C5SB08.000F20E12
C5SB08.000F20E12
    CJKJ(川晶)
    SMD5032_4P
    尺寸:5032 金属封装 4pin 频率:8MHZ CL:20PF 精度±10ppm 工作温度-20~70℃
C5SB08.000F20E12 数据手册
产品规格承认书 SPECIFICATION FOR APPROVAL 客户名称: 客户料号: 产品名称: 石英晶体谐振器 产品型号: SMD 5032 川晶料号: 产品类别: 电子 产品频率: 08.000000MHz C5SB08.000F20E12 制作日期:2025 年 10 月 15 日 客户确认 客户确认签章 确认人 部 门 日 期 ◊请客户确认签章一份产品规格承认书做副本。 公司地址:四川省南充市高坪区青莲街道蓝天路 86 号 Add: No.86 Lantian Road, Qinglian Street, Gaoping District, Nanchong City, Sichuan Province 网址:www.chuanjingjscc.com TEL: 0755-2328 3182 FAX: 0755-2328 4557 制 作 李平华 审 核 曾育林 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 批 准 签 章 JODY Page 1 of 7 ELECTRICAL SPECIFICATIONS HLC Parts Number : Item Symbol Specifications Min Type Max Units Notes Nominal frequency FO 08.000000 Mode of Oscillation OT fundamental Load Capacitance LC 20 pF Frequency Tolerance FT ±10 ppm At±25℃ ±3℃ ±20 ppm with working temperature Frequency Stability MHz Reference to 25℃ Working temperature range TR -20~70 ℃ Drive Level DL 100 uW CI/RR 80 Ω Insulation Resistance IR >500 MΩ Shunt Capacitance C0 C0 7 pF ±3 Ppm/yr -45~90 ℃ Series Resonant Resistance R Aging Storage temperature range Unit Weight 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 Max g Page 2 of 7 RELIABILITY SPECIFICATIONS NO. TEST ITEM TEST 1 DROP TEST 2 MECHANICAL SHOCK 3 VIBRATION 4 SOLDERABILITY 5 RESISTANCE TO SOLDERING HEAT 6 7 8 LOW TEMP. STORAGE HIGH TEMP. STORAGE THERMAL SHOCK METHODS Device are dropped from a height of 150 cm onto 2 mm thickness stainless plate executing 3 times of random drops. Device are shocked to half sine wave (1000 G) three mutually perpendicular axes each 3 times. Frequency range 10 ~ 2000 Hz Amplitude 1.5 mm Sweep Time 20 minute Test Time 2 hours MIL - STD - 20E Method 208C Temperature 245℃±5℃ Material H63A (Silver 2 ~ 3 %) Immersion depth 0.5 mm minimum Immersion time 3 ± 0.5 seconds Flux Rosin resin methyl alcohol solvent ( 1 : 4 ) MIL - SLD -202, Method 210, Condition I or J 10 sec immersion into 260 ± 5℃ solder pot, above 180℃ is 90 ~ 120 sec. Leave at - 55 ℃ ± 2℃ for 1000 ± 12 hours Leave at 125 ℃ ± 2℃ for 1000 ± 12 hours Total 100 cycles of the following temperature cycle 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 Page 3 of 7 DIMENSIONS 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 Page 4 of 7 RELIABILITY SPECIFICATION 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 Page 5 of 7 REEL SPECIFICATIO HC-49SMD 8045 7050 6035 5032 4025 3225 2520 2016 W 24.00±0.30 16.00±0.05 16.00 ±0.05 12.00±0.05 12.00±0.05 12.00±0.05 12.00±0.05 8.00±0.02 8.00±0.02 E 1.75±0.10 1.75±0.10 1.75±0.10 1.75±0.10 1.75±0.10 1.75±0.10 1.75±0.10 1.75±0.10 1.75±0.10 F 11.5±0.10 7.5±0.10 7.5±0.10 5.5±0.10 5.5±0.10 5.5±0.10 3.5±0.05 3.5±0.05 3.5±0.05 T 0.40±0.05 0.35±0.05 0.35±0.05 0.35±0.05 0.35±0.05 0.35±0.05 0.25±0.05 0.25±0.05 0.20±0.05 P 12.00±0.10 8.00±0.10 8.00±0.10 8.00±0.10 8.00±0.10 8.00±0.10 8.00±0.10 4.00±0.10 4.00±0.10 P0 4.00±0.10 4.00±0.10 4.00±0.10 4.00±0.10 4.00±0.10 4.00±0.10 4.00±0.10 4.00±0.10 4.00±0.10 P2 2.00±0.10 2.00±0.10 2.00±0.10 2.00±0.10 2.00±0.10 2.00±0.10 2.00±0.10 2.00±0.10 2.00±0.10 D0 φ1.50+0.10 φ1.50+0.10 φ1.50+0.10 φ1.50+0.10 φ1.50+0.10 φ1.50+0.10 φ1.55+0.05 φ1.50+0.10 φ1.50+0.10 D1 φ1.50MIN φ1.50MIN φ1.50MIN φ1.50MIN φ1.50MIN φ1.50MIN φ1.15MIN φ1.10+0.10 φ1.10+0.10 A0 4.60±0.10 4.85±0.10 5.40±0.10 3.90±0.10 3.60±0.10 2.80±0.10 2.80±0.10 2.25±0.10 1.80±0.10 K0 4.40±0.10 1.90±0.10 1.80±0.10 1.50±0.10 1.40±0.10 0.90±0.10 1.00±0.10 0.80±0.10 0.70±0.10 B0 14.20±0.15 8.60±0.15 7.40±0.10 6.40±0.10 5.40±0.10 4.30±0.10 3.50±0.10 2.70±0.10 2.20±0.10 A HC-49SMD 8045 7050 6035 5032 4025 3225 2520 2016 φ330±1.0 φ178±2.0 φ178±2.0 φ178±2.0 φ178±2.0 φ178±2.0 φ178±2.0 φ178±2.0 φ180±2.0 B 2.30±0.20 2.00±0.50 2.00±0.50 2.00±0.50 2.00±0.50 2.00±0.50 2.00±0.50 2.5±0.50 2.3±0.50 C φ13.5±0.20 φ13.2±0.20 φ13.2±0.20 φ13.2±0.20 φ13.2±0.20 φ13.2±0.20 φ13.2±0.20 φ11±0.20 φ13.5±0.20 D φ21.5±0.20 φ20.0 min φ20.0 min φ20.0 min φ20.0 min φ20.0 min φ20.0 min φ13±0.20 φ13±0.20 N φ100.0±0.5 φ60.5±1.0 φ60.5±1.0 φ60.5±1.0 φ60.5±1.0 φ60.5±1.0 φ60.5±1.0 φ60.2±1.0 φ60±1.0 W1 24.5±0.20 16.5±0.20 16.5±0.20 12.5±0.20 12.5±0.20 12.5±0.20 12.5±0.20 8.0+1.0/-0 8.0+1.0/-0 T1 2.30±0.20 1.80±0.20 1.80±0.20 1.80±0.20 1.80±0.20 1.80±0.20 1.80±0.20 1.75±0.20 1.8±0.20 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 Page 6 of 7 PACKING SPECIFICATION 备注: 每盘1000pcs 每箱10盘(10000pcs) 地址: 四川省南充市高坪区青莲街道蓝天路86号 Fax:0755-86021232 电话:0755-26010812 Page 7 of 7
C5SB08.000F20E12 价格&库存
很抱歉,暂时无法提供与“C5SB08.000F20E12”相匹配的价格&库存,您可以联系我们找货
