION TXC P/N: AB08000302 REVISION: A1 PAGE: ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity : 40%~70% Measure equipment Electrical characteristics measured by S&A 250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.046±0.002 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE FL 8.000000 MAX Notes UNITS MHz - - Fundamental - CL 8 pF 4 Frequency Tolerance - ±30 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - -40 2 Oscillation Mode 3 Load Capacitance ±50 ~ 125 ℃ - - - -3 ~ 3 ppm 8 Drive Level DL - 100 200 μW - 9 Effective Resistance Rr - - 80 Ω - 10 Shunt Capacitance C0 C0 - - 7 pF 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 125 ℃ 7 Aging FMT-DOC015 VER.C TXC confidential and proprietary document 1st Year at DC 100V - 3 TXC CORPORATION TXC P/N: AB08000302 A1 REVISION: PAGE: 4 Unit:mm ■ DIMENSIONS 0.9 ± 0.15 5.0 ±0.15 Connection 3 1 3 GND 4 3.2 ±0.15 4 GND 1 2 2 1 4 2.0 1.7 2.0 1.2 1.0 1.2 2 0.9±0.15 1.3 ± 0.15 1.4 ±0.15 Suggested Layout 2.4 ± 0.15 3 *Coplanarity of solderable areas Camber 0.10 mm Max 5.0±0.15 ■ MARKING TXC Logo Pin 1 Location TXC □□□□□ ■ □□□□ 3.2±0.15   Frequency Code ex: 8.000000 MHZ = 8.00 Tracking Code 0.9±0.15 Production location: China or Taiwan ■ SUGGESTED REFLOW PROFILE 2.6 1.2 (℃) 10 sec 260 220 180 1.4 0.9 Total time : 200 sec. Max. Solder melting point :220 ℃ Connection 150 Suggested Layout Time (sec) 120 sec FMT-DOC015 VER.C TXC confidential and proprietary document 60 sec TXC CORPORATION AB08000302 TXC P/N: REVISION: A1 PAGE: ■ STRUCTURE ILLUSTRATION 5 4 6 1 2 3 NO COMPONENTS 1 Lid MATERIALS FINISH/SPECIFICATIONS Kovar (Fe/Co/Ni) - 2 Package Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu - 3 PAD Au Tungsten metalize + Ni plating + Au plating SiO2 - 5 Conductive adhesive Ag+Silicon - 6 Electrode Noble Metal - 4 Crystal blank FMT-DOC015 VER.C TXC confidential and proprietary document 5 TXC CORPORATION AB08000302 TXC P/N: REVISION: A1 PAGE: 6 ■ PACKING F G E B H INDEX MARK C A DIMENSIONS A B D C D Feeding E 1.65±0.10 5.40±0.10 3.50±0.10 8.00±0.10 12.00±0.30 F G H 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT : mm) REMARK : Trailer Parts 160mm(Min) Empty Sealed Leader 160mm(Min) 230mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC015 VER.C L L1 W W1 180±1.00 13±0.50 16.5±0.20 12±0.10 L pcs / Reel (UNIT : mm) Standard Reel Quantity is 1,000 pcs per reel TXC confidential and proprietary document TXC CORPORATION TXC P/N: AB08000302 REVISION: A1 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 5 (5 Reels x1 ) 2. Reel X 10 (10 Reels x1 ) 3. Reel X 20 (10 Reels x2 ) 4. Reel X 40 (10 Reels x4 ) Label Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Label B) Size:80 X 40mm [STORAGE] 1.Don't be caught in the rain. 2.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 3.If customers have special requirements, we can paste labels according to it. FMT-DOC015 VER.C TXC confidential and proprietary document TXC CORPORATION AB08000302 TXC P/N: REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant) 1.Mechanical Endurance No. Test Item 1.1 Drop Test 1.2 Mechanical Shock 1.3 Vibration Test Methods REF.DOC 120 cm height, 20 times on Stainless Plate . JIS C 6701 Device are shocked to half sine wave ( 5000 G ) three mutually perpendicular axes each 3 times. 0.3m sec. duration time Frequency range 10 ~ 2000 Hz~10 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 Hrs MIL-STD-202 Method 213 MIL-STD-202 Method 204 (Total test time 12 Hrs) 1.4 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 1.25 mm Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol J-STD-002 solvent ( 1 : 4 ) 1.5 Terminal Strength 1.6 Board Flex Mount on PCB board and shear strength 1.8kg for 60 sec. Duration Time: 60 sec, Deviation: 3mm AEC-Q200-006 AEC-Q200-005 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for all 1000 Hrs. 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for all 1000 Hrs. REF. DOC MIL-STD 202 Method 210 MIL-STD-202 Method 108 JIS C 6701 Total 1000 cycles of the following Thermal Shock : 1 cycle 125 ± 3℃ 2.4 Thermal Shock -55 ± 3℃ 2.5 Temperature Cycle MIL-STD-202 Method 107 25℃ 5 min. 5 min. 20 sec. max. Total 1000 cycles of the following temperature cycle : - 40℃ ± 3 to 125℃ ± 3 , Dwell time:15min. JESD 22 Method JA-104 2.6 Biased Humidity + 85℃ ± 3℃ , RH 85% , 1000 Hrs. MIL-STD-202 Method 103 2.7 Moisture Resistance 20 cycles ( +25℃~65℃ , 80%~100% RH) , 24hrs/cycle. MIL-STD 202 Method 106 2.8 Operational Life + 125 ℃ ± 3 ℃ for 1000 Hrs. MIL-STD-202 Method 108 FMT-DOC015 VER.C TXC confidential and proprietary document
AB08000302 价格&库存
很抱歉,暂时无法提供与“AB08000302”相匹配的价格&库存,您可以联系我们找货
